Home » Newcomers » Newcomers » How can I display non-english characters in view and editor parts
How can I display non-english characters in view and editor parts [message #234972] Thu, 27 September 2007 10:33 Go to next message
Originally posted by: wjfang.gmail.com
I know there is a language package to translate all menus, actions, etc. to
non-english, such as chinese. That is not what I want. I want to simply
display chinese in view part or editor part. How can I achieve it? Thanks a
lot!
Weijian
Re: How can I display non-english characters in view and editor parts [message #234989 is a reply to message #234972] Thu, 27 September 2007 10:52 Go to previous messageGo to next message
Weijian,
Java support full unicode so given that your OS has the available fonts
to display the Chinese characters that you tell Eclipse to display, this
should just work.
Weijian wrote:
> lot!
> Cheers,
> Weijian
Re: How can I display non-english characters in view and editor parts [message #235001 is a reply to message #234989] Thu, 27 September 2007 11:06 Go to previous messageGo to next message
Hi Ed,
> Java support full unicode so given that your OS has the available fonts to
> should just work.
This was what i thought. But it seems does not work like this.
I created (not using eclipse) a chinese.txt that contains chinese charaters.
I can use notepad to open it and read its chinese. But when i used eclispe
to open it, I can not read the chinese.
When I create a text file containing chinese using eclipse, it does display
chinese. But when I try to save it, I saw a message dialog saying "save
could not be completed. some characters cannot be mapped using "Cp1252"
character encoding. "
Any idea? Thanks!
Weijian
> Weijian wrote:
>> to non-english, such as chinese. That is not what I want. I want to
>> simply display chinese in view part or editor part. How can I achieve it?
>> Thanks a lot!
>> Cheers,
>> Weijian
Re: How can I display non-english characters in view and editor parts [message #235016 is a reply to message #235001] Thu, 27 September 2007 11:24 Go to previous messageGo to next message
I see I need to set text file encoding to UTF-8 instead of using the default
cp1252.
How do i programmatically set the text file encoding?
Thanks.
"Weijian" <wjfang@gmail.com> wrote in message
news:fdggtm$nkf$1@build.eclipse.org...
> Hi Ed,
>> should just work.
> charaters. I can use notepad to open it and read its chinese. But when i
> used eclispe to open it, I can not read the chinese.
> display chinese. But when I try to save it, I saw a message dialog saying
> "save could not be completed. some characters cannot be mapped using
> "Cp1252" character encoding. "
> Any idea? Thanks!
> Cheers,
> Weijian
>> Weijian wrote:
>>> Hi,
>>> it? Thanks a lot!
>>> Cheers,
>>> Weijian
Re: How can I display non-english characters in view and editor parts [message #235022 is a reply to message #235016] Thu, 27 September 2007 11:36 Go to previous message
--------------080709090404010208010404
Weijian,
You can use IFile.setCharset. Note that you can use
Window->Preferences->General->Workspace to change the default encoding
for all text files. Folders and projects also support setting a default
encoding for the contained text files (which can be done
programmatically using IContainer.setDefaultCharset).
> cp1252.
> Thanks.
>> Hi Ed,
>>> should just work.
>> Any idea? Thanks!
>> Cheers,
>> Weijian
>>> Weijian wrote:
>>>> Hi,
>>>> it? Thanks a lot!
>>>> Cheers,
>>>> Weijian
<html>
<head>
</head>
Weijian,<br>
<br>
You can use IFile.setCharset.&nbsp; Note that you can use
Window-&gt;Preferences-&gt;General-&gt;Workspace to change the default
encoding for all text files.&nbsp; Folders and projects also support setting
a default encoding for the contained text files (which can be done
programmatically using IContainer.setDefaultCharset).<br>
<br>
<br>
Weijian wrote:
<blockquote cite="mid:fdghup$qgh$1@build.eclipse.org" type="cite">
<pre wrap="">I see I need to set text file encoding to UTF-8 instead of using the default
cp1252.
Thanks.
"Weijian" <a class="moz-txt-link-rfc2396E" href="mailto:wjfang@gmail.com">&lt;wjfang@gmail.com&gt;</a> wrote in message
<a class="moz-txt-link-freetext" href="news:fdggtm$nkf$1@build.eclipse.org">news:fdggtm$nkf$1@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Hi Ed,
</pre>
<pre wrap="">Java support full unicode so given that your OS has the available fonts
should just work.
</pre>
</blockquote>
<pre wrap="">This was what i thought. But it seems does not work like this.
Any idea? Thanks!
Weijian
</pre>
<pre wrap="">Weijian wrote:
</pre>
<pre wrap="">Hi,
it? Thanks a lot!
Weijian
</pre>
</blockquote>
</blockquote>
<pre wrap="">
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------080709090404010208010404--
Previous Topic:IPC in Eclipse
Next Topic:install eclipse sources
Current Time: Wed Jul 02 15:16:49 EDT 2025
Powered by FUDForum. Page generated in 0.11254 seconds
