| Concurrency in incquery [message #1352320] |
Tue, 13 May 2014 08:04  |
We've been experiencing some problems since we switched to tag 0.8.0M3. When the incquery is accessed concurrently from multiple threads, it starts throwing exceptions and causes the whole workbench to freeze.
The situation is as follows:
Our models are contained in projects and there is a view which content is calculated using queries. When the user opens a project, a resourceSet is created, and a job is started to read its content. In the meantime, the view tries to initialize its content and instantiates its queries. The following is the first exception which occurs during initialization of the query:
Thread [main] (Suspended (exception ConcurrentModificationException))
owns: ReteBoundary (id=153)
owns: ReteEngine (id=154)
HashMap$EntryIterator(HashMap$HashIterator<E>).nextEntry() line: not available
HashMap$EntryIterator.next() line: not available
StandardTable$Column$EntrySetIterator.computeNext() line: 620
StandardTable$Column$EntrySetIterator.computeNext() line: 615
StandardTable$Column$EntrySetIterator(AbstractIterator<T>).tryToComputeNext() line: 141
StandardTable$Column$EntrySetIterator(AbstractIterator<T>).hasNext() line: 136
NavigationHelperImpl.processAllFeatureInstances(EStructuralFeature, IEStructuralFeatureProcessor) line: 289
EMFPatternMatcherRuntimeContext.enumerateDirectBinaryEdgeInstances(Object, IPatternMatcherRuntimeContext$ModelElementPairCrawler) line: 125
EMFPatternMatcherRuntimeContext.enumerateAllBinaryEdgeInstances(Object, IPatternMatcherRuntimeContext$ModelElementPairCrawler) line: 137
ReferenceFeeder.feed() line: 36
ReteBoundary.accessBinaryEdgeRoot(Object) line: 254
ReteContainerCompiler.binaryEdgeTypePlan(Tuple, Object) line: 185
SubPlanProcessor.processConstraint(TypeBinary) line: 135
SubPlanProcessor.dispatchConstraint(EnumerablePConstraint) line: 86
SubPlanProcessor.processEnumerableConstraint(EnumerablePConstraint) line: 58
QuasiTreeLayout$Scaffold.run() line: 81
QuasiTreeLayout.layout(PBody, IOperationCompiler<?>, IPatternMatcherContext) line: 45
EPMBuildScaffold<Collector>.construct(PQuery) line: 53
EPMBuilder<Collector>.construct(PQuery) line: 54
ReteBoundary.construct(PQuery) line: 528
ReteBoundary.accessProduction(PQuery) line: 460
ReteContainerCompiler.patternCallPlan(Tuple, PQuery) line: 157
SubPlanProcessor.processConstraint(PositivePatternCall) line: 131
SubPlanProcessor.dispatchConstraint(EnumerablePConstraint) line: 84
ReteEngine$1.call() line: 178
NavigationHelperImpl.coalesceTraversals(Callable<V>) line: 971
EMFPatternMatcherRuntimeContext.coalesceTraversals(Callable<V>) line: 86
ReteEngine.constructionWrapper(Callable<Void>) line: 226
ReteEngine.accessMatcher(PQuery) line: 174
ShortnamePathCollisionMatcher(BaseMatcher<Match>).accessMatcher(IncQueryEngineImpl, IQuerySpecification<BaseMatcher<Match>>) line: 71
ShortnamePathCollisionMatcher(BaseMatcher<Match>).<init>(IncQueryEngine, IQuerySpecification<BaseMatcher<Match>>) line: 60
generic.eiq line: 7
generic.eiq line: 7
generic.eiq line: 7
generic.eiq line: 7
ShortnamePathCollisionQuerySpecification(BaseQuerySpecification<Matcher>).getMatcher(IncQueryEngine) line: 68
IncQueryEventSource<Match>.<init>(IncQueryEventRealm, IncQueryEventSourceSpecification<Match>) line: 44
IncQueryEventRealm.createSource(EventSourceSpecification<Match>) line: 50
IncQueryRuleInstanceBuilder<Match>.prepareRuleInstance(RuleInstance<Match>, EventFilter<? super Match>) line: 34
RuleSpecification<EventAtom>.instantiateRule(EventRealm, EventFilter<? super EventAtom>) line: 85
RuleBase.instantiateRule(RuleSpecification<EventAtom>, EventFilter<? super EventAtom>) line: 78
ExecutionSchema(RuleEngine).addRule(RuleSpecification<EventAtom>, EventFilter<? super EventAtom>) line: 113
ObservableCollectionHelper.prepareRuleEngine(IncQueryEngine, RuleSpecification<Match>, EventFilter<Match>) line: 116
ObservablePatternMatchList<Match>.<init>(IQuerySpecification<Matcher>, IncQueryEngine) line: 84
IncQueryObservables.observeMatchesAsList(IQuerySpecification<Matcher>, IncQueryEngine) line: 84
When this happens, the worker thread is currently doing the on-load model traversal:
Thread [Worker-4] (Suspended)
BasicNotifierImpl$EAdapterList<E>.newData(int) line: 108
BasicNotifierImpl$EAdapterList<E>(BasicEList<E>).grow(int) line: 727
BasicNotifierImpl$EAdapterList<E>(BasicEList<E>).addUnique(E) line: 416
BasicNotifierImpl$EAdapterList<E>(AbstractEList<E>).add(E) line: 301
BasicNotifierImpl$EAdapterList<E>.add(E) line: 193
NavigationHelperContentAdapter(EContentAdapter).addAdapter(Notifier) line: 349
NavigationHelperContentAdapter.access$1(NavigationHelperContentAdapter, Notifier) line: 1
NavigationHelperContentAdapter$1.call() line: 297
NavigationHelperContentAdapter$1.call() line: 1
NavigationHelperImpl.coalesceTraversals(Callable<V>) line: 987
NavigationHelperContentAdapter.addAdapter(Notifier) line: 289
NavigationHelperContentAdapter(EContentAdapter).handleContainment(Notification) line: 139
NavigationHelperContentAdapter(EContentAdapter).selfAdapt(Notification) line: 63
NavigationHelperContentAdapter(EContentAdapter).notifyChanged(Notification) line: 40
NavigationHelperContentAdapter.notifyChanged(Notification) line: 201
ARResourceImpl(BasicNotifierImpl).eNotify(Notification) line: 374
ResourceImpl$ContentsEList<E>(NotifyingListImpl<E>).dispatchNotification(Notification) line: 261
ResourceImpl$ContentsEList<E>(NotifyingListImpl<E>).addUnique(E) line: 294
ResourceImpl$ContentsEList<E>(AbstractEList<E>).add(E) line: 301
ARLoad.load(XMLResource, InputStream, Map<?,?>) line: 38
ARResourceImpl(XMLResourceImpl).doLoad(InputStream, Map<?,?>) line: 253
ARResourceImpl(ResourceImpl).load(InputStream, Map<?,?>) line: 1518
ARResourceImpl(ResourceImpl).load(Map<?,?>) line: 1297
Does concurrent calls causes this? Do I need to take extra measures to avoid concurrent calls even when the model is written on one thread? Do I need to delay query initialization until the model is loaded?
Thanks in advance
Balázs Grill;
FUDForum. Page generated in 0.04160 seconds
