Home » Eclipse Projects » GEF » Drag child of figure
Drag child of figure [message #232082] |
Fri, 23 March 2007 09:51 |
Originally posted by: michele.l.evinco.it
I've a problem with the drag of a child Figure.
The situation is :
i've a figure that had size like the editor size where there's draw a
map the i drag objects from another view to the mapfigure so i add this
object like childs of mapfigure and the mapfigure is updated.
Now i want change the position of that child with an operation of drag.
The problem is that i can't understand how to manage the dragevent on
that figure.
i've tryed to implement the method getDragTracker on childEditPart and
i have installed an implementation class of XYLayoutEditPolicy on child
EditPart as EditPolicy.PRIMARY_DRAG_ROLE but the event never been captured.
What's the best way for implement the drag operation of child figure
written over another ?
Thank's
Michele
Re: Drag child of figure [message #232089 is a reply to message #232082] |
Fri, 23 March 2007 10:42 |
the only way that i find to get the drag event is to implement a
mouseMotionListener on the child figure but it's no good because i want
work with the editPart of figure to get the model to set the new coordinate
is there a better way to do this?
michele wrote:
> Hello,
> The situation is :
> a map the i drag objects from another view to the mapfigure so i add
> this object like childs of mapfigure and the mapfigure is updated.
> that figure.
> Thank's
> Michele
Re: Drag child of figure [message #232129 is a reply to message #232121] |
Fri, 23 March 2007 17:16 |
I've a model element and his relative editpart for the object that i'm
placing into the mapfigure.
I've installed an implementation class of XYLayoutEditPolicy on child
EditPart as EditPolicy.PRIMARY_DRAG_ROLE.
But the drag event never been raised.
Del Myers wrote:
> I'm confused: are you just adding a child figure to the parent, or do
> you have a model element for the object that you are placing into the
> mapfigure? Generally in GEF, what you would do is update your model to
> have a new object as a child of whatever is represented by the mapfigure
> in your view. Add the new object to your model, have a separate editpart
> for that model element (created by your editpart factory), and refresh
> the children of the editpart that the mapfigure is on.
> Once you have an editpart for the new object in your model, it can have
> its own edit policies for dragging, etc.
> Del
>> want work with the editPart of figure to get the model to set the new
>> coordinate
>> michele wrote:
>>> Hello,
>>> The situation is :
>>> draw a map the i drag objects from another view to the mapfigure so i
>>> add this object like childs of mapfigure and the mapfigure is updated.
>>> that figure.
>>> child EditPart as EditPolicy.PRIMARY_DRAG_ROLE but the event never
>>> been captured.
>>> Thank's
>>> Michele
Re: Drag child of figure [message #232201 is a reply to message #232137] |
Mon, 26 March 2007 14:01 |
i've tried with NonResizableEditPolicy installed in childEditPart as
DIRECT_EDIT_ROLE but understandsReuest() never been called.
After i've tried to install NonResizableEditPolicy in mapEditPart and
here the understandsReuest() is called.
So I think that this method works only for editpart directly draw on
rootEditPart!
But I can't find the method for editpart drawn over another editPart
that isn't rooteditpart!
Del Myers wrote:
> Try something like NonResizableEditPolicy.
> The roles don't matter that much. I don't really understand why they are
> there. What you need is an edit policy that understands the REQ_MOVE
> request in the understandsReuest() method.
>>> to have a new object as a child of whatever is represented by the
>>> mapfigure in your view. Add the new object to your model, have a
>>> separate editpart for that model element (created by your editpart
>>> factory), and refresh the children of the editpart that the mapfigure
>>> is on.
>>> have its own edit policies for dragging, etc.
>>> Del
>>>> new coordinate
>>>> michele wrote:
>>>>> Hello,
>>>>> The situation is :
>>>>> i add this object like childs of mapfigure and the mapfigure is
>>>>> updated.
>>>>> drag.
>>>>> on that figure.
>>>>> been captured.
>>>>> figure written over another ?
>>>>> Thank's
>>>>> Michele
Re: Drag child of figure [message #232252 is a reply to message #232223] |
Tue, 27 March 2007 08:32 |
--------------060508030003060409040702
Content-Type: text/plain; charset=us-ascii; format=flowed
In attachment there's the code .
Del Myers wrote:
> It should work for objects not inside the root edit part. Can you post
> your editpart factory, and your childEditpart code?
>> rootEditPart!
>>> are there. What you need is an edit policy that understands the
>>> REQ_MOVE request in the understandsReuest() method.
>>>> i'm placing into the mapfigure.
>>>> child EditPart as EditPolicy.PRIMARY_DRAG_ROLE.
>>>>> do you have a model element for the object that you are placing
>>>>> into the mapfigure? Generally in GEF, what you would do is update
>>>>> your model to have a new object as a child of whatever is
>>>>> represented by the mapfigure in your view. Add the new object to
>>>>> your model, have a separate editpart for that model element
>>>>> (created by your editpart factory), and refresh the children of the
>>>>> Del
>>>>>> new coordinate
>>>>>> michele wrote:
>>>>>>> Hello,
>>>>>>> The situation is :
>>>>>>> there's draw a map the i drag objects from another view to the
>>>>>>> mapfigure so i add this object like childs of mapfigure and the
>>>>>>> drag.
>>>>>>> dragevent on that figure.
>>>>>>> childEditPart and
>>>>>>> Thank's
>>>>>>> Michele
name="CodeExample.txt"
Content-Disposition: inline;
filename="CodeExample.txt"
This is the EditPartFactory registered to my GraphicaViewer --> viewer.setEditPartFactory(new MapEditPartFactory());
public class MapEditPartFactory implements EditPartFactory {
public EditPart createEditPart(EditPart context, Object model) {
EditPart returnValue = null;
if(model instanceof MapRootElement) {
MapRootEditPart mrep = new MapRootEditPart();
returnValue = mrep;
}else if (model instanceof it.evinco.horusstandalone.views.editor.model.AntennaModel){
try{
returnValue = new it.evinco.horusstandalone.views.editor.parts.AntennaEditPart ();
}catch(Exception e){
e.printStackTrace();
returnValue.setModel(model);
}else if (model instanceof it.evinco.horusstandalone.views.editor.model.AmbientiModel){
returnValue = new AmbientiEditPart();
}else{
throw new IllegalArgumentException();
return returnValue;
This is the childEditpart that extends AbstractEditPart that extends AbstractGraphicalEditPart :
public class AntennaEditPart extends AbstractEditPart {
private EditPart parentEditPart = null;
public AntennaEditPart() {
super();
public void configureNode(Node node) {
Rectangle newBounds = getFigure().getBounds();
newBounds.setSize(getFigure().getPreferredSize());
node.width = newBounds.width;
node.height = newBounds.height;
node.data = this;
protected IFigure createFigure() {
IFigure returnValue = null;
AntennaFigure antennaFigure = new AntennaFigure();
return antennaFigure;
private AntennaFigure getCastedFigure() {
return (AntennaFigure) getFigure();
protected void refreshVisuals() {
super.refreshVisuals();
protected void createEditPolicies() {
installEditPolicy(EditPolicy.DIRECT_EDIT_ROLE, new AntennaDragPolicy());
installEditPolicy(EditPolicy.SELECTION_FEEDBACK_ROLE,new SelectionFeedbackEditPolicy(1));
protected AntennaModel getCastedModel() {
return (AntennaModel) super.getCastedModel();
public ConnectionAnchor getSourceConnectionAnchor(ConnectionEditPart arg0) {
return null;
public ConnectionAnchor getSourceConnectionAnchor(Request arg0) {
return null;
public ConnectionAnchor getTargetConnectionAnchor(ConnectionEditPart arg0) {
return null;
public ConnectionAnchor getTargetConnectionAnchor(Request arg0) {
return null;
public DragTracker getDragTracker(Request req)
System.out.println("Called HelloTopEditPart.getDragTracker() with req="+req);
if (m_dragTracker==null) {
m_dragTracker = new DragEditPartsTracker(this);
return m_dragTracker;
static DragTracker m_dragTracker = null;
this is AbstractEditPart :
public abstract class AbstractEditPart extends AbstractGraphicalEditPart implements PropertyChangeListener {
protected Label textLabel;
public void activate() {
if (!isActive()) {
super.activate();
getCastedModel().addPropertyChangeListener(this);
public void deactivate() {
if (isActive()) {
super.deactivate();
getCastedModel().removePropertyChangeListener(this);
protected abstract IFigure createFigure();
protected AbstractBaseElement getCastedModel() {
return (AbstractBaseElement) getModel();
public void propertyChange(PropertyChangeEvent evt) {
refresh();
public abstract void configureNode(Node node);
protected void refreshAllParts() {
refresh(getRoot().getChildren());
getRoot().refresh();
private void refresh(List pChildren){
for (Iterator i = pChildren.iterator(); i.hasNext();) {
AbstractEditPart p = (AbstractEditPart) i.next();
p.refresh();
refresh(p.getChildren());
And this is AntennaDragPolicy:
public class AntennaDragPolicy extends NonResizableEditPolicy {
public boolean understandsRequest(Request arg0) {
System.out.println("understandsRequest");
return super.understandsRequest(arg0);
public Command getCommand(Request arg0) {
System.out.println("getCommand");
return super.getCommand(arg0);
--------------060508030003060409040702--
Re: Drag child of figure [message #232289 is a reply to message #232252] |
Tue, 27 March 2007 17:49 |
Del Myers Messages: 82 Registered: July 2009 |
Member |
I imagine that your AmbientiEditPart is the parent for your AntennaEditPart.
Does AmbientiEditPart have an instance of XYLayoutEditPolicy installed on it? If
it does, you should be okay. Just make sure that the command that your
XYLayoutEditPolicy sets the constraints properly. Look for other examples of how
to use it.
Del
>>> rootEditPart!
>>>>>> Del
>>>>>>> i want work with the editPart of figure to get the model to set
>>>>>>> the new coordinate
>>>>>>> michele wrote:
>>>>>>>> Hello,
>>>>>>>> The situation is :
>>>>>>>> of drag.
>>>>>>>> childEditPart and
>>>>>>>> on child EditPart as EditPolicy.PRIMARY_DRAG_ROLE but the event
>>>>>>>> Thank's
>>>>>>>> Michele
> returnValue = mrep;
> try{
> }else{
> return returnValue;
> super();
> @Override
> node.data = this;
> @Override
> @Override
> @Override
> return null;
> return null;
> return null;
> return null;
> if (!isActive()) {
> super.activate();
> if (isActive()) {
> super.deactivate();
> refresh();
> p.refresh();
> @Override
> @Override
Re: Drag child of figure [message #232312 is a reply to message #232289] |
Wed, 28 March 2007 09:38 |
I've still try this solution but it isn't ok for me.
if i install myXYLayoutPolicy on AmbientiEditPart i intercept all events
of mousedown and drag on the AmbientiFigure and i can't find the
childFigure (AntennaFigure) and her EditPart on the request.
This is bad for me because i want move the figure of "AntennaFigure" and
register her new position in her model so i must install a policy on
AntennaEditPart to obtain, on the event the relative EditPart by the
function getHost().
If I do that, install a policy on AntennaEditPart (the childEditPart),
the events never fired so the policy is never been called.
So i think that isn't possible with GEF to move a figure that is drawn
on a parent figure by a drag operation, or more probabily i can't
understand how to do this.
this is the way i draw the childFigure (AntennaFigure) on the
refreshVisuals method of AmbientiEditPart :
Iterator it = getModelChildren().iterator();
while (it.hasNext()){
AntennaModel am = (AntennaModel)it.next();
AntennaEditPart aep = new AntennaEditPart();
AntennaFigure antennaFigure = (AntennaFigure)aep.createFigure();
getFigure().add(antennaFigure,new
Rectangle(am.getLocation().x,am.getLocation().y,16,16));
> AntennaEditPart. Does AmbientiEditPart have an instance of
> XYLayoutEditPolicy installed on it? If it does, you should be okay. Just
> make sure that the command that your XYLayoutEditPolicy sets the
> constraints properly. Look for other examples of how to use it.
> Del
>>> post your editpart factory, and your childEditpart code?
>>>> and here the understandsReuest() is called.
>>>> rootEditPart!
>>>>> they are there. What you need is an edit policy that understands
>>>>> the REQ_MOVE request in the understandsReuest() method.
>>>>>>> or do you have a model element for the object that you are
>>>>>>> placing into the mapfigure? Generally in GEF, what you would do
>>>>>>> is update your model to have a new object as a child of whatever
>>>>>>> is represented by the mapfigure in your view. Add the new object
>>>>>>> to your model, have a separate editpart for that model element
>>>>>>> can have its own edit policies for dragging, etc.
>>>>>>> Del
>>>>>>>> the new coordinate
>>>>>>>> michele wrote:
>>>>>>>>> Hello,
>>>>>>>>> The situation is :
>>>>>>>>> of drag.
>>>>>>>>> childEditPart and
>>>>>>>>> Thank's
>>>>>>>>> Michele
>> EditPart returnValue = null; if(model
>> returnValue = mrep;
>> try{
>> returnValue = new
>> returnValue.setModel(model); }else{
>> return returnValue;
>> super();
>> } @Override
>> node.data = this;
>> @Override
>> IFigure returnValue = null; AntennaFigure
>> @Override
>> @Override
>> return null;
>> return null;
>> return null;
>> return null;
>> with req="+req);
>> if (!isActive()) {
>> super.activate();
>> getCastedModel().addPropertyChangeListener(this); }
>> if (isActive()) {
>> super.deactivate();
>> refresh();
>> p.refresh();
>> @Override
>> @Override
Re: Drag child of figure [message #232345 is a reply to message #232312] |
Wed, 28 March 2007 16:28 |
Member |
It is definitely possible to do; I do it all the time.
Your problem here is that you are trying to move figures around inside the
refreshVisuals of the parent, rather than setting constraints on the children.
The refreshVisuals() of your AmbientiEditPart should have nothing to do with
that. What is probably happening here is that you are setting the bounds of a
figure, but you also have an XYLayout on the parent, which lays-out the children
based on rectangle constraints on the figure.
Also, your edit parts shouldn't be added to the parents within any code that you
write in your edit part. That is the job of the factories. What you should be
doing is listening for additions/subtractions of children in your model, and
calling refresh() on you AmbientiEditPart whenever these kinds of changes
happen. This will cause all of the edit parts to be added/subtracted to/from the
hierarchy and be activated, added to the required maps, etc. If you don't let
GEF take care of that, your child edit parts will never get any notifications
because GEF doesn't know about their existence. Typically, your model should
follow a publisher/subscriber pattern. In the activate() method of your
AmbientiEditPart, you would subscribe your AmbientiEditPart as a listener to
your AmbientiModel. When additions/subtractions of AntennaModel elements happen,
you would call refresh() on AmbientiEditPart.
Your AntennaEditPart, then, would do the same sort of thing, except it would
listen to changes in location (for when drag events occur). When you discover
changes in location in your AntennaModel, you call refreshVisuals() in
AntennaEditPart. Your refreshVisuals() would do something like this:
refreshVisuals() {
AntennaModel model = (AntennaModel)getModel();
IFigure figure = getFigure();
Rectangle rect = new Rectangle(model.getLocation().x, model.getLocation().y,
16, 16).
getParent().setLayoutConstraint(this, figure, rect);
This assumes that you have an instance of XYLayout as your layout manager in the
figure for your AmbientiEditPart.
You should look over some of the examples that come with GEF. It can be hard to
understand at first because it isn't well documented. There are a lot of little
methods that you won't know about unless you stumble across them. They typically
do everything that you want, but you just don't know about them. Looking over
the examples again will probably help you to find all of that stuff.
I hope this helps.
Del
> function getHost().
>> Just make sure that the command that your XYLayoutEditPolicy sets the
>> Del
>>>>> as DIRECT_EDIT_ROLE but understandsReuest() never been called.
>>>>> on rootEditPart!
>>>>> editPart that isn't rooteditpart!
>>>>>>> that i'm placing into the mapfigure.
>>>>>>>> Del
>>>>>>>>> a mouseMotionListener on the child figure but it's no good
>>>>>>>>> because i want work with the editPart of figure to get the
>>>>>>>>> michele wrote:
>>>>>>>>>> Hello,
>>>>>>>>>> The situation is :
>>>>>>>>>> of drag.
>>>>>>>>>> childEditPart and
>>>>>>>>>> Thank's
>>>>>>>>>> Michele
>>> returnValue = mrep;
>>> try{ returnValue = new
>>> return returnValue;
>>> private EditPart parentEditPart = null; public
>>> AntennaEditPart() {
>>> super();
>>> } @Override
>>> node.data = this;
>>> @Override
>>> @Override
>>> @Override
>>> return null;
>>> return null;
>>> return null;
>>> return null;
>>> if (!isActive()) {
>>> super.activate();
>>> if (isActive()) {
>>> super.deactivate();
>>> refresh();
>>> p.refresh();
>>> @Override
>>> @Override
Re: Drag child of figure [message #232438 is a reply to message #232345] |
Fri, 30 March 2007 10:42 |
Thank's Del, now it works.
The drag events are routed to AntennaEditPart.
thank's for you patience and your suggestions
> the refreshVisuals of the parent, rather than setting constraints on the
> children. The refreshVisuals() of your AmbientiEditPart should have
> nothing to do with that. What is probably happening here is that you are
> setting the bounds of a figure, but you also have an XYLayout on the
> parent, which lays-out the children based on rectangle constraints on
> the figure.
> that you write in your edit part. That is the job of the factories. What
> you should be doing is listening for additions/subtractions of children
> in your model, and calling refresh() on you AmbientiEditPart whenever
> these kinds of changes happen. This will cause all of the edit parts to
> be added/subtracted to/from the hierarchy and be activated, added to the
> required maps, etc. If you don't let GEF take care of that, your child
> edit parts will never get any notifications because GEF doesn't know
> about their existence. Typically, your model should follow a
> listener to your AmbientiModel. When additions/subtractions of
> AntennaModel elements happen, you would call refresh() on AmbientiEditPart.
> would listen to changes in location (for when drag events occur). When
> you discover changes in location in your AntennaModel, you call
> refreshVisuals() in AntennaEditPart. Your refreshVisuals() would do
> refreshVisuals() {
> model.getLocation().y, 16, 16).
> manager in the figure for your AmbientiEditPart.
> hard to understand at first because it isn't well documented. There are
> a lot of little methods that you won't know about unless you stumble
> across them. They typically do everything that you want, but you just
> don't know about them. Looking over the examples again will probably
> I hope this helps.
> Del
>> events of mousedown and drag on the AmbientiFigure and i can't find
>> the childFigure (AntennaFigure) and her EditPart on the request.
>> and register her new position in her model so i must install a policy
>> on AntennaEditPart to obtain, on the event the relative EditPart by
>> the function getHost().
>>> Del
>>>>>> on rootEditPart!
>>>>>>>>> whatever is represented by the mapfigure in your view. Add the
>>>>>>>>> new object to your model, have a separate editpart for that
>>>>>>>>> Del
>>>>>>>>>> michele wrote:
>>>>>>>>>>> Hello,
>>>>>>>>>>> The situation is :
>>>>>>>>>>> the mapfigure so i add this object like childs of mapfigure
>>>>>>>>>>> operation of drag.
>>>>>>>>>>> childEditPart and
>>>>>>>>>>> XYLayoutEditPolicy on child EditPart as
>>>>>>>>>>> Thank's
>>>>>>>>>>> Michele
>>>> returnValue = mrep;
>>>> return returnValue;
>>>> AntennaEditPart() {
>>>> super();
>>>> } @Override
>>>> node.data = this;
>>>> @Override
>>>> @Override
>>>> @Override
>>>> return null;
>>>> return null;
>>>> return null;
>>>> return null;
>>>> } public DragTracker getDragTracker(Request req)
>>>> if (!isActive()) {
>>>> super.activate();
>>>> if (isActive()) {
>>>> super.deactivate();
>>>> refresh();
>>>> p.refresh();
>>>> @Override
>>>> @Override
Current Time: Fri Apr 26 02:18:39 GMT 2024
Powered by FUDForum. Page generated in 0.03865 seconds
