Home » Modeling » GMF (Graphical Modeling Framework) » Diagram node as image
Diagram node as image [message #235656] Wed, 08 July 2009 10:27 Go to next message
Hi, does anyone have any ideas how to set a diagram node to display as an
image?
Thanks in advance,
Gary
Re: Diagram node as image [message #235707 is a reply to message #235656] Thu, 09 July 2009 05:38 Go to previous messageGo to next message
I use a custom figure.
In your Figure Gallery > Figure Descriptor > Rectangle > Custom Figure
In the properties of the Custom Figure:
Name: as your want
Qualified Class Name:
org.eclipse.gmf.runtime.draw2d.ui.render.figures.ScalableIma geFigure
Then generate etc.
Now you'll see some error on the files XXXPart.java
look for the method CreateContents()
and put something like this
URL url = this.getClass().getResource("");
ScalableImageFigure name_your_put = new
ScalableImageFigure(RenderedImageFactory.getInstance(url),tr ue,true,true);
this.add(name_your_put);
Try this
Re: Diagram node as image [message #235761 is a reply to message #235707] Thu, 09 July 2009 07:15 Go to previous messageGo to next message
Thanks for your reply!
Just wondering, do you know of a way to do this before code generation?
The model I am working with is still undergoing change, so I currently
have to change my model and regenerate the code on a weekly basis, because
of this don't want to be editing the code after generation if I can avoid
it.
I'm rather supprised that GMF doesn't allow you to select an image (in the
place of a shape) for a node, I would have thought many people would want
this sort of functionality!
Thanks in advance,
Gary
Re: Diagram node as image [message #235768 is a reply to message #235761] Thu, 09 July 2009 07:23 Go to previous messageGo to next message
Originally posted by: aurelien.pupier.esial.net
Hi Gary,
comments below.
> because of this don't want to be editing the code after generation if I
> can avoid it.
You can set @generated NOT flag to the modified function or modified the template used for generation.
> the place of a shape) for a node, I would have thought many people would
> want this sort of functionality!
You can open a bug to ask for this enhancement.
> Thanks in advance,
> Gary
Re: Diagram node as image [message #235809 is a reply to message #235707] Thu, 09 July 2009 09:33 Go to previous messageGo to next message
Hi, a quick question!
-in the code you suggested, do i put the image url as shown below?
URL url = this.getClass().getResource(" --my image url-- ");
also what does 'RenderedImageFactory' reference in the lines below?
ScalableImageFigure nodeFig0 = new
Re: Diagram node as image [message #236139 is a reply to message #235707] Tue, 14 July 2009 07:43 Go to previous message
using eclipse ganymede, cannot import
org.eclipse.gmf.runtime.draw2d.ui.render.renderedImageFactor y;
for use with the previously mentioned suggestion for replacing my nodes
with images.
Does anyone know of a solution?
thanks in advance,
Gary
Previous Topic:Drag parent by dragging child
Next Topic:Confirm delete shape
Current Time: Sun Nov 09 00:39:48 EST 2025
Powered by FUDForum. Page generated in 0.44489 seconds
