Home » Eclipse Projects » GEF » ComboBox in Properties View
ComboBox in Properties View [message #236870] Tue, 10 July 2007 06:20 Go to next message
Originally posted by: neliacatarina.portugalmail.pt
I want to put a combobox in one of the lines of my properties view. I have this:
public static String[] tokens = {"test1","test2"};
static {
descriptors = new IPropertyDescriptor[] {
new TextPropertyDescriptor(NAME, "Name"),
new ComboBoxPropertyDescriptor(TOKEN, "Inicial Place",
tokens),
public Object getPropertyValue(Object propName) {
if (NAME.equals(propName))
return getName();
if (TOKEN.equals(propName)){
return getTokens();
return super.getPropertyValue(propName);
where getTokens() returns an array of Strings.
I can't see any combobox when I run it. Can you tell me what am I doing wrong?
Re: ComboBox in Properties View [message #236876 is a reply to message #236870] Tue, 10 July 2007 10:43 Go to previous messageGo to next message
Hi Nelia,
Put a breakpoint in PropertySheetPage or PropertySheetEntry to make sure
both IPropertyDescriptor are being retrieved when your object is selected
and that the child property entries are being created.
Cheers...
Anthony
"Nelia Santos" <neliacatarina@portugalmail.pt> wrote in message
news:929891982.4071184062877252.JavaMail.root@cp9.dzone.com...
> Hi
> this:
> static {
> tokens),
> return getName();
> return getTokens();
> wrong?
> Thanks
Re: ComboBox in Properties View [message #236929 is a reply to message #236870] Fri, 13 July 2007 14:15 Go to previous message
Originally posted by: vaceslav.ustinov.gmail.com
You have an Error in your getPropertyValue() function.
The return value of getPropertyValue must be an "int"-value, this is the index of your array.
In your example for test1 you must return "0" and for test2 "1".
apply for the function setPropertyValue() the same.
See my example.
public void initProperty(){
String[] values = { "false", "true" };
PropertyDescriptor comboBoxPropertyDescriptor = new ComboBoxPropertyDescriptor("PropertyId", "PropertyLabel", values);
comboBoxPropertyDescriptor.setCategory("Basic");
public Object getPropertyValue(Object id) {
if (id.equals("PropertyId"){
if (booleanFunction())
return 1;
else
return 0;
public void setPropertyValue(Object id, Object value) {
setPropertyValue((Integer)value);
public void setPropertyValue(Integer value) {
if (value.intValue() == 1)
this.booleanVar = true;
else if (value.intValue() == 0)
this.booleanVar = false;
firePropertyChange("PropertyId", null, value);
Regards.
Vaceslav Ustinov
Nelia Santos schrieb:
> Hi
> static {
> tokens),
> return getName();
> return getTokens();
> Thanks
Previous Topic:How to use GEF in Applet?
Next Topic:setAlpha() + setImage() on a figure problem
Current Time: Tue Nov 04 00:40:09 EST 2025
Powered by FUDForum. Page generated in 0.02967 seconds
