Home » Language IDEs » ServerTools (WTP) » Hot deploy in Ganymede
Hot deploy in Ganymede [message #231170] Mon, 11 May 2009 12:12 Go to next message
Is is it possible to hot deploy JSP and Java classes in Ganymede when
build automatically is selected?
2.
Is it is possible to drop JSP into my project and ganymede to pick them
up? Or do I have to do something magic?
Thanks.
Re: Hot deploy in Ganymede [message #231224 is a reply to message #231170] Tue, 12 May 2009 04:23 Go to previous messageGo to next message
Originally posted by: wknauf_NO_._INSIDE_hg-online.de
> 1.
Probably depends on your target server.
But in general: in the "Servers" view, open the server configuration. There is a
group "Publishing", and it defaults to "Automatically publish when resources
change".
> 2.
Hit "F5" or "Refresh" in the Project explorer so that eclipse sees the file (I
assume that you drop the JSP in the project directory outside of eclipse?)
Best regards
Wolfgang
Re: Hot deploy in Ganymede [message #231232 is a reply to message #231224] Tue, 12 May 2009 04:28 Go to previous message
I see that you posted the first question in another thread "Building Working
Set" with better resonses than mine...
Wolfgang Knauf schrieb:
>> 1.
> There is a group "Publishing", and it defaults to "Automatically publish
> when resources change".
>> 2.
>> them up? Or do I have to do something magic?
> file (I assume that you drop the JSP in the project directory outside of
> eclipse?)
> Best regards
> Wolfgang
Previous Topic:Problem from Web browser
Next Topic:Using EclipseTest Framework for WTP
Current Time: Fri Nov 07 08:37:27 EST 2025
Powered by FUDForum. Page generated in 0.03612 seconds
