Home » Language IDEs » ServerTools (WTP) » Serializing Documenation elements
Serializing Documenation elements [message #231351] Fri, 15 May 2009 07:27 Go to next message
I'm using the Wsdl EMF API, to create WSDLs programmatically.
The problem I'm facing currently is
when i add a documentation element to a WSDL element, it isn't serializing
it. However, when i debug through the code, I do find that the value are
transiently retrieved.
Is there some flag/switch i need to turn on, in order to serialize these
elements??
-Ravi
Re: Serializing Documenation elements [message #231410 is a reply to message #231351] Fri, 15 May 2009 13:51 Go to previous messageGo to next message
Ravi,
To better understand the problem, could you please paste a small code
fragment/snippet that shows the API calls you are making to incorporate
the documentation elements as well as the document serialization?
Re: Serializing Documenation elements [message #231491 is a reply to message #231410] Mon, 18 May 2009 06:03 Go to previous messageGo to next message
Thanks for the reply Gabriel.
That's the piece I have in my code to add a documentation element to the
wsdlelement.
public static void createDocElement(Object definitionObj,
Object wsdlElementObj, String elementName, String attrib,
String val) {
if (definitionObj instanceof Definition) {
Definition definition = (Definition) definitionObj;
if (wsdlElementObj instanceof ExtensibleElement) {
WSDLElement wsdlElement = (WSDLElement) wsdlElementObj;
Attr attr =
definition.getDocument().createAttribute("ProcessInfo");
attr.setValue(elementName + ":::" + val);
Element documentationElement =
wsdlElement.getDocumentationElement();
if (documentationElement == null) {
.createElement("DocumentationElement");
documentationElement.setAttributeNode(attr);
wsdlElement.setDocumentationElement(documentationElement);
try {
definition.eResource().save(null);
} catch (IOException e) {
// TODO Auto-generated catch block
e.printStackTrace();
System.out.println("Document##"
+ wsdlElement.getDocumentationElement());
However, the wsdl fragment for which i run the code against still looks
like this
<wsdl:portType name="RTestW">
<wsdl:operation name="NewOperation">
<wsdl:input message="tns:NewOperationRequest"/>
<wsdl:output message="tns:NewOperationResponse"/>
</wsdl:operation>
</wsdl:portType>
and I would expect
<wsdl:documentation>ProcessInfo=elementName:::value</wsdl:documentation >
</wsdl:operation>
</wsdl:portType>
Gabriel Indik wrote:
> Ravi,
Re: Serializing Documenation elements [message #231636 is a reply to message #231491] Tue, 19 May 2009 17:26 Go to previous messageGo to next message
Ravi,
Are you using the WSDL models as standalone models? If so, maybe you need
to manually sync the changes from the DOM to the EMF models.
See if the following line helps or not?
try {
====> definition.elementChanged(definition.getElement());
Raymond
Re: Serializing Documenation elements [message #231652 is a reply to message #231491] Wed, 20 May 2009 01:28 Go to previous message
Originally posted by: valentinbaciu.hotmail.com
Ravikanath, you seem to have run into a limitation of the WSDL EMF model.
I have opened https://bugs.eclipse.org/bugs/show_bug.cgi?id=277056 to track
this.
In the mean time, try this working example, which shows you how to work
around the limitation.
public class DocumentationSample extends TestCase
private static final String WSDL_PREFIX = "wsdl"; //$NON-NLS-1$
public void testSupportsDocumentationElements() throws Exception
ResourceSetImpl resourceSet = new ResourceSetImpl();
WSDLResourceImpl wsdlResource =
(WSDLResourceImpl)resourceSet.createResource(URI.createFileU RI( "documentationTest.wsdl"));
WSDLFactory factory = WSDLFactory.eINSTANCE;
Definition definition = factory.createDefinition();
wsdlResource.getContents().add(definition);
definition.setTargetNamespace("http://www.example.org");
definition.addNamespace(WSDL_PREFIX, WSDLConstants.WSDL_NAMESPACE_URI);
definition.updateElement(true);
Document document = definition.getDocument();
document.createElementNS(WSDLConstants.WSDL_NAMESPACE_URI, WSDL_PREFIX + ":"
+ WSDLConstants.DOCUMENTATION_ELEMENT_TAG);
// Workaround WSDL EMF model limitation.
Element definitionElement = definition.getElement();
// Change this line appropriately to ,ake sure you insert
// the definition element as the first child.
definitionElement.insertBefore(documentationElement, null);
// End workaround
definition.setDocumentationElement(documentationElement);
Element docChild = document.createElement("DocumentationElement");
docChild.setAttribute("ProcessInfo", "someValue");
documentationElement.appendChild(docChild);
wsdlResource.save(null);
The above code creates a WSDL document that looks like this:
<wsdl:definitions xmlns:wsdl="http://schemas.xmlsoap.org/wsdl/"
targetNamespace="http://www.example.org">
<DocumentationElement ProcessInfo="someValue"/>
</wsdl:documentation>
</wsdl:definitions>
"Ravikanth " <ravikanth.somayaji@gmail.com> wrote in message
news:c92b98a5d999b68c6119fdf781322c51$1@www.eclipse.org...
> wsdlelement.
> String val) {
> Attr attr =
> try {
> like this
> </wsdl:operation>
> </wsdl:portType>
> and I would expect <wsdl:portType name="RTestW">
> </wsdl:operation>
> </wsdl:portType>
>> Ravi,
Previous Topic:Tomcat and Eclipse for my RCP
Next Topic:WTP headless build issues...
Current Time: Fri Nov 07 08:37:40 EST 2025
Powered by FUDForum. Page generated in 0.03713 seconds
