Wide Labels below small figures [message #235636] |
Wed, 13 June 2007 18:54 |
Originally posted by: mlevison.gmail.com
Sometimes the user wants to give a name to an object that is wider than
the figure it sits below. How do I accommodate this?
The standard solution to labels below figures is a composite figure
using a Flow/Toolbar layout to position the children
( http://dev.eclipse.org/newslists/news.eclipse.tools.gef/msg1 8144.html).
Like Alex I see two problems with this solution?
1) The label is clipped to the bounds of the parent
2) For purposes of attachment etc the bounds grow to include the label.
Instead I would like a piece of text that sits below my figure but
doesn't change its bounds. In addition when the figure is moved the
piece of text should move to.
Is this possible? How?
Cheers
Mark Levison
Re: Wide Labels below small figures [message #235738 is a reply to message #235636] |
Thu, 14 June 2007 21:00 |
BTW the Interface HandleBounds and getHandleBounds seem designed with
this problem in mind. I haven't coded it yet so I'm not certain that is
the solution - but we have a good chance here.
Re: Wide Labels below small figures [message #235745 is a reply to message #235738] |
Fri, 15 June 2007 05:42 |
I'm very interested in this topic as well Mark, please keep us posted on
your progress. If I can close some other issues I might start to look at
this myself as well.
/Johan
Re: Wide Labels below small figures [message #235986 is a reply to message #235745] |
Wed, 20 June 2007 01:12 |
My solution
1) Wrap the original figure in a wrapping figure that also includes the
label. The wrapping figure grows to be as large as required by the label.
2) Implement the interface HandleBounds on the wrapping figure and get
it to report the size of the original figure.
To get connections to appear in the right place:
Override the Anchor that you're using and in the getBox() return the
same bounds that you did for HandleBounds (see HandleBoundsAnchor).
Sample code - N.B. This code has been sanitized to avoid reveal
corporate details. Its not guaranteed to compile.
public class LabelWrapperFigure extends Figure implements HandleBounds
public LabelWrapperFigure(IFigure wrappedFigure) {
layout = new ToolbarLayout();
layout.setMinorAlignment(ToolbarLayout.ALIGN_CENTER);
layout.setStretchMinorAxis(false);
layout.setSpacing(2);
layout.setVertical(true);
// why didn't flowLayout work??
// FlowLayout layout = new FlowLayout();
// layout.setHorizontal(false);
// layout.setMajorSpacing(2);
// layout.setMajorSpacing(0);
// layout.setMinorAlignment(FlowLayout.ALIGN_CENTER);
// layout.setMajorAlignment(FlowLayout.ALIGN_CENTER);
setLayoutManager(layout);
setOpaque(true);
add(wrappedFigure);
Label label = new Label();
label.setText(" some text ");
label.setTextPlacement(PositionConstants.SOUTH);
add(label);
public Rectangle getHandleBounds() {
// Get size from your figure somehow
return wrappedFigure.getBounds();
public class HandleBoundsAnchor extends ChopboxAnchor {
private final HandleBounds handleBounds;
public HandleBoundsAnchor(IFigure figure) {
super(figure);
// TODO consider requiring a derivation of ModelElementFigure
if (false == (figure instanceof HandleBounds)) {
// This won't compile we've got custom exception code
throw new IllegalArgException();
handleBounds = (HandleBounds) figure;
protected Rectangle getBox() {
return handleBounds.getHandleBounds();
FUDForum. Page generated in 0.03923 seconds
