Home » Language IDEs » C / C++ IDE (CDT) » changing "Problems" path
changing "Problems" path [message #235280] Mon, 29 June 2009 09:58 Go to next message
Originally posted by: marco.binz.annax.ch
I'm using Eclipse / CDT on Windows, my source files however are on a
linux server. We access the files with a network drive connecting to the
server using samba. Compilation is done on the server, using plink (a
"command line PuTTY".
Paths to files with errors or warnings are of corse returned by the
compiler in linux style, e.g. /home/Projects/Projectx/main.cpp
Since these paths are not known to Windows, I can't doubelick on a error
/ warning in the "Problems" view to jump to the problem.
Is there a way to tell Eclipse (or the error parser, or make, or...) to
change the path from /home/Projects/... to Q:\Projects\...?
Marco
Re: changing "Problems" path [message #235294 is a reply to message #235280] Mon, 29 June 2009 14:27 Go to previous messageGo to next message
> change the path from /home/Projects/... to Q:Projects...?
Doubleclick will work only for paths which are in eclipse workspace. In
CDT 6.0 eclipse can find absolute path in any workspace folder as long as
it ends with it (gotta be full path). I.e. you can create a project
"LinuxFiles" and link your Q:Projects/ folder to LinuxFiles/home/Projects/
(using New-Folder/Advanced/Link-to-folder-in-the-file-system) so you get
/home/Projects/Projectx/main.cpp in LinuxFiles project. If this is C++
project you'll get F3 code navigation to there as well. But beware that
network folder like that can slow things down as eclipse is eager to
refresh the whole workspace on builds.
Andrew
Re: changing "Problems" path [message #235299 is a reply to message #235294] Tue, 30 June 2009 04:56 Go to previous messageGo to next message
Unfortunately, we're still working with Eclipse 3.4.1 / CDT 5.0.1 here,
so I tried to do it in the Project itself, not in a special "LinuxFiles"
project. But eclipse doesn't allow this, it says "Cannot create a link
to 'Q:\Projects' because it overlaps the location of the project that
contains the linked resource."
So guess I'm out of luck until we update to the new eclipse / cdt,
unless anyone has another idea?
Btw, F3 code navigation works, guess that relies on the data collected
by the indexer and not the compiler.
Marco
> as it ends with it (gotta be full path). I.e. you can create a project
> LinuxFiles/home/Projects/ (using
> Andrew
Re: changing "Problems" path [message #235313 is a reply to message #235299] Tue, 30 June 2009 09:03 Go to previous message
> to 'Q:Projects' because it overlaps the location of the project that
So you already got the files in your workspace. But it is not going to
work in CDT 5.0.X with absolute paths in output. It may find relative ones
with some luck.
You can try to imitate directory structure on Windows filesystem starting
from root, i.e. place your files like Q:\home\Projects\Projectx\main.cpp.
This may allow to use "Open external location" from Problems View
(right-click on error/warning) - if you can see the full file name in the
description of the error. I think it has to be current drive, i.e. start
eclipse in a folder on Q: drive. But don't expect double-click to work.
I'd really advise to update to CDT 6.0. It's well worth it.
Andrew
Previous Topic:Starting debug session from command line
Next Topic:CDT Plug-in "dropins" folder problem
Current Time: Sun Oct 19 02:22:43 EDT 2025
Powered by FUDForum. Page generated in 0.03609 seconds
