How to add a menu item on the context menu [message #234727] |
Fri, 26 June 2009 09:23 |
Originally posted by: billgrand08.gmail.com
I see that we can use the
" org.eclipse.gmf.runtime.common.ui.services.action.contributi onItemProviders "
extension point, can someone give a example how to add a menu item on the
context menu, I define as below, but it doesn't work(add a menu named
"AssignToGlossaryMenu"), thanks.
<extension
id="ContributionItemProvider"
name="ContributionItemProvider"
point=" org.eclipse.gmf.runtime.common.ui.services.action.contributi onItemProviders ">
<contributionItemProvider
checkPluginLoaded="false"
class="com.mine.actions.ContributionItemProvider">
<Priority
name="Lowest">
</Priority>
<popupContribution
id="org.eclipse.gmf.runtime.diagram.ui.DiagramEditorContextMenu ">
<popupMenuGroup
id="PopupMenuGroup"
path="/"
separator="true">
</popupMenuGroup>
<popupMenu
id="AssignToGlossaryMenu"
path="/PopupMenuGroup">
</popupMenu>
<popupAction
id="AssignToGlossaryAction"
path="/AssignToGlossaryMenu">
</popupAction>
</popupContribution>
</contributionItemProvider>
</extension>
FUDForum. Page generated in 0.03126 seconds
