Home » Archived » BIRT » Avoid page break inside table row in pdf?
Avoid page break inside table row in pdf? [message #233969] Thu, 12 April 2007 07:41 Go to next message
Hi all,
I have posted a similar question, but I'll ask again being more precise.
REMINDER: I'm talking about pdf output.
I have a table with multiple rows. When some row cannot be drawn at the end the page
it is drawn partly on the this page and the rest on the next page. This could be
desirable in some cases but not in all cases.
Bruno Lowagie explained in another post:
>> When using high-level objects, we're talking about PdfPTable.
>> As described on p178-179 of the book 'iText in Action', the
>> PdfPTable object has three options:
>> (1) split the table BETWEEN rows (what you desire)
>> (2) cut a row in two parts (what you experience)
>> (3) omit a row that doesn't fit (I don't ever use this, but
>> people asked for this and we implemented it).
>> (1) is the default option;
>> (2) can be set with setSplitLate(false);
>> (3) can be set with setSplitRows(false);
>> When using low level PDF functionality, it's up to the tool
>> (in this case Eclipse/BIRT) to decide if the content is written
>> on the current page, or if a new page is needed.
So is it possible to "split the table BETWEEN rows" and not "cut a row in two parts"
using BIRT? Or maybe it is a feature that isn't yet implemented?
Bojan
Re: Avoid page break inside table row in pdf? [message #234120 is a reply to message #233969] Thu, 12 April 2007 11:50 Go to previous messageGo to next message
Bojan,
What version of BIRT are you using. I am using M6 and I do not see this
problem.
Jason
Bojan Milenkoski wrote:
> Hi all,
> Bojan
Re: Avoid page break inside table row in pdf? [message #234327 is a reply to message #234120] Thu, 12 April 2007 18:17 Go to previous messageGo to next message
--------------050306060800020409000806
Content-Type: text/plain; charset=ISO-8859-1
I'm using BIRT 2.1.2.v20070205-1728.
Maybe this is fixed now.
I have attached an example. Look at the end of page 5 and 6(ignore the font problems).
Thanks for answering.
> Bojan,
> problem.
> Jason
>> Hi all,
>> the end the page
>> This could be
>> in two parts"
>> Thanks,
>> Bojan
Content-Type: application/pdf;
name="report.pdf"
Content-Disposition: inline;
filename="report.pdf"
JVBERi0xLjQKJeLjz9MKNiAwIG9iaiA8PC9GaWx0ZXIvRmxhdGVEZWNvZGUv TGVuZ3RoIDQz
Nz4+c3RyZWFtCnicrZRLS8NAEMeHES/rwbeCeJhjvWz3lU32JIhawQe2xldR C7W2vorUi2e/
uZNEbYSiVCVMdjO7+5/fTCYZiI1UWE+JimQSKO0IRSobqtuOtKG0Kyq0lt6L rVTUxUDERtqY
IicTQ32hZOwCvQirtAwf7sdcQlGjJo7G3p/FYKLC89wbLlW3NYUMh+mus9uL 0PmaJhO81OQs
pX1RgYUS7Zc4pfBaSZeMCj/2gd/wWq61HwLPlYHLgYbxI6ekGg087oEsyoA+ UTTnmxDvto6u
+1Q962rafKL6d4kZ0n50ZjqxUifk4yBdnGeH+zCBdbZ1tl22GtsG22ExwhTe 4S3PO9jER2zh
Jd7iPbaxDRfdUmHGRjEhkcqTj+KsEDlKD5t/UdReS2/IWyd9oQiLsAqznMRF Bc7hGBpwBCdw
AHvsOoBNqMEOnOaeBnuGT8X6Ge+eYIl5vpZ/BrPvn+OIVJ2XkSOvI2kKrnlY Ya4ltn+Qz9pV
xWX5mT/JaSeNLcstwPL/0RqWjwJF/E8IxWvf5c66wSbXehItz3vYynoxn13l 9wfuvjZMwnTu
73AH3uErtj4x3gBYbfDmCmVuZHN0cmVhbQplbmRvYmoKOCAwIG9iajw8L1R5 cGUvUGFnZS9D
b250ZW50cyA2IDAgUi9QYXJlbnQgNyAwIFIvUmVzb3VyY2VzPDwvWE9iamVj dDw8L1hmMSAy
IDAgUj4+L1Byb2NTZXQgWy9QREYgL1RleHQgL0ltYWdlQiAvSW1hZ2VDIC9J bWFnZUldL0Zv
bnQ8PC9GMSAxIDAgUi9GMyA0IDAgUi9GMiAzIDAgUi9GNCA1IDAgUj4+Pj4v TWVkaWFCb3hb
MCAwIDU5NS4yOCA4NDEuODldPj4KZW5kb2JqCjEwIDAgb2JqIDw8L0ZpbHRl ci9GbGF0ZURl
Y29kZS9MZW5ndGggMzA3Pj5zdHJlYW0KeJydks1PwkAQxcl4m6OJ9zniZdmv dnevRPCM9mAI
QlKQItJovfDvO1uD1FAIcJkm89H3e9lXYT9Dk5KXifCBsgVKkvHTG1pSmrIl duk+W+MgwxFW
6LQwjlxwwjoqUQpnA20xsVJIv+tv6p9IenrE5ysuog5T/Xa+i/2oN0zIRyQm nMeyRVXPFGlr
hNZsQwlHWYldGEAOH7CBcecGirqWUMGMewVPviDnzjusuC5gzHszeIUVrHmW H/hNrPC6AW9Y
JuzaLW7P3z/hVVE44jWkQpE1tc/OXYP2n05DXklhfZv8xQfX8BrOVroHvm0C N4UOwtEGfOlB
VKnoD0WxX0+8bSzNS+q9LBU9fNLolDFNKj3yElKL1FLqQgxxHbs+x2vKIZpM uEw5c2N4i4k7
mbMfupevSgplbmRzdHJlYW0KZW5kb2JqCjExIDAgb2JqPDwvVHlwZS9QYWdl L0NvbnRlbnRz
IDEwIDAgUi9QYXJlbnQgNyAwIFIvUmVzb3VyY2VzPDwvWE9iamVjdDw8L1hm MSAyIDAgUj4+
L1Byb2NTZXQgWy9QREYgL1RleHQgL0ltYWdlQiAvSW1hZ2VDIC9JbWFnZUld L0ZvbnQ8PC9G
MSAxIDAgUi9GNSA5IDAgUi9GMiAzIDAgUi9GNCA1IDAgUj4+Pj4vTWVkaWFC b3hbMCAwIDU5
NS4yOCA4NDEuODldPj4KZW5kb2JqCjEzIDAgb2JqIDw8L0ZpbHRlci9GbGF0 ZURlY29kZS9M
ZW5ndGggMzI4NT4+c3RyZWFtCnicpZ1Njxy3EYYXk9ucAktyEseHPtqAQPX3 B3IQYMjOWc4e
AseBElmRbMVColz898NusnZqqt4edxVteFeq6We7X5IPud3LHX88f3V/7sZq rocwL9X9m3Nd
1eunZ9/0VdNW92/PX1Rf3r8/f31/fnn+eJ7a0E3VtEyhn6oP5zpM/VL9ch76 OtQz1X/evkhd
ffvn818cxHqeeFWp8r93l5eefTNU83pJ8Qp/WD/8cm6215qq7bvQtjFGE6bq /sP5i9PXp9en
f59+Pn1395vTu+3jh9PH06tYexdf+e/pdaz8dPoxfnxz+i4e9+r099OPp/fx tdcq79CHuWUX
38XTLFQGaY8ffyNrUy07WZcxNFXfbTnvPmVXe3UedvqmDv2MTm8GPNfbxbE1 Xi74E37B/ERq
cKALtgLrWT5WD5fSxLxzFY/u+uqHD9Wzv75tqhf/qV6mzh62oTrHV8EXz/Xr 7jYTNxqwzcLp
FpymMMWPQxPqJo3uF9uYXcfwP+LIfRdH9Zv1b3eP7z6P/z66+yT/6XGs/Tb+ 91myIDI/xTH+
6vT99/Ev76MS2x8+Xo/5FKqb4ii7ZGrqbruIrYwa4fDx+RxTv714NSvkcrOE qVMnsQE3Grqr
mho39NytOkxtH5o8jfzp9J41zVUo5sswh7lDWc1AOksf6kWHpTpI60BcDdTU YxjHqxb66vT2
9CoOrzShroPrn3ESjTXuOc977Uk7oGYwA+ksS2h1G+QyaAIzsJ5l6JYwT5qi OsAciKt3ujEu
f/NV77w4/Sta/jetdzxnNwBfUx0JbiCY4imbMrbeJmKk+HHg5mK0q/i0Daw4 jvs2LUiPgeAy
K41HkNWBcMllXKqDvA7kRhONe+v16viwfrklDGnNfr79U6VPz4HXMjt5CrI7 EOa2jJ7LILkZ
4G5LiuoAcyCeTtnUbnSnPH/+tFLdkoWNpx6Br1sZCX74eKZ3iidtHec+tHgF Pw4U6D3Ocxjn
pPcToLdISmNSJzUDXG0ZNddRVgdSoPa4bOuEVBuILXKTpDq3GWBSy9CpjDKb AS61pHIdYQ6k
QGrVHTekHuO3qDOwNNeB1hbiInaOqDwdx/X+C4htAErEnuqwgDvf60xKVJTV gTC5VVyqg7wO
pETuKX5VtG4jwVX6LCxK70AukqvwuQyymwEmuaKoDjAHUiK57JZbksdTN+Bm OteR5AaCSZ4i
Kmf7eef+2wCUSD50ocmr9++A5DIrDUyQ1YFwyWVcqoO8DqRE8mEM7cJHkx5L 1xm1ryC7A2GK
y+i5DJKbAa64pKgOMAdSorjqlBuKx1N3aFVOdaS4gWCKp4jK2C6uowtU/DhQ ong3BHog/Hug
uMxKAxNkdSBccRmX6iCvAylRvJvD0MN1HFku45OyIL4DYZbL9LkMwpsBbrmk qA4wB1JiueyX
p+ruKQsbzzuiNTnVkeIGgime8iljmy60PVT8OFCieDM93IP/ASgus9KoBFkd CFdcxqU6yOtA
ShRv49dHq/iO4zI/CQvyOxDmuIyfyyC9GeCOS4rqAHMgJY6rjnm6t443Lb67 TnUkuYFgkqeA
0tlh6ddPSPLjwCXNsAzwNiLXQRoLUTCZDMsSljTp3n0GJhPZpjT8QZs6ED6Z yGbNddSuDoRl
Ui2bLxC1rAMpmbbi2Wq2At58wCCbmSYg0MwOhM1ZspVTGTWyGWB5VBPni0NN 7ED47CivL9fR
BTqQktlR9P/+7DiMfRjQRo1UR/OJgSjYSzHE+4/20F6KJw97KT7Neyme3D0y 76YY2iZ0YJbc
yqgZDh9/WSLWF0e9OWKI6KLb2gYU7KYY6nlNtL+bQmYlbXRWM8AmbhWW6iCt AynZTcFbyLCb
QjYDTSu6GczAZVpVbZDLoAnMAJvsFEV1gDmQkt0UvHf2dlOs5xzA3ohcR4Ib CKZ4yiaN7edx
fWCKFD8OFHx31i/xbmJ/N4XKSuMRZHUgXHIZN9dRXgdS8D1Tv3Trwwn4NAd8 26Tyk6sgvwNh
fsv4qYzSmwHut6RyHWEOpOCbGdUxNx7a9vMQZu1sKgPJjx9/UTzHU8aO8/rA FChuAEoUn9q1
8fd2VMikeUyCpGaA6a2iUh1kdSAlesdGX+ZDP4+RybOmILkZuGitYucySG0G mNaKojrAHEiJ
1qpDbmgdT12DtTjXkdgGgqmdIipTh3p9UIrUPg6UqD3E+9D9PRUqKw1LkNWB cL1lXKqDvA6k
RO94/e3DInF76VbhyVcQ3oEwx2X2XAbRzQB3XFJUB5gDKXH8qld+xfF46g48 p8x15LiBYI6n
iErZrl33LSHHjwMljndT6Pa3VKisNDBBVgfCHZdxqQ7yOpASx/vtV4vAU02s ucxPzoL8DoRp
LuPnMkhvBrjmkqI6wBxIieaiY25qHk89gB+u5DrS3EAwzVNEZW0z7NyIG4AS zZsljPvbKlRW
GpggqwPhmsu4VAd5HUiJ5m27NjwfTbd+fqHyk7MgvwNhmsv4uQzSmwGuuaSo DjAHUqK57ph9
zZs+zGhtTnWkuYFgmqeI0tpu/a1l+FNXA1Cied2EeX9rhcpKAxNkdSBccxk3 11FeB1Kiefyq
y3J095SKT8qC+A6EWS7TpzIKbwa45ZLKdYQ5kBLLZb/csHw9dQ2W5lwHlluI i+U5opJ2iosp
3CNpAAos7+b+4b4c7HlQWfPARFkdCLNcxaU6yOtACizvYku1Pd5ApS1X8bOy KL4DuViu0ucy
CG8GmOWKojrAHEiB5bpfblgeT43us3MdWW4gmOUpopI2XvEC13IDUGL5OIYu TYh3fwSWy6w0
MEFWB8Itl3GpDvI6kBLLxyX0lzVj75cVVW5yFeR2IExvGTuXQWozwPWWFNUB 5kBK9L7ukNt6
R2SYgKypjvQ2EEzvFFHZ2sdFFC/ix4ESvfs5jHnj4udAb5mVBibI6kC43jIu 1UFeB1Ki99Bc
3/jdXMNlejIWpHcgTHIZPpdBdjPAJZcU1QHmQEokl91yS/K+u35DJhqrqY4k NxBM8hRROduO
O/fjBsAn+bD+gKbr6u3d07b9L3ePgOYyLQ1NkNaBcM1lYKqDxA6kRPNu76kb 9FzGJ2lBfAfC
PJfpcxmENwPcc0lRHWAOpMTzDmzl1obHk9ZoUU51ZLiBYIancErYeg76LKbj S/xuutD05DfY
4aay0pAEWR0I91vmpboObCdK7G7G1bWjv8qk0pOrIL0DYXrL9Lmsw1uP53JL iOqashMlaotO
2bd73eOKVuNUR3YbCGb3Fk/K2i51WPQ+G9PxBXa3y/BwB/4YbW5TWWlEgqwO hNst8uYyCmwn
CuxulzkM+GE6kluGJ1NBeAfC5BbhUxVltx7P5RZQLiPKThTILfpk1+31tOh2 OteB2xbi4naO
p2SdugB/++T48SVuT1MYB3Ib7G5TWfOARFkdCHNb5aW6DmwnStye45cHAwmZ raJnTVF0B3Ix
W0XPZZ3cejwzW0FU15SdKDF7p0e02uumbPBrYrmO1DYQTO0tnjJ1GEIPl+3j x5eoHXv4YdUG
e9pUVBqQIKoD4WaLuFQGee1Eidnj9ebIX3FbhidRQXgHwtwW4XMVZLcez90W EJUBZSdK3OZ9
ooWOJ6vBb4zkOhLaQDChUyhlaDfhu+zjx5cI3beheVirwfY1lZWGIcjqQLjR Mi/VdWA7UWJ0
P4R2PPSevCo5uQmSOxCms0yeyzq49Xius4Sorik7UaKz6BBt9LrxGi24qY6M NhDM6C2WErSJ
a6TeKWM6vsTotg8Pj83ARjUVlQYiiOpAuNAiLpVBXjtRInQ7haHZey4OrJbx SVEQ34Ewq0X8
XAXprcdzqwVEZUDZiRKrRa9oq+P5BrTqpjqy2kAwq1MupWndru9egbQ+DpR4 vb5vwcNKDfam
qbQ0FkFaB8LFloGpDhI7kBK16yVMo9i1gqWW0clQEN2BMKll8lwGwc0A11pS VAeYAykR+7pP
gNjrzmq0+KY6EttAMLFTLulpM8cFE6/Xx4ECsZt5DktDYoPtaCotjUeQ1oFw sWXgXEeJHUiB
2M3S0v+H6cBdtUxPooL0DoS5LcOnMspuBrjbksp1hDmQArdltyi31/PVizY1 14HbFuLids6l
VB3HlQVuG4ASt6cmNCO5DfaiqbR5PKK0DoS5rQJTHSR2ICVuTz2/n9t9EwcV PDuKgjuQi9Yq
dy6D2GaAaa0oqgPMgZRofd0jQOt1A3UPJE11pLWBYFqnXMrSft75XtwAsDTx 1QFNOamO0hiI
kulj6EKfvzV4gva4qValcQ9a1YHw6UM2LNVByzoQnkm2LV0gaFsHUjJRDeP6 fojHH++rtqbp
B7S1A2EzlmzqXAYtbQZ4HtnOdHGgnR0Inxvl9VEdXKADKZkb1SDYeyPOppnE +yant9XMdTSt
GIiX5/8DTz1yKgplbmRzdHJlYW0KZW5kb2JqCjE0IDAgb2JqPDwvVHlwZS9Q YWdlL0NvbnRl
bnRzIDEzIDAgUi9QYXJlbnQgNyAwIFIvUmVzb3VyY2VzPDwvWE9iamVjdDw8 L1hmMSAyIDAg
Uj4+L1Byb2NTZXQgWy9QREYgL1RleHQgL0ltYWdlQiAvSW1hZ2VDIC9JbWFn ZUldL0ZvbnQ8
PC9GMSAxIDAgUi9GMyA0IDAgUi9GNSA5IDAgUi9GNiAxMiAwIFIvRjIgMyAw IFIvRjQgNSAw
IFI+Pj4+L01lZGlhQm94WzAgMCA1OTUuMjggODQxLjg5XT4+CmVuZG9iagox NSAwIG9iaiA8
PC9GaWx0ZXIvRmxhdGVEZWNvZGUvTGVuZ3RoIDMyODU+PnN0cmVhbQp4nKWd za8cxRXFrclu
VhE4YAiLXhIJlfv7Q1lYQkDWJF5EhMiJcWxwsIjZ8O+naqqu5869p8d9b2Hx 3vOZPq/63Kpf
1fRUz/jt+cun52Fu1nYK69Y8fXFumzZ9e/zN2HR98/Tl+fPmT09fn79+ev72 /Pa89GFYmmVb
wrg0b85tWMat+e08jW1oV9J/vvyStvnrX85/czhSO/GssvLrq+tDj7+ZmjWd UjzDH9KX387d
5bGu6cch9H2M0YWlefrm/Pnp69Pz039PP5++e/C706vL1zent6dnUXsVH/nf 6XlUfjr9GL++
OH0Xj3t2+ufpx9Pr+NhzlXcaw9qzkx9iMxvJIO3x4+9k7ZptJ+s2h64Zh0vO Bx+zs71phzXf
tWFcUfNmg+d8hzi25usJf8BPmDekBgc6YashtfK2eXcqXcy7NvHoYWx+eNM8 /vvLrvnql+bb
3NnTZaiu8VHwy4t+291mx50C9gU4XcFlCUv8OnWh7fLo/uoyZtMY/lccua/i qH6R/vbg4YPP
4p+PH3xQfnoUtd/H/x9lCqLnpzjGn52+/z7+5XVE4vLD29sxn0MNSxxl10xd O1xO4iKjIhw+
vrSxjJcHb2aFIndbWAbViM1wp9BD07W40OuQcFj6MXRlGvnz6TUrzU0oxsu0 hnVAWc2G3MoY
2k2HJR2kdVhcBeraOczzTYW+PL08PYvDK0+oaXD9O06iUeOc87y3nPQTKoPZ kFvZQq9rUGRQ
ArMhtTINW1gX7SId2BwWV+8Mc1z+1pve+er0n0j5PzTesc1hArxmHQFucDDE czZFbHuZiBHi
xw13F6NdxJfLwIrjeOzzgvQQAC6z0ngEWR0WDrmMSzrI67DcKdG8t14nxqf0 67Yw5TX7yeW/
Jn8DWMvohCmI7rAwtGXyIoPgZgNHW7pIBzaHxdMnF7I73SdPnnyhu6XwGpue Aa4XGfF9+HhG
d44nYZ3XMfR4AT9uqKB7Xtcwr5nuPwC6RVIakzqp2cDJllGLjrI6LBVkz9tl mVBkQ7ZFdOJU
RzcbGNcyd5ZRbLOBcy1dRUc2h6WCa9Ujd7ie45PUFYBadEC2xXFlu0RUqM5z ugIDbBsMNWwv
bdjKpeRHmm2VtQxLlNVhYXyruKSDvA5LDd9L/K3XVaLZhVslL7Ci5A7LFXAV vMggt9nAAFcu
0oHNYakB/LZL7gMem+7ApXTREeAGBwM8R1S8juvO1bfBUAP4NIRu1S9u3WbS tIKsDgsHXMYl
HeR1WGoAn+bQbzej6bqG78Iuq0Dkgio4LAx2WYQigxqYDRx26SId2ByWGth1 9+zDHpse0Nqc
dQS7wcFgzxEVu0Ps0BHCftzA0sRHZzQRZR2lMThqJpVhCvQC9CMwqciaEgCg pg4Ln1RkWUkH
dXVYeCZZWTpBUFmHpWb6GtYwjTd8NO+Zu2SxaSICxXZY2Nwla11kUGqzgeeR haaTA4V2WPgs
Kc+PdHCCDkvNLClGgZ4a2za0YFul6GgyMTgqNmKmeAmyHNqI+eTdRsyn7o2Y Ka4my6ZnyKKD
Mlgc1xVimpb0qrGc8FPnj7raNkPFZsw0Dmnw7W/GqLQFGJTWYWFztwpMOkjs sNRsyPAqGTZk
VCHKpIIK4bBc51VVhyKDMpgNbLZTLtKBzWGp2ZThPbS3KZPabMEWS9ER6gYH Qz1nU+T2XZjl
7RtWQ8WTtKmPlxX7mzIqK41IkNVh4aDLuKSDvA5LxVOnqd/SfS5l0WzuPmlS 4YlUEN5hYXDL
7EUG0c0GDrd0kQ5sDkvFU5nbXrl/wZeaHgCwFxkRfvh4xneOp3CN1g0v5ccN NXy3a0q0ty0j
k9KY1EnNBs62jEo6yOqw1LDddenViXejqLnHtohOnOroZgPjWuYuMohtNnCu pYt0YHNYargW
PXKX69j0hFbirCOyDQ7Gdo4oUR3XOb1qitg+bqhge9ziZWi/uy2jstKwBFkd Fs63jFt0lNdh
qeB73IZ0XY1f9gCIy/yELMjvsDDMZfwso/RmA8dcuoqObA5LBeagY3YxH9cp rJrZLAPIjx9/
RbzEU8TOa3oNEyBuMNQgvvR0BYM2ZmTSMiZBUrOB4a2ikg6yOiw1eMeib2D5 1mTL4IVSENxs
uFKtUhcZhDYbGNXKRTqwOSw1VIv+ePLFHtKxXXQNXXQEtcHBsM75FKXjlm5o QFgfN7A0U4uu
F7KMshw+vmbqmKbQ7W+/qHrSuAf1dFj49CFLSjqoqcPCM4m60vnpupoNNZNU /KX9znMQMFHJ
ItPEA4rssLDJSta4yKDEZgPPI0pM56ZLbDbwKVGeG+ng5ByWmilR9v7ulJhu Z5WbTe1KOppG
DI6KrZchXmaMcuflZfzp15t9lw/f7bs8LPsuH8WfrTsvwzKHEeyjFB1UweK4 Lgzp0Zt7qooc
hzS438dmqNh5GeZ41TDf2XlRaQs1KK3DwqZtFZh0kNhhqdl54VUy7LyoQpSp BRXCYblOraoO
RQZlMBvYpKdcpAObw1Kz88J7aG/nJZU4EqTBzTpC3eBgqOdsityxS78ToX7c UPH8bBjjlUS3
u/OistKIBFkdFg66jEs6yOuwVDxzGsY1vRZx6NVZFZ5IBeEdFga3zF5kEN1s 4HBLF+nA5rBU
PKORvXLvpZshVnRDi3PWEeMGB2M8R1TI9kN6hRQxftxQw3gfn4HPu7svKisN TJDVYeGMy7ik
g7wOSw3jQ0dvnHzfpZHKTryC7A4LQ1xGLzJIbjZwxKWLdGBzWGoQF51yF/HY dI8W5awjxA0O
hniOqIhNn6KBl/HjhhrEu8sHDuxtwqisNDBBVoeFIy7jkg7yOiw1iHcDvfFX LOMIcpmeiAXp
HRYGuQxfZJDdbOCQSxfpwOaw1EAuuuUu5LFp8OJrlhHih49ngOd4ktd+XdMd Sgjw44YKwPut
D9P+FoxMSmNSJzUbONwyatFRVoelAu5+m9JtAYfWb5GcMNXJzQaGtYydZZTa bOBYS1fRkc1h
qcBadsg9rPs4xBfAadEB2BbHFe0SUZG6tDuX4AZDDdrL5cOL9rZIVNYyLFFW h4XhreKSDvI6
LDV4Lwu99ff9a7dKX4BF6R2WK+QqfJFBdrOBQa5cpAObw1IDueiWu5AvLeA1 igjvQ8cysHMs
xenUhxnurxoMNWBPS2jLmv0JAPsmJY1EmdJ0MIdZRiQdZHRYamCeW3qbr9yI hDjfJCcwZXLT
wQxhGbnIILHZwBGWLtKBzWGpQVh1xh2EY9M9WnWzjkA2OBjOOaKic4jrJLzR 0WCowTl2AF1j
fwpwlllpSIKsDgtHW8YlHeR1WGrQHnt6s60iG7ItC0DEggI4LIxzmb/IIL7Z wDmXLtKBzWGp
4Vz2zD3OY9MI2ouMKD98PGM8x1PIdku6XQgxftxQw3jfhal8BMUfAeMiKY1J ndRs4HzLqKSD
rA5LDd/9SB+vJfgGbIvoxKmObjYwrmXuIoPYZgPnWrpIBzaHpYZr2SP3uO7m sIDPjyg6Itvg
YGzniBLVbovrJ16/jxtq2I7nvpZbET8DbMusNCxBVoeF8y3jFh3ldVhq+I7f tr03KkDIZQUI
WlABh4WBLguQZZTfbOCgS1fRkc1hqQFddM0XqFcytanlFnyyStEB5xbHlfOS UGG7djuX3QaD
j/Mp3WnarXO6/zDf0vLgQ026SltGJkrrsDDSVWDSQWKHpYL0bt1CtxlIVxUo 2KIKOCxX0lUB
igzymw2MdOUiHdgclgrSVdeUBV1zHtvtwepcdMS5wcE4z/kUtvOQ/uUIxPlx Qw3n8xqGgTgH
N6+ptDQuQVqHhXMuA5MOEjssNZwvXRhH8IwdEC6zE64gu8PCCJfRiwySmw2c cOkiHdgclhrC
ZafsEp5uYEXrctYR4QYHIzznU8COc+jgZ8QZDDWET+27q/GH6NY1lZbGJUjr sHDCZWDSQWKH
pYbwaQjzBl9zA4zL9AQsSO+wMMZl+CKD7GYDZ1y6SAc2h6WGcdktu4yPE7zG Ljpi3OBgjOd8
Ctk+rqJ4FT9uqGF86MM6EuPg3jWVlsYlSOuwcMZlYNJBYoelhvFhCtvt5ya+ h3NZAYIWVMBh
YZzLAhQZ5DcbOOfSRTqwOSw1nMuu2XtnXWq37QG1WUecGxyM85xPYdu1YcZr +XFDDefdlMAo
nINb2FRaGpcgrcPCOZeBSQeJHZYazrt1/6ocUC7zE7Igv8PCKJfxiwzSmw2c cukiHdgclhrK
ZcfsUh7b7RfAbNYR5QYHozznk9Bu/d4T9sPHX7OkW07B9JNlkOT48RXzyLak f8GvTCPgdjlV
Thr4oJwOC59GZEmLDmpqd7BEsqzl7EBZzYaaqaptwzgde1ecKjBNOqDADgub p2SBswzqaz2e
pZHlLWcGyms28LlQnlrRwbnZHTUzoeh3NRP+H4xPC4QKZW5kc3RyZWFtCmVu ZG9iagoxNiAw
IG9iajw8L1R5cGUvUGFnZS9Db250ZW50cyAxNSAwIFIvUGFyZW50IDcgMCBS L1Jlc291cmNl
czw8L1hPYmplY3Q8PC9YZjEgMiAwIFI+Pi9Qcm9jU2V0IFsvUERGIC9UZXh0 IC9JbWFnZUIg
L0ltYWdlQyAvSW1hZ2VJXS9Gb250PDwvRjEgMSAwIFIvRjMgNCAwIFIvRjUg OSAwIFIvRjYg
MTIgMCBSL0YyIDMgMCBSL0Y0IDUgMCBSPj4+Pi9NZWRpYUJveFswIDAgNTk1 LjI4IDg0MS44
OV0+PgplbmRvYmoKMTcgMCBvYmogPDwvRmlsdGVyL0ZsYXRlRGVjb2RlL0xl bmd0aCAzNzM2
Pj5zdHJlYW0KeJylnU2P3MYRhoXJbU6BYynOx4FHBxBabH4TOQgwbOfsRIfA cSBEViRHsRDL
F//9NKe7dmqqXo5Y1Qpiy+/yFedh98Ne7rZ2Ppy/eHHup2Zpx7CszYvX57Zp t389+3poYte8
eHP+vPnTi3fnr16cvzl/OM9d6OdmXucwzM37cxvmYW1+OY9DG9qF8h8vf0jb /PUv5785Gtt5
0qvKyc9vrx969vXYLNtLSq/w++0fv5zj5WOx6YY+dF3CiGFuXrw/f3766vTq 9N/Tj6dvH/3q
9Pbyz/enD6eXKXubPvLT6VVK/nP6If3z9enbdNzL0z9PP5zepY+9UrzjEJaO vfg+nWalGNAe
P/4Oa2zWHdZ1CrEZ+gvno8/Yq705Dzt9bMOwoNObC57X26e5NV1f8Cf8BfMT qcmBXrC1sJ3l
Q/PwUmLiXZp0dD80379vnv39TWy+/F/zTR7s8TJVl/RR/ofHtg9zpPx2uM2N cp55uHyUG1HS
qQv6JJbD7wxR38QWj9HSb/NgnpKNWZ8/n96xcboFYhNlXMLSQ1BHJZ9pCO2q aCnWuOaC6/rE
dgrTxC/QF6c3p5fp7pHvI+/S/eNf6d6RMj69b1hvp2s3wmvgqOQzrYlTXoSS 6mtgPHw7w9iv
YZlVh2JdMhdcA9NP6Y6/8IH58vTvdKv/B7+JZ0vTkenKaktzjrw2NJjXFzIl 6jCEYYRiHz7+
7s131+wxtGneDEtY8/3300e/A2ZLVJqHANVR4WYLXIoBr71x5wpNe8vTpvaY /rixu1yf5+lX
85x+AZklNpkJsB0VJrPALimgth7PdRYlikHL3vCMxsXneDMaz58/VYNRBE0n Tcu+FjTnSGlD
gymd4ZSj3RTkZ7vG42uU7mOIIzn9e+C0ZKXpCFgdFe605KVcA9sbNU73Q+gm NpHuii3ZyVLA
7qgwsSV7iTW69XgutixRrlv2Ro3Yckh23U6n7dHim3PktqHB3L7gKVXbtF5O 0O3Dx9e4Hfvy
6UxS+w9AbYlKExKgOipcbYFLMeC1N2rUjulfkc0jZjdwW8KTqADeUWFuC/iS Anbr8dxtUaIY
tOyNGrflmOy6nc47olU458htQ4O5nfmkrNMaQxeh3McLFXZP6ximh5X7j0Bv SUtzEtA6Klxv
CVxyROyoVAg+rUuYD6/dkp5kBfSOCvNbwucYsZsL3HDZKjmqOSoVjqth2XN8 Wlv48Fxy4Lil
cXW88Cll57SCwgXcUKhxfJ7Dmu+Fjx4/+o12XNGWeYloHRXmuAKmHBA7KjWO LzG0O4s4sFzx
F2URv6NytVzhlxjQmwvMctWiHNQclRrL5cDsWp7Om+aFdjbnyHJDg1me+ZS0 47h1keXHCzWW
T22IE1n+KbBc0tK8BLSOCrdcAlMOiB2VGsun/vaR72OaywtAzoIL4KgwzSV/ iQG+ucA1ly3K
Qc1RqdEcjMyu6enU/QC8zTky3dBgpmdEJW4/7zyQGwo1pg9dGB7W88fAdElL UxPQOircdAlM
OSB2VGpMH8Zw84Xbe5+zK3pyFtA7KkxzCV9iwG4ucM1li3JQc1RqNJfDck/z dOoRLc85R5ob
GkzzjKis7dptHwfS/HihRvNu2L7PWzR/AjSXtDQ1Aa2jwjWXwJQDYkelRvNu DvN8nU93LZfw
pCyAd1SY5ZK9xADdXOCWyxbloOao1FguRuWu5TG9ArQ05xxZbmgwyzOikrbt 9D4xa6HG8jSP
rw/nvwWWS1qamoDWUeGWS2DKAbGjUmN5bEN7u2rcFV3yk7WA31Fhokv8EgN6 c4GLLluUg5qj
UiO6Hph90dOp4dN2zpHohgYTPSNKb8dlCDNezo8XKkQflzXEmUT/DIguaWlq AlpHhYsugUuO
iB2VCtHHtQvdDEQHkkt2MhawOypMcomeY0RuLnDJZavkqOaoVEguB2VP8O20 /ah1LTkQ3NK4
Cl7wlK/TtG0cBYIbCjWCzzEMHQkONrYp2jItEa2jwgRXwJQDYkelRvB5uHn+ a/bWcEVeXEXk
jspVbwVeYsBtLjC9VYtyUHNUavQWQ4LdTuecgKiXGJl9+HjmdeZSmg7rznO4 oVDj9diH6WHh
BpvbJCtNR81qLnCnJSzlgNZRqXF6nLZ9z7c7VoHRgprs1NTmArNZIpcYEJsL 3GbZohzUHJUa
m28HY8fmIV1gtO7mHPlsaDCjM5sStI/b35xBRh8v1Bjdj2F9WKnBnjZFSzMS 0Doq3GoJTDkg
dlRqrE7Ts+2PrNSSnDwF5I4Kc1uClxhwmwvcbdmiHNQclRq3xZBgt7e92EDU S4zMPnw88zpz
KU1jqur9NLZCjddxYY/YYDObZKXpqFnNBe60hKUc0DoqNU53MXQ3i8P+PlWJ TopqdHOBKS25
SwywzQWutGxRDmqOSo3SYkR2n63TaeGTcs6R14YGMzvjSVGHddz+sioy+3ih xuy2DfSXdp+g
LWyKliYloHVUuN0SuOSI2FGpsTtxjXrFRm5LdHIVoDsqzG9JnmMEbi5wv2Wr 5KjmqNT4LcZk
z+/ttBNYhksO/LY0rn4XPKXrvIQOrtyGQoXfw9KFaSG/weY1RVumJaJ1VJjf CphyQOyoVPg9
pGvFH+2u3wIDiiv64iuid1Suiiv4EgN2c4EprlqUg5qjUqG4HJZdxec5LOBr YiVHihsaTPGM
p4yd2p2HbkOhRvFpCOvDEg52rSlampaA1lHhiktgygGxo1Kj+LSEdoCKI8cl PgkL8B0V5rik
LzGANxe447JFOag5KjWO74yLlnzbhY1W5ZwjyQ0NJnnmU84O3fYvJPnxQo3k wxziwzoO9qwp
WpqXgNZR4ZJLYMoBsaNSI/mYlFvh1lQkucQnYwG+o8Ikl/QlBvDmApdctigH NUelRnIxLvuS
p/P2aF3OOZLc0GCSZz7lbJdWUr1hxlaokbxb2cM42LKmaGleAlpHhUsugSkH xI5KjeR9F8YB
fakNWy75SVnA76gwyyV+iQG9ucAtly3KQc1RqbFcDMy+5dv+a7Qw5xxZbmgw yzOfkradQ4eX
8uOFGstjDNNKloP9aoqW5iWgdVS45RKYckDsqNRYHocwgyUDGS7ZSVfA7qgw wyV6iQG5ucAN
ly3KQc1RqTFcDIo2Ow3eMgNPc47MNjSY2ZlLitovaf3E6/fxQoXZ/dqHdSCz wUY1RUvzEdA6
KtxsCVxyROyoVJjdrzN/4vvIg7ikJ1EBvaPC3JbwOUbs5gJ3W7ZKjmqOSoXb YljSr7CzfG8n
juAnoZYcSG5pXCUvgMrZOe48iRsKNZLPU4gPyzfYtaZoy8REtI4Kk1wBUw6I HZUayec19Ecf
xBV9MRbROypXyRV8iQG7ucAkVy3KQc1RqZFcDMu+4+m8PViWS44cNzSY45lP KTtiwQ8eXWN3
ml/DwxIOdrApTpqRgNNR4XZLWsolrvX4Gq/TPBrHI98JV9BkKIB2VJjUErvE ktp2NNdZViiX
HevxNSKLcXgK7q7Fy22TNVp7c45MNjSYySMQsx8D/HHIBw9mFOmD6DGh5IjC 0Ki5X6Qpen2Y
Bzvj1NWkyQ6upqPC7xcjkl9fVePhnEVeU3ph4Jo6KjX3paEPcqM8vCvJS0u3 GHBpHRV2VxrB
TUZfXNPBnENeVnpR4LI6KvzuN6JbmX5xxsNr7n16rJ/u3PvacdsDeIvcLpSj u4ahcQehK2+r
ohnmeUPo0tnWmX6U/fbOJNs7DLxJv/v59Hr7/fYjI9P/Hj/6pPzuScp+nf7/ OP335b1OUie/
I8F336X/eHd6n3/z4fadTS5Q3dSFFnyPpOTgMlga1yVg++igtzt0w7BtQQLL gKFw52J/7A0v
uiE9E/R33vFC0RZjEK2jwm7RCphyQOyouC5SedcLfpUMb3uhLkS5q6AL4ahc b6jqOpQYXAZz
gd3uVItyUHNUXCNU3v6Cj9De+19s5+zBN0pKjlQ3NJjqmU2Z203bViSk+vGC 77Ox+TK1+vSk
UHZJgL2OipVmJGB1VLjoEpdywOuoVHym1PXD9pWGj3+qpMhJU0DuqDCzJXiJ Abe5wM2WLcpB
zVGp+IRGDMnlExr9l8KKrunUI1qZc44ENzSY4BlR+dqu2xc/keDHCzWCx/RJ d9khAXY6Klaa
mIDVUeGCS1zKAa+jUiN4nLYLf+zn8yl6MhbQOypMcglfYsBuLnDJZYtyUHNU aiSXw3JP8jZd
abQm5xxJbmgwyTOidDaucfsaKJL8eKFC8rimJ1La6wgkl6w0MQGro8Ill7gl R7yOSoXkcV22
b/gDyYHjEp6EBfCOCnNcsucYoZsL3HHZKjmqOSoVjqtRueP4dmr0iF1y4Lil cXW8ICpl5377
uiVw3FCocXxeQizfZwEbHRVrmZiI1VFhjitcygGvo1Lj+BK3b/wfclzBF2ER vKNydVyxlxig
mwvMcdWiHNQclRrH5ajcczydGr1nbMmR44YGczwjKmXHcduOhBw/XqhxfGpD v+p3ML5l0sIC
VkeFOy5xKQe8jkqN41OPnsah4pKdfAXsjgpTXKKXGJCbC1xx2aIc1ByVGsVv B+W+4unUI/g2
Y8mR4oYGUzwjKmP7Zed53FCoUXzowlSWcbDfUbHSxASsjgpXXOJSDngdlRrF h3ThwZYJLLmk
J2MBvaPCJJfwJQbs5gKXXLYoBzVHpUZyMSx3Je/n27eip7macyS5ocEkz4jK 2a7deVtpQ6FG
8m4IS1nHwX5HxUoTE7A6KlxyiUs54HVUaiTv5I8PAG5LaBIVQDsqzG3JXGKA bC5wt2WLclBz
VGrcvv1RTHfETudt0VqccyS2ocHEznzK07bD7y19/Pgardv54REcbHRUpDQn AamjwrWWtJRr
XHujRup4ke3AZkcFTp4CcEeFqS3BS6y5rcdzsWWJct2yN2q0FuNx1+x0Zvgg nXNktqHBzL4Q
SlGXBfzwXsPRXEP5smj+gJflqHANxYsrsX511uMrFFy7cPhTZ0lNQgFqR4U5 KLhzqrFtR3P/
RKXEumM9vsK924FA5v0f1tljrwplbmRzdHJlYW0KZW5kb2JqCjE4IDAgb2Jq PDwvVHlwZS9Q
YWdlL0NvbnRlbnRzIDE3IDAgUi9QYXJlbnQgNyAwIFIvUmVzb3VyY2VzPDwv WE9iamVjdDw8
L1hmMSAyIDAgUj4+L1Byb2NTZXQgWy9QREYgL1RleHQgL0ltYWdlQiAvSW1h Z2VDIC9JbWFn
ZUldL0ZvbnQ8PC9GMSAxIDAgUi9GMyA0IDAgUi9GNSA5IDAgUi9GNiAxMiAw IFIvRjIgMyAw
IFIvRjQgNSAwIFI+Pj4+L01lZGlhQm94WzAgMCA1OTUuMjggODQxLjg5XT4+ CmVuZG9iagox
OSAwIG9iaiA8PC9GaWx0ZXIvRmxhdGVEZWNvZGUvTGVuZ3RoIDM0NjQ+PnN0 cmVhbQp4nKWd
TY8ctxGGhcltToFjx5KTQx8dwKD6+wM5LGDYzlnJHgLHgRBZkR3FQixf/PdD Dlk7tVVvj7qK
MiDJtf2o+ZJ8yOmd7tn35y/vz8PcrO0U1q25f31umzb98fybsen65v7N+fPm T/dvz1/fn1+c
35+XPgxLs2xLGJfm3bkNy7g1v56nsQ3tSvWfLv9I2/z1L+e/OYh0ntiqXPnl h+uXnn8zNWtq
Umzh9+m3X8/d5Wtd049D6PsYowtLc//u/Pnp69Or039PP52+ffKb0w+X39+d 3p9extoP8Ss/
n17Fyn9OP8bfX5++jce9PP3z9OPpbfzaK5V3GsPas8YP8TQblUHa48ffyNo1 207WbQ5dMw6X
nE+esdY+Og87fdeGcUWnNwOe9g5xbs3XBn/EG8xPpCYHarAVSGd53zw0pYt5 1yYePYzN9++a
539/0zVf/a95kQd7ukzVNX6V/+NdO4Slo/rj4TYT5TzLePkqN6JU5z7ok1gO vzFEQ9O1eIzW
Ic2DZY42Zn3+fHrLxulxIDZRpjWsAwzqQPKZxtBuKi2VdVwz4Oqfrp3DPPMO +vL05vQyrh55
HXkb149/xbUj1vj0fpT18XTtJ9gHDiSfaYs5ZSeUqu4D4+HpDNOwhXVRDJU1 ZAZcAzPMccVf
+cB8dfp3XOr/wRfxbGk8MvastjTXkdcGgnl9SaZEHccwTlDsw8ffXHx3zV4u 82lcw5bX3z8C
r2VQmoUgqAPhXouwVAZp7QRXTjaP/AHNcyBMOdG8UgWtsx7PpRMQlQFlJ5gh 8atxF9XzPdeR
IQaCGZJboaZ8Pwf54tF4vM+QKbRxmIcudFNW5OMnvwOSyKw0b0BWB8IlkXmp rgPbiRtdNO+9
gku73xT/tWEM/XzporvLr+bu+gtsezI9CQXSOxDmoExfyjq89XjuoISorik7 4RmUy87X6UG5
u/uiUUNSdI1nHtCGlutIcAPBBL8kVL62cQ+aoeCHj68RvBvKS4To98fAbxmV 5iSI6kC43yIu
lUFeO1Hjdxf/6KDfwG6ZnVQF2R0Is1tkL1UQ3Xo8t1tAVAaUnaixWw7JLbvj qSe0Gec6sttA
MLtzRKnrvHWh76Dex4EKv+dtCvPDBv4JEFympWkJ0joQLrgMXOoosQOpUHze 1rA83i34Jo48
l11A0oIucCDMc9kDuYw6wAxw0yVV6ghzIBWuy7Fp9JhkbeethdelpQ5EtxBX 0Us+5e0SN1K4
jxuAGtGXJWwdif57LbpKW+YlSutAmOgqMNVBYgdSI/rahfbRxtHcslzlL8qi /A7karmKX8og
vRlgliuK6gBzIDWWi4HZtzyeN84L7WyuI8sNBLM851PSTlNikeXHgRrL5zZ0 M1n+KbBcpqV5
CdI6EG65DEx1kNiB1Fg+D/Li7wMX5aoLyFrQBQ6EiS57oJRBB5gBLrqkqA4w B1IjuhibfdHj
eYcRaJvrSHQDwUTP+ZS3w7JzWW4AakQf+zA+bOdPgegyLc1LkNaBcNFlYKqD xA6kRvRxClOv
JxN2XKYnYUF6B8Icl+FLGWQ3A9xxSVEdYA6kxvGdYdGOx/NOaGvOdeS4gWCO 53xK2b5Nt0cg
x48DNY73Y3r7tDj+DDgu09K8BGkdCHdcBqY6SOxAahzvl7AsRx2X6UlYkN6B MMdl+FIG2c0A
d1xSVAeYA6lxfGdYtONdPD3alXMdOW4gmOM5n1K27fXNV1agxvE4i6+X5Z8B x2VampcgrQPh
jsvAVAeJHUiN410b2sP7uExPwoL0DoQ5LsOXMshuBrjjkqI6wBxIjeM7w6Id j+eFl9i5jhw3
EMzxnE8qO61jWPA+fhyocHxat9At5PgfgOMyLc1LkNaBcMdl4FJHiR1IhePT 1od+2fnWG/Rc
9gBJC3rAgTDPZQfkMspvBrjnkip1hDmQCs/l0Ox6ns47TNraUgeeW4ir5yWf 0nae0/2YwHMD
UOP50oWxJ8/BHWMqbZmXKK0DYZ6rwFQHiR1IjefL+Oji76q5VlyFL76i8A7k qrjKXsoguhlg
iiuK6gBzIDWKy1G5+2LP8XjiGQh7KSPDDx/P/M7hlK7jtnM9bgBq/J6GMJd9 /BN0s5vMSnNS
ZzUD3G0ZluogrQOpcXua023F6HU6sluEJ1N1eDPAzJbJSxkENwPcbElRHWAO pMZsMSY3zB5j
L6O9ONeR2waC2Z0DKlmH+P/6fXgbwNKkO1NB0y5llOXw8TUryDCFracVBNxO p3qUpj7oUQfC
VxHZqVQHvepAeCbRs9Q+3bNmoGatira1w8HXIbKLaeUBXexA2Gole7iUQQeb AZ5HdDC1TXew
GeBromwb1UHjHEjNmijHfn9NbNt0J+Hj5OmZuVxH64iBuBGhL8+R6gzLkiKM 8Vqjp0d30pOY
6YmqN/Fvv5xep7+nC5D436dPPip/exprv73Un+ZnOyOTn8D67rv4P29P7/Jf 3j9+kvOSaZyW
0IM7Hksd9IKFuO4M6auzfltljMO1wZsqDMCNvv7QA37jGK8d5htP+Km0RRuU 1oGwVVsFpjpI
7EBcnVSe8uO9ZHjMT3VEWVtQRziQ69qq+qGUQTeYAbbqKYrqAHMgrhEqj/vx Edp73i+dcwJv
rpQ6Ut1AMNVzNmVu36f7l5DqxwHfC7TLE39jP6enrvO3cIDoMivNSJDVgXDR ZVyqg7wOpOKF
09hvKRe4yANyy/BkKgjvQJjcMnspg+hmgMstKaoDzIFUvKSRo3J345GHsY8I eHOl1JHjBoI5
niMqZeO0HPF2fhyocbyNE63cVgEeeFBZaWKCrA6EOy7jUh3kdSA1jneXT7hA b8YAyWV6Mhak
dyBMchm+lEF2M8AllxTVAeZAaiRXw3JD8jQx0Lac60hyA8EkzxGls8M6p++V IsmPAxWSD1u8
NC0bOXjYQWWliQmyOhAuuYxb6iivA6mQfNjGdLF96DsgKjwJC8I7EOa4zJ7L KLoZ4I5LqtQR
5kAqHFejcsPxdOoebMulDhy3EFfHS0Sl7Lym72YCxw1AjePLQNcz6FEHlbVM TJTVgTDHVVyq
g7wOpMbxZU53CMBHHbTlKn5RFsV3IFfLVfpSBuHNALNcUVQHmAOpsVyPy77l 8dToArvUkeUG
glmeIypppy7dvYQsPw7UWD5NYS7vmYDnHFRWmpggqwPhlsu4VAd5HUiN5bH9 C7o/Eigus5Ov
ILsDYYrL6KUMkpsBrrikqA4wB1KjuBiUm4pPbQDfLc9lJPjh45neOZ6ydRjS TUtI7+NAjd7D
kjpffSrjo0haVZ3UDHC1ZVSqg6wOpEbt6Nqm7r0DXovY5KiObQaY0zJzKYPI ZoA7LSmqA8yB
1DgtRuOm0/HULbg5otSR1QaCeZ0jKk27aecC3ADUeN23oSvbNnisQWWlaQmy OhDutoxLdZDX
gdS43Q+hP3gLggpPvoLwDoQ5LrOXMohuBrjjkqI6wBxIjeNyVG45Hk8NPiAk l5Hhh49nfud4
Utd+W8IGb5cyADV+t5cPbb74DR5pkElpTuqkZoC7LaOWOsrqQGrcbqf0kcuH XpKL5KSpTm4G
mNYydi6j1GaAay2pUkeYA6nRWgzILa3TqSewEZc6ENtCXNUuEZWpa9w69et+ G1Chdr+OYR52
P/dWZS3TEmV1IExvFZfqIK8DqdC7jz21DFpvbbeKXmxF0R3I1XCVvJRBcDPA DFcU1QHmQCoM
l2OitV42dNWcy0jqw8czpXMmZejchxHu1gag4sbjfp7Dut74nF6ZlaaizmoG uNAyLNVBWgdS
I/S8pZ9xQJNn7zJbpiYzdWozwEyWkUsZJDYD3GRJUR1gDqTG5MeDAUyO52vB U0Wljlw2EMzm
nEvJOcYNEm/Qx4Eam8ctdMONT+VVaWk2grQOhBstA1MdJHYgNUZPPb66BlbL 7GQpyO5AmNky
eimD5GaAmy0pqgPMgdSYLQZFm53uUQXP4ZQ6MttAMLNzLiVqP+9cVRuAGrOH LgwP+zS4O02l
pfkI0joQbrYMTHWQ2IHUmD2MYdx2PlEf6S07gFwFHeBAmN4yfymD+GaA6y0p qgPMgdToLUZG
6x3PN6FtONeR3gaC6Z1zKVvbuHHqG2NsQI3e3fBwZQ0/hFelpfkI0joQrrcM THWQ2IHU6N3N
qeuV3kBsGZ0sBdEdCBNbJi9lENwMcLElRXWAOZAascWYaLHTTdVoF851JLaB YGLnXNLTbuvC
qO+FsQEVYnfbxK6vwc1oKi3NR5DWgXCxZeBSR4kdSIXY3baGbRPX2Dtmy+yk KcjuQJjZMnou
o+RmgJstqVJHmAOpMFsMyt3+s7DpxOgSutSB4hbiqngJqIxd+rBBxQ0AS5Nu HgU/frLUURoD
UbOULGvoHn7kDrjjTfVqEQD1qgNhS4nqWKqDnnUgPJPsW2og6FsHUrNorV3o R/BGHli1VDeX
JQh1swO5rlqql0sZdLIZ4HlkF1PjQBc7ELY+qvZRHTTQgdSsj2L8b6yPYy8+ qik/+V/qaEUx
EDcifOizArr0M7y6D39YwLOHDwv4rHxYgP2jArYtgLdBL1XQAUePvm4O22WM 5VKffngGvNfp
8OFsLRKNKhNbN8p4OFtXZauorJtlBpi9omFFRN0w4+HXVUi2qlR1o4yHs3VB MlTWkBl4cf4/
8jiA5QplbmRzdHJlYW0KZW5kb2JqCjIwIDAgb2JqPDwvVHlwZS9QYWdlL0Nv bnRlbnRzIDE5
IDAgUi9QYXJlbnQgNyAwIFIvUmVzb3VyY2VzPDwvWE9iamVjdDw8L1hmMSAy IDAgUj4+L1By
b2NTZXQgWy9QREYgL1RleHQgL0ltYWdlQiAvSW1hZ2VDIC9JbWFnZUldL0Zv bnQ8PC9GMSAx
IDAgUi9GMyA0IDAgUi9GNSA5IDAgUi9GNiAxMiAwIFIvRjIgMyAwIFIvRjQg NSAwIFI+Pj4+
L01lZGlhQm94WzAgMCA1OTUuMjggODQxLjg5XT4+CmVuZG9iagoyMSAwIG9i aiA8PC9GaWx0
ZXIvRmxhdGVEZWNvZGUvTGVuZ3RoIDEzMjY+PnN0cmVhbQp4nKVZwW7cNhAV mJtOQZsmQU88
pkBBi6JIiughQJCkQA8F0u6hSFO4dVw7dWK07iW/35FIdmc5swuTMhA7fuJb znvkG8niXf9i
1xsn58GqOcjdZT/IYflx9nqSepS7q/6Z/GZ307/a9W/6u96Pynjpg1eTl7f9 oPwU5OfeToMa
5ox/Wj9kkD993//cwFjmgaoi8u/1/tLZayvnpSSo8P3y7XOv12tajpNR4wgy tPJyd9s/E6/E
hfgoPom33QNxvX6/FXfiHLBruPKPuADkL/EBvl+KtzDuXPwmPogbuHZB9NpJ zSMq3sA0IcOM
2vuPP6FVy3BEa3BKy8msOruvUbUH86Dp9aCmmZu+mtBSr4G95fYFf4ELxhOR zcEVXEtYZrmT
/5eiQe8sYbSZ5PtbefbLlZYv/5Zv4mLbdavOcBV/uB6M8jrjh8tdzUjz+Gm9 ihORUDeqYMks
VeNPLJKReuBXaTbLTvAO8hgD9J24QSt1KAltFTur2bBSGyhxpkkNgcjNMKO3 ntHkkB6ccg5b
9EJciXPoILGX3EAP+QP6B2B4ix+oPdyyo2VdaKDEmYIaiQsJZUyoHb/MYU1Q syekDDOsekbT
4hgHnX/Gi/NS/Akt/1fczGNaYUrrmbRGnMt3BQPlO0ojgZ2sol2kavzJJnw0 337dU1NQzsZG
/IiJd6k0b0VGaQMFx7tUm3Eqt55xwiB37C61pNvCp9lR+WjQ8+VLPs9fTKZL 6TmgjPQGCsp0
KT3BVHnteJzpkpRxyqpntKzIGmlNVgS+vpVkSVJSp2lxmSY14ly2Kxgo26tC EtURmg9/7773
+C3ZNvBwE6P9FRPtUmjekYzQBgqOdiE2w4zaesaWaBurBo02kjyW61J3Dimj u4GCcl3oTigj
u3Y8znVByjDDqmdsyXW5HKdyDVPD8z1NacS5XFcwUK6jRBLUISj6ZFA1fkuu 9aR0umc/ZoJd
Ks1bklHaQMHBLtVmnMqtZ2wJtvZqdCTYR8Jdas9JZbQ3UFC4S+0JptJrx+Nw l6SMU1Y9Y0u4
yyU5FW6Y2XC34Ihz4a5goHCvCsusugB3TceG+97jN4TbBZf+YOmeMNkuheYd yQhtoOBsF2IT
zKmtZ2zItgtBWc09jx/Ld6k/h5XR30BB+S70R5STXzse57sgJZhj1TM25Ltc llP5Xqa2zK04
4Uy+axj7fCeJJLDeqIkNeAUBqYGr3B8MCefUVDC2dBI/L6+n1lbylLYS4mna /JynDRTUSoit
GWd8baBgTaWzuUDG2QbKlrY1Q0z4RxKmZxGjUwPijG6g7HsW8TnBjM3VBKyn NDkXx5jcQEH9
kdSXcabABsqWDlnsANoWlyOriR5iJJxrJBWME5WP6WCPlu79Wrk2Kpj8EvVW XImL5XyseyB+
F+fiWnwUl8sb7+5x97R72D3pvux+7H6A3x/Cv0fxtA3Gx/fh797BLzfwIet/ 7g7P1qKoATQw
hycJ52yoYKC7A1w1gTR7O4/KUbfrCBsOXCw07yGcOHEhanNgGLUNFNy3S8EJ 5xQ3ULacuWCX
Kg5diBG5qTBGNFBQXy19iDBnQzUBd7uSlXCO1kDZcvCCV+jYycsy58icoySc iXoNYx/1pI0k
163vUZioVxCQGrhqmTaUcE5NBWPDg6B1YTnePnbGQzxNO5/ztIGCGgqxNeOM rw0UrKl0NhfI
ONtA2fAgaP24vG6537sp4nNqPpzPDZR9vyI2J5hxuZqA9ZQe5+IYjxsoqDOS +jLOFNhA2fAc
SDYA85fyf3JVTo0KZW5kc3RyZWFtCmVuZG9iagoyMiAwIG9iajw8L1R5cGUv UGFnZS9Db250
ZW50cyAyMSAwIFIvUGFyZW50IDcgMCBSL1Jlc291cmNlczw8L1hPYmplY3Q8 PC9YZjEgMiAw
IFI+Pi9Qcm9jU2V0IFsvUERGIC9UZXh0IC9JbWFnZUIgL0ltYWdlQyAvSW1h Z2VJXS9Gb250
PDwvRjEgMSAwIFIvRjMgNCAwIFIvRjUgOSAwIFIvRjYgMTIgMCBSL0YyIDMg MCBSL0Y0IDUg
MCBSPj4+Pi9NZWRpYUJveFswIDAgNTk1LjI4IDg0MS44OV0+PgplbmRvYmoK MTIgMCBvYmo8
PC9UeXBlL0ZvbnQvQmFzZUZvbnQvVGltZXMtUm9tYW4vU3VidHlwZS9UeXBl MS9FbmNvZGlu
Zy9XaW5BbnNpRW5jb2Rpbmc+PgplbmRvYmoKMjMgMCBvYmogPDwvRmlsdGVy L0ZsYXRlRGVj
b2RlL0xlbmd0aCAxNDI5Ny9MZW5ndGgxIDI5Mzc2Pj5zdHJlYW0KeJztfXl8 lNXV/7n32WbN
zCSTyUy2mWGSCTDEhCQQApE8YYlgBMJqgkbDKrgRZHGrgFYEAijuC6hoK1DQ MkkQw2KN1bq1
VFrF4tKW16LiklfaIm5k5ve9z0wQUevbd/nn92Em3+fc7dzl3HPOPXcSBmJE ZKZlJJFzxuKF
gU/9d/0OJRuItMGzmy+5wnRkd2+kDxIpf7rk8mtn95l/+fVE9iiRf/+cWdNm /v7d4BaiwmXg
GTgHBalLUuPIdyCfN+eKhddsVEvWI/8OUWbvy+fNmEbRlLOIRsnI97ti2jXN 9p+mSkTTi9E+
0HzVrObq4EyRryNyzlN2U7aBzZQthymbKH64B7G58cOiTlD+ERHLSSD5aqPH 6U+sNwtQO/uK
MugL5mP9aTTJ9DlWup266W5y0yS6h6VSHnloMo1mMtpEaA1bH18c/5DOpjvo 0fhT7Kb4VtTf
Ri/QF5jBX2RG5TQW7SfTLPpQeo8a4g+QiVaQlYbQBOahafQG3p9hDnfSXfQr 9pP4FxjVTTeh
v0qqpur4s/ET1JfWyOuUg+Yn6Xbaw9T4jPhcyqVe1MIj8Tfif6UwNdDP6HHM KcI65VEUpMto
Od3HfNILSN1NP6cYs/FGabjyDEYaTVPoSrqaWmgrvcJSWZ1yUDkavz7+AamU Rr0xp7n0IRvA
xvDHZFt8aPwtuoB20UtYr3h3yhfIm5ULYlXxB+O/pnR6ilnYXvasUqLc2n1j /JH4L8mG+fSH
RMZinOn0U3qWXqa/0z/40vhSGkUTMfJvWA4LsDAk/gb38SV8ifQanYXVNmK2 i+hhimJHdtMe
ehqyeZsO0XvMzbLYuWw6u539g9v4TP6qtF7aIb0uM/kXkHeI8iGjhfQY7aTf 0T56lSnov5jV
sUvZPHYve5Ad4lH+Cf9cNsk/lb+Wu5Vw7FDs6/jY+GfkpUw6j66jpZDtz6id dtDv6QD9g/5J
x5mTDWJz2CMsyg6xT7iZ9+LjeDO/hz/Gn5DGSrdLz8oD5GHyZfI++S3lFmW1 Nk2LndgUuzP2
ROwP8afif4DupKD/MNVAojdCKx6jZ+g19P4m/ZneFfqD/oewqewijLKArWR3 sSfYb9gf2EdY
JRnvXnwIH4FR5/GrIKeb+J38Loz+Kt77+Vv8z/xj/pmkSL2kgdJ86REpKnVI +6X3Zaccls+S
+8vj5KlyHDtTopyjTFS2KNuUXytH1Up1ptqsHtFu0m42/a67b/dfYhSbE4vG 2qG7JmjSdZDE
Q/Qo9H4H9uAVSPT3mPEhOoZdyGRBVoB5V7AaVsvGsPPZhWwWu4mtYHew+9h6 9ij7JVaANXAN
c4/waj6RT+Oz+M18BV/Ld+C9m7/M3+AHeRdmniGFpIjUXxotTZUukK7EGhZK S6SbIdnbpa3S
q9Jr0gfSEakLu5Yh58qL5Ovk++XN8g75D8p5yhV4P6o8o3Qqf1BOKCdUrmaq 2WqReqm6RX1X
U7WBWp22Sntd+6epmWWzvph5gE55cR9sMJdv5W55KetCQQ6TyYGVR7APE2EV /6QqKYZ9SRH1
mFs698lpglPVZfgzvpDtoQHsN7RU5RK8onyI2tg7/JD8HD+bDrAm5pM3S1cq r/AgbYM3Wsf3
8j1sGO3glXwK3yARe49tofeg79fQXewytoC2sS42mN3AytlSep17pInsZqqM P8plZmaj2VHC
DOhGeSZdRP/yxSroHfow9pBsl38C/9RB92BHH6e/sl/QV0yJfwLvJsEbTYOX WQN9X07C6zXC
zpbCHn3wIJerr9IOpsKLl6tD5evoKH1JHyq7oVHD4Ek/iM2VH5L/Fi+PF8LC YGW0BXY3h86B
xbwHLXkaeZG7EJZugS8pgVXX0VSaSTfA690ej8Y3xH8avzY+j34L3q9YP/YV 2wiL6ABHJb2E
9230JlsNOzznX6/zh16xmdRJHzEvy2clsIcuZbGyTtmq7FB+pexT+0PaN9N6 aPS70GYLVjCD
/kAf0efMhL3xUT8qw3wHYe71dDlvkJ6m4SyTmmGzveHHhyVXsgC93ATpbYA9 Pw3bOAo/cSH9
ig4yzjKwohkY34R+aiHni9F6E3bwp6wdJTPhtfvSx1h3ChvEF2I8HT3dA6/V iTm9Q+9D2nFj
Xv3gF0awKejrczqfZmKEgVTHWrEDO6kCnnWE9DvIO485aRjrxX4OviZYaArl UIXyN8apX2xs
fBCfKz2NMyaO8o04vbLobDYfs3BgHd2UzsbRgNgEzOE1Ir16kl419OzKIYMr BpUPKCst6V9c
dFZhv0jfPr0Lwvl5oV7BgD83Jzsr0+fN8KS701JdTkeK3Wa1mE2aqsgSZ9Rv ZKimKRANN0Xl
cGjUqEKRD01DwbRTCpqiARTVfLtNNNBkNAt8u6WOlrNPa6knWuonWzJnoJIq C/sFRoYC0X0j
QoEONnV8PdJrR4QaAtEuIz3GSK8z0nakg0EwBEZ654wIRFlTYGS0ZvGclpFN I9Bdq9UyPDR8
lqWwH7VarEhakYpmhJpbWcZQZiR4xsjBrZxMdkwqmhkaMTLqC40QM4hK+SOn zYzWja8fOSIr
GGwo7Bdlw2eEpkcpNCzqiBhNaLgxTFQdHtWMYQJzxWpodaC1X2fLmg4nTW+K 2GaGZk67sD4q
TWsQY7giGHdENOO6w95vsug8dXj9ilNrs6SWkd65AZFtaVkRiHaOrz+1Niie DQ3oA7w8v6ap
pQZDr4EQaycGMBpf3lAfZcsxZECsRKwqsb5ZoZGipOnSQNQcGhaa03JpE7Ym syVKE64NtmVm
6rvihyhzZKBlUn0oGK3KCjVMG5Hd6qaWCde2+/SA79s1hf1ana6EYFtTHMmE zX5qYtbJOiNl
NBep2gknJcvEjEKjoRDRwIwAZlIfwpoGicesQdQyYxCa4dXAwBWdiR2ZGzUP b2pxDhblgj+q
5DtDgZbPCBoQ6vrk2yXTkiVqvvMzEkmhJydVDfU96WgkEu3bV6iINhx7ijkO NfIDCvst7uAD
Q83OAAjER3WQ7bSGwUUQfzAoNnh1h07TkYkuG1+fyAdoelYb6UWRhihvEjWd PTXpk0XNsp6a
k+xNIWjyDhJBeXrUFD7543B60kbOGRxlnn9RPStRXzsxVDt+an1gZEtTUra1 k76VS9QPOlmX
TEXThtdLWTyZ4lmSUQulvPBkY5Gpt0XlfPyohlLPjEpQSqOABWqizqZRiWeD JRj8QZ4OzXQK
U0f8qOAyyDdsyVlGB0e+nR/yrfy3ZmdrkTBfOcxrJ01tabF8q64GDqilpSYU qGlpapnWEV82
PRRwhlp28c18c0vzyKaeDe2I716dFa1Z04BFzGGDoaychrWG2MrxrTpbOXFq /S4nbiorJ9W3
ccaHNw1raM1DXf0uhCK6UcpPlopcQOSolkHR27jJqMrapRMtM2plo8DIz+hg ZJSZesoYzejg
iTKnUYZXIcIUsfkK3jj1NRq2g7OYqnXwKj2NFDkmkUWTY4x8JlWJcWkvC5MZ wa6XvBHn8cru
yrHOY5VjuiupCmnnCTz6FwddQVc+HgwBxImA1HlCV+hrCsidGIuapVZpFu5Z CmKry/SyFcoK
63HluFVWFdU6S5llXawstqqkSEy1Wkyagj4k6zGTSSJTwGkpslRZJEsHu163 SAG/Eb9LrIPf
0257bLiYT2NXd2M3puLscmVUMFdqRYVA/2J21fw0aUAwXSo1no8NYCVnHRMP qZW5vvgi9mni
idCIFsV2sceYiPyqnjSbrKpF62C5epa6gQ2yWixXsbCW5yA/BagYq/PZLlns jUAEjWMOd3dR
1ZiuY93MVUEuMWhaMN2tqlrBwIHloTXM13fR1PLJo/hK5nv5urXNgYXZ0yeL 8arZCj6Xb4Ts
S/RgMdMRIJRjJ5xSQCqWZGmE4jTGksgnP3a5GOtw4xjn+41U1NWIISDpat4b obUv9oHo7U48
HsfsJcrT0/kgsvDwKbOVT862W8y1f3Ep+O8UVzbBzWlK/AM5RelELBCgO/Xa aywrLZvZVm2r
eXPKU+aXzKYprgZPQ+YU/yWuOZ45mZf4TRW8Qh1oHmgfzUerI8019s3m3/KX 1efNz9vf5G+r
r5tft7uc3oCXezvinXp+qqfMu8lk9zuKHNyhI+fYRErOwXG4oWX2ch+0+oKv /dqY35iusc7j
88dAoF2R+QLYwUZqbGQlGR6XU1NDvcjlLB+Y0UvVVJfT4yktGVg+0OUMh3nJ gWtuW3f1gTdi
X+FZWufJKRtXmiBK5307YhfHmnbeg1B5E3to5z0fVk+6IobXs4hsLofY+bPV kOCjEH4YMjDT
FN18Gb+er+YSlztYn/aLFaZ08IueMpmhlTYzbtn1kBnjjbpdIdkvB+SoLMs+ y262GfFqQtCV
Y4SNQCOrKo81dkEpqDEYdKnagIF55aVSOPbBA3+4kvHiw3Jo3ch43su3iD0s xU3BhhnksCr9
4ie9OzN3Zb0iv+jd793v259pGp41PHt4zhTfevlu71Z5U7ZJzQxQb7U8c5Q8 3DvcNzzTlOfN
8+VlSp6wPEVe6d2QtSF7Q87W7K05plTKceYEcvrnLM65OWddzhs5phyxLx53 elkOd9ocOULV
uNAVHQqEqnbsEXXwR9o5szk62BQ95LcV2bhN7J1tU5piPujxIERklOl3HHRe zX25PRt4zNjB
ysoxTmxid2T+YbiHSOP8Spgjc5VGGuHAd1FOvLPNVSHm0OYwiJ7irJBNzgrF 5AJ1VUSMV0Or
yodPqtet5ixfFs9KY+KOhY7w09ggNKN2fP3TlIUAIxvIiR8aNGhQA5vfCH1x BQemlkM3BpSF
Q1CW/IF5pSWITaE2sqrJthMFzo2f/CoyeFZD/RxT7IiPmV5484tzxpTGjp/j YUrs67uY+e3W
qvMnXzTr0uuzj7zy0S9ntE+vPlYXFrs0BraShV3qQ2/qJSvSX07n12evzuab pF8om907pd3K
Tvdb3j/7TB43W+tZm8GDFjvJLCPNE/TbnTb4sDzdNs7OdPttdm63M08H47rD n1aUxtOEeNM2
ZSkMIn/SCb2C/kE4JSiWNxXYo7ZO7IHN4zy41H+b/2H/dv8zfsV/SDs4Lo/l ZUY8BzOuZgfJ
1/ekMR1LmhM00FVR1JjcEPEQ2fldwlEKp2WIVEgVQoX4qDEt37AtQ3paueek GIfy0hIR42se
PCjUK28Mc9qvGn/+1VdNGFjrv+qa+tGjZltj3VlXPHftqzdc8tqSe2Pv//HF 2FdseXDOlTc3
X/qT9PekueefWz+zqd/yhy+4+fKVzy7I2rv82djR92BPEK48AnK1kJ3+qlfY AvYKs81ni9gm
2i6zvWtTu+xMlT1yvtzbPsp+gX2z/Sn7C3Yz4yayqXZNsVjtGtlsdnsH+6We KcluCU6U22S7
ZOeyhTTd3mnfj8we1ptMOPp27CRZBgN1sPodym0WZhEbkerUHtae0SQt01HF l+IE9qXsZuex
UYZVH56Pg2YMbFsYdhWOv+7GSiFCnDRkkBXKWRH5BufzDoejR3ULbWfbxtj2 2f5sUyihtBBv
BGfkAFbqKk0PuZiL8SXdW/hPPtm5M3Y0tp0VHJd+duKiz2Nv8lz2WcwKjTsf kvEqm3Ay3bKL
5Pghvb/DVWaxZloHy4Mso5Qp1q3WX1n3Wd+0WoJWZpU08luLrLzIWmUdZ5Ws Qqmsu8VBwx5/
inMmayabCYtuL9IYTvsmPYWPk5iUacdRb0uqTqWwYay023Bgzi7DhFlSQxoj OH3SVc4zgqmp
5edLz159/EYW+7vW9YL8CFN+tyh2bizt16yYX/Ml5j4t/oFykfIaZdIb+thb zKvcqzwP033q
i+bXpdetn0nmfHNvW297H3cfzyJlkfkWxaSlaRkZaRkZfXhfKV/Reiv3K/ea X5Z+Y1Wq2Dg4
6wlOYodwpeWGn3J5ywxqsYOyqXqGt1A2pegpqWUptRc72DgHc+jp3jL4sN56 r9RCi+T4NGUK
fUpGV5nF2Sw7vWCjxhyaXyvGrnfwNe1ZSyYmXPh8cRo1YsdhRzCdY5DB4Yig ItEoPDoTrkZR
5VAAxxIFAxmeDCUsLAVnE8xHrmL+YbF9n8Teia1k17EyZt8ysyT2duZji3/2 25c2Lt7Ksy44
+iG7jU1lV7K7H74oWnPVzR/Fvop99Mk9ws+E4h9I+xAvpdJUPW+uabOdTzLP Ns+1z3XOdV3n
XOXULKOsNzoKNTODLFIDjHfw1Xpqs5sVu5nb+qkfGu1L616UPPe7xjjnzz+e DNiwiMOJ+bOg
y62pOFfDBfmeDMPm+SZWEIi8u+vNjxjLUALF02dMUHafaNo5fdn6f34cWFI2 bn4bBhwdPyKf
JQ+lEJWw+focLdOUreR4Ms/NGpU9Ov9t519d5oG+Gt/54dm+S8K3hO/w3Zm5 CcfZi5kvZdlU
1Z7uUX2eArVPeoPvan4L36Q+qb6g2p4pe9PJc/JK+rv62fP0yFlleXqv3nj4 csrm5Z3I43k1
xllRnOIoOzuHiTMtmvNljpyT04+Vko5SEfFwmhzUs11VQT3LiYc3syzYwRc+ KWs2u6WfUBXU
GRTVBkWLfmih625rbv+wqY+5t73Bb3vYxv02Frcxm56CMy9zXBkra8Ku3FrM GCvtE7w4g/01
g43LuDhjXoaU4SudW51UmqugLvO7GoXmRBK5w0LmXTjPhOBBjjVGDqcK/xtJ OIm2ohw2v6Er
kdlFefHOp7JyyiblzczjjZGGRnDA8KQUZ2VlpeGfqXE+Q2yJA82TLrk9GcFw QbjA2MMBZQg5
B5YnvDVDCKqmu7GnxkHIZsUjf3x1b0etlJUf+8jq1KRRP2/8+dNT1t/xm/Pq 5tVOYhcN/Civ
vH7EeSNLnVb+7lkP3NWw6qlYx5rl52WX+0w1NW0rp66tzc4PZI8fOST2x9QS b0HlkCkl4fK8
WZDKZGhDFbTBR/+hj693NKQ2eOY45qbO9dzgvdZ3L7/X9oLzBe+fnG94P1Q/ NH2Y9mH6F2ra
oLRB6eemnuup8TbY5tq0wanlnnKvdLVytWOFcotjlW9L6mbPrtSdHnOKsUtZ ZYI+meouSym1
ixJfbplB4Qvtu5mMiHehnuqyko6mpKMdla7DXu1muEmgKpChMVHKglRkFwl7 cFwKS8nM0oJu
X2Z99TfxJ4wlcqwrIky+8XAkYfGgwmDmQ/wsYeKGZAeWK2oiKCVsh9w/9nHK jHFzb1h6Wd3s
dOaOHNv3Yexj5un69Xv8k5KJk27f+vSGC+YV/erXLMxkprH8zSL2robsCiA7 N2Wzn+0iZ/wL
vcZacb/5Afs9zi3KZsse8x57R6bJ5Gaj+DlqjWVc7hb7TnVn5ouWl2xvWA7a vtA+t9uzHdnp
OrQmXU9xlTnSn0l/NV1KN6STW2XQlAxQvla3OVJS61KaUniKN5WhYqcvq4yV phpONCeQcKa9
+iRopDBBvdkG1R0wsY3iEwMnpn1xaiqspl22pnqF9eRZNQqyovSEUItyL86d l/twrpzrCJp0
u6PM5MtJWkjkW161C/Gg7vbqvd1VXj3XgQfM0ivs1wgAq7qNeDEVk0CLVDEZ NEpNmq+gbT1N
YXpG0GgwECpSK8Sk2zIEibabLUONbHWwKkKi/WFhVY3G8Ck6pJQiBk0Rw+P4 yKgio9MiBK+R
qyIRnH2l4uSbj7ObiS0PFIQHiD0nKWhESmlCJzQ1g3/FvAM/3B77ePlc5n6t i6Wq3bp007Rh
Uwuka6ZcWFnJ2ISiBx558vY/MxOLxF6MPX3D6lHs8uuWDh++ALoQfzQ2nm2C z5conVbrYzxa
WAtkDNR2mpRlGUySFUp3I4Z0miUHMZ320yG0bMQ1Xk5XL3Yy561mB3OHuRP3 lczbhHdiGfZS
J3yYz+PJ2M0voyC/tLXSGzE8lW/MYS92Yv7xxsSp0NUozvruRKzuKpUUOBxn 0uWI62a6y504
KMqNFQ8c4FrLfAPuXdR32qD+7pAjUp4q72Ry7MS6r7/+7eaLHI6jspJfdpP0 mdDxCdDxB6Dj
dniIe/VRR9gHps/TPk+XX+RHFJ7qU3xm3uCckjbF0+C9l9+n3me619ZhPsDf Vt4xH7B9oHyg
HrE7N5t+y3+nPmd6waYsMq1SbzZJLihem8WaIfTPLWvuCi2zKasZN4WUIH3L pOcfN66UVbj4
Egy4cf7wet081zk7dbZnrldmjQ3iKEwrS4VPpURcG853nwyA1Qkt3Rv+zspi L39yR+zzFha4
58or7777yivv4b3WMLUl9uKnf489d3N8y0NbtmzcsGWLWO/q2OXyvVivk7Lp Af2sQWmj0nhq
mVRhr0gryxohjbaPThuR9WWWeYo6xdKQOsUzxduQfVz7MsvESM0Uq1I0t1iV x2p1OlIygqbM
5lyW6+qTkuIIO524HvTRrc20DCP5cqoS60S0UunsrnQe7llupVhwVWXiBs2w YvtsdbZlLtY8
2zs3WxWLTgumi3NEuC+xsa4gO2XVq5la+stLdzEeO7Gr/rZxsQ+Y59bZ02+6 ZcYlK+XwhrqZ
sb/EumPHY2/WTO7+UNrVvu3B9s2PPgzvkBIbL0+Qw5TGynak9lZYWgciVq8N PsADR6CJhyoe
igdlXPgVf+bgMhiVbLemqE5OaaqcxmVJguNW05qg1h1su55qddiLUnpTIL04 vSldOprODLfW
K1wmqJ6anVuWnpGRKVdIutdXthQBbQcr0M3cyOGKL3KprIL07IFl4qILybmf 35g4syNjun14
4sfbPXbkrBHvRyI4uJ3HDgujKEL8izfruSmJj5YqNJzG0KUIM1xOY23UObE2 Onj81Po22Um7
40eJxY+2Sk42SNxIDY+kxI/oKXZXVZozzYdHqrdK6YgfbUdG0DbkE301pAXT 0oJMS5FCvQoK
jCMmBZ7iCxaKrRqeP/z8pXXjx/qGDZh+kU8Od6fwf5zguxqnn93L9Y59QQPF 4z1RI/dQofhF
Jq0nUmbCo4jfNU8TnvRou9MlZHZU9yPhzX9YZrfJTJZTpHzijvwUzt0FTnPA zM0IhnV7ZnEm
kxyBQEoxjoxdfDX5cEB2VzaKj9xKi6ioq6obd8n5jTAtLAAKhauNCEyErwjm B4WfgDYF18uj
Thxia35+8P4HfrOz+zzx5xQtzRNv3x57Tdl9PPZ43cHb73597PGspprZjSL2 vR+zLsCszXRM
N9eYmFacmSN0Zb8eRMLENc3LM7QyPkQbp93FH9Te4G9qVk3iRWKnoRZDqwzN ar+gMaFhBRMn
lfESk+Y2mTSNSyaJuGoySZKmo4Wmo1YredX4lGe1nm3VrXXWJqvUbF1m5Rut nVbusAasxVbJ
ZPpWp3aj04C52NxplsxCNhYhm0ikpKgRkV9P2rhCiU8jV5xlKMuKG57vCfU4 Qj1zASaABw6c
BhFiRCJwRUEXE5+lsuD9LJ1PYAWxj7u3xw4iDC+W9n9VIz19YriQ0gO4F+5X nkcM3qr3Mqle
tVwd5TgnY4p7smdSxqTMlan3OXd6vpS/VL7wOXJ8vg72lO70Zri93oyMnND1 7tVu7kZsPOtJ
zkPEbUjpvazc5w2ZGtw3uZ93S+Rucje7D7nlOtwofDkZctBqNT7Qc5ltZd4Z +axXIBAqDnWG
pJBYfZ6hGc7jWLMro+IqBKpVlcIJIdbtqmh0VRjX4xRcj4VLwhKNWBXupzy9 oJeIVVUNp1Ra
UBLhbFh4owdY7xk1oy9svHCfJdj3gkllpVlVdTNuHPNS7OfbZbsSqBhdK2TS vc4yYc9/Dh7M
3maFF9523uzC7K3rY1ey600ZprMvH8i6l8AqkrdQWEWYhJUkby/IjzCs5EJx PinvUA71oYf1
iud8TJF8Dl+adEnokvw5fbakdaS94ngl7UWPaVTaOZ6p/smhyflT+8zxawXm cvMgx6C08sxR
DtVaIHy2qw4RkOpA6IlrJYsbl+yFbdkkriF6ttuKnWN5QVd1pCnSHOG5Qa9V HzwAgq3v6zxW
UhRxds13HoNpwbiEA2+cX1o0v6qxu8T46EAEIKxUHMMFISGzgd+cWFzcQEtL TvXgUvQZ84J3
s7LybtlyGR/6m5V/YL1irx7/RZyuZD520a1Duv9y+9z5t995+dy7lHeW/pQN 2fr0ooWxPW/8
Ndb5KBqMZEvY2BPn3/6L7S1rn9gqopMvY0fk9+HZ7biTLkekyhfuNKl2SbaI SFDHfTMlLG6d
FvtuvpCssBS3t8yaDNEF1XtBb6zXu536yFFlTj01vczvZFVw8M51JmYypYYV hYu7mvgAnEtF
wsHgp7FUXJUi0KtIRGTFXbyysqhSnObBoCvkKh2YCm0qdYWktCDXZHbincML Rl1klhqueu9n
LPa46/rYERarY5PYhhOdMc5ivCE26hGhBcnIG1owSvxxBHnjR6RtOLXD9Hs9 M93l84Vdm1O2
ZCvn2y+xL7avsO90veBS01kHf0wPkZ4XxjWjuKTsNmIXEysScbEjK6eWcqO5 nblSbm5AtLNl
WW21Dut+K7daTSjYCZVgtnQ4mk16aqqekVWWmhoKeqt7B6zjenMrinfYAjjq 9/BNUEab+GQU
1xmbLZ7DcnS7qyynKAJ5QEkaxc9xyAMygQOGTOB1DieeLnG7vAoy665Inv4D kn64l/FbieRH
oYaXDgWk/B6NYa2jhw0ZPXpQfd5/5n1yb+drF0xfvOjIW7GbJzM29LZxF8+o YzueShtdVDK5
eGrpmjXR5ROvKArcNO0n7axP0YaJg4aeI2S4Bj7pIuiImdp1P+MOLZ37tBo+ Wnudv62ZyrVz
ND6eX6xxOGucyZKel3DKXIM3JlU1WeCUw4oeyCtTKiE2qAUPm8XFDyXmKjjY iFgirhHd3/as
J70qrvFaHo8Yh8MwPkZr5ks1M/z1Qd3syijTeuOB3JGnvPllmhcPI9AXn8zR VY3zv3G8a1gK
izJ37B+xc2P/wFE7i6//+i2+ubsBa1yJNXK5kHJpm95L0dI1folytXeVZ5VP 9mX7cnxebzjD
7c4AfJne1Gxs+w7OKdcmFCJoUUnN8OZaZqeuSuVety9VzrBaKcOZwTMyAiwn nCsMBnYiqJ6G
VW/MZc7co7n8kHjkVvmdCNFxJemudBm2AVebcLRVXWLfu41ffPV4WkQt5Eoq wSkeNyMDdxW8
PRkJhxsOuYIrmbdmcJ+Buj4nMI7N8/vz+l+4/EJFfTD2xzWRqqGw/HBsrKlm 8YP9+im70z1X
3Nkr/9cWa+xtVto4IDZE7Lwv/p/yGuy8m0bsIlN8/04zAj2TOFMX7iBVsjiN MN1ilcK80qOG
HThT3PNwN3k+HedGSdH8LqizcHnCrtl8hBIu8TbuHAUDShKfTf1VeiJ2JHbj pNnzh19pDvfz
VmTK4a/fkobFQjvvPCv1VS7VbsNMjJgHM7GxpXqeRXdj28XjBu0GC7cU2+xl mnjwYltKmdnr
yy0zQR90MxKSyDERr4qcOQC/ZTJySEhOPJiIm4xcb7Nd5A62gSYVz8y4ZDYp VlXt4NvalBTr
Hr5NnC7Yx0xzX3HK9y2ziAe3aJKNhLqbbRZj76DFGeKXHqyoy/l6l8hktZu4 JHVIG3SLZnJr
molZzGaRzeLMzRHmaBbJLDFYDPqQTBozc4v4gES3QmVSKgNaMWxKqJI7vQwH 0DY9V9GDMCrF
yZ/hnIs05+K3qhwCSi+z7MZcbQkzs1XZYWZdcDQ+4W28RSL9fsT4pWpFhZgv JowpCiWD2a04
yytIgxEA9ryEVTWKeJAx4aJZSHKF1rMLceu1sAs+jXUf/fwojCqbH4ZR7eke KUBJyxqDnbPS
xF1khr4E92Op3CqTqlktshZWhWfYrrK4ytRKO7OEjXPFJszEyo5ambXK5jwO 8xBxiEEMHyH8
YZf4vazr5HslTrg7WGbs/diVsQ+g29ez5V+/xX4VG4ZzIXlbxbkwgXpmVY5Z aTQcgTxm5YU+
Q/5hbsyGszgmWWlWw9rJyWjsKA7+KpMxiy7czvA0rmTfzGKltD32QeynYnSo 8PATT2Pk5L0R
I0804pTk52rI1xj55N0K+QtFvufzAuTHGDOFtr1/yYUPnPf5xY7Kz0w+k/FX b4/+rdL4a+Zd
B55M++qrE91OMqWjrRlgiT8LJNKGxsbScCd99VUs7KRk+cmX2qImi3hFElup Q/otNcsLKBWo
0XKoQXmRprIP6ELUXQYMl3IoW36cJqP9IuQXgN7JK+LdaD8FeBQoBcYAYeAC 4PwkJgLV4HkZ
2Io+Lhb9GPRvdKm2j87GWATcA0wD7lKm0N2ou1etoOmiHGOtQR8hpO9H+YPq Vrod6ftQ3yDa
GlTwT6FzUd8P6TuVKfG4tpY0lBHS3Sj3YPw7xJxBwxh/gbwg3oV0X/Q9GvUr QCeDTkrO12uk
/yZ4jLWKNa4SachnCcpvByYAq4ELIB/BXww+P/JrkbZiXmZQG5AiE/VCm0p+ NkVBCzH+8OS6
yVg31nFyTZi/Mafvh5Bp9anAnMS6PgT2AftPmdvpWPstLKARUqmxf2LNdmAI 30fDIJeYWJfy
XvxzAWjeQaxrD6DIM6m/ieJbMc8qZQfdh3wJUGlgATF5A82TjmEPdtB16j30 CMqJ9weOUz7/
hDLVfCqH/OrR//nALPT5nKEPM8Uc4p+A+uX3KBN9NQGXYuyXe+QkZIP8KOxr PdqeEBYBud4M
zIUM7gOuEvPD+EVC5tj3z9mU2C/Q9hDGqRXAmH4DWHtiX2kR+OejL2aMk9iH BAVQfylk+kvg
GeBZMYceGHqWhNHXVpL41vg/QdOATGAfcLvQN6AJ2CjaYHwL2lsMfYXOCN0U +iF0Q3nR0NWJ
Yu6JNRi2sDppM1eA/wLAB/RWH6cLk+iNtkI+04XOCnvp6VvoltDrHmro9GVC 79lHYp1Cp06h
dymdNF7MwRgXutVDhd2h32sFldKNOT0gHaB1QmeFvvVQIReha8IehU0kad0p a+2XtJF+4M81
dB262EN7ZHGSvkoPoM8p6u3Q049prPwWjZV+R2OVa0HvwPp2oQzrkQ/Ah0Vo nKmT+mAvx4H3
/tPofQLaAXYpxrpN3gZZHKAHDbke4L3kA0xRtsU/VIi9rGzjS4z0d+jpYJ2J OkEFTq37d8v/
O+BvKNtoNtIfKQficaznDmET2sesGAj0UJS3AcuAvqYIu890GevQJpNTJToG zJN1GqzoVC53
UpWcTjrklI/yyeo5ht9dh/5fZB/TWuzXLVo6haQP4RsxFn8D5wMg+gcdc4oe fUvnTtelHtqj
r6dToTPC74IqoD7Y3W5gD/BWEv8BvAt9vNKwX5wNwj8b5wN8NLA2oa/xrpP6 +TJtAL21Rz9P
09O+p+mndrpenk7F2SL8u3G2wE4xj7U96xf+Ufg44SOFnxNnX0/70+kp/HfD d/zJ8MP7aGrS
rvsAxUAR+tib9CN7pI74MdjoEfW1+B6tKr5HeiW+R70/vkm7LP6SuiO+Aevu c/JM7Uz4MmFP
PWepkJM4F3vOUSVMs5P+7AGjLcY3ztEphh8g9VrY36U0Hf3+Tpyrwg6lDbA7 yBP93SRvocvl
d2kd5u6QtifK5Yk0VvhEeTHSKIdPF/VWaZ1RP0H+Jy2W+yC9BXQ9uVSNFqu/ FjzxfUbZ3xJ1
okyZSvdC74rkVfRzpZXqxV6JdfAB8VfE3sPmM03L6EGNoMPv0gPyV1hzJ9b4 okHXG/okeNvj
X4n1aUMoQ5GwPtEGEDzKgxRIyuMeQxadhozuNnQYshB9qq8b8QYpB9H+YbrB ZKEHTAXwT59R
pgZfYozVSuebdEPusnFe/x328TF0bDKtVNzxLw39fzwel76CDX0M+xJAVKqk k0/5mNbDllYa
8knQ1cJ+pI8pXegI1jfJiCc+ho4/Rlep22iN2gm9O4Cz4AD27WOs5TIahPTt 8rb412g7En2Q
GBvl4434RJxTeny/sBetk7yajvHRRszBiP8wrvQe5nsnrYQvqTZ9TD9TAyKu YQy6lwv0T8DI
LwWWAGsSMMqcCcqC6OMGo3wWvcS3Shz6Lepfln8B21tP1dJmssizET98RDfx IlohjYXedeHM
kMCHvNyPektdVCt9YZw/KxQLlRvtPDjHj1Cd3AD+Tpopt9FMKY60F7gb+gg+ pYOmKjMQZ12E
fpLgA8Fjpjp1NdJF8cdFO2OML+IeAflaKjH4ToEx1x6IOT96ypzvhmxvhD6I +SJ96nzFXE/O
MznH75ufsU7RL/iMNm9TNW4D7wD5CRobz9fSNmAjfwtxeCctYffEd7MNVMPe AzYk8QSNMmgr
MJ5q5CVsJVAHyPISegi0EPQj4ACwAdgL/Kc8gJaj72dB28W9QID/Cr4LFPWP AU8Df+mpOxVi
rO8rPxXy+/Hdp+aVEqoQ4P3g0/t9u85o/xCVydfADxfHdwtIi8kioKZQH81E ffi7KJ8CvtPy
Sm+6V56Hdj8ynx8De5WKDRkmoJ+6xp79APX8F/DOKTQgKOyrUJzP/9M5/rvA /i4FLjHkv5HO
MnToCGJyLf4c20sXsUPxr+DPVYFEnjINeT5Erp59QvlKo/y0/YOuDJQmkHR6 OdKVAj350/f1
x/Lod+6p6NGDHmglpAvIf0F74PQ8zgNdQBU61u+7+ZPj/hAmURnkVCNPwlze /W5edVKRAG9G
/j7Uv08FAifzk6iPgGgrANmGBCDr3QL8XQoKSBNQN8FoP1TgFLnWC7lKnYLX 4Df2p0fPT98f
8JL8PPzRYcTMkyjzdHpSv5P+4ls6Pz6h7yfzwpe8d1qbb2ziG9uArfxQn/8/ AbbzCvAi8ML/
6TjQc0bQVcBJiOleQ7wRRaz6M9wxf0tribpXEn39LNGJi+GHcKs+8QTKJiMd Bv074EXZXFCc
Rl8fQroZda8D+4CNchZdk4wrfciPTPB2b0r2l5/gF3xfIdr5emCC/+sVwHqk fw9Ay75+DvQu
0M/QPgq+BtAlKLsJtAz5OqAG+T8gPxTgSA8GPgQwzxMIY04Ugf8hYLGIR77n Hvq/S3/g/vFf
pYnPAKjRiDkx39PvEP9l2rOfP0JPv2v07P+P0Z67xHdoUg6I+V4ROOXu8y/v OD0U+/llEseA
T+VV8W7ElJoRRyOWNWJuET8mqRFvHzDiSZb8TNGgInYW8auInUX8CrrBuOe9 ivksoPPEPd+Y
V885copv5f1oFuBJAn6PhqPNHzGfo2wLOdiW+GeILdcJiLPNOMf2in9DHf8t qAM+9xm2N/4Z
6D7kc3CWmXvOtB7f+h0f+90z7f80/++ekf+NM3VcEnNPQ0/57CROry9KopfA 6Wfxv4sfO7v/
22f5D5zRp57T/9N8zznfgx+LS0+PA34s/2P9/bv50+OOU/KtAv+i3sifHpf0 5E/Hd+q/q3uJ
eCYT9taD0+zu3wXsdJg8L/5mj732zOF0Oz5pbz13hKU0AhjZQ+E/esOP9AHW JO9dIaRxBsav
E+eb6QSVmJ6gEuSfNP5dPnwOaEPi7IuvYTsQS39ufCfBcuQ1eZ/Rtj6Jhh/T 59P1VsTnRnwI
mRlzX4e9OEZFwBAgFWgFrji517hDYuyXpDrx+3rcjw/HP0Nfn/1QLPhDFPe8 q8R9D3kH8o7k
L4wu/y6Y7b+InwCvQDqmBCSUSbfixow4QYWstU3fwDT934N5ww/DMvj/DrZR CdhvTsCx7rtw
zvkuXNCF1Ek/jrQ/nsEZnMEZnMEZnMH/Kt7913Df98NI/1UCniP/Al/895GB +Mh71imIEflS
EsicQJQ1MIHs84A3iHIRZ/g9QBgQ6Y1ANInO/2XsP4MzOIMzOIMzOIMzOIMz OIMzOIMzOIMz
EH8ep7bQP6iS5pFKnJxURJNRNtY5jyTxpy2TpAfIwRj5453Sfe1Od4neId3f 7kgr0aud0t1U
B3CKSmOoE+A0T7qdlgIczWvbCvuX7BKJdktKiRPtV1MAWAZItBFPZuR1QLRf 3Z7mEd3/tM3h
MviubysuSyTand6Sumq3dA0xaZZ0JYXILy0BzQWdAZoDOl2aSXZjnnq7w1my DONVoXmVlE59
UF0teagEdISUSVlGs0VtKYlxFrX17ltSbZGGS16jiUOyUxmoSdLaSvyBPZL4 +lZdWtlutor5
rWxzppc8LS2XNHKj1TK0yvA7npYsVASIlUxqN9tL1lXbpElY5iSIxY85MnrY eOrSlW3oCOON
lLLJg7rLpBxKB62RctvS/Z17pDuNZneIXjDe0DZTqSDt9pSSzmqzNBS1UelW SPxWY7R17eFB
JVQdlnpTMcAh1KVILRXbKbUg1YJtasHWtGBrWjCLFmw1SatQswptiqTrqFm6 mtYBDyMto8v0
Nkhwl5HI612yS/JJXkjCuQeyYyjNbDeniJl521LTjGbedltKSdXT0gIaB3BM fmF7hrdk3h6p
r7GUfu3eLMHQ3Ga2QXQZib0Ao0fswdNStpRrSCLHkEC02o88I4fkJ8Zf4fuF dPhr/IDYX/Ff
Kxj0t0m6L0l/n6DxTr6/HaPoHfyPgh6qzubvobOL+Z/pYaQ438Ofo2IwvMU7 xCz4m3wXVYEe
RH4m6C7QUtDdbcGX/B28ox0Ec1/fZveIxfLn2iJFyYQ/P5nIyEomUj0l1fn8 1/xZykYXfwLN
A32Wd1Iv0GdAvaCdfCG9BPokH0BDQHck6fN8r9Bp/hTfSYNA29tSxBSibZog 29tUQX7ZRolc
XZF/L/8l30aZaPpEWzgTpVvaw3l+xx70x/hjfGFbjj+12sIfYfXsGBptpIOC Uip/tK1cdLKu
bW/Av4uv4+t0b7merxfqm6Ti/OLC4k1SID9QGCgPbApUO/mtpEB4MFi+Gs9y CnBoD6AD6/iq
Nrk8Wt2NNYl1cVqG50Yj1YRns5EiPJ0na48aqSq+nMYBHH0sAZYCy4AbScbz OuB64CfADUbJ
QmARcDXcRzM4msHRDI5mg6MZHM3gaAZHs8HRbIy+CBAcTeBoAkcTOJoMjiZw NIGjCRxNBoeY
bxM4mgyOOnDUgaMOHHUGRx046sBRB446g6MOHHXgqDM4dHDo4NDBoRscOjh0 cOjg0A0OHRw6
OHSDoxgcxeAoBkexwVEMjmJwFIOj2OAoBkcxOIoNjgA4AuAIgCNgcATAEQBH ABwBgyMAjgA4
AgaHExxOcDjB4TQ4nOBwgsMJDqfB4TT2ZxEgOA6B4xA4DoHjkMFxCByHwHEI HIcMjkPgOASO
Q/zqVml/9W/Ash8s+8Gy32DZD5b9YNkPlv0Gy36w7AfL/uTSFxrC4FCbJcBS YBkgeDvB2wne
TvB2GrydhnotAgRvFBxRcETBETU4ouCIgiMKjqjBEQVHFBxRg2MjODaCYyM4 NhocG8GxERwb
wbHR4NhoKO4iQHD8+0r5b28Nv5HVm3C48mWsj0GX0icGXUIHDXoDtRr0J7TJ oNfTTQa9jsoN
ejWFDYr+DLqQ/CbW5i93VHvgAsYBFwPzgIeB7cAzgGakXgX+CsT5AL2X7NDG aQ9r27VnNGW7
dkjjDnWc+rC6XX1GVbarh1QeqM7idsOPwrXQbcZzKZ6fAjhE8KwyUlW8DOOW wc8OwLuMl+mu
rsCnfdmrfdkzfdn2vuy2vqzazM9hsuHpAlTOMXFWr9vCQ/0HgfJwwVB4plt3 fpLhbwsP9Hew
vQnSR4+AfgK0ApuAm4ByoAQoBPIBv1HWF+3r9V7JLvcCBUAQCIghyOMholSX Sd/F7WxT+2/s
ZBbjFPQG3562gmKQjraCcSBPtRVM91eb2U4qEGEQexI7tw10e5v/MKqfSJDH 2/x7QLa0+ctA
GtsKzgK5oK1gn7/aziaTXxask5J0ItYt6IQ2/xQ0G9/m7wMSaSsIi9Z9MVA+ avuwejoMmp/k
ykuMFGrzDwHp1eavEK1NVCA2nqlUaExPAQSV2jGhT3exepnpVn+X/07/J2D/ GIKFerwZ6JBB
Xs0X3ytt8e8tfAiNq/1t1RbRHudDa5JGBX3Svyl/lX89+mL5O/33+8/y31rY YULxWsx7lTFE
m/+mgPiGgzT/Mn+xf2HhYf8C/7n+af4J/sZ88U0M/gv9e8U0qYHV8207/XXo cDRWkd/mPye/
w5hijf9av+4v8FcE9gr50qBEv+WFe4UEqCQxej/It29+h9DxyeUdzKX31Y5q 67QLtGHaEC2k
9dJytRzNbUo1OU0pJpvJYjKZVJNs4iYyucXXSETEP6x3q05BVFk8ZSPt5OLJ E/8SnzMTp3Mp
mibV8tqJw1httHMG1U4PRI9PDHUwy/ipUSU0jEVTa6l20rDooEhthxafEC2P 1Ea1ugvqWxm7
tQGlUb6yg9Gk+g4WF0XLs8R/CNLKaPnarF3EmG/52oYG8noWV3mrUoe6KmpG fM+jKfn85lsd
It5TkznRe2on1ke35jRES0QintNQG71R/Hchu7iD20eO2MVTBGmo3yU3c8fI CaJcbh7RgGaH
jWbQ5hQ0owJB0Mw0jAKiGfzJMNEMe5RoFwY72gUFQTuLncJGu7DFbrSTmWjX ejAwckRrIGC0
ySc6aLQ5mE+ntIHGgHdEazhstAoFWL1oxepDAWNifYyO/H40KfQbTRjiOqMj PzMGixZ90yQ/
2WTAySYDjLEk9k0bf6KNu3dPG3dvtIn8D1+zhkVYe/9FS54T/wNLU2jkLKAp unrxHG902fRA
oHXJouR/zRJumj5jjqDTZkUXhWaNiC4JjQi09n/ue6qfE9X9QyNa6bmRk+pb n9NnjWjrr/cf
GZo2oqG9qrK++ltjrTo5Vn3l93RWKTqrF2NVVX9PdbWorhJjVYuxqsVYVXqV MdbIuULv6+pb
TTRMfHueQdu51QIdbsoKNgzzOJuHCoXeNSToXZK1Wya2hayRhqgtNCxqB0RV YXVhtaiCnYmq
FPHf7CSrvEuGBLN2sy3JKieKXaFhdPK7S0Sj2uiA8bXR4MSp9UJVovq079+z BeJlVHtp5NwR
+EF+oQG8T21JC773tfD7XosWLVogHosiC4hqo30n1kYHjsdMNA1DNY1oQNlZ PWWSZJS1ms0j
O+KdqIxgEmyhGE6kIkx8I6puwa1L4xvVjRoXV4WF7Zk5JfOexgm+FMA9jl/d VmTcl/nV7b3y
xf1lYXvRgATF/VTQtsxgifhCmXKwCpqfoLqrEIl1+esK15VvzN9YuLFcFV8r uwmF/k3iKG0r
2iTRwsiCHkEgubCBEl/UivEeacvOMQbeKBKRSENkAev5BpnTXj3fL/ONYBck e11gdL+wZ0MS
5Qso0ThRGVnUw7QoyWJULjJYjAH/H4SD8IYKZW5kc3RyZWFtCmVuZG9iagoy NCAwIG9iajw8
L0NhcEhlaWdodCA2OTkvVHlwZS9Gb250RGVzY3JpcHRvci9GbGFncyAyNjIx NzYvRGVzY2Vu
dCAtMjEwL0ZvbnRCQm94Wy02MjcgLTM3NiAyMDAwIDEwMTBdL0ZvbnRGaWxl MiAyMyAwIFIv
U3RlbVYgODAvQXNjZW50IDcyOC9Gb250TmFtZS9KTkRGUlYrQXJpYWwtQm9s ZE1UL0l0YWxp
Y0FuZ2xlIDA+PgplbmRvYmoKMjUgMCBvYmo8PC9UeXBlL0ZvbnQvRFcgMTAw MC9DSURTeXN0
ZW1JbmZvPDwvU3VwcGxlbWVudCAwL09yZGVyaW5nKElkZW50aXR5KS9SZWdp c3RyeShBZG9i
ZSk+Pi9Gb250RGVzY3JpcHRvciAyNCAwIFIvQ0lEVG9HSURNYXAvSWRlbnRp dHkvQmFzZUZv
bnQvSk5ERlJWK0FyaWFsLUJvbGRNVC9TdWJ0eXBlL0NJREZvbnRUeXBlMi9X IFszWzI3N101
WzQ3NF0xNVsyNzcgMzMzIDI3N10xOVs1NTYgNTU2IDU1NiA1NTYgNTU2XTI2 WzU1Nl01NjNb
NTU2XTU3MVs3MThdNTc4WzcxOF01ODBbNjEwXTU4N1s3MjJdNjAyWzU1NiA2 MTddNjA2WzYz
NCA1NTZdNjA5WzQ5NyA2MTRdNjEyWzUwMCA2MzUgNzM5IDYwNCA2MTAgNjA0 IDYxMCA1NTZd
NjIxWzU1Nl02NDFbMjc3XV0+PgplbmRvYmoKMjYgMCBvYmogPDwvRmlsdGVy L0ZsYXRlRGVj
b2RlL0xlbmd0aCA0MTk+PnN0cmVhbQp4nF2TsY7bMAxAd3+FxutwsCXSTgoE BIq7JcO1RdN+
gCPRgYFGNhxnyN9XJiMV7ZAH6ImUSIeq347vxziupv6+TP7EqxnGGBa+TffF sznzZYyVdSaM
fn2uhP7az1Wdkk+P28rXYxym6nAw9Y+0eVuXh3n5EqYzf6rqb0vgZYwX8/Lr 7ZTWp/s8/+Yr
x9U0FZEJPKSDPvr5a39lU0va6zGk/XF9vKacvxE/HzMbJ2urxfgp8G3uPS99 vHB1aJoG6NC4
vaWKY/hvG5xmnYd/w590DYlqqdA5VQMVOi/KNlTogipLhY5VycFK0OMtUiFY VXKXEvRG21Eh
gKodFQKq6qkQdptyIP0LsdmrOlMmWrnRoaNMtBqFSJmYThQliUJ0mthudylR G3KtRAkRnlFM
mailunagTIRWVLd9KSU+q++kLiGC1tVJXUIEratrKRNTW6I6ykTwqnaUiRBU 7SkTgVV9pkyE
QZX0KETUHjvpUYioPXaBMhHlH9qmLhPbvUxgHrVtGLcnUwbd35clzbi8Kxnu bazHyOXpzdO8
ZZn0q/4AhljthAplbmRzdHJlYW0KZW5kb2JqCjQgMCBvYmo8PC9UeXBlL0Zv bnQvRGVzY2Vu
ZGFudEZvbnRzWzI1IDAgUl0vVG9Vbmljb2RlIDI2IDAgUi9CYXNlRm9udC9K TkRGUlYrQXJp
YWwtQm9sZE1UL1N1YnR5cGUvVHlwZTAvRW5jb2RpbmcvSWRlbnRpdHktSD4+ CmVuZG9iagoy
NyAwIG9iaiA8PC9GaWx0ZXIvRmxhdGVEZWNvZGUvTGVuZ3RoIDE5ODE0L0xl bmd0aDEgMzE1
MTI+PnN0cmVhbQp4nOy9eXxUVdYuvKcz1nRqrkol5GQOqYQEEhKCkRzGMAgJ YQwSiQoIokKC
gigtcSKAAzgBggq2ioitBhCIaEtUFHCCVnFAW7BlsjENrYAKpOpb+1SFwf7e 9773+333d/8x
YdU+e59pn7XXetaz9tkVEEYIKagRUaRdO+tmfei5iY9AyxMIiU9MnnHdjYNW 5VUgJPVASDh7
3Q1zJj+0rNe3CNmKEOp7xZRJV0981700jFBVI5xTPAUarNXy61BvgXr6lBtv vnXLmfaTUP8G
IfuJG6ZfezV6o5sVoQkfQv3kjVffOkOpsLUidBMI0mc0TJpR8+Tfz0H9AELW YmErCpmyBoVY
JgohFD3UIZFp0UN8X+SG6CFyBCGcGJP4z23oc5yFA+gUdqFXcBJ6H72KvsQ5 aC76CE9EPuRH
50g60rGARBRAI9E69D6WUA3aGP0BrUVj0I8Mo4fQAZyLRqMPsR20Mwo9iYZh b/RFdAyT6AG4
Qk9UhZZgjzBL+BLfhQRMyb3RfGSDM+9GHtQLdPgpnqtsiu5FJeiv7Irov9Fy HCA5yI5moMPo
BPQvj/QgtdEb0dVoHnoLi7Sv8Eg0F92EztH50WegJxIaAfedgO5Ay+CuvXAr eUWYiBJRORqI
BqNadCNag14ik4UTCCOCMtEN0Pcd6Ch+CX9Nj9LfmMyuYvcLGZFyuGcqKkQ9 4MkmoGvQTHQ/
Wo7exAgn42r8uNCt/U7QiQ5X6ArHNKK70EK0EfbasRN78Wj8JLmD7Cb/Yi8I X0Z3w1FFaBb0
6W70FnoXHUM/YRF3wQX4Lvwa/hvBZA45Q/Uoir6BslEFqkbj0Wx0J1qCHkcb 0BugzbfIUNqX
zqbN7Bg7G9mOrGgc9Ol2tBHtQnth3Fw4kWSSH2kKvZc+Qz+kp+BJ3OxuOPYA PEUB9PEK+B0B
zz8TxrkJPYieRi+izWgr9GcP+hv6Gh2CXvfA0/Bc/BR+HZ/GZ0gKSSVlZDp5 jDSTreQf1EeH
05G0ni6lK+h79FPmZH3YEPYk28z2iXniUenqyHOR76PDomOjd0Yfjr4efTv6 afRf4Cc26EEa
ykVTQdf18FzzQJMvozfhdyf6An2F9qFv0CGwOoStOIS748F4BB6Fb8AN+EG8 GD+Kl+N38cdE
JU7iJZWkilxH5pOdZDctpZfRFpbNurH+bBybxm5m84Vu8DtUuF9YK6wTXhRO COdEl7hORvKH
7Tnt30amRGZF/h5Vo/Zop2hBdGr0FBJQJxi9q9F1oJOVoJNnwTr+glrRdvQh aOUz6N036O/o
W7QfevgzOoc92IcD8BvCuWBbw/D1+FZ8J4zicrwSP4M34xb8Bn4Hf4T34L/h T/CX+Dv8D/xP
/C98glASJMkkjYTJBDKFzIPf+eQR8jhZQd4HO9lN9pDPyVHSRjWaSvNpD/gt o71pH7qIvkj3
MC/zg7Yr2S3sNtD4GtbK3mJ/Y98LSNAEt5Au5ApDhPuEVmGH+cx2MSBmijeJ d4v3iM+JLRKT
fFKxdJe0UFopPS19JnvkNHm1/Do8RTYO4gR00Q8ei99Dr9ArcA1uwiOxDS/C NchDwuhpVk8G
syfIYpJDXuRHiqWsmZf0BfQgxcTBltCH8KNoE8boMnQP7oVm44dhpN/DM8C6 ctEKuo1GyAAM
sICfxT3QabobMGkvaKsId8UVaDDZyT4WdoxvIunkKvwVu0pU2HvoEfI6q2Pd GQbdzgHYXUAf
QMXoX3QmPQhecSNbAh45FzN0ObkMnYTyc7AhDWeQLqgcD6JBXEUn4wR4Tn7u XkCJqWQ9KUfb
8aNkGs3Gt+Nu6BSKoI3CO+hxoZrtjQ5jm6I6tNxmKmMdXAeeEd9P61jn6JjI L7iJBshbNJNc
jn9iV5OpkZdxJS4ih2hXPJPcjM/ijTgbLOh9MpT0xgnkWbD9U+hHsKFz6N9o A3uEPhD9lr4Y
GU7eQOnCePQJIJqIhpOt+Gf0KeDpm2AVMmDuS6wYbaI3oRO0jrSQdvwL+QU9 hV4GFH6FZOGv
iYHaxAnsAD403Y470cmAaQQ9B6h8Df0X6h39DiXjm6O7o9twCPxlK+DSv4V3 yHT0MODFm4Ao
dwCOXQ3WfAOy4jngAXb43Qi2/xPggx+GRwAMvQn8dAXg5VbAi72AGkdh/zfo NPju4+hrglGV
+AT0/AR6G57vDJbRa6gbxAw7+NLB6Gn2CejuVbSQYvSO5BZ7sfnor8I2qZfR Z6RR3uvysst6
lvYoKe5eVNita0F+l7zccE7n7KzMjPS01BQ9uVNSYighGPD7vB63y6k57Dar RVVkSRQYhRvn
9k8bUKc3Z9Y1s8y0gQPzeD3tami4+qKGumYdmgZcekyzXmcepl96pAFHTv7d kUbsSOP8kVjT
y1BZXq7eP01v/qhfmt6Cxw0fC9sP9Eur0ZvbzO2h5jbLNCs2qKSkwBl6/8CU fnozrtP7Nw+Y
NWVR/7p+cL31FrVvWt9Jal4uWq9aYNMCW83+tBnrsb8XNjeIv3/P9QTJNuhV c0Jav/7NwbR+
vAvNNKP/1RObq4aP7d8vlJJSk5fbjPtem3ZNM0rr0+wIm4egvuZtmsW+zZJ5 G30qfxx0n74+
t3XR/S0auqYubJ2YNvHq8WOb6dU1/B7OMNy3X7P/toOBC1W4uKvv2KaL94bo ov6BqTqvLlrU
pDe3Dh978d4U/llTA9eAc0nGgLpFA+DW93MtBvKhI7z7/FFiDzUprT9vqbte b1bS+qRNWXR9
HQxIwqJmVD0nZUNCgvEa8IaE/vqikWPTUprLQ2k1V/dLXO9Bi6rnbAwaevDS PXm56zVnTJvr
7Y74htV28cak8/vMLfNwvjWk+rw6Me9R2iAwg2b9Wh16MjYNHqQH/5jUAy26 tgccBj81GM5q
ngjDMLVZ6Vu3SOvJ2/n5zUKGlqYvOoVg2NPafry05ep4i5ihnUJ8kxvHeQOD /R3bzeFwc04O
twupLwwk9LGXWe+elzurhYxOm6HpUID6UNVYOK2mZz7oPCWFj+p9LQa6BirN jcPHxuo6uia0
ARn54ZpmUsf3tHbs8Y7iexo79pw/vS4NzPdVxLmut1nOPP/Pofnc/af0bMa+ /2b3pNj+ISPS
hgwfN1bvv6gurtshIy+pxfb3OL8vvoVjO0DhzSwDNDUoDSyuetxY3gD/hIwB af2n1g0ED4M+
Nrv7jqUhUhPbIiFqXgrMdvz5K/PKWCu/FssQTbOf2EzBbM0GrA9o1uoGxj5r 1JSU//KcFkm+
6KSW6Al+lllcOC3+SM09w5fWL7ukfknvrIso9JdlkiEjxy1apF6ybwBg1KJF A9L0AYvqFl3d
Em28Jk3X0ha9Bmyw76IZ/es6Rr8luvW+UPOA+2vgIabgnmDZBPVZn4YXDF9v 4AUjxo19TYNs
YcHIsRuAbfat61OzPh32jX1NR8gwW8n5Vl7TeQ0NweAVG4hs7gq9ZiDUaO5l ZoNZv7YFI7NN
7mjD6NoWEmvTzDb4yUOIcEsBvgKEAeJL2asEbxGlFnLKCCCBbaFIldgWjIKy KGwhtFnZ9m0g
rJ0uay8bpp0sG9pehsphWzsHH10LUpwpzgz4wIihczptPWcI6CzSGSREGDVF htO5wqdIQ0OM
JAsQf7+aj8aQBYqoaJDY3GXHR5h6BilYacEZhs0+BjGNTWCUBZ33vAZcKBCG O9YObTtZ36Yd
1A6i8vKuBbgWp2WS7kWukuKSQpEQr8eFj71TXXl306g39m3bPTkvMnwbbnrm Q7xy74K9B4Bk
Fny7NHIQehOtg1g/yuxNleGwkUSiI9rowooLa84WfI1hhQ6pZxwKTo53yIqP 2MeUA9MjLMHV
gjevH8w7dBo6dPBkLe/S4ViP6mvdhT6X10MkUUordrm6F5F/mz0a/fq+N3dP zhU+fTNy658/
jEz6HHqEF+C/7V+GQ1w/lXg+2UxWwigUGWloUCWFHGwtwsCaDEzw9XQtgs5u Q8dBt6fZgFw+
CrUH22vrD6L82rauBe4UmrKQ5PVs/5SsjByD642DizZjL1wvw/CjQVQla4F5 rdUh6dgGjS+z
ATPj1wBdtscu8ChO7Bk5iL1wAdDR89EjtD/oiKLBhlfDGumH+4GJcaaokl9n YAys+mvDSn81
kOELFO2Gm7bgFRuY/u5r+CoYr4Sg1l4bTgi0naxtAzMpL+MDJuFCXEM+39ke Dgo/nvGA/aF7
okfYw0IrsB0d7uRUmSwyi2g76vvVJ3YmONSCEzcIAig90fBYbYGpSNZkIiek OqaiYMoby0zD
GNoWGwxU3lYO2kC1uNZdVOJChd34WKC0VJLh8RV2Kyl2A7/JTEuVRCreM2Q8 RJQNh56PHNyw
4QhOuKKsqtcIo3Bo2RWXjSkvxn//+/eQetkjkdPfRSyRU5hsnVU3+FqcdqTp pqsHXR85xRN1
YGuI+YClKugxIzQEDVUmoAl4giLkQhZULBSLo+lvisgEoQVPALfyiKIkoa3k JoSp37BQCntE
qyRqtLcF/xkxPBlJ5AFIv5uRSG5BmNQbTo1DeTmqRHUw8kFV9LdQz/qfA2HT HeqHHjzddrK9
LayVmRrWTraXNgldwn/StnNlo1q3O72kEKe4RfHnYjzzg1ciH0T27x13jA7G 6M9fnLmc/tqz
Dq4/F57iIRiBZDzYGA/PoiILZLI25BbnePAKN3blO/K1PH9Pf6WjUqv0VHor fWPcj7qfcW90
bw1sSm5VWy2t7k/dXwUOuA/5DvlPuk/5TvkTHE6Hy+F2eFiB3bC32vfYmb0F X284nTgJOXhb
s9kqQOtVmzWndQL0ZCtpQEkw3kzQtpJ65CCLDVvC1MVSVCJI0iQCyJSzOQVN 1bn1kekbNSd2
bsXDkA5KWWbaMxibdgo88iQ364O1AE+1ZU5XKdbaateLpO/IsZuszOlhdgSN 8K/G9FmIKK8h
W/TABlepqyX66wZnqdISbYVCjRWWWGGNFbZYYY8VbjhhvbUUhXE4/lMD5ldf izOKiwu7AV0W
JZGJErhXLwI4VRwzQJEkRY6k/vb6R/8cWH1Z5OSYbHyu+Ny99msffffRrAFF Y/r2m0z/nfPh
V9++OOaVun6/XVkYOXPDO2tffzA8rKHL4PHXgaamgNfcDmOWi34ycvRAP/Ha 0D2pLD9wVia6
PDphauKs8AoiWFWbI+gNgGmlZbpsktXBvShRU7Gar1aqB9QTKlMDgDJ1eAZu xCcww1tpZzg6
0XDk2BwBPD0wL7A4EA2wAG/3wsgkCTAGC7cUZFZmksw7XbANYKlrOtETugBK WlvwMsOxJLA6
QMBTg0uCzUEabMFPG5YlMGTQknfy57jHwlC11x6ujTmuiREwXvXmh7O0Nr++ DceGKD5SzkJn
YcyowbczfODNcVcuOb8pShmg4LjSffApiWmpmVOw21kz+Jo7p4z1Bbo57DNv Hd6n1zVJkTPd
apreff+T+bfUjp355K9b/43npdwy7p7rxk1lx8ktEyuqr7yp6M9j7vruyYaW cNcnRv15wda9
gFU9wFNuF7aCh9hwg/En1Rq0EokoVBaoSCXZIluJLUADgk/0SwGry2Z3lZEr SA2ZQtaR14mY
TUfQSWQ6rbPdThfSlXQNWSO/YG2hW9h2sovuo1+wL2SXIijWQcIgy0CrQIgN W2AMRZkpWBKY
YhORVcUSgZSLtuAxhmK1eaxWG1MgSE0wrKrVo6pWqkqKSFpowHCLhm2Pjdg+ lZJB+5gqqhUG
6PpNEFatmvJXwBkVBjsZEs51hi9fLVdXqXSeuk09rgLGT1AXq1RtIR8Z0IEE BwIjIeB0TZuq
bM1wzRZy4wa76m/Bj5twBGjUBmN5eCgMZ219e5vWFuaYdKi8zFWaX8u98LA5 nqVNJjw1dQmE
ZSgd8MMHGJeajojOu6KhaqVUc5YSEO5ZNebIp5TgQloopdEUtxuTOe3butHg r29tKNxQHvmp
YULkTzh8gq46N+lkZC9JxrsiJRyj7wJPWSWsQSmYGH3dhqXUA8IRrcxxmTbU MVS7yjFOm24/
KJ/2nvZZdayzbC3bo+uXa+XOcs8ybblzheeo83vXoYRTXofH623Brxg+zenR NEiDvdYAqjLd
5wB3HvwyEnHipmTbdAd2tJDFGw+YLjHO0AJu3VPuqfRs8+z27PeIHgC9jS4n U8CBNoQ2gx/V
b0JuzU3cva14GUpDHvIV8pJ05MDrkBOCgka+Mix4KgwDCqbGo149+M3BtvaD PIyf5DEWtJzf
Xguo1366tjSmbXuXsHA+HITD7gzR67nIYbJ43JfiSEUYuMtd2I+vHDT5+auG 9Zja9cf95Lvi
SLBvzsjOa79cFjn5yOv/xs8GPerkye/8ZfKUou4u0hY58w+3+x9vLo989dRP 4CFroofZSsCl
BJSN2owpsi5kke5y96w+cp+syfKUrFnyfHmpvNK3Rj4tn0n4Lc0uyliUVL9H 8sg5wRJ9gDTW
N1me6roejrxHfkx+Tv4863vxqO9wlhtMVU4NVWXgjEkaoBdRwagn4FV4P6ag +ac5bG0ICJ04
xDmctnyON/PQYnQACAuo13CnTnXYMLJpthm2RttxW9Qm2lrwFYaWE5pqeBu9 BHk17xIv9b5B
PkKd8WqyB5kRBdgd/+D2zekF4FMDUK5aHIcmU7MA9/VYyDSZhRRXJseezO4a SunmwzHyEdO5
yFZGfpb7lg4qHd61dsq6b1Ycbrz93Wl4PE569u327uP7jSwbPq53yYxyNtI3 ZkDPEa9dfnTn
qsihu27/8T28kKS/eu6Zm28aNnV9w40jNnHr/gwQ6ROwbgd61RjgAMtGIL8y rDj8DIgZrpAG
WAfYxwljxTGOyWyyNEuYY5tjn+O4V7jPvtDxOHvc8YJjp22n4wvpC2uCBaxW AWD5s6ERh27S
jm1oN9qPRMSDNMEMEISCMjeSBKfyBscPiNKcp1j5sRPQak5StK14DV7ZwdjB MgHihx40CQoY
qNaOnR3ODvboTpGAuYPWUgC6XSWfldAd4fHf/rVshCdy3NW3+vTL7EmsfDg4 8kXkoecOTr+p
9Ufc8gFnjdyrZ4OdBVAm+tio7Sn3zKiUp8lz5AXy4/Kjnp/Ib/LJwKkUqyJR b6KUKGdLmf7S
TiM9U+XrnLfJC+UV8gvyV9JX3q8yDtMfpB/kw4EfMnx3SLfJhJuZHpyQhtMm zVCxA2JlC/Vu
qsJLAP46zMxnS+Rm1lkTglNjbpuQrU81bFW2OtsSG7PdqZvRDig7QcGsN37u yF44PbnAVNtP
1nLLutiUuFZi0Q24Areg7kWcxAINTEnNxDHqGnPg4ruwjVtRj+qC2uvWfYMT fvh4X+SZyPfP
7yR7LxgRrvaNHlA64rWyIzsP4PGRz6Iockv7t9to9c03mkY0chPY0NvRw8Iv wPRDaIPRpRJS
EcNuOJjk9/vDSlgNewYKlY4Kz+BADRlHx1mXKuBFQXulY4KDOLbil5CLfGCo FpoP9mKAr/Gm
IDT1ZArKno63YVJpuinFdzqykV2zE/sHRhI+kIT1JCOpKqkuiSX5sg2pSqqT aAfLW7ExsbRb
h/vV1zaA3k7WxjkC11tph+fVYkFEaTpyFrnSC7sxv+mEIonpiN2GC2oiTxyP /Bz52wd4ymf/
wpkJkf2BhQ1/+uquF+645R2idfklchb3w0Vn8Kpvot8kNs5cHvnr082ty0Er IyEvfhdivQUd
NcJjlFV0lbTKwooVgxh0DGMy1lXdUoKYICsMAnAywpDOYFFoITsNhyTny5Vy s9wqM1mhDNog
syYqwP3OzRYkY6RJW0kfJAKFLO4u8k0L6bPJUOsA1raShxElfQx3FSRbkKzn kyrCVsHpCTb2
BuxTICxg0s9wtqI9iBSA0qtA7WVW5G8h69bfwIMxqA0SO25ptQ3ggRAewgdj SUI798IyTrCg
iOcKUpmZm9XWQqrAiaopI3E3Vl547vgA8kthuzKejioStp6KbDwVaTjFcacG IbGTqZ39RpfR
apWNyGwMGSOOkRiSZNkCihCIoqrJFtljschAZZIp80DKgzBXUFASC0QsMtVi IVRWZFlgRLYw
qslvkn5wUQafPM+sMTwTLLst+y10vwUjyyrYilqYpQXf8KphwzbSAke4W+ke SgqoQasopWVW
i5+amrgNNBG3ILCf+gZz4gC0YOoBPs0P1yWa4LSEK0QrK+NiagWDNri44ZNV tO9aGPkEkti8
WaRkNs6LfBz5hCxurxe2tr9Pis8MAH8fD8jUj5VDDO+KnzduvDV7fsJdoXsT F2ULLkZFHRVS
i2tAQr/QoKwFCQuzXkvYlfB1wtdZpzMtviDOL/ycHs0/WnCg8Fz4VP6pAjk9 2NNV45rqmhK8
Pfga2pKwj+wNfB48mvDPrGPZ9rFB3DU9kXayS06MUqLpOL0F+4yExALg+DMS 9yQeSBQSU+wO
lea588iJPJwHGcvGbsFys8z2xMo0l1kaiZ0c5XlZHgtCyYg44CMMeD4dLOwE klALTTc6pxhw
booBJ6YYcFaKAWc4UnAU9JLDJKlfciesddI7kU4tpL+RYK12FiI4gMxwtDoI cmgO3VHgiDoE
4EXlhlqogxGlO8w8rr8RyOnnN8q7T/DjAr/h3+3f72f+YLc+78dwsz5szvvU 8s2Gk23nYCgB
CKAZfnjK0MY3oDTNuq2e00kQl7+UzwRAuoAa6nE9EEtDw4YKAVItxYYCJUhH vnZRsub1+FMy
s8QY+BbzlC0Wt4GmiOfBtwQfiRwtOP7uR9udhTmByA9OVv7siHv+8tefP+rv GjxoaA3GCeEv
++QPvKz3zFIf+S3w4OrnZhfccPjNK/qN6NlrwJCXFizf7HYGytK79CqPvCGJ Cd3SL+/Wv/za
qaCU28F+7gH7CaHNRo9QCOdYa0gNnUam0dvJ7fQ2YUbSgtAr6AWyjv4l4YXQ BryJbHE2J7nD
ag8ykFAcRHaXAwhPqmEJZjFLsgNvM7loqlHuyrJIKB2X4+mYOHAyJlGM86Fa iRcDPm/DInb0
4wCt26k9IcmXzsFYl05ITDqU2Hm0icbx6FUKA9GQH4PjBviIpWgxd2kARGam 8jgi++KIHFcc
TcX+/pGfNnzwryU49aU3Dtgjx9WagSOWDB3fv38jXpK39e2fPnsJF63fvjqp ZuTcX264avJE
Hu3nRI8INYA2DpSIPjGWZYQqaV9rJYSkwYm3JkqXqT0DPUNjvVWdGjutQet8 O9ARdNT+C/qZ
/qbac9Rs72zXjE7MS8E2bQRjuy3BQtwC8duoHSOHQ7djjx22sOrOEiwJoCS7 A9SAqiHkY93M
jOlq3IyJhH1QL8BVWMCdtHQ+EaXLJwDhDyVhf+ePYsDbBogC2smP5T98Pqq8 A13AKv0d6WyT
XSvbbgZ8iGEpKSXi+WDvB6CJGZlpd4RlRU4Ehi2b8NxHWG/7fNpMnHyuZObI YU3D5w6/488z
h/T+7psofmIdyTh7uqFx2jeTZj4YOQoamw1WNAOsyI90/KXx0ALXomTiT8au +5QFtnvsbQpz
y5riU2minAAYHXAGve5kl14jy4u0puS/KpvtHypfK9/LkkVSXXzyT6Ma0zpp yf2S++vqaNtk
223Sra5bkxdKj+nPKM/Z3pC2ybvlr+Q96j7LD9Jx+Yz0m/yT52ziyWRf2LnA RcYkX5f8Z5Xq
cmCbjhdDktVCjht+hDVQJqniasZYdCVluSXlQ5nDUkZ2ES8Nb7BTUZWMKyFk mureAwoX5BZS
YRS6xCyrRZ6rfJgUeCBAkgI40A/5NJ/uo77GVD39brhkegx3TjiY41BKhwmb hL6toZ6nTO1m
vinGcFHkN87zx0qAOTGOj7zcAGAXm93hIAS4U97GESWYxEExyYCzkjgyJnFk TDLOH+zkngIB
prahDMcdpLYe8KYBMMm8tRb9dYMam25SS+VYYdaUWE2J1exmbb09hlgX8uGY W5UI3HxQ96KS
4hSOYhkd6R0b316A54xZDBoecvaJzyMn5zyHu71zOHIGX19T80AQb3Uq19/1 aHjlSuzYv2/d
4X9/NWW8W501a/7dYEFGZDg7CxaUgYrwEOM+vRg3+e/OJ8Vpw2xDUoflsEx/ dkFXVIhZ0JGJ
SYV/R+hEMV2U31j8Upe1+ayqeHb2jOJ7OjVlCz27VIQGdBqYOzYgZIWzu/Rw 9wiWhoU8d+du
JGC1WIJYQNaANS9Ag5aEUEi3BIEwBEOWzvaEoFiQ45U6Z9lVDenQJcQLYJg0 HQmxIRK4jdhB
3UJOisPSPTto0RJeJ6kAnkEy2NBDvZEl37LEQh0W3dJqodTiho0qy2rLNssJ iwQ84l0jVAxm
8mBmOnJqTt15wsmch7pb/Jbu6v0F3KPLT
Re: Avoid page break inside table row in pdf? [message #234341 is a reply to message #234120] Thu, 12 April 2007 18:19 Go to previous messageGo to next message
--------------030506020308090205060109
Jason Weathersby wrote:
> Bojan,
> problem.
> Jason
>> Hi all,
>> the end the page
>> This could be
>> in two parts"
>> Thanks,
>> Bojan
name="report.pdf"
8m
Re: Avoid page break inside table row in pdf? [message #234395 is a reply to message #234341] Thu, 12 April 2007 19:54 Go to previous messageGo to next message
I believe this is fixed now, but if you get an opportunity try using the
M6 download.
Jason
>> Bojan,
>> problem.
>> Jason
>>> Hi all,
>>> the end the page
>>> This could be
>>> in two parts"
>>> Thanks,
>>> Bojan
Re: Avoid page break inside table row in pdf? [message #234762 is a reply to message #234395] Mon, 16 April 2007 08:47 Go to previous messageGo to next message
Thanks Jason.
It is fixed in M6.
> M6 download.
> Thanks
> Jason
>> font problems).
>>> Bojan,
>>> problem.
>>> Jason
>>>> Hi all,
>>>> precise.
>>>> the end the page
>>>> This could be
>>>> in two parts"
>>>> Thanks,
>>>> Bojan
Re: Avoid page break inside table row in pdf? [message #364909 is a reply to message #234762] Thu, 28 August 2008 05:01 Go to previous message
Originally posted by: berni_hofer.destweb.net
hey guys,
i am using birt 2.3.0 and still have the same problem described above
with page breaks inside of rows.
do anybody have a solution for this problem?
cheers, bernhard
Bojan Milenkoski schrieb:
> Thanks Jason.
> It is fixed in M6.
>> M6 download.
>> Thanks
>> Jason
>>> font problems).
>>>> Bojan,
>>>> problem.
>>>> Jason
>>>>> Hi all,
>>>>> I have posted a similar question, but I'll ask again being more
>>>>> precise.
>>>>> REMINDER: I'm talking about pdf output.
>>>>> I have a table with multiple rows. When some row cannot be drawn at
>>>>> the end the page
>>>>> it is drawn partly on the this page and the rest on the next page.
>>>>> This could be
>>>>> desirable in some cases but not in all cases.
>>>>> Bruno Lowagie explained in another post:
>>>>>>> When using high-level objects, we're talking about PdfPTable.
>>>>>>> As described on p178-179 of the book 'iText in Action', the
>>>>>>> PdfPTable object has three options:
>>>>>>> (1) split the table BETWEEN rows (what you desire)
>>>>>>> (2) cut a row in two parts (what you experience)
>>>>>>> (3) omit a row that doesn't fit (I don't ever use this, but
>>>>>>> people asked for this and we implemented it).
>>>>>>> (1) is the default option;
>>>>>>> (2) can be set with setSplitLate(false);
>>>>>>> (3) can be set with setSplitRows(false);
>>>>>>> When using low level PDF functionality, it's up to the tool
>>>>>>> (in this case Eclipse/BIRT) to decide if the content is written
>>>>>>> on the current page, or if a new page is needed.
>>>>> So is it possible to "split the table BETWEEN rows" and not "cut a row
>>>>> in two parts"
>>>>> using BIRT? Or maybe it is a feature that isn't yet implemented?
>>>>> Thanks,
>>>>> Bojan
Previous Topic:remove theme problem (API)
Next Topic:BIRT 64 Bit Installation
Current Time: Mon Sep 08 14:21:03 EDT 2025
Powered by FUDForum. Page generated in 0.04140 seconds
