Home » Eclipse Projects » GEF » Eclipse 3.3.0 GEF fails with IndexOutOfBoundsException - works on Eclipse 3.2.1
Eclipse 3.3.0 GEF fails with IndexOutOfBoundsException - works on Eclipse 3.2.1 [message #237460] |
Wed, 01 August 2007 14:52 |
No real name Messages: 2 Registered: July 2009 |
I have a GEF based editor running in production status
under Eclipse 3.2.1 Build id: M20060921-0945 and GEF
version 3.2.1.v20060921. In this Eclipse environment
my plug-in behaves "as expected."
Platform environment is
Windows XP Professional Service Pack 2 and
Sun Microsystems, Inc. JRE 1.5.0_12
I prepared a duplicate copy of the Eclipse 3.2.1
project to begin movement of my plug-in to
Eclipse Europa 3.3.0 environment
Build id: I20070625-1500 and GEF
version 3.2.100.v20070620
I have made ZERO code changes to my
plug-in's Java source. I removed two
Bundle-Localization header
from plug-in's MANIFEST.MF files.
When I attempt to open the editor window in
the Europa environment, I receive the following
error trace:
"Error opening the editor"
java.lang.IndexOutOfBoundsException: Index: 2, Size: 1
at java.util.ArrayList.add(Unknown Source)
at
org.eclipse.gef.editparts.AbstractGraphicalEditPart.primAddS ourceConnection(AbstractGraphicalEditPart.java:518)
at
org.eclipse.gef.editparts.AbstractGraphicalEditPart.addSourc eConnection(AbstractGraphicalEditPart.java:239)
at
org.eclipse.gef.editparts.AbstractGraphicalEditPart.refreshS ourceConnections(AbstractGraphicalEditPart.java:612)
at
org.eclipse.gef.editparts.AbstractGraphicalEditPart.refresh( AbstractGraphicalEditPart.java:565)
at
org.eclipse.gef.editparts.AbstractEditPart.addNotify(Abstrac tEditPart.java:235)
at
org.eclipse.gef.editparts.AbstractGraphicalEditPart.addNotif y(AbstractGraphicalEditPart.java:212)
at
org.eclipse.gef.editparts.AbstractEditPart.addChild(Abstract EditPart.java:198)
at
org.eclipse.gef.editparts.AbstractEditPart.refreshChildren(A bstractEditPart.java:727)
at
org.eclipse.gef.editparts.AbstractEditPart.refresh(AbstractE ditPart.java:677)
at
org.eclipse.gef.editparts.AbstractGraphicalEditPart.refresh( AbstractGraphicalEditPart.java:564)
at
at
at
at
org.eclipse.gef.editparts.SimpleRootEditPart.setContents(Sim pleRootEditPart.java:101)
at
org.eclipse.gef.ui.parts.AbstractEditPartViewer.setContents( AbstractEditPartViewer.java:601)
at
org.eclipse.gef.ui.parts.AbstractEditPartViewer.setContents( AbstractEditPartViewer.java:610)
at
com.bankofamerica.capire.workbench.graphicaleditor.PrimaryEd itor.initializeGraphicalViewer(PrimaryEditor.java:286)
at
org.eclipse.gef.ui.parts.GraphicalEditor.createGraphicalView er(GraphicalEditor.java:153)
at
org.eclipse.gef.ui.parts.GraphicalEditor.createPartControl(G raphicalEditor.java:163)
at
org.eclipse.gef.ui.parts.GraphicalEditorWithFlyoutPalette.cr eatePartControl(GraphicalEditorWithFlyoutPalette.java:77)
at
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:661)
at
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:426)
at
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:592)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:29 9)
at
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:179)
at
org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:268)
at
org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
at
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:400)
at
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1256)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1209)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:16 04)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:499)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103 )
at org.eclipse.ui.internal.PartStack.add(PartStack.java:485)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112 )
at
org.eclipse.ui.internal.EditorSashContainer.addEditor(Editor SashContainer.java:63)
at
org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorA reaHelper.java:217)
at
org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAre aHelper.java:207)
at
org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:774)
at
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:673)
at
org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:634)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2719)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2633)
at
org.eclipse.ui.internal.WorkbenchPage.access$12(WorkbenchPag e.java:2625)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2577)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2572)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2556)
at org.eclipse.ui.actions.OpenWithMenu.openEditor(OpenWithMenu. java:340)
at org.eclipse.ui.actions.OpenWithMenu.access$0(OpenWithMenu.ja va:328)
at
org.eclipse.ui.actions.OpenWithMenu$2.handleEvent(OpenWithMe nu.java:190)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:106)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:153)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
at org.eclipse.equinox.launcher.Main.main(Main.java:1144)
The location referred to in the trace
at
is "viewer.setContents(getModel());" in the following method
* Set up the editor's initial content (after creation).
* overrides GEF part method
* @see
org.eclipse.gef.ui.parts.GraphicalEditorWithFlyoutPalette#in itializeGraphicalViewer()
protected void initializeGraphicalViewer() {
super.initializeGraphicalViewer();
GraphicalViewer viewer = getGraphicalViewer();
viewer.setContents(getModel()); // line #286
viewer.addDropTargetListener(createTransferDropTargetListene r());
getEditorSite()
.getActionBars()
.getStatusLineManager()
.setMessage("Capirè Work Bench Graphical Editor");
IWorkbenchPage page = PlatformUI.getWorkbench()
.getActiveWorkbenchWindow().getActivePage();
if (page == null) return;
try {
page
.showView(" com.bankofamerica.capire.workbench.graphicaleditor.NodebookV iew ");
} catch (PartInitException e) {
return;
} catch (Exception e1) {
page.getActivePart();
return;
Since this is working "as expected" in an earlier Eclipse/GEF environment,
I believe I have an "invalid implementation" that has remained hidden for
more than two years that I cannot identify today.
Any assistance would be gratefully appreciated.
Here is the unchanged plugin.xml file
<?eclipse version="3.0"?>
<plugin>
<!-- First attempt to merge CWB 1.3 definitions with CGE -->
<!-- oXygen and Quantum interfaces omitted -->
<extension point="org.eclipse.ui.editors">
<editor name="CapireGraphicalEditor"
extensions="cpxl, xls"
icon="icons/knot_24.gif"
default="true"
class=" com.bankofamerica.capire.workbench.graphicaleditor.PrimaryEd itor "
contributorClass=" com.bankofamerica.capire.workbench.graphicaleditor.MainActio nBarContributor "
id=" com.bankofamerica.capire.workbench.graphicaleditor.PrimaryEd itor " />
<!-- Test scenario properties editor from CWB 1.3.x -->
<editor name="CapireTestPropertiesEditor"
extensions="txl"
icon="icons/banana-icon.jpg"
default="true"
class=" com.bankofamerica.capire.workbench.editors.TestPropertyEdito r "
contributorClass=" com.bankofamerica.capire.workbench.editors.TestPropertyEdito rContributor "
id=" com.bankofamerica.capire.workbench.editors.TestPropertyEdito r " />
</extension>
<!-- The CGE versions of the two preference related extensions -->
<!-- *** SHOULD *** be sufficient for the ITF. -->
<extension point="org.eclipse.ui.preferencePages">
<page name="Capire"
class=" com.bankofamerica.capire.workbench.preferences.PreferencePag e "
id=" com.bankofamerica.capire.workbench.preferences.PreferencePag e "/>
</extension>
<extension point="org.eclipse.core.runtime.preferences">
<initializer
class=" com.bankofamerica.capire.workbench.preferences.PreferenceIni tializer "/>
</extension>
<extension point="org.eclipse.ui.views">
<!-- CWB 1.3.x views -->
<category name="Capire" id="capire"/>
<view
name="Test Results"
icon="icons/little_c.gif"
category="capire"
class="com.bankofamerica.capire.workbench.views.TestResultView "
id="com.bankofamerica.capire.workbench.views.TestResultView "/>
<view
name="Infix Converter"
category="capire"
class="com.bankofamerica.capire.workbench.views.InfixView"
id="com.bankofamerica.capire.workbench.views.InfixView"/>
<view
name="Postfix Converter"
category="capire"
class="com.bankofamerica.capire.workbench.views.PostfixView "
id="com.bankofamerica.capire.workbench.views.PostfixView"/ >
<view
name="Test Facility Controller"
category="capire"
class="com.bankofamerica.capire.workbench.views.JettyView"
id="com.bankofamerica.capire.workbench.views.JettyView"/>
<!-- CGE specific view additions -->
<view
name="Utility Display"
category="capire"
class=" com.bankofamerica.capire.workbench.graphicaleditor.UtilityDi splayView "
id=" com.bankofamerica.capire.workbench.graphicaleditor.UtilityDi splayView "/>
<view
name="Nodebook"
category="capire"
class=" com.bankofamerica.capire.workbench.graphicaleditor.NodebookV iew "
id=" com.bankofamerica.capire.workbench.graphicaleditor.NodebookV iew "/>
</extension>
<!-- Nodebook operation group -->
<extension
point="org.eclipse.ui.viewActions">
<viewContribution
targetID=" com.bankofamerica.capire.workbench.graphicaleditor.NodebookV iew "
id=" com.bankofamerica.capire.workbench.graphicaleditor.NodebookV iew.pushbutton ">
<!-- Reset button -->
<action
label="Reset"
icon="icons/reset16.gif"
tooltip="Ignore changes"
class=" com.bankofamerica.capire.workbench.graphicaleditor.actions.N odeBookActionDelegate "
toolbarPath="nodebook_group"
enablesFor="*"
id="nodebook.toolbar.reset">
</action>
<!-- Apply button -->
<action
label="Apply"
icon="icons/apply16.gif"
tooltip="Apply changes"
enablesFor="*"
id="nodebook.toolbar.apply">
</action>
</viewContribution>
</extension>
<!-- CWB 1.3.x pop-up menu definitions -->
<extension point="org.eclipse.ui.popupMenus">
<objectContribution
id="com.bankofamerica.capire.filemenu"
objectClass="org.eclipse.core.resources.IFile"
nameFilter="*.cpxl">
<menu
id=" org.eclipse.ui.articles.action.contribution.navigator.capire "
label="Capire"
path="additions">
<separator name="group1"/>
</menu>
<action
id=" org.eclipse.ui.articles.action.contribution.navigator.valida tor "
label="Validator"
icon="icons/green_check.gif"
helpContextId=" org.eclipse.ui.articles.action.contribution.navigator.valida tor "
menubarPath=" org.eclipse.ui.articles.action.contribution.navigator.capire /group1 "
class=" com.bankofamerica.capire.workbench.actions.CapireValidatorAc tion "
enablesFor="1"/>
<action
id=" org.eclipse.ui.articles.action.contribution.navigator.capire testlauncher "
label="Test Launcher"
icon="icons/gold_star.gif"
helpContextId=" org.eclipse.ui.articles.action.contribution.navigator.capire testlauncher "
class="com.bankofamerica.capire.workbench.actions.CapireTestAction "
enablesFor="1"
state="true"
style="push"/>
</objectContribution>
<objectContribution
id="com.bankofamerica.capire.testmenu"
nameFilter="*.txl"
objectClass="org.eclipse.core.resources.IFile">
<menu
id=" org.eclipse.ui.articles.action.contribution.navigator.capire .test "
label="Capire">
<separator name="group2"/>
</menu>
<action
id=" org.eclipse.ui.articles.action.contribution.navigator.testla uncher "
helpContextId=" org.eclipse.ui.articles.action.contribution.navigator.testla uncher "
menubarPath=" org.eclipse.ui.articles.action.contribution.navigator.capire .test/group2 "
enablesFor="1"
state="true"
style="push"/>
<!-- Invoke Validator and Test Launcher for XLS files -->
<objectContribution
id="com.bankofamerica.capire.filemenu.xls"
nameFilter="*.xls">
<menu
label="Capire"
path="additions">
<separator name="group3"/>
</menu>
<action
id=" org.eclipse.ui.articles.action.contribution.navigator.valida tor.xls "
label="Validator"
helpContextId=" org.eclipse.ui.articles.action.contribution.navigator.valida tor.xls "
menubarPath=" org.eclipse.ui.articles.action.contribution.navigator.capire /group3 "
enablesFor="1"/>
<action
id=" org.eclipse.ui.articles.action.contribution.navigator.capire testlauncher.xls "
helpContextId=" org.eclipse.ui.articles.action.contribution.navigator.capire testlauncher.xls "
enablesFor="1"
state="true"
style="push"/>
</extension>
<extension point="org.eclipse.ui.newWizards">
<category id="capire.wizards" name="Capire"/>
<wizard
name="New Capire Project"
project="true"
category="capire.wizards"
finalPerspective=" com.bankofamerica.capire.workbench.perspectives.CapirePerspe ctiveFactory "
class="com.bankofamerica.capire.workbench.wizards.NewProjectWizard "
id="com.bankofamerica.capire.workbench.wizards.NewProjectWizard ">
<description>Create a skeleton Capire project</description>
</wizard>
</extension>
<extension point="org.eclipse.ui.perspectives">
<perspective
name="Capire"
fixed="false"
class=" com.bankofamerica.capire.workbench.perspectives.CapirePerspe ctiveFactory "
id=" com.bankofamerica.capire.workbench.perspectives.CapirePerspe ctiveFactory "/>
</extension>
</plugin>
Here is the Eclipse 3.2.1 working
plug-in manifest file
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: CapireWorkBench
Bundle-SymbolicName: CapireWorkBench; singleton:=true
Bundle-Version: 1.5.3
Bundle-Activator:
com.bankofamerica.capire.workbench.graphicaleditor.BundleAct ivatorPluginModule
Bundle-Vendor: Capire Team
Bundle-Localization: plugin
Require-Bundle: org.eclipse.gef,
org.eclipse.ui,
org.eclipse.compare,
org.eclipse.core.runtime,
org.eclipse.core.resources,
org.eclipse.ui.editors,
org.eclipse.ui.views,
org.eclipse.ui.workbench,
org.eclipse.ui.workbench.texteditor,
org.eclipse.ui.ide,
org.eclipse.jface,
org.eclipse.jface.text
Eclipse-LazyStart: true
Export-Package: com.bankofamerica.capire.workbench.graphicaleditor,
com.bankofamerica.capire.workbench.graphicaleditor.actions,
com.bankofamerica.capire.workbench.graphicaleditor.model,
com.bankofamerica.capire.workbench.graphicaleditor.model.com mands,
com.bankofamerica.capire.workbench.graphicaleditor.parts,
com.bankofamerica.capire.workbench.actions,
Bundle-ClassPath: CapireWorkBench.jar,
jacob.jar,
castor-1.0M2-xml.jar,
commons-logging.jar,
xerces-J_1.4.0.jar,
log4j-1.2.13.jar,
servlet-api-2.5.jar,
jetty.jar,
jetty-util.jar,
commons-validator-1.3.0.jar,
ext/user-javaapi.jar,
ext/commons-logging.jar,
ext/commons-el.jar,
ext/commons-logging-api.jar,
ext/jasper-runtime.jar,
ext/jasper-compiler.jar,
jdbc/db2jcc_license_cisuz.jar,
jdbc/db2jcc_zos.jar,
jdbc/ojdbc14.jar,
jdbc/terajdbc4.jar,
jdbc/mysql-connector-java-3.1.12-bin.jar
Re: Eclipse 3.3.0 GEF fails with IndexOutOfBoundsException - works on Eclipse 3.2.1 [message #238064 is a reply to message #237460] |
Wed, 22 August 2007 20:16 |
Brian Jakubik Messages: 140 Registered: July 2009 |
I had a very similar issue when I moved to 3.3 from 3.1, worked fine on
3.1, but on 3.3 it was hit and miss depending on what I was editing.
It ended up being in a subclass of AbstractGraphicalEditPart in
getModelTargetConnections or getModelSourceConnections, I had duplicates
being added to the list (bug on our part, but not surfaced until 3.3) so
you might look there if you have not resolved this yet..
The stack trace is almost identical to what I saw, hope that helps...
Brian Jakubik
> Bundle-Localization header from plug-in's MANIFEST.MF files.
> error trace:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> * * overrides GEF part method
> * @see
> getEditorSite()
> .getActionBars()
> try {
> page
> return;
> return;
> <plugin>
> default="true"
> extensions="txl"
> default="true"
> </extension>
> <page name="Capire"
> </extension>
> <initializer
> </extension>
> <view
> name="Test Results"
> icon="icons/little_c.gif" category="capire"
> <view
> category="capire"
> <view
> category="capire"
> <view
> category="capire"
> <view
> category="capire"
> <view
> name="Nodebook"
> category="capire"
> </extension>
> <extension
> <viewContribution
> <action
> label="Reset"
> enablesFor="*"
> </action>
> <action
> label="Apply"
> enablesFor="*"
> </action>
> </viewContribution>
> </extension>
> <objectContribution
> <menu
> label="Capire"
> path="additions">
> </menu>
> <action
> label="Validator"
> enablesFor="1"/>
> <action
> enablesFor="1"
> state="true"
> style="push"/>
> <objectContribution
> nameFilter="*.txl"
> <menu
> label="Capire">
> </menu>
> <action
> enablesFor="1"
> state="true"
> style="push"/>
> <objectContribution
> nameFilter="*.xls">
> <menu
> label="Capire"
> path="additions">
> </menu>
> <action
> label="Validator"
> enablesFor="1"/>
> <action
> enablesFor="1"
> state="true"
> style="push"/>
> </extension>
> <wizard
> project="true"
> </wizard>
> </extension>
> <perspective
> name="Capire"
> fixed="false"
> </extension>
> </plugin>
> Bundle-Activator:
> org.eclipse.ui,
> org.eclipse.ui.ide,
> org.eclipse.jface,
> jacob.jar,
> xerces-J_1.4.0.jar,
> log4j-1.2.13.jar,
> jetty.jar,
> jetty-util.jar,
> ext/commons-el.jar,
> jdbc/ojdbc14.jar,
> jdbc/terajdbc4.jar,
Re: Eclipse 3.3.0 GEF fails with IndexOutOfBoundsException - works on Eclipse 3.2.1 [message #238389 is a reply to message #237460] |
Sat, 08 September 2007 01:47 |
Originally posted by: none.ibm.com
The last three lines below are new in 3.3:
protected void addSourceConnection(ConnectionEditPart connection, int index)
primAddSourceConnection(connection, index);
GraphicalEditPart source = (GraphicalEditPart) connection.getSource();
if (source != null)
source.getSourceConnections().remove(connection);
As the other reply said, the same connection being added twice could cause
this problem.
Current Time: Fri Apr 26 04:03:59 GMT 2024
Powered by FUDForum. Page generated in 0.02980 seconds
