Home » Modeling » GMF (Graphical Modeling Framework) » How to make a Compartment become invisible when it is empty?
How to make a Compartment become invisible when it is empty? [message #232483] Fri, 05 June 2009 02:08 Go to next message
Hi people,
is there a way to make a Compartment become invisible when it is empty?
Thanks for all the help I'm getting here!
Alessander
Re: How to make a Compartment become invisible when it is empty? [message #232683 is a reply to message #232483] Fri, 05 June 2009 07:43 Go to previous messageGo to next message
Hi Alessander,
I don't know how other's do it, but I gave the figure that contains the
compartment a custom layout, which sets the compartment's size to 0 if
it is empty. However, for this I always check the model element to see
if it contains elements in that compartment. To do this I had to pass
the edit part that corresponds to the laid out figure to the very same
when it is created. Maybe there is an easier way to check if a
compartment is empty.
Matthias
Alessander Botti Benevides wrote:
> Hi people,
> Best regards,
> Alessander
Re: How to make a Compartment become invisible when it is empty? [message #232826 is a reply to message #232483] Sun, 07 June 2009 06:55 Go to previous messageGo to next message
I have never done it on my own but in gmfgen ,find your gen compartment
,find the "Hide If Empty" property and simply set it true.
It may work.
Re: How to make a Compartment become invisible when it is empty? [message #233128 is a reply to message #232826] Tue, 09 June 2009 11:34 Go to previous messageGo to next message
Thanks for the suggestion,
"Hide If Empty" was set true, but it don't makes the compartment invisible.
Re: How to make a Compartment become invisible when it is empty? [message #233136 is a reply to message #232683] Tue, 09 June 2009 11:44 Go to previous messageGo to next message
Hi Matthias, thank you very much!
But setting the compartment's size to 0 does not makes it totally
invisible in my case, maybe because it has a Stack Layout...
So, I have a different solution: Suppose my metamodel has an EClass named
"C" having an EReference named "attribute" which is the Containemnt
Feature of the compartment named "AttributeCompartment" in the gmfgraph
file:
(i) add "view.setVisible(false);" in the end of the method
decorateView(...) in CAttributeCompartmentViewFactory.java:
protected void decorateView(View containerView, View view, IAdaptable
semanticAdapter, String semanticHint, int index, boolean persisted) {
(ii) create a method handleNotificationEvent(Notification event) in
CEdidPart.java:
protected void handleNotificationEvent(Notification event) {
getPrimaryShape().updateContents();
super.handleNotificationEvent(event);
(iii) create the method updateContents() inside the class CFigure in
CEdidPart.java (substitute "???" for the name of your GMF project):
private void updateContents() {
CEditPart ceditpart = CEditPart.this;
C element = (C) ceditpart.resolveSemanticElement();
EditPart compartmentEditPart =
getChildBySemanticHint(???.diagram.part.???VisualIDRegistry. getType(???.diagram.edit.parts.CAttributeCompartmentEditPart .VISUAL_ID));
if (compartmentEditPart != null) {
if (element.getAttribute().size() == 0) \\ where getAttribute() refers to
EReference "attribute".
((View) compartmentEditPart.getModel()).setVisible(false);
else
((View) compartmentEditPart.getModel()).setVisible(true);
Best regards
Re: How to make a Compartment become invisible when it is empty? [message #233152 is a reply to message #232483] Tue, 09 June 2009 12:28 Go to previous message
You could try overriding the figure for compartment. Override isVisible()
method on the figure. Make it return false if children are empty. Children
of the compartment, however, won't be direct children... you'd have to go
down a couple of levels to reach them.
Alex
Previous Topic:Context Menu entry does not work when plug-in downloaded and installed
Next Topic:How to set Avoid obstructions and Closest distance on my connections by default.
Current Time: Wed Aug 20 16:21:46 EDT 2025
Powered by FUDForum. Page generated in 0.04632 seconds
