Problem with compartments [message #235037] |
Wed, 01 July 2009 17:04  |
I'm trying to create an element with one compartment like the Topic
element in the Tutorial Part 2, so I followed the Tutorial, it worked well
on the example, but when I tried to do with my own diagram it didn't work,
when I drop some element into my package compartment, I can't move o
resize the element inside the package, they go automatic to the corner of
the compartment when I drop it in the compartment. I tried to change the
layout of my packagefigure but it didn't work either.
In my .graph configuration I used the same of the tutorial. A Figure
Descriptor with a Rounded Rectangle using the Flow Layout False and some
labels.
And I created a Compartment named taskCompartment with my PackageFigure as
Figure.
In the .map, I let the wizard create the package node, and put the other
by my self.
Frist I created a compartment mapping on the Package Node and associate it
with the compartment of .graph.
After that I inserted a Child Reference on the Package Node and a Node
Mapping on it.
On the Child reference I put this:
-Child : Node Mapping <Task/Task>
-Children Feature : EMPTY
-Compartment Feature : Compartment Mapping <taskCompartment>
-Containment Feature : taksReference : Taks
-Referenced Child : EMPTY
On the Task's node:
Element : Task
Diagram Node : Node Task(TaskFigure)
Tool : Creation Tool Task
I'm sure that I miss something, but I didn't find it following the
tutorial again.
I can send by e-mail two screenshots to show what is the problem if you
didn't catch.
Re: Problem with compartments [message #467974 is a reply to message #467952] |
Mon, 03 August 2009 09:39  |
Tobias, Alex
Thank you guys very much.
Stack Layout working a job for me right now, but still remains a problem
with adding node over the label.
I am relatively new in this GMF story, probably there are many ways to
solve this problem (probably a combination of layouts), but I still don't
know how to do it. I will work on it.
Thank you again.
Sinisa
FUDForum. Page generated in 0.07110 seconds
