When I start then eclipse has got a lot of errors. [message #234102] |
Thu, 23 July 2009 19:42  |
--------------020808000704040906060509
Hello everyone!
I was starting eclipse at last day so didn't have problems... but, why
suddenly I start eclipse then has got a lot of errors since this morning.
Just a little message below to my errors.
1. An error occurred while automatically activating bundle
org.eclipse.jdt.ui (312).
2. Unable to create editor ID org.eclipse.jdt.ui.CompilationUnitEditor:
The editor class could not be instantiated. This usually indicates a
missing no-arg constructor or that the editor's class name was mistyped
in plugin.xml.
3. Ignored attempt to add saveable that was already registered
4. Unable to create view ID org.eclipse.jdt.ui.PackageExplorer: Plug-in
org.eclipse.jdt.ui was unable to load class
org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart.
For more error message and Exception stack trace, I attached a
file(errors.log). that was exported from Eclipse Log viewer.
Please help me I'm finished work today.
name="errors.log"
Content-Disposition: inline;
filename="errors.log"
!SESSION 2009-07-24 07:49:26.312 -----------------------------------------------
eclipse.buildId=I20090611-1540
java.version=1.6.0_14
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=ko_KR
Framework arguments: -product org.eclipse.epp.package.jee.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product org.eclipse.epp.package.jee.product
This is a continuation of log file D:\work\workspace\.metadata\.bak_0.log
Created Time: 2009-07-24 07:49:46.046
!ENTRY org.eclipse.osgi 4 0 2009-07-24 07:49:46.046
!MESSAGE An error occurred while automatically activating bundle org.eclipse.jdt.ui (312).
!STACK 0
org.osgi.framework.BundleException: The activator org.eclipse.jdt.internal.ui.JavaPlugin for bundle org.eclipse.jdt.ui is invalid
at org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:157)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:750)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:352)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:280)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:408)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:449)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:211)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass (BundleLoader.java:376)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:452)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:405)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:393)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:105)
at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(Bund leLoader.java:321)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:231)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1193)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:160)
at org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:874)
at org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:267)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:263)
at org.eclipse.ui.internal.registry.EditorDescriptor.createEdit or(EditorDescriptor.java:235)
at org.eclipse.ui.internal.EditorManager.createPart(EditorManag er.java:845)
at org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:606)
at org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:462)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:595)
at org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(Ed itorAreaHelper.java:271)
at org.eclipse.ui.internal.EditorManager.setVisibleEditor(Edito rManager.java:1417)
at org.eclipse.ui.internal.EditorManager$5.runWithException(Edi torManager.java:942)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:134)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3855)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3476)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:803)
at org.eclipse.ui.internal.Workbench$28.runWithException(Workbe nch.java:1384)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2316)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
Caused by: java.lang.NoClassDefFoundError: org/eclipse/jdt/core/IBufferFactory
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Unknown Source)
at java.lang.Class.getConstructor0(Unknown Source)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:152)
... 62 more
Caused by: org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter $TerminatingClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.jdt.core (303).
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:125)
at org.eclipse.osgi.internal.loader.SingleSourcePackage.loadCla ss(SingleSourcePackage.java:33)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:449)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
... 68 more
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.jdt.core.JavaCore.start() of bundle org.eclipse.jdt.core.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:805)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:754)
... 78 more
Caused by: java.lang.NullPointerException
at org.eclipse.jdt.internal.core.JavaModelManager.containersRes et(JavaModelManager.java:748)
at org.eclipse.jdt.internal.core.JavaModelManager.loadVariables AndContainers(JavaModelManager.java:3001)
at org.eclipse.jdt.internal.core.JavaModelManager.startup(JavaM odelManager.java:4589)
at org.eclipse.jdt.core.JavaCore.start(JavaCore.java:4965)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1 .run(BundleContextImpl.java:782)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:773)
... 83 more
Root exception:
... 68 more
... 78 more
... 83 more
!ENTRY org.eclipse.ui 4 0 2009-07-24 07:49:46.078
!MESSAGE Unable to create editor ID org.eclipse.jdt.ui.CompilationUnitEditor: The editor class could not be instantiated. This usually indicates a missing no-arg constructor or that the editor's class name was mistyped in plugin.xml.
!STACK 0
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter $TerminatingClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.jdt.ui (312).
Caused by: org.osgi.framework.BundleException: The activator org.eclipse.jdt.internal.ui.JavaPlugin for bundle org.eclipse.jdt.ui is invalid
... 57 more
... 62 more
... 68 more
... 78 more
... 83 more
!ENTRY org.eclipse.ui 2 2 2009-07-24 07:49:46.171
!MESSAGE Ignored attempt to add saveable that was already registered
!STACK 0
org.eclipse.core.runtime.AssertionFailedException: unknown saveable: org.eclipse.ui.internal.DefaultSaveable@c44cfb from part: org.eclipse.ui.internal.ErrorEditorPart@c44cfb
at org.eclipse.ui.internal.SaveablesList.logWarning(SaveablesLi st.java:187)
at org.eclipse.ui.internal.SaveablesList.addModel(SaveablesList .java:117)
at org.eclipse.ui.internal.SaveablesList.addModels(SaveablesLis t.java:289)
at org.eclipse.ui.internal.SaveablesList.postOpen(SaveablesList .java:684)
at org.eclipse.ui.internal.PartList.partOpened(PartList.java:23 4)
at org.eclipse.ui.internal.PartList.access$0(PartList.java:210)
at org.eclipse.ui.internal.PartList$1.propertyChanged(PartList. java:40)
at org.eclipse.ui.internal.WorkbenchPartReference.fireInternalP ropertyChange(WorkbenchPartReference.java:375)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:610)
!ENTRY org.eclipse.equinox.registry 4 1 2009-07-24 07:50:07.031
!MESSAGE Unable to create view ID org.eclipse.jdt.ui.PackageExplorer: Plug-in org.eclipse.jdt.ui was unable to load class org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart.
!STACK 0
... 57 more
... 62 more
... 68 more
... 78 more
... 83 more
!ENTRY org.eclipse.ui 4 0 2009-07-24 07:50:08.843
!STACK 0
... 57 more
... 62 more
... 68 more
... 78 more
... 83 more
!ENTRY org.eclipse.ui 2 2 2009-07-24 07:50:08.843
!STACK 0
org.eclipse.core.runtime.AssertionFailedException: unknown saveable: org.eclipse.ui.internal.DefaultSaveable@89eb77 from part: org.eclipse.ui.internal.ErrorEditorPart@89eb77
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:31 3)
at org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:180)
at org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:270)
at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
at org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:473)
at org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1256)
at org.eclipse.ui.internal.PartStack.handleDeferredEvents(PartS tack.java:1224)
at org.eclipse.ui.internal.LayoutPart.deferUpdates(LayoutPart.j ava:400)
at org.eclipse.ui.internal.PartSashContainer.handleDeferredEven ts(PartSashContainer.java:1409)
at org.eclipse.ui.internal.WorkbenchPage.handleDeferredEvents(W orkbenchPage.java:1416)
at org.eclipse.ui.internal.WorkbenchPage.deferUpdates(Workbench Page.java:1406)
at org.eclipse.ui.internal.WorkbenchPage.closeEditors(Workbench Page.java:1380)
at org.eclipse.ui.internal.WorkbenchPage.closeEditor(WorkbenchP age.java:1435)
at org.eclipse.ui.internal.EditorPane.doHide(EditorPane.java:61 )
at org.eclipse.ui.internal.PartStack.close(PartStack.java:543)
at org.eclipse.ui.internal.EditorStack.close(EditorStack.java:2 06)
at org.eclipse.ui.internal.PartStack$1.close(PartStack.java:122 )
at org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation$1.handleEvent(TabbedStackPresentation.java:83)
at org.eclipse.ui.internal.presentations.util.AbstractTabFolder .fireEvent(AbstractTabFolder.java:270)
at org.eclipse.ui.internal.presentations.util.AbstractTabFolder .fireEvent(AbstractTabFolder.java:279)
at org.eclipse.ui.internal.presentations.defaultpresentation.De faultTabFolder.access$1(DefaultTabFolder.java:1)
at org.eclipse.ui.internal.presentations.defaultpresentation.De faultTabFolder$1.closeButtonPressed(DefaultTabFolder.java:70 )
at org.eclipse.ui.internal.presentations.PaneFolder.notifyClose Listeners(PaneFolder.java:626)
at org.eclipse.ui.internal.presentations.PaneFolder$3.close(Pan eFolder.java:206)
at org.eclipse.swt.custom.CTabFolder.onMouse(CTabFolder.java:21 99)
at org.eclipse.swt.custom.CTabFolder$1.handleEvent(CTabFolder.j ava:327)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3880)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3473)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
!ENTRY org.eclipse.ui 4 0 2009-07-24 07:50:09.812
!STACK 0
FUDForum. Page generated in 0.06199 seconds
