rotate method on RenderedMapModeGraphics not implemented [message #236371] |
Fri, 17 July 2009 14:08 |
Esteban Dugueperoux Messages: 472 Registered: July 2009 |
--------------070501050909050408020609
I have created my own PolylineConnection named PolylineLabelConnection
to have behavior described in
https://bugs.eclipse.org/bugs/show_bug.cgi?id=281246. Now I can have
with draw2d rotable label with connection (see attachment).
Now I want adapt it to my GMF editor, then I reuse PolylineConnectionEx
class code and create a PolylineLabelConnectionEx derived from my
PolylineLabelConnection with only setDecoration() method in adding like
from patch (see bug report above).
My problem is about RenderedMapModeGraphics which not implements
Graphics.rotate(double) method.
Why this method isn't implemented?
Otherwise to bypass my problem, how can choose another Graphics than
RenderedMapModeGraphics?
Thanks.
Content-Type: application/octet-stream;
name="com.miasoftware.miastudio.mapping.model.zip"
filename="com.miasoftware.miastudio.mapping.model.zip"
UEsDBBQACAAIAK998ToAAAAAAAAAAAAAAAAOAAAAR0VGLy5jbGFzc3BhdGiV kEFrAjEQhc/6
K5bcna1CoYddpZQtKNQW3XqVmAzrtOkknSSl/vtWWlEKFbzNG773ZnjV5PPN FR8okTzXaghX
qkA23hJ3tXpu7wc3ajLuV8bpGINO23G/dxTISXbFK7GtVRSjiv3yZyz/BY3n A+ilAzSOQkR4
sQmczmy236dhtmjWd4/z9nY6bxblX444obB2YHGTO8j060SBZdJstdjVQ7sL WM5Gy2YwhOvL
/wkWwXhBEHzPJGifXO6I45kkn1PI6RC2Id6zVXnS3RdQSwcIlLj+YswAAABv AQAAUEsDBBQA
CAAIAK998ToAAAAAAAAAAAAAAAAMAAAAR0VGLy5wcm9qZWN0vZLNagMhFIXX nacIs4+muyzM
DLTNdJUQSPoAVm+nhvEHdYY8fq4zJjSBQKHQ3TnXc/xEZfVJd7MBfFDWrMpn sihnYISVyrSr
8uPQzJdlXRXMeXsEEd8gCK9cxHBVPDHDNVTv64bRUeFEWK3BxIrRi8JhLoek 6U/z2atO7h0I
NNm9Yo0bmQZ5f+tbAqJTLgA5ykiE9Sj4wMc8+CscC9y3faKGydIbz+g94TdI J4FsuFFfEOLL
vxH34hs0/zMvD/IVIyr2HqbopB/f7rSe0GPuQSWdddf1rTLb+/xFIu766jf/ 5wxQSwcIJHdR
3+MAAAB8AgAAUEsDBBQACAAIAK998ToAAAAAAAAAAAAAAAAUAAAAR0VGL2J1 aWxkLnByb3Bl
cnRpZXMrzi8tSk7V01OwVSguStbnSsrM08vMS84pTUktBor5uoY46nr6uenr xHApoAI9LgBQ
SwcIORKKizAAAAA8AAAAUEsDBBQACAAIAK998ToAAAAAAAAAAAAAAAAoAAAA R0VGLy5zZXR0
aW5ncy9vcmcuZWNsaXBzZS5qZHQuY29yZS5wcmVmc5WQy0oEMRBF9/MVAfch 3SDiQDaKAw4i
guI+ndxuasiLSjLg35v2sZ6eTVEUdbiPmwOTODYvhjuh1H5UezWKx6f3DzEq db+D9ZQLZGbM
YESLIs/gQinqYZd4kf8fJ1elTYw+QiYP7ovDgigpeoo4Fn74qliPGtFMHm4j Xw0vqG/e1Dlx
0IO83Qi22ArcS7LG6x6ggM+4iIbsyfScG3QcprbINdxrCxNYd1GwqZdE/rjV 16dhWru4Di2p
scWBtnOZU1cJ0pTeQn12iJVm6pbBnHgjjNjCleiv058uvwFQSwcIWV04bdwA AABqAgAAUEsD
BBQACAAIAK998ToAAAAAAAAAAAAAAAAYAAAAR0VGL01FVEEtSU5GL01BTklG RVNULk1G803M
y0xLLS7RDUstKs7Mz7NSMNQz4HIqzUvJSdX1hUrC5YxgMn6JualWCu6ubjCB 4MrcpPyczGQM
CWRzgbCwNDEnMy0ztYgrKLWwNLMoVReizkohvyhdLzU5J7OgOFUvpSix3CiF CwBQSwcIRKd0
e2gAAACdAAAAUEsDBBQACAAIAK998ToAAAAAAAAAAAAAAAAjAAAAR0VGL3Ny Yy90ZXN0L0Nv
bXBhcnRtZW50RmlndXJlLmphdmGFUk1PwzAMvfdX+JhJVQVcEYeBAE0qHxq7 oyz1sog2iRIX
mFD/O2mTMqqKkR6c1M/P9rMtF29cIhB6usxUY40jME4WKGplPRaV4x8XVbHc enJc0LVxFbpT
yDslW4enEPeO270S/hRm9T/Nxph6y13JD6Y9WbtE0yC5Q7HSHimkzWy7rZUA UXPv4cY0ljtq
UFNMCvhJqCsP6fmVZQApZAZmi+CHcCblQB3NFWj8mLrY4nLAR0QRKnpQ2rhl raTuadkEXSzL
1f3j6+bpuby928xCX8ghiX1k+FSe7XjtcQ6zXCgt2UXyhF+R/oHrMH3HIvTo jWNmffGzjpNv
MaC7IeKozx+SxpgfYafblARMDHFIIJHijaVVgN1gRrkBQuet04PACXmen/Vf aqP7zfpuVAWW
q6DvlC+HcR1Bpks+1qAGc8w4AobFKpVGFqp87knXKIhrWSMbWVNsWD7aGFvi Lgw+TzzzQ9jY
niPB10ruKSkcG+my7htQSwcIjBpb2HQBAACrAwAAUEsDBBQACAAIAK998ToA AAAAAAAAAAAA
AAAkAAAAR0VGL3NyYy90ZXN0L1BvbHlsaW5lQ29ubmVjdGlvbi5qYXZh1Vrd b+O4EX92gPwP
PBxwdfZcJbeHvjS7h81l022AbBJ4ExR9OtAWbWtXFgVRcupu8793hkNSlETJ 9n4UaB4ShxzO
DH8znA/SOZ9/4kvBSqHK8+Oj46NkncuiZB/5hkdVmaTRRVHw7U2ipzuTZtzN yGIZiXma5EpE
ccGfXsbRRTZfyQIJRSaK80HSopBPN3LOSzlMeCmzTMzLRGZ7kpESexIfpsFU VuWOfb0VqVjy
MsmWN3wL5IPEf0uWVSEGSd4VPF8lczVIdL0Ho312ei/TbZpkw4ymsuQln6Xi rZjLgu+0DIKG
cOzjFUsh16IstqBJkg1j50inYBueLVOhnfP0xYvjI/aCXWQM1qZiLbJS68jk gn1+A7v7xGqD
PrMZVyJmMG33HrlPNZnmyONYsXIl2EKmqXyCLeFQgvM8ZQvBSzCB+qumffV4 8xt9uLmmDxdd
4eRNz2zNt2wmWF7ITRKDMk9g7xV7StIUhyvUr5QsFkC8BrU0O9Rj7jgpliNe KmrKvFwlaVyI
zEoAdUUcsQdYO5NVBtuZ83RepYRPopj4F5gIVVAVaFCueImCNC+zICEI1Jqn KYQR5sA3WsN8
ygsIMiKT1XKlFU9UnoIClpOFl/EsZsAGDZOUoIvVdqGdub0ZB2D7hD2jUCVK xkm3WCx4lZag
B85GsDB2K8wg2ROt6IkFVXOptD2Rz1qJdCMU2yTcSjZHyP5Vz0bFU2fte/33 9Pgor2ZpMmfz
lCsVcCiDdD1VO6vyPGRyfDQaNYMq+4xePsqLZMNLwdphj6mSFyV9noARYhcN A0vIAT0/MgOv
OzTR7ePNjc8kEASMaIzrJBk/6TM5+oz7ABORwd7zDNJQMc7EU8eY45MTFDMC V9UhQBPRp7MJ
O+uf/eUM5uEXUTxrsToWjMAuf5fyk3FcWRVzcr0S/RS8RgOE3oaU9PuNEoJR TP0RZN3KMlls
xyd68hRRIOtuZBIzb57RPqscAPOGtcorUOGDFk4W8YYftCL+cEv9izzXzoIb WCYb8NWCYipL
rVeA8+Is/o/nyY63tpXzgq/dJA16P8ihzdkCkmQA26/Ryz4MWlF+3Prf8TMg JQs27vhdkoEL
gRzYgFmuIUzcqlFrmGX2w2s27ixp89eAj+ySqMYI1B87/TTVMxOpEpo+cDrQ 61rSOpuZsAbH
lkUvMXzGbKajonVBNFy5gmBW84KoKnQ02rIV3wi2lhsRT4hHITY8TWKKa3pd boNJzSBkfxIX
tD5NUeTXssLm1lTvcX7cCUA0aQzmdBRBx54KyJkZObZJMJRGVjKFz5gccIqS G7hHc5vEw9ur
48ezLaRTsUlkpdItBFswBaJEMibauC73QYyfbYlXlQEbndiNZJsc/qQgjUF0 Vphsm5gWWqa3
hTZkdYqEU/67Jhl7p8Ds+zW4VZWm1tEpiHgLyHkXAPAYwGAJuOHZOfx5hVxt oh+fRCr5N2LN
kp9/trxGpjyk3eBRMQMnrbXw3zgxkkakV6QhGeuVvjqG6lkfFrK0hoFW7TD1 q7mMxW/tHPPq
VA+7godSdftEGPD/gdURHGVm5BJLRNCw6TFSgxdYtdCi2ybrpEjEqTU2/sJI pnEz+ox3B62T
qBA89QKYWRoKbr2Qh3aNbg6Dqiw4OtSikGsqw+rgQ+AYJN9DCXcg2GKX1Dbu d7OPQI1oG1wu
HakPd9gaP5gT5AMcpIxo1DJGeMidXcw3q5FdAFd/gyZgUqFMFZAL44FwzMam FLea9ridiaWg
aLNmsFFVy/dKvR1amqonrmu1Hj0KWYICcP5C9Z3Tph4LamTqvv1hg+Lm24LW rKgaKjZK4gEN
TXU4CJmrFnVx9DI62x9I0rAXSK98Nkrawlsn4G4x2TgcranGwehMY/XTbDHq E9EjOgSvEd2a
aotuTu8W7UxD3YFq+kjErhfeucOiHl3JllO8wKZaKGiqJtR9NusFE9+wfbQ5 R49oIRPGFzhp
2tqSOlsAQPeU1xS6oE5QEvpVEMI4FUxsLcqVjKNg4ZSaHmcPa7Gffgp4cgPP dgqItPYOQqSp
aw8oqH43lYaXpE2dYfXSQ7YgseHPqvqDl/4jkF1C9FRjx/fElhtAdg/QY8iO IMRmCmusB2nG
avpzS/2YY4Fou0LtFW+TotxOxRJPhsdvwlrLyUvg1OSUI/Qg2oMKHCpRBwrw jxX0SzMBZZWg
7kfMBTRY2idmApNVIcisLj/mWhesNVWVllTtYWmqCXEFEIl0QQuaObCZUPuD h+cxJL7ZYFZZ
TzNJE912MuApmq2X+sgPmtKCJQUSmGuwpMBmcz4HoHELcuE1qLb5Obj/dB1t A/69ulCi/X9u
RI1Zmr2oVjFAnKirdV6CnSgaBBtVu6pVQz4Hch9eeZi+4Ee/beuBuibwbz3a /V7X85LMUfTF
+g+iVOGTY7tDiPSp8ULTJbTLB+N37xAqOOpbfUFo2m06wcSFemexb+s8Dztt R9EgaCpQjHYv
4xqOWbi+kCL+4N3cqMMMoqXzhWApfG4l1ZSQYpwOewSOL+t/Rgd2PgyVInmu SA85vCXCFHBf
SHDJcnsJhl4KD+nofnp3fzV9+Ocfl3e3t1eXD9d3t39M7x4frqYT4jxycEwQ jHPTFLR8O3CK
nOuGOix9sRJqZpsuBiv6nKynbbLe1W2aTEOFS4fi3XBZoTrt0oQ4mn508IrH IWKvlqR71Ni3
aTrwDgtv59w1r6MKwNXIoMP3WIia2QAcSK/x8rtNLwcHkvPpKbuVLJXgi5Au hIhFPPHiKIul
oPI2MtTh3jUUP0eeQnAIuOtvbIlp66emoXsU3degXms0aFQReHYLmRT47bJn LXKv4kkFGtZQ
PwZsPTvXTSzaGufaNm5RtS4edICsp30LEVPkuZMP3kn7DyqIgv9mbs5h5yU7 +nD3OL28Cj6D
7DIdOuc3MliPpX6N/tJnqb1thMjAfwSJfT+74TOR+tA4AEaHRSN3FxGuCWwF TOx0xHIVq6v4
IXu4G44spodj6CDNGw2qTbNfENgaj1Z9UDY6gEMCm7sc6Qlrgdbie4Y1p86B QS2g5jcJap5v
fP0J6VwwDVvzoBBmr4+GApijCYUvO1nbIRC6whzweNqZA8LWw8X03dWDH7Ya 106htPoVd160
zQOuvUL+/xUXX/vIXyT4vRL6BkG73Qx+W8AUc/QFgW4z0OoBUWz9TmxeNd0X wMa/uCuk1kNn
l68plHc02qNGNV94jfDgQywp0Xkf8ApS71sVdaCuher71Fp26/LfWxGQp03v haZBUaG3uXpr
/rtcqwW6cUDV5PQU14iLTVVbkPYTBvdEN4WD25lJmQquZ1S1FvhuuODQe/U/ RA5t1nH5z2u2
z8ZNHzYyd5qBvesrScvW0Ht49K77LmbKpdLd137gU4z93zuTEdxWsQFbmCSw C7X7EE6Y138S
4Xfdn+o52rarH3l6dHbeu5i1VxEYprR8c7cRRZHEopW46ULafnuTLc0Hs3+o gx7u3t6xi6qU
f17qS6rSvR1A81TNjt2dGnFyDFyCgF//BVBLBwiyIgmjRQoAANIrAABQSwME FAAIAAgAr33x
OgAAAAAAAAAAAAAAACkAAABHRUYvc3JjL3Rlc3QvUG9seWxpbmVMYWJlbERl Y29yYXRpb24u
amF2YaVXW0/jRhR+DhL/4eybHRIHqFZqm7JadgMUicKK8F5N7BNnivF4PRNI uuK/98zF9ti5
lNKXKJ45l+/czxQsfmQpgkKpxocHhwf8qRClgr/YM4vYi4q+ikyU/o0o0wjj jBcSo6RkL6dJ
dD6TqmSx+kLC0lIs82S8j9yI/CpyqViu5F7Sq5IVCx7vJ7phM8z2UtwLxRSb ZTjBWJRMcZHv
pU9RPKEq19GEP2Eu30z+TfBcvY30HmMyP81wO7kk16fO+Oj6iUJkYjDq9w8P oA/nkDhLnhEy
bT9c8nRZIhAAzBNMQAmYIRQZi+lD5MAM44/PGc8f4ZvI1vQHKQo5ASEDXyNz b34+S57HCD9F
H/Xn6PCgWM4yHkOcMSlrXuP2xqGAK61ZgjkHsilDcp6Shwe93pYAwA9tUK8o +TNTCIkgHQiV
S+pz41LIRGyZziDHF3sYhJt0Jc7tny6dprRG7IAfhBpQryeXBZZW9Otb2Exs gLe4+dvZp6rk
eQqyxS//O/8AtgGh4y1Y6tSDFNUXXa6ysp7PIZiZEzgjFy6zzF30tFNXEz6f k2srL0crGNah
iVbjmnDdJVz7hOuGcDWA9QBeeKIWA1ggTxfKXRIQq+7TGRxXIHqGkgSbK0vZ W9F3F8QrYCax
yzXssjWGOLZa93pTt4VHXGtPytpXvt6mvGYbdvka7/jaK/ebBK5DFWzxlIms 5SpRLcscLO9G
wJ8FT0CiunFAA1sjhTOt0UjxNjJri3ymYjOTKsH3OMcSqWfYgqtr0Slw6rQT rMHT69urm4uH
u9uxBe/84GvT3Oa22H2eY0qlH4QRTZ9cZvp/hdzSaGi682jGP5haRNSE8tOA WMmX9LsKfZtc
J6mNqjj91rTTZWrBZWSr6gyMLiUmmJaIMrCcY1tgDshMBg1L+OmX49Dmiydn 6AR1aEfN//7J
z8d1ElRWCEVJQz3fep1K/DoWee0/Z4CzSQ+DG8xTUx5GmfxeKtcCIls3ffA/ bfoeVWcuu/vt
b2er7gQ68R2GKf9bB8src9MCiMIaIV+4ihcQEPkDDZPzjKe5niBB6EDHjMrq 5uLy4VeDouHs
zUpkj+Oa5v766nePKCA9IQSesUNwShwma+kQ2kjNadjVkOCcLTO1T/wITklY sE3H0VYdmmOz
nJsRpqu/laobQdaKukGutxda71aq+TprWz/+94TYlxFhlRLB/pzoJEUL0kZS vDshtnj36PS9
SdLG+H/TYYs02JEPo9Ojnan4tgzxGnTBiMCuh0G1UEO1XIZuD+uNRjChHVWC WqAxXB/WK2ix
lIupMt123LqgRvmVVtagPkjdQXt8hWGEq4LlSeDc42dQ/yT6GA6gfWMzwlyF de9sBvZvzch3
nbNG0EyDhnzgTVvnRj2kd3I20gfefPcCQDs8dLhLYRwUzDPByBCv678CSdCZ fLGKsbDbcrVX
kN8f7iZ3cL5UgjpljrTZUWFbhhnpfjRkGNF8yhXFIH58oMdWFQgbbrOzcHlX sO9L7ew2sDnP
siYU3tJX+RXsYZno1ZeeEPplFqOYw+bLzooOgi034AkJI5N1za2ZYIM67Qa2 afRu7/68vp1e
PExbUHTiE5APbgXt+Fk/pcy225AONuecFyst9QOXF7l+gSR199gW95MBnLgS 91P8UpRo7TCP
16D9hI1mS6VIt05Yekd3+TVe3b+qPubgtjt2l6mBNCRMw3eDmrDyEUvPGe+B 1bQBUXhdwOQe
/fwDUEsHCDuGnogPBQAARRAAAFBLAwQUAAgACACvffE6AAAAAAAAAAAAAAAA JgAAAEdFRi9z
cmMvdGVzdC9Qb2x5bGluZUxhYmVsTG9jYXRvci5qYXZhlVNdi+IwFH2uMP/h Prayk4LLPsks
wg4DAy7IsH8gptc2TE1KEscR8b/vTRpr61RhrIR8nJxzz0nScPHOSwSH1s0f Jv6T20YbB9qU
DEUtG4usMHw/K9gfrRQKJ7Wa34O9vshyZ/AuZqkFd9rcxZSot+jMga20VO4b 0KWMZvLp9GEC
U4hqsLNYgNPQ1FwgcDguaqneYaXrA3VwyddYP6PQhnuTJ9AKeCCIwEsAJxbm Q7OwUhHdT/bL
D/OHSbNb11KAqLm1Q/JzIeSkxi0qZ7vajr7gpDHygzvsKYHop06QYCohXcJY Z3aCSDgM6ElX
C0k8Beylq6ChCepfmFjL0LaLhhu+7a22073fvwp7y1/oHS3XrXTYmnsjbQZj 7tNRc5lPIElc
JS3raT0N/SenYQZvGITRhiKiT6lgE64gpPtKigq2O+tgjf4wk8tp3jr2DLgL dNZxf902YXA/
PEKW6EaDuyHj76GJ1V+n9qFl0S2m8T1FjSzelKS76tD4nh1ERS/CBYBNs3mL Hq+iQEEb0xvL
WRQNFJ0opWtsS097W3Uv+NJNd6IeQs9gBLzkQ2yhyTsdkSqpfYK/3FWMr20a Ok4/Y2kQ45A7
rmZpx8s+H3slsc8fF0l2eOytHLIsu7JicIMG6f2eK7zA+xb8SVAeZ1DHH9ny PEnkJg3F/x6r
ePWa5bPs2CKTL6J9voC4FhxU5RGnsw06QGYpzrghHeyM0baQt4FqOiwii4+L /v8BUEsHCD5d
fggrAgAAFAYAAFBLAwQUAAgACACvffE6AAAAAAAAAAAAAAAAIAAAAEdFRi9z cmMvdGVzdC9V
TUxDbGFzc0ZpZ3VyZS5qYXZhjVLBTsMwDD2vX5FjJk0VTBqXigNM4rSJC3yA 21hdRJoUx2Eg
tH+nbdptHVC4JLH9/OT3nBqKFyhRMHrOEl3Vjlg4KlMsjK49popgv1Tp2hlH a2c9g2U/hXzQ
ZSCcQmwgRzMJ0BbvHSmkKdSTcyYH2sCHCz/P7veclgT1Thc+KsiSpA650YUo DHgvnrebdfuI
Qwt8Z7TKiz78TGY9upHNzdVxxNb4vBUW9zEtbTBmIZar1XBc3cyzhoH0GzA2 oKoG4got9/TA
TDoPjH08kF3g5DRLhbxz6m+Ko5axZtltQ1iocN4Kno1sFSZekXdU6saaeeQY bsE2/4hkbBhq
cYuybT4tVY4/U5qb5hMuxPX82NXEJblgVXT2ZPiAeKzhNaBkCthJm4FSstOQ 9cGFucf8uV1t
8nAy5ru3JfLdwOPPyjJaRciB7OUe/0G67Yb4nfF8yI7u8AVQSwcIDQtX5VUB AACoAwAAUEsD
BBQACAAIAK998ToAAAAAAAAAAAAAAAAkAAAAR0VGL3NyYy90ZXN0L1VNTENs YXNzRmlndXJl
VGVzdC5qYXZhvVjbbts4EH22v4LrJzpQZFvxvjTIg9dpgQDJbpC4e0FRFLTE yNylRVWk63qL
/vsOScm60ZfE2QaGI5EzwzMzZ4akUxL+Q2KKFJXqsttly1RkCoks9mnIWSqp H2VkHUT+dCHS
ufg6ScKFyC73CL5j8Sqj+yRuyZzyvQIsXqg11d+PG6nocp/wvZBMMZFMRSIV SZTcJ/znX7dk
I1Zqn0xMxZKqbOM/0BAMxtztjFwr//GP2c65OCPpgoXSfycS93o1qZslpGGn 2JpFMVXSv2Yy
5WRzUO5xQTmEuDs4O+uiMzQx+UUhJ1IiJVBkzSCC3t/d2oSB2KCbruachbkc TE31g52faQPf
uigXgVAr+PdFsAgtCUvwo8pYEiOSxfLDx/63bieHiiJ0hRK6Rvk77l92O08s IRwZkEiabytj
RnCkRcywL6l6ZP9SPB4OPQRftZkZ/apwrw4TaZw9LdYiEeJrma/TmsPGqFbL zYSQNApkyhXs
qMFeUGgrkr9awWLWiBYSGqwdviMJpDnDdV0tCyvDmA29ecoXhkecrDj3UG+S McJ7HhoFHgLm
+b/8dnttPNX1ZDXN46jwUr/g3ozMOQU1PWRYhiMPdTuddn59YwMKQD1QKVZZ SCcS8krJEvfM
1Ccx/9uP2VOv3zf+lUtqFw3WrQPWqSa2oI5tKvhqmbTBofzvNTEGuzBaNjZ4 FFaeLeS6AK44
X1J6t5HgkJWgGjCioJzmK0UbuQxNvOQbZAP34ePBvO6L1xOjPPqUZuwLUbQR twaORt4ysQYQ
D2L94xBcuCJxc/0GsUT9KAzjOgYGnQPCcMvk/4YgJ3BuA7QnBRY5FcuUZGoJ fQT3fRJFuGTN
lvnPVAwaisHRmhcv1hwbN22kYeNdiKhBejBk6S5x/5WYr9eBncyZbYshaGEA thsAp7P+8OoX
OyJwc60RnMr4w+uPW+vfaK7rxU9mu3P1Fl3vDA4Hb3KKOBh+QMXJ7QM6TlYf 0BnbRj4YhESi
UXkKsHu93oTMUTWDU1OxFRnbNqbbQyceDT34nI/g06+eJg7ZCZqGAn14Ml9g DOXWLLygA3/d
weDFIF22n2GuhbXptIV5cQpEsKcBbm2eAs94OnJFcvzyRGujr5PpkSPRAPAM TaH0lD6fq4U5
2yagAncmfebv3Au+4Syh03I4zMu/PWXOtbW7IMrr275YvZpAFXFbW8GNATaK o7RtBZtLQWVN
XAWwlZhV7OLqIkV16huR4YKWvqahyIhxMKJhvwyKaYC3IiQK4KWuwXqkqlM4 1GuZJomY+b6q
tE17jQFY24uRh05popcN0KVLKOUitd3dAbbieg8EP2dPMvoMn0im0OYNbm17 a6O4eU04ixPT
/Fo3cH/69tfZ2webC90Yt8qeM4ZumkalA0BTyJSGHYuk4lhFpPSsJoJtwd8L KB29c1VUyrFC
N3/PdRyS2hnzgofe8Aip88ALjhEbH2vtvGXOpmMJDFIUO9TzhlcWTZ3q+eM2 A5Mo0vHnOjvm
p4J2wwBzZT94m0SpWSqvBltpzdErpLWKS52p8V0WcOghla2oxe00p335HaoG uBZCz/vZilqC
W4W7FVcs5SxkalMlfn6cGfn+Wa8IjObnDi3P7Y7R3B8GW67uMHQO+v9EuMwD 4DS0LwBW4VAA
at7vUPHcXhzhfUa5YZVcsPSZvpepdxjRfr8v/R7uFSwDdB4MqxGqybdjozdf 2GhlLUQtHc+x
qj3GFr/5aLXGzrdrLmhP2oLka5nv/mZq+7NR+TOYSKndk9cLxinCP9lhJvWu IiSNcB92s+1s
5EOHjSZJpKeJChd2uhP5klOaakvoe/f7f1BLBwilqxX+VgUAABYWAABQSwME FAAIAAgAr33x
OgAAAAAAAAAAAAAAABoAAABHRUYvc3JjL3Rlc3QvY2xhc3Nfb2JqLmdpZnP3 dLOwTBRgEGA4
wsDw9++/X7//Pnz55euPPy/ef3/z6ad33Sav2o1etRt86jd71270bdjiU7fR u3aDX+MW3/rN
AS3b/Zu3ffj6yx/IaN3u17w1oHV7QMu2ggVH/v//z4ABFH+yMDIwSDLogDgg OxlYExOmJYqX
+AqkRgZ3d0aqnCnRDfng9KbG32JnU4GHDoMrd2fRySkyxt2NJV6yNvKNa8qk PQ5INGyo4DGo
ke5i/nUgTEGqJ79YTtzw2dmqtoPvf/8uqvCuKm/yqpKo79I36O3rVWSwBgBQ SwcIN/D3qNkA
AADkAAAAUEsDBBQACAAIAK998ToAAAAAAAAAAAAAAAAiAAAAR0VGL3NyYy90 ZXN0L2ZpZWxk
X3ByaXZhdGVfb2JqLmdpZnP3dLOwTBRgEGA4wsDw9++/X7//Pnz55euPPy/e f3/z6ad33Sav
2o1etRt86jd71270bdjiU7fRu3aDX+MW3/rNAS3b/Zu3ffj6yx/IaN3u17w1 oHV7QMu2ggVH
/v//z4ABFH+yMDIwSDLogDggOxlYExOmJYqX+AqkRgZ3d0aqnCnRDfng9KbG 32JnU4GHDoMr
d2fRySkyxt2NJV6yNvKNa8qkPQ5INGyo4DGoke5i/nUgTEGqJ79YTtzw2dmq toPvf/8uqvCu
Km/yqpKo79I36O3rVWSwBgBQSwcIN/D3qNkAAADkAAAAUEsDBBQACAAIAK99 8ToAAAAAAAAA
AAAAAAAcAAAAR0VGL3NyYy90ZXN0L21ldGhwdWJfb2JqLmdpZnP3dLOwTBRg EGA4wsDw9++/
X7//Pnz55euPPy/ef3/z6ad33Sav2o1etRt86jd71270bdjiU7fRu3aDX+MW 3/rNAS3b/Zu3
ffj6yx/IaN3u17w1oHV7QMu2ggVH/v//z4ABFH+yMDIwSDLogDggOxlYExOm JYqX+AqkRgZ3
d0aqnCnRDfng9KbG32JnU4GHDoMrd2fRySkyxt2NJV6yNvKNa8qkPQ5INGyo 4DGoke5i/nUg
TEGqJ79YTtzw2dmqtoPvf/8uqvCuKm/yqpKo79I36O3rVWSwBgBQSwcIN/D3 qNkAAADkAAAA
UEsBAhQAFAAIAAgAr33xOpS4/mLMAAAAbwEAAA4AAAAAAAAAAAAAAAAAAAAA AEdFRi8uY2xh
c3NwYXRoUEsBAhQAFAAIAAgAr33xOiR3Ud/jAAAAfAIAAAwAAAAAAAAAAAAA AAAACAEAAEdF
Ri8ucHJvamVjdFBLAQIUABQACAAIAK998To5EoqLMAAAADwAAAAUAAAAAAAA AAAAAAAAACUC
AABHRUYvYnVpbGQucHJvcGVydGllc1BLAQIUABQACAAIAK998TpZXTht3AAA AGoCAAAoAAAA
AAAAAAAAAAAAAJcCAABHRUYvLnNldHRpbmdzL29yZy5lY2xpcHNlLmpkdC5j b3JlLnByZWZz
UEsBAhQAFAAIAAgAr33xOkSndHtoAAAAnQAAABgAAAAAAAAAAAAAAAAAyQMA AEdFRi9NRVRB
LUlORi9NQU5JRkVTVC5NRlBLAQIUABQACAAIAK998TqMGlvYdAEAAKsDAAAj AAAAAAAAAAAA
AAAAAHcEAABHRUYvc3JjL3Rlc3QvQ29tcGFydG1lbnRGaWd1cmUuamF2YVBL AQIUABQACAAI
AK998TqyIgmjRQoAANIrAAAkAAAAAAAAAAAAAAAAADwGAABHRUYvc3JjL3Rl c3QvUG9seWxp
bmVDb25uZWN0aW9uLmphdmFQSwECFAAUAAgACACvffE6O4aeiA8FAABFEAAA KQAAAAAAAAAA
AAAAAADTEAAAR0VGL3NyYy90ZXN0L1BvbHlsaW5lTGFiZWxEZWNvcmF0aW9u LmphdmFQSwEC
FAAUAAgACACvffE6Pl1+CCsCAAAUBgAAJgAAAAAAAAAAAAAAAAA5FgAAR0VG L3NyYy90ZXN0
L1BvbHlsaW5lTGFiZWxMb2NhdG9yLmphdmFQSwECFAAUAAgACACvffE6DQtX 5VUBAACoAwAA
IAAAAAAAAAAAAAAAAAC4GAAAR0VGL3NyYy90ZXN0L1VNTENsYXNzRmlndXJl LmphdmFQSwEC
FAAUAAgACACvffE6pasV/lYFAAAWFgAAJAAAAAAAAAAAAAAAAABbGgAAR0VG L3NyYy90ZXN0
L1VNTENsYXNzRmlndXJlVGVzdC5qYXZhUEsBAhQAFAAIAAgAr33xOjfw96jZ AAAA5AAAABoA
AAAAAAAAAAAAAAAAAyAAAEdFRi9zcmMvdGVzdC9jbGFzc19vYmouZ2lmUEsB AhQAFAAIAAgA
r33xOjfw96jZAAAA5AAAACIAAAAAAAAAAAAAAAAAJCEAAEdFRi9zcmMvdGVz dC9maWVsZF9w
cml2YXRlX29iai5naWZQSwECFAAUAAgACACvffE6N/D3qNkAAADkAAAAHAAA AAAAAAAAAAAA
AABNIgAAR0VGL3NyYy90ZXN0L21ldGhwdWJfb2JqLmdpZlBLBQYAAAAADgAO ACQEAABwIwAA
AAA=
--------------070501050909050408020609--
FUDForum. Page generated in 0.02903 seconds
