How to create a local simpleContentComplexType ? [message #23108] |
Thu, 29 May 2003 16:03 |
Originally posted by: dirk.schesmer.divos.de
Hi there, I try to create a simpleContentComplexType being local to an
global element called title.
As a result, I always get an additional namespace prefix "Q1". I do not get
this "Q1" prefix when I create a global type titleType having the same
structure and associating it then to an element title (see version 1 and 2
in the code).
Can please anyone give me a clue how come? I attached the code below!
Thanks for help,
Dirk V. Schesmer
public XSDSchema initSimpleContentComplexTypeDefinition() throws Exception {
XSDFactory xsdFactory;
XSDSchema xsdSchema;
Map qNamePrefixToNamespaceMap;
XSDElementDeclaration elementDecl;
xsdFactory = XSDFactory.eINSTANCE;
xsdSchema = xsdFactory.createXSDSchema();
xsdSchema.setTargetNamespace("http://dyomedea.com/ns/library");
xsdSchema.setElementFormDefault(XSDForm.QUALIFIED_LITERAL);
xsdSchema.setAttributeFormDefault(XSDForm.QUALIFIED_LITERAL) ;
xsdSchema.setSchemaForSchemaQNamePrefix("xsd");
qNamePrefixToNamespaceMap = xsdSchema.getQNamePrefixToNamespaceMap();
..put(xsdSchema.getSchemaForSchemaQNamePrefix(), XSDConstants /*}*/
..SCHEMA_FOR_SCHEMA_URI_2001);
String targetNamespace = xsdSchema.getTargetNamespace();
qNamePrefixToNamespaceMap.put("lib", targetNamespace);
XSDConstants.SCHEMA_FOR_SCHEMA_URI_2001);
qNamePrefixToNamespaceMap.put(null, "http://dyomedea.com/ns/library");
elementDecl =
xsdSchema.resolveElementDeclaration(targetNamespace, "title");
XSDComplexTypeDefinition simpleContentComplexTypeDefinition =
xsdFactory.createXSDComplexTypeDefinition();
simpleContentComplexTypeDefinition.setDerivationMethod(
XSDDerivationMethod.EXTENSION_LITERAL);
XSDSimpleTypeDefinition baseTypeString =
xsdSchema.getSchemaForSchema().resolveSimpleTypeDefinition(
"string");
simpleContentComplexTypeDefinition.setBaseTypeDefinition(
baseTypeString);
XSDSimpleTypeDefinition anonymousSimpleTypeDefinition =
xsdFactory.createXSDSimpleTypeDefinition();
simpleContentComplexTypeDefinition.setContent(
anonymousSimpleTypeDefinition);
XSDAttributeDeclaration simpleAttributeDeclaration =
xsdFactory.createXSDAttributeDeclaration();
simpleAttributeDeclaration.setName("bookId");
simpleAttributeDeclaration.setTypeDefinition(baseTypeString) ;
XSDAttributeUse simpleAttributeUse = xsdFactory.createXSDAttributeUse();
simpleAttributeUse.setContent(simpleAttributeDeclaration);
simpleContentComplexTypeDefinition.getAttributeContents().ad d(
simpleAttributeUse);
// version 1:
// create simpleContentComplexType as global type used by "title" element
simpleContentComplexTypeDefinition.setName("titleType");
xsdSchema.getContents().add(simpleContentComplexTypeDefiniti on);
elementDecl.setTypeDefinition(simpleContentComplexTypeDefini tion);
// version 2:
// attempt to create simpleContentComplexType as "title" element's local
type
// => a new namespace prefix "Q1" I have no clue where it comes from ?!
//elementDecl.setAnonymousTypeDefinition(simpleContentComple xTypeDefinition)
//xsdSchema.getContents().add(elementDecl);
xsdSchema.updateElement();
return xsdSchema;
Re: How to create a local simpleContentComplexType ? [message #23188 is a reply to message #23108] |
Wed, 04 June 2003 23:33 |
Dave Spriet Messages: 14 Registered: July 2009 |
I think there could be a defect here. I will email Ed about it.
The fix would be to move some code around.
xsdSchema.updateElement(); //Update Element after you set the namespace
stuff just so a Document is created.
elementDecl = xsdSchema.resolveElementDeclaration(targetNamespace, "title");
xsdSchema.getContents().add(elementDecl); //Add the element right away to
the XSDSchema. Then do the rest of the code.
Dave Spriet
Webshpere Business Integration
spriet@ca.ibm.com
"Dirk V. Schesmer" <dirk.schesmer@divos.de> wrote in message
news:bb5b0u$6b7$1@rogue.oti.com...
get
> in the code).
> Thanks for help,
> Dirk V. Schesmer
> elementDecl =
> "string");
> baseTypeString);
> // version 1:
> // version 2:
> type
> return xsdSchema;
Re: How to create a local simpleContentComplexType ? [message #23326 is a reply to message #23108] |
Mon, 09 June 2003 19:58 |
Dirk,
This should work better in the next driver.
> in the code).
> Thanks for help,
> Dirk V. Schesmer
> elementDecl =
> "string");
> baseTypeString);
> // version 1:
> // version 2:
> type
> return xsdSchema;
Re: How to create a local simpleContentComplexType ? [message #572637 is a reply to message #23108] |
Dave Spriet
spriet@ca.ibm.com
get
> in the code).
> Thanks for help,
> Dirk V. Schesmer
> elementDecl =
> "string");
> baseTypeString);
> // version 1:
> // version 2:
> type
> return xsdSchema;
Re: How to create a local simpleContentComplexType ? [message #572740 is a reply to message #23108] |
Ed Merks Messages: 33216 Registered: July 2009 |
Dirk,
> in the code).
> Thanks for help,
> Dirk V. Schesmer
> elementDecl =
> "string");
> baseTypeString);
> // version 1:
> // version 2:
> type
> return xsdSchema;
Ed Merks
FUDForum. Page generated in 0.04326 seconds
