Home » Language IDEs » ServerTools (WTP) » Glassfishv3 Startup Failure
Glassfishv3 Startup Failure [message #233554] Mon, 13 July 2009 06:42 Go to next message
Originally posted by: chrisjames64.hotmail.co.uk
I installed Glassfish v3 and the server adapter into Eclipse 3.5. I
created a Glassfish v3 server instance using the default settings.
When I then try starting the Glassfish v3 server from within Eclipse it
fails with the following message...
"It appears that the domain [domain1] or some other process in [port:
4848] is already running, stop it first.
Command start-domain failed."
However, if I start the server from the Glassfish installation directory
via...
\glassfishv3\glassfish\bin\startserv.bat
....then it starts fine and Eclipse picks up the fact that it is running
and sets the status in the servers view to [Started, Synchronized].
I can then stop the server from within Eclipse, without a problem.
Any thoughts as to why the server startup from Eclipse doesn't work?
Many thanks
Chris
Re: Glassfishv3 Startup Failure [message #233655 is a reply to message #233554] Tue, 14 July 2009 09:46 Go to previous message
> via...
> Many thanks
> Chris
Sorted.
I had to remove \JDK1.6.0_14\bin\java.exe and javaw.exe from being
treated as an "Internet Browser" in my PC Security Suite settings.
It was okay to leave the jre and eclipse ticked as "Internet Browsers".
Previous Topic:Vex: "Insert Element" shortcut doesn't work
Next Topic:Strange Launcher Behavior
Current Time: Mon Aug 04 08:25:03 EDT 2025
Powered by FUDForum. Page generated in 0.03803 seconds
