| Can't run Update Manager: NCDFE for UpdateManagerUI [message #238297] |
Fri, 19 October 2007 11:39  |
(I first wrote this in eclipse.platform a few days ago, but I got no
response.)
I'm using SDK 3.3.1. I've been using it for a few weeks, and I managed to
update a bunch of plugins when I first set it up, using the Update
Manager. Today, I thought to check to see if there was a new version of a
particular plugin, and when I tried to bring up the Update Manager,
nothing happened. I checked the console, and saw this:
java.lang.NoClassDefFoundError: org/eclipse/update/ui/UpdateManagerUI
org.eclipse.ui.internal.ide.update.ConfigurationManagerActio n$1.run(C
onfigurationManagerAction.java:43)
org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
How the heck could I have lost my Update Manager classes?
I searched for this class in my plugins, and I found it in
"org.eclipse.update.ui_3.2.100.v20070615.jar". Why isn't Eclipse finding
this?
Note that I also have a separate installation of RAD 6, and a week or so
ago I updated the RAD Update Manager. I wonder if that somehow did
something to my Eclipse 3.3 Update Manager?
Any advice on fixing this?
| Re: Can't run Update Manager: NCDFE for UpdateManagerUI [message #238738 is a reply to message #238711] |
Wed, 24 October 2007 15:59  |
Originally posted by: wegener.cboenospam.com
You mentioned RAD 6 in some of your earlier posts. Is it possible that you
opened up your Eclipse workspace with the RAD 6 product? If so, it is
possible that this made a change to the workspace that prevents the Eclipse
update manager from working.
As another thought, have you tried to run the update manager from a
different workspace? Start Eclipse and point to a new workspace location.
You shouldn't even need to create/import any projects. Open up the Update
Manager to see if you can get past the problem.
"Eric Rizzo" <eclipse6@rizzoweb.com> wrote in message
news:ffnqsh$qfs$1@build.eclipse.org...
> David Karr wrote:
> > I could use more clarification on the process you describe. By
> > "bundles", you mean jar files in the plugins directory? You're saying
> > to extract the contents directly into that directory?
> I'm suggesting to re-download the Eclipse ZIP (or open it if you still
> have it locally) and extract the Update Manager plugins (JARs, most
> likely) into your existing Eclipse installation (in the /plugins
directory).
> Doing this is not generally recommended, and there is potential that you
> could mess up your installation even more; but if your only alternative
> is to completely re-install, this might be worth trying first since it
> is a much less labor-intensive option.
> Hope this helps,
> Eric
FUDForum. Page generated in 0.13172 seconds
