After upgrading to 3.2, I can no longer "Display" the results from a scapbook page [message #233242] |
Tue, 25 July 2006 11:20  |
Originally posted by: markscottwright.gmail.com
I get this error:
(java.lang.String) org.eclipse.core.runtime.CoreException: Unable to
access archive
C:\tools\eclipse\plugins\org.eclipse.jdt.source_3.1.1\src\or g.junit_3.8.1\junitsrc.zip
The error is correct - that file doesn't exist. But why is it looking
for it? This only happens when I attempt to "Display" the results from
my code. I can display this, for example:
Integer.parseInt("1");
I don't get why eclipse wants to look at "junitsrc" anyway. Is it
attempting to generate a stack trace?
Mark
Re: After upgrading to 3.2, I can no longer "Display" the results from a scapbook page [message #233338 is a reply to message #233329] |
Wed, 26 July 2006 11:53  |
Markus Keller wrote:
> On 2006-07-25 17:33, Mark Wright wrote:
>> Mark Wright wrote:
>>> I get this error:
>>> access archive
>>> looking for it? This only happens when I attempt to "Display" the
>>> results from my code. I can display this, for example:
>>> Mark
>> Here's the stack trace from the error log:
>> !SUBENTRY 1 org.eclipse.debug.core 4 120 2006-07-25 10:31:20.140
>> !MESSAGE Unable to access archive
>> !STACK 0
>> java.util.zip.ZipException: The system cannot find the path specified
>> at java.util.zip.ZipFile.open(Native Method)
>> at java.util.zip.ZipFile.<init>(Unknown Source)
>> at
>> org.eclipse.debug.internal.core.sourcelookup.SourceLookupUti ls.getZipFile(SourceLookupUtils.java:63)
>> at
>> org.eclipse.debug.core.sourcelookup.containers.ExternalArchi veSourceContainer.getArchive(ExternalArchiveSourceContainer. java:199)
>> at
>> org.eclipse.debug.core.sourcelookup.containers.ExternalArchi veSourceContainer.findSourceElements(ExternalArchiveSourceCo ntainer.java:78)
>> at
>> org.eclipse.debug.core.sourcelookup.containers.CompositeSour ceContainer.findSourceElements(CompositeSourceContainer.java :78)
>> at
>> org.eclipse.debug.core.sourcelookup.containers.CompositeSour ceContainer.findSourceElements(CompositeSourceContainer.java :45)
>> at
>> org.eclipse.debug.core.sourcelookup.AbstractSourceLookupPart icipant.findSourceElements(AbstractSourceLookupParticipant.j ava:67)
>> at
>> org.eclipse.debug.core.sourcelookup.AbstractSourceLookupDire ctor$SourceLookupQuery.run(AbstractSourceLookupDirector.java :136)
>> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
>> at
>> org.eclipse.debug.core.sourcelookup.AbstractSourceLookupDire ctor.findSourceElements(AbstractSourceLookupDirector.java:72 1)
>> at
>> org.eclipse.jdt.internal.debug.core.JavaDebugUtils.resolveSo urceElement(JavaDebugUtils.java:262)
>> at
>> org.eclipse.jdt.internal.debug.ui.console.JavaStackTraceHype rlink.getSourceElement(JavaStackTraceHyperlink.java:130)
>> at
>> org.eclipse.jdt.internal.debug.ui.console.JavaStackTraceHype rlink.linkActivated(JavaStackTraceHyperlink.java:85)
>> at
>> org.eclipse.ui.console.TextConsoleViewer$2.handleEvent(TextC onsoleViewer.java:103)
>> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
>> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
>> at
>> org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3348)
>> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2968)
>> at
>> org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
>> at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
>> at
>> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
>> at
>> org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
>> at
>> org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
>> at
>> org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
>> at
>> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
>> at
>> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
>> at
>> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
>> at
>> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
>> at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
>> at java.lang.reflect.Method.invoke(Unknown Source)
>> at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
>> at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
>> at org.eclipse.core.launcher.Main.run(Main.java:977)
>> at org.eclipse.core.launcher.Main.main(Main.java:952)
> The stacktrace looks like
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=138877
> To avoid the problem you could try to update the source attachment path
> of JUNIT_HOME/junit.jar entries in your Java projects (context menu >
> Properties > Java Source Attachment).
> However, I would recommend you to remove references to the classpatch
> variable JUNIT_HOME altogether. In Eclipse 3.2 you can add a JUnit
> Library, which is much more stable:
> - on Java projects with JUNIT_HOME/junit.jar on the build path, open
> context menu > Properties > Java Build Path > Libraries
> - remove JUNIT_HOME/junit.jar
> - click 'Add Library...', choose JUnit and then JUnit 3.8.1
> HTH,
> Markus
Thank you! That fixed the problem. I'm so happy - I love Eclipse's
scratch pages!
FUDForum. Page generated in 0.05410 seconds
