Failed to create the part's controls [message #1355063] |
Wed, 14 May 2014 14:55 |
Ferran Romero Messages: 3 Registered: May 2014 |
Junior Member |
Hi all,
First of all, I'm a eclipse Newbie, also in this forum, so please be kind with me and with my poor knowledge. I've downloaded Eclipse for a general purpose IDE (but primarily for PHP development), and got the Kepler version.
I've installed the PDT (PHP Development Tools), JavaScript Development Tools, Eclipse Color Theme and Subversive with SVNKit 1.8.3. After that, I've done a checkout from a repository to import it to Eclipse, and then open the PHP Perspective.
When I try to open some PHP files I've got "Failed to create the part's controls" error, with this details:
java.lang.IllegalArgumentException: Argument not valid
at org.eclipse.swt.SWT.error(SWT.java:4378)
at org.eclipse.swt.SWT.error(SWT.java:4312)
at org.eclipse.swt.SWT.error(SWT.java:4283)
at org.eclipse.swt.custom.StyledText.setStyleRanges(StyledText.java:9736)
at org.eclipse.swt.custom.StyledText.replaceStyleRanges(StyledText.java:7749)
at org.eclipse.jface.text.TextViewer.addPresentation(TextViewer.java:4845)
at org.eclipse.jface.text.TextViewer.changeTextPresentation(TextViewer.java:4924)
at org.eclipse.wst.sse.ui.internal.provisional.style.StructuredPresentationReconciler.applyTextRegionCollection(StructuredPresentationReconciler.java:901)
at org.eclipse.wst.sse.ui.internal.provisional.style.StructuredPresentationReconciler.processDamage(StructuredPresentationReconciler.java:876)
at org.eclipse.wst.sse.ui.internal.provisional.style.StructuredPresentationReconciler$InternalListener.inputDocumentChanged(StructuredPresentationReconciler.java:271)
at org.eclipse.wst.sse.ui.internal.provisional.style.StructuredPresentationReconciler.install(StructuredPresentationReconciler.java:600)
at org.eclipse.wst.sse.ui.internal.StructuredTextViewer.updateHighlighter(StructuredTextViewer.java:987)
at org.eclipse.wst.sse.ui.internal.StructuredTextViewer.setDocument(StructuredTextViewer.java:865)
at org.eclipse.php.internal.ui.editor.PHPStructuredTextViewer.setDocument(PHPStructuredTextViewer.java:645)
at org.eclipse.jface.text.source.SourceViewer.setDocument(SourceViewer.java:590)
at org.eclipse.ui.texteditor.AbstractTextEditor.initializeSourceViewer(AbstractTextEditor.java:4047)
at org.eclipse.ui.texteditor.AbstractTextEditor.createPartControl(AbstractTextEditor.java:3575)
at org.eclipse.ui.texteditor.StatusTextEditor.createPartControl(StatusTextEditor.java:54)
at org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.createPartControl(AbstractDecoratedTextEditor.java:447)
at org.eclipse.wst.sse.ui.StructuredTextEditor.createPartControl(StructuredTextEditor.java:1517)
at org.eclipse.php.internal.ui.editor.PHPStructuredEditor.createPartControl(PHPStructuredEditor.java:2265)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPartControl(CompatibilityPart.java:142)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityEditor.createPartControl(CompatibilityEditor.java:96)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:323)
at sun.reflect.GeneratedMethodAccessor26.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Method.java:483)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:877)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:857)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:119)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:333)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:254)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:102)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:71)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:53)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:129)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:949)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:633)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:735)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:706)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:700)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:685)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1147)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer$1.handleEvent(LazyStackRenderer.java:65)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:41)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:180)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4491)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:205)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:80)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:58)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:171)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:576)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.bringToTop(ModelServiceImpl.java:543)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.delegateBringToTop(PartServiceImpl.java:619)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.bringToTop(PartServiceImpl.java:331)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:1046)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:3112)
at org.eclipse.ui.internal.WorkbenchPage.access$21(WorkbenchPage.java:3034)
at org.eclipse.ui.internal.WorkbenchPage$8.run(WorkbenchPage.java:3016)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3012)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2976)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2967)
at org.eclipse.dltk.internal.ui.editor.EditorUtility.openInEditor(EditorUtility.java:413)
at org.eclipse.dltk.internal.ui.editor.EditorUtility.openInEditor(EditorUtility.java:177)
at org.eclipse.php.internal.ui.actions.OpenActionUtil.open(OpenActionUtil.java:54)
at org.eclipse.php.internal.ui.actions.OpenAction.run(OpenAction.java:177)
at org.eclipse.php.internal.ui.actions.OpenAction.run(OpenAction.java:151)
at org.eclipse.php.internal.ui.actions.SelectionDispatchAction.dispatchRun(SelectionDispatchAction.java:190)
at org.eclipse.php.internal.ui.actions.SelectionDispatchAction.run(SelectionDispatchAction.java:168)
at org.eclipse.php.internal.ui.actions.PHPExplorerActionGroup.handleOpen(PHPExplorerActionGroup.java:171)
at org.eclipse.dltk.internal.ui.scriptview.ScriptExplorerPart$4.open(ScriptExplorerPart.java:678)
at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:866)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
at org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:864)
at org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:1152)
at org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(StructuredViewer.java:1256)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrategy.java:275)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.java:269)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:309)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1392)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3742)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3363)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1113)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:140)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:611)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
There's some files in the same project that I'm able to open without any errors, and some others that throws this exception. I think there's a problem with the PHP Editor, since I'm able to open all files with the integrated text editor.
Any suggestions?
Thanks in advice,
Re: Failed to create the part's controls [message #1375996 is a reply to message #1368856] |
Fri, 23 May 2014 08:04 |
Shiho P. Messages: 1 Registered: May 2014 |
Junior Member |
Same problem... I'm using Kepler on Lubuntu 13.10 / 32bit.
It works for some php files but not all of them. Can't find the logic behind.
Last time I had it back to work by doing a new svn checkout but today it won't do the trick.
If someone has any idea...
EDIT : I work on 2 different projects. The one using Sf1 / SVN is the one causing me troubles. The other one (Sf2/Git) works perfectly.
[Updated on: Fri, 23 May 2014 08:08] Report message to a moderator
FUDForum. Page generated in 0.04590 seconds
