| Getting charts to appear... [message #22602] |
Thu, 24 March 2005 15:25  |
Originally posted by: mbatchelor.no_s_p_a_m.pentaho.com
Hey all,
I've bound a simple bar chart to my dataset using the properties. I've then
specified the x-axis and y-axis values using row["whatever"].
However, whenever I preview, regardless of whether I'm previewing as html or
in a PDF, no chart ever appears.
Anyone have any hints?
Marc
| Re: Getting charts to appear... [message #23385 is a reply to message #22602] |
Mon, 28 March 2005 17:15  |
Hi Marc,
I sync'd the source with CVS earlier this morning and charts appear in the
output correctly. Here's the sequence of steps that I followed:
A] Sync'd and updated source for all BIRT plug-ins
B] Ran build.xml from the viewer/ plug-in which updates the viewer web-app
with all required BIRT libraries in the expected folder structure
C] Re-built the chart.reportitem plug-in via a Project => Clean (because
its build.xml does a selective build for runtime components causing only a
partial compilation)
D] Ran the workbench
E] Created a new chart; specified a dataset; bound its X series and Y
series to appropriate dataset columns; viewed the output in HTML and it
worked
There is a pending issue with viewing charts in PDF that is being
addressed but HTML output should work.
Rohit Colaço
ECE Project Lead
Hey all,
or
Marc
FUDForum. Page generated in 0.05635 seconds
