Home » Language IDEs » ServerTools (WTP) » Eclipse and Jdom error
Eclipse and Jdom error [message #232856] Wed, 24 June 2009 05:17 Go to next message
Hi guys, thanks all for your help
i use eclipse ganymede (3.41) and i want to install fromework jdom,
i download jdom-1.1.zip, i am exstract this zip file in e:\jdom, i open
eclipse
and i go in Project propreties, build path, add exsternal jar file
I select jdom.jar.
Later i crete this easy project
package prova;
import java.io.FileWriter;
import org.eclipse.equinox.app.IApplication;
import org.eclipse.equinox.app.IApplicationContext;
import org.jdom.Document;
import org.jdom.Element;
import org.jdom.output.XMLOutputter;
* This class controls all aspects of the application's execution
public class Application implements IApplication {
/* (non-Javadoc)
* @see
org.eclipse.equinox.app.IApplication#start(org.eclipse.equin ox.app.IApplicationContext)
public Object start(IApplicationContext context) throws Exception {
Element carElement = new Element("auto");
carElement.setText("Hello Word");
Document doc =new Document(carElement);
XMLOutputter outputter =new XMLOutputter();
try
outputter.output(doc, new FileWriter("JDOMoutput.xml"));
catch(Exception e)
System.err.println(e);
return IApplication.EXIT_OK;
/* (non-Javadoc)
* @see org.eclipse.equinox.app.IApplication#stop()
public void stop() {
// nothing to do
but when i launch this application i ha this error:
!SESSION 2009-06-24
10:11:48.857 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_13
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=it_IT
Framework arguments: -application prova.application
Command-line arguments: -application prova.application -data
E:\work2/../runtime-prova.application -dev
file:E:/work2/.metadata/.plugins/org.eclipse.pde.core/prova. application/dev.properties -
os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 4 0 2009-06-24 10:11:49.357
!MESSAGE Application error
!STACK 1
java.lang.NoClassDefFoundError: org/jdom/Element
at prova.Application.start(Application.java:22)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
Caused by: java.lang.ClassNotFoundException: org.jdom.Element
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:481)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:397)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:385)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:87)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
... 14 more
where i mistake? can you help me?
bast regads
Antonio
Re: Eclipse and Jdom error [message #232875 is a reply to message #232856] Wed, 24 June 2009 08:57 Go to previous message
Originally posted by: dcarver.starstandard.org
Crossposting the newcomers newsgroup.
Dave
> eclipse
> I select jdom.jar.
> package prova;
> /* (non-Javadoc)
> * @see
> try
> catch(Exception e)
> /* (non-Javadoc)
> // nothing to do
> !SESSION 2009-06-24 10:11:48.857
> - os win32 -ws win32 -arch x86
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> ... 14 more
> bast regads
> Antonio
Previous Topic:displaying an image on JSP
Next Topic:Galileo and WebSphere CE
Current Time: Thu Nov 06 18:21:32 EST 2025
Powered by FUDForum. Page generated in 0.03684 seconds
