Home » Modeling » GMF (Graphical Modeling Framework) » GMF migration to 2.2 : OCL error
GMF migration to 2.2 : OCL error [message #236181] Wed, 15 July 2009 05:52 Go to next message
Originally posted by: aurelien.pupier.esial.net
I tried to migrate to GMF 2.2.
right-click and "migrate to 2.2" works fine except for OCL.
I have OCL for constarint in GMFMap. It works fine with the older version of GMF but now I have this kind of error :
Invalid expression body 'jonas::JOnASProfile::MINIMAL'. Cause: Invalid expression body 'jonas::JOnASProfile::MINIMAL'. Cause: Unknown type ([jonas, JOnASProfile, MINIMAL])
Invalid expression body 'self->javaeeservers->forAll(j1,j2 | j1.oclIsTypeOf(JOnAS) and j2.oclIsTypeOf(JOnAS) and j1 <> j2 implies j1.oclAsType(JOnAS).instanceName <> j1.oclAsTypeOf(JOnAS).instanceName)'. Cause: Invalid expression body 'self->javaeeservers->forAll(j1,j2 | j1.oclIsTypeOf(JOnAS) and j2.oclIsTypeOf(JOnAS) and j1 <> j2 implies j1.oclAsType(JOnAS).instanceName <> j1.oclAsTypeOf(JOnAS).instanceName)'. Cause: Unrecognized variable: (javaeeservers)
Is there known issues about it?
Why "type" or "variable" are not knew anymore?
Thanks for your help
Aurelien Pupier
Re: GMF migration to 2.2 : OCL error [message #236279 is a reply to message #236181] Thu, 16 July 2009 09:27 Go to previous messageGo to next message
I have the same issue using migrating my GMF model to 2.2. My OCL
constraints containing enumerations can not by parsed even though they
are valid according to the OCL console/interpreter. In particular I
cannot adress an element of the enumeration (e.g. Gender::male)
I tried using the enumeration full qualified and unqualified. Neither works.
Thanks for your effort.
Aurelien Pupier schrieb:
> (javaeeservers)
> Aurelien Pupier
Dipl.-Inf. Maik Wurdel
Stipendiat GRK MuSAMA
Lehrstuhl Softwaretechnik
Institut fuer Informatik Tel. : +49(0)381-498-7443
Universität Rostock e-mail: maik.wurdel@uni-rostock.de
Joachim Jungius Straße 9
D-18055 Rostock
Re: GMF migration to 2.2 : OCL error [message #237125 is a reply to message #236279] Tue, 21 July 2009 09:43 Go to previous messageGo to next message
posted bug : https://bugs.eclipse.org/bugs/show_bug.cgi?id=284126
Maik Wurdel a écrit :
> works.
>> (javaeeservers)
>> Aurelien Pupier
Re: GMF migration to 2.2 : OCL error [message #478078 is a reply to message #237125] Thu, 06 August 2009 04:15 Go to previous messageGo to next message
After a little amount of time... I find time to look deeper on it so :
bug was set as INVALID and it is right...
In fact the problem seems to be only if we have the enumerated definition in another .ecore.
I upload an example with the bug.
As it was set as fixed too, I don't permit me to reopened it all the more that the first description was not totally right.
Do I need to create a new?
>> works.
>>> Hi,
>>> (javaeeservers)
>>> Aurelien Pupier
Re: GMF migration to 2.2 : OCL error [message #478684 is a reply to message #478078] Thu, 06 August 2009 08:13 Go to previous messageGo to next message
Seems was not that too...
I can't extract an easy example but in my project it doesn't work.
As the error is : Unknown type ([jonas, JOnASProfile, MINIMAL])
It means that it can't find the jonas package, isn't it?
Because if it will but can't find my enumeration it will be Unknown type ([JOnASProfile, MINIMAL]), isn't it?
I loaded my .ecore with the jonas package : it appears in the list of the gmfmap.
So did I to precise other things? Is that the ns prefix URI which count? the name? the Ns prefix?
I set up all of them to jonas to try but seems that doesn't work anymore.
I remove my constraints and rewrite them but same effects.
Can it be possible that it comes from the migration?
Any ideas are welcome
>>> Hi,
>>> they are valid according to the OCL console/interpreter. In
>>> particular I cannot adress an element of the enumeration (e.g.
>>> Gender::male)
>>> works.
>>>> Hi,
>>>> (javaeeservers)
>>>> Aurelien Pupier
Re: GMF migration to 2.2 : OCL error [message #478703 is a reply to message #478684] Thu, 06 August 2009 09:00 Go to previous messageGo to next message
--------------080603000005040606010405
If no more dummies mistake, I think I found in which case.
See attached.
It seems not working if there is a subnode which is declared in another .ecore.
You can compare with the same OCL constraint in the enclosed :
- With the supertypes : it works
- With a subType declared in the same .ecore of the declaration of the enumeration : it works
_ With a subType declared in another .ecore of the declaration of the enumeration (even if it is loaded) : it doesn't work
If someone can confirm that, (and let me hope I'm not so crazy :s)
Aurelien Pupier a
Re: GMF migration to 2.2 : OCL error [message #481006 is a reply to message #478703] Wed, 19 August 2009 06:44 Go to previous message
Hello Aurelien,
This sample project really helps. I've corrected this error. Thank oyu for
investigating it!
Alex Shatalin
Previous Topic:Double EditPart.java files
Next Topic:Drawing on the diagram surface
Current Time: Thu Sep 25 03:32:48 EDT 2025
Powered by FUDForum. Page generated in 0.03269 seconds
