Home » Language IDEs » ServerTools (WTP) » XML Design page change lost when prompted for checkou
XML Design page change lost when prompted for checkou [message #231108] Wed, 06 May 2009 14:54 Go to next message
If I attempt to alter an SCM controlled xml file through the Design tab of
the XML Editor, I briefly see my change appear in the editor and the file
marked as dirty. The SCM system kicks in and prompts me to check out.
Upon confirming the checkout dialog, the change is reverted and the file
is no longer marked as dirty. Note: Making a change through the
Properties view suffers from the same problem.
If I retry the scenario above but attempt the change in the Source tab of
the XML Editor, it works as expected: I don't see my change appear in the
editor; the SCM system kicks in and prompts me to check out; upon
confirming the checkout dialog the change is made to the file and it is
marked as dirty.
I could not find a bug on this issue but it appears to be in at least 3.3
and 3.4. Is this expected behavor or a known issue?
PS: I am using P4WSAD (Perforce)
Thank you,
John
Re: XML Design page change lost when prompted for checkou [message #231116 is a reply to message #231108] Wed, 06 May 2009 17:47 Go to previous messageGo to next message
Hi John,
Your scenario is mentioned in
https://bugs.eclipse.org/bugs/show_bug.cgi?id=231026#c1 under the 2nd of
the two outstanding issues.
I do not think your issue is being actively tracked, however. It might
be worth opening a bug.
-Nick
> of the XML Editor, I briefly see my change appear in the editor and the
> file marked as dirty. The SCM system kicks in and prompts me to check
> out. Upon confirming the checkout dialog, the change is reverted and
> the file is no longer marked as dirty. Note: Making a change through
> the Properties view suffers from the same problem.
> of the XML Editor, it works as expected: I don't see my change appear
> in the editor; the SCM system kicks in and prompts me to check out; upon
> marked as dirty.
> 3.3 and 3.4. Is this expected behavor or a known issue?
> Thank you,
> John
Re: XML Design page change lost when prompted for checkou [message #231124 is a reply to message #231116] Thu, 07 May 2009 10:25 Go to previous message
Thank you for finding the defect. As you suggested I opened a new defect
to track this: https://bugs.eclipse.org/bugs/show_bug.cgi?id=275305
Previous Topic:Generic External Server says shutdown failed before stop script has returned
Next Topic:Problem from Web browser
Current Time: Fri Nov 07 08:37:27 EST 2025
Powered by FUDForum. Page generated in 0.03428 seconds
