Home » Language IDEs » C / C++ IDE (CDT) » GCC/GDB setup
GCC/GDB setup [message #232966] Tue, 14 April 2009 12:01 Go to next message
HI
how/where do I setup Mingw and gdb in eclipse? I downloaded and then? I
get this error while debug:
Error launching external scanner info generator (gcc -E -P -v -dD
Many thanks
Michael
Re: GCC/GDB setup [message #232986 is a reply to message #232966] Wed, 15 April 2009 03:09 Go to previous message
Hello again
the above questions were for vista64. I downloaded the current mingw but
couldn't find gdb.exe. so i deleted the mingw folder and copied to the
same place the mingw ( with gbd.exe ) from codeblocks. That version is a
little older, will that work? Do I have to set some paths? how? Why that
error as above?
In the linux setup, how should I link those?
opengl32.lib
glu32.lib
odbc32.lib
odbccp32.lib
Later I need a intel Mac setup. Any tips for that?
Many thanks and regards
Michael
Previous Topic:Problem of linking GSL lib in Eclipse
Next Topic:Using CDT 5 Parser
Current Time: Fri Aug 22 07:52:47 EDT 2025
Powered by FUDForum. Page generated in 0.04554 seconds
