Home » Eclipse Projects » GEF » MultiPageEditorPart and Actions
MultiPageEditorPart and Actions [message #231972] |
Wed, 21 March 2007 15:09 |
Originally posted by: johan.piculell.ericsson.com
Hello. I have really tried to get my actions to work in my
MultiPageEditorPart for several hours and it drives me crazy. Could
someone give me a hint or point to some decent examples ion this?
My design seems quite common to me, a MultiPageEditorPart consisting of
two editors, one TextEditor and one subclassed GraphicalEditor. I want, as
one example, to have a delete button that deletes text in the TextEditor
(this works) and graphical objects in the GraphicalEditor. But I cannot
even get deletion of graphical objects to work at all. My problem seems to
boil down to that I have no idea about how to get the actions to work in
the GraphicalEditor once it is embedded in the MultiPageEditorPart.
Re: MultiPageEditorPart and Actions [message #231980 is a reply to message #231972] |
Thu, 22 March 2007 03:10 |
Originally posted by: none.unknown.com
There are known issues with getting actions to work in a MPEP. Search this
newsgroup.
"Johan" <johan.piculell@ericsson.com> wrote in message
news:41dc9efee689ae47c50c7ca5a3b3b3fc$1@www.eclipse.org...
Re: MultiPageEditorPart and Actions [message #232010 is a reply to message #231980] |
Thu, 22 March 2007 07:04 |
I know there are issues because I have searched this group, and also seen
the answer "search this group" before. But my problem is not very
specific, it is more of the sort that I have no idea at all how you should
design your MPEP and I cannot find any good examples. Does anyone know of
a very simple example that you can use to get an idea of the whole thing?
regards
/Johan
> newsgroup.
Re: MultiPageEditorPart and Actions [message #232018 is a reply to message #231980] |
Thu, 22 March 2007 09:59 |
I could also put my question like this:
For some reason, undo/redo works just as I want it to from a contextmenu
that I made. Functionality 100% correct in both text editor and graphical
editor and they don't interfere with each other. But delete does not work
at all apart from being able to delete from the text with the "del" button
no matter which editor I'm looking at. How come redo/undo automagically
works, but I cannot get delete to work at all (it is disabled in my
graphical editor contextmenu)?
regards
/Johan
> newsgroup.
Re: MultiPageEditorPart and Actions [message #232026 is a reply to message #232018] |
Thu, 22 March 2007 11:03 |
Originally posted by: prashanto.chatterjee.softwareag.com
Hi Johan,
I have struggled a lot with Multi-page editors and I guess, since I have a
working application, I can share a few points with you.
1. Specify the following in your multi-page editor's ActionBarContributor:
/* (non-JavaDoc)
* Method declared in AbstractMultiPageEditorActionBarContributor.
public void setActivePage(IEditorPart part) {
IActionBars actionBars = getActionBars();
if (actionBars != null) {
actionBars.clearGlobalActionHandlers();
if(part instanceof GraphicalEditor){
ActionRegistry registry = (ActionRegistry)
part.getAdapter(ActionRegistry.class);
for (int i = 0; i < globalActionKeys.size(); i++) {
String id = (String) globalActionKeys.get(i);
actionBars.setGlobalActionHandler(id, registry.getAction(id));
}else if(part instanceof ITextEditor){
ITextEditor editor = (part instanceof ITextEditor) ? (ITextEditor) part
: null;
ActionFactory.DELETE.getId(),
getTextAction(editor, ITextEditorActionConstants.DELETE));
ActionFactory.UNDO.getId(),
getTextAction(editor, ITextEditorActionConstants.UNDO));
ActionFactory.REDO.getId(),
getTextAction(editor, ITextEditorActionConstants.REDO));
ActionFactory.CUT.getId(),
getTextAction(editor, ITextEditorActionConstants.CUT));
ActionFactory.COPY.getId(),
getTextAction(editor, ITextEditorActionConstants.COPY));
ActionFactory.PASTE.getId(),
getTextAction(editor, ITextEditorActionConstants.PASTE));
ActionFactory.SELECT_ALL.getId(),
getTextAction(editor, ITextEditorActionConstants.SELECT_ALL));
ActionFactory.FIND.getId(),
getTextAction(editor, ITextEditorActionConstants.FIND));
IDEActionFactory.BOOKMARK.getId(),
getTextAction(editor, IDEActionFactory.BOOKMARK.getId()));
//update the action bars
actionBars.updateActionBars();
What you have above is basically standard code; only difference being that
you update actions based on the currently active editor?
If Undo-Redo works for you then you probably have this in your code.
2. Update your selection in the graphical editor as:
/* (non-Javadoc)
* @see
org.eclipse.gef.ui.parts.GraphicalEditor#selectionChanged(or g.eclipse.ui.IWorkbenchPart,
org.eclipse.jface.viewers.ISelection)
public void selectionChanged(IWorkbenchPart part, ISelection selection) {
// If not the active editor, ignore selection changed.
if(getSite().getPage().getActiveEditor() == myMPE &&
myMPE.getActiveEditor() == this){
updateActions(getSelectionActions());
I found the above code while searching the newsgroup. This solved my
problem.
Hope this helps.
Prashanto
news:4725aee8a782ccb042e07a115ec1a7dc$1@www.eclipse.org...
> regards
> /Johan
>> this newsgroup.
>>> as one example, to have a delete button that deletes text in the
>>> TextEditor (this works) and graphical objects in the GraphicalEditor.
>>> But I cannot even get deletion of graphical objects to work at all. My
>>> problem seems to boil down to that I have no idea about how to get the
>>> actions to work in the GraphicalEditor once it is embedded in the
Re: MultiPageEditorPart and Actions [message #232033 is a reply to message #232026] |
Thu, 22 March 2007 13:04 |
Thanks a ton Prashanto! Now I'm getting at least some progress.
A few more questions then,
I assume "myMPE" is an MultiPageEditorPart, but how can you call
myMPE.getActiveEditor()? This method is protected, what eclipse version
are you running?
Apart from this I have managed to get delete working, but the "del" key
only works in the graphical editor until I display the text editor, then
text editor overrides the key and all "del" key events goes to the text
editor. Guess I need to reset this somewhere when changing back to
graphical editor?
And I still cannot get copy/paste/cut to work in the graphical part, but
this might be out of the scope for this discussion since I probably miss
some fundamental stuff here.
thanks and regards
/Johan
Prashanto Chatterjee wrote:
> Hi Johan,
> /* (non-JavaDoc)
> : null;
> /* (non-Javadoc)
> * @see
> problem.
> Hope this helps.
> Regards,
> Prashanto
>> regards
>> /Johan
>>> this newsgroup.
Re: MultiPageEditorPart and Actions [message #232042 is a reply to message #232033] |
Thu, 22 March 2007 13:35 |
Hi Johan,
About the method being protected; just override it and change the modifier
to public ;-)
About 'del' key not working once you switch to text-editor, I have a post to
the group for which I couldn't get any answer :-(. Maybe we can get cracking
at it now together.
About cut, copy and paste use the following code in your GraphicalEditor
implementation:
/* (non-Javadoc)
* @see org.eclipse.gef.ui.parts.GraphicalEditor#createActions()
protected void createActions() {
super.createActions();
ActionRegistry registry = getActionRegistry();
IAction actionCut;
actionCut = new CutAction(this);
actionCut.setId(ActionFactory.CUT.getId());
registry.registerAction(actionCut);
getSelectionActions().add(actionCut.getId());
IAction actionCopy;
actionCopy = new CopyAction(this);
actionCopy.setId(ActionFactory.COPY.getId());
registry.registerAction(actionCopy);
getSelectionActions().add(actionCopy.getId());
IAction actionPaste;
actionPaste = new PasteAction(this);
actionPaste.setId(ActionFactory.PASTE.getId());
registry.registerAction(actionPaste);
getSelectionActions().add(actionPaste.getId());
You would need to write your own implementation for cut, copy and paste
depending on the model that you use.
Prashanto
news:8b40c4b04da75232776d3260674a1298$1@www.eclipse.org...
> Thanks a ton Prashanto! Now I'm getting at least some progress. A few more
> questions then,
> are you running?
> graphical editor?
> thanks and regards
> /Johan
>> Hi Johan,
>> a working application, I can share a few points with you.
>> /* (non-JavaDoc)
>> part : null;
>> that you update actions based on the currently active editor?
>> /* (non-Javadoc)
>> * @see
>> problem.
>> Hope this helps.
>> Regards,
>> Prashanto
>>> graphical editor and they don't interfere with each other. But delete
>>> does not work at all apart from being able to delete from the text with
>>> the "del" button no matter which editor I'm looking at. How come
>>> redo/undo automagically works, but I cannot get delete to work at all
>>> (it is disabled in my graphical editor contextmenu)?
>>> regards
>>> /Johan
>>>> this newsgroup.
>>>>> of two editors, one TextEditor and one subclassed GraphicalEditor. I
>>>>> want, as one example, to have a delete button that deletes text in the
Re: MultiPageEditorPart and Actions [message #232050 is a reply to message #232042] |
Thu, 22 March 2007 15:00 |
Thank you, thank you, thank you!!
Now I'm back on track, now let's hope someone picks up our silent cry for
help on the key registration thing.
/Johan
> Hi Johan,
> to public ;-)
> at it now together.
> implementation:
> /* (non-Javadoc)
> IAction actionCut;
> IAction actionCopy;
> Regards,
> Prashanto
>> questions then,
>> are you running?
>> graphical editor?
>> thanks and regards
>> /Johan
>>> Hi Johan,
>>> /* (non-JavaDoc)
>>> part : null;
>>> /* (non-Javadoc)
>>> * @see
>>> problem.
>>> Hope this helps.
>>> Regards,
>>> Prashanto
>>>> regards
>>>> /Johan
>>>>> this newsgroup.
Re: MultiPageEditorPart and Actions [message #234214 is a reply to message #232050] |
Tue, 15 May 2007 15:35 |
Originally posted by: rudolf.hornig.gmail.com
put the following code in your GrahicalEditor.configureGrahicalViewer:
String id = ActionFactory.UNDO.getId();
getEditorSite().getKeyBindingService().registerAction(regist ry.getAction(id));
id = ActionFactory.REDO.getId();
id = ActionFactory.DELETE.getId();
this will register the commands belonging ti UNDO/REDO/DELETE to the
graphical editor too. It seems that the text editor steals the key
bindings when activated, and does not restore the original state when
deactivated.
Rudolf
> for help on the key registration thing.
> /Johan
>> Hi Johan,
>> modifier to public ;-)
>> post to the group for which I couldn't get any answer :-(. Maybe we
>> can get cracking at it now together.
>> GraphicalEditor implementation:
>> /* (non-Javadoc)
>> IAction actionCut;
>> IAction actionCopy;
>> paste depending on the model that you use.
>> Regards,
>> Prashanto
>>> version are you running?
>>> key only works in the graphical editor until I display the text
>>> editor, then text editor overrides the key and all "del" key events
>>> goes to the text editor. Guess I need to reset this somewhere when
>>> changing back to graphical editor?
>>> but this might be out of the scope for this discussion since I
>>> probably miss some fundamental stuff here.
>>> thanks and regards
>>> /Johan
>>>> Hi Johan,
>>>> have a working application, I can share a few points with you.
>>>> /* (non-JavaDoc)
>>>> (ITextEditor) part : null;
>>>> being that you update actions based on the currently active editor?
>>>> /* (non-Javadoc)
>>>> * @see
>>>> selection) {
>>>> problem.
>>>> Hope this helps.
>>>> Regards,
>>>> Prashanto
>>>>> contextmenu that I made. Functionality 100% correct in both text
>>>>> editor and graphical editor and they don't interfere with each
>>>>> other. But delete does not work at all apart from being able to
>>>>> delete from the text with the "del" button no matter which editor
>>>>> I'm looking at. How come redo/undo automagically works, but I
>>>>> cannot get delete to work at all (it is disabled in my graphical
>>>>> regards
>>>>> /Johan
>>>>>> Search this newsgroup.
>>>>>>> Could someone give me a hint or point to some decent examples ion
>>>>>>> this?
>>>>>>> consisting of two editors, one TextEditor and one subclassed
>>>>>>> GraphicalEditor. I want, as one example, to have a delete button
>>>>>>> that deletes text in the TextEditor (this works) and graphical
>>>>>>> objects in the GraphicalEditor. But I cannot even get deletion of
>>>>>>> graphical objects to work at all. My problem seems to boil down
Re: MultiPageEditorPart and Actions [message #235529 is a reply to message #234214] |
Wed, 13 June 2007 05:42 |
Thanks Rudolf for replying on this, did not check this thread for a long
time since I thought it was dead more or less.
Anyway, I actually added the single line:
getEditorSite().getKeyBindingService();
in configureGraphicalViewer() the other week after some debugging internal
Eclipse classes and that resolved my problem. Now getKeybindingService is
deprecated so this feels like a temporary workaround for sure.
regards
/Johan
> deactivated.
> Rudolf
>> /Johan
>>> Hi Johan,
>>> /* (non-Javadoc)
>>> IAction actionCut;
>>> IAction actionCopy;
>>> Regards,
>>> Prashanto
>>>> thanks and regards
>>>> /Johan
>>>>> Hi Johan,
>>>>> /* (non-JavaDoc)
>>>>> /* (non-Javadoc)
>>>>> * @see
>>>>> selection) {
>>>>> problem.
>>>>> Hope this helps.
>>>>> Regards,
>>>>> Prashanto
>>>>>> regards
>>>>>> /Johan
>>>>>>>> this?
Current Time: Fri Sep 20 07:21:00 GMT 2024
Powered by FUDForum. Page generated in 0.04079 seconds
