Home » Language IDEs » Java Development Tools (JDT) » modify static vars in debugger?
modify static vars in debugger? [message #238137] Wed, 15 November 2006 18:18 Go to next message
Originally posted by: wharley.bea.com
Suppose I have this:
class A {
private static boolean b = false;
public void foo() {
if (b)
System.out.println("Hello, world!");
Now suppose I step into foo(). How can I modify the value of b? It doesn't
seem to show up in the "variables" pane of the debugger, because it's
static. I can right-click on it and Inspect or Display it, but I don't see
how to modify it from there.
I'm sure I'm missing something obvious, but what is it?
Thanks!
Re: modify static vars in debugger? [message #238144 is a reply to message #238137] Wed, 15 November 2006 19:43 Go to previous messageGo to next message
In the variable view, click on the menu (small arrow top-down)>Java>Show
Static Variables.
HTH,
Olivier
Re: modify static vars in debugger? [message #238146 is a reply to message #238144] Thu, 16 November 2006 03:16 Go to previous message
"Olivier Thomann" <olivier_thomann@ca.ibm.com> wrote in message
news:ejgc75$at6$1@utils.eclipse.org...
> Static Variables.
Thanks!
Previous Topic:Run console app outside of IDE?
Next Topic:Using libraries packaged in a plugin from a Java project
Current Time: Fri Sep 26 00:14:56 EDT 2025
Powered by FUDForum. Page generated in 0.04330 seconds
