JSDT tests errors/failures [message #230972] |
Sat, 02 May 2009 08:09 |
Konstantin Scheglov Messages: 555 Registered: July 2009 |
I've checked out from CVS following plugins:
org.eclipse.wst.jsdt.core
org.eclipse.wst.jsdt.core.tests.compiler
org.eclipse.wst.jsdt.core.tests.model
However when I try to see how good is JSDT to use its API, and try to
run even simple tests, such as
org.eclipse.wst.jsdt.core.tests.dom.ASTTest, I see that there is a lot
of errors (7) and failures (47) in 168 tests. I see assertations that
will fail alwais:
assertTrue(TagElement.TAG_SINCE.equals("@since")); //$NON-NLS-1$
because of
public static final String TAG_SINCE = " "; //$NON-NLS-1$
So, this raises question - is JSDT really working if it has no tests?
Konstantin Scheglov,
Google, Inc.
Re: JSDT tests errors/failures [message #230983 is a reply to message #230972] |
Sat, 02 May 2009 15:36 |
> will fail alwais:
> because of
Konstantin. How are you trying to run the tests? What version of
Eclipse are you using, the code in head needs to have Eclipse 3.5.
I was able to successfully run the wst.jsdt.core.tests.compiler tests suite.
I did have problems getting the jsdt.core.tests.model tests to run.
Honestly, I'm not sure how accurate most of those really are. What I
did find out is that not all of the tests are run during a build. There
are many invalid or just plain wrong tests.
The test suites that are run typically are:
JSDTCompilerTests
JSDTModelTests
org.eclipse.wst.jsdt.web.ui.tests
AllWebUITests
org.eclipse.wst.jsdt.web.core.tests
AllWebCoreTests
I'll open a bug against JSDT to see if we can get the extraneous tests
removed or at least working and added to the test suite.
Dave
Re: JSDT tests errors/failures [message #230991 is a reply to message #230972] |
Sat, 02 May 2009 15:41 |
I've opened the following bug to help address the problem you have raised.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=274729
Please copy yourself on that bug and provide us with any additional
information you may have. I.e. Which tests and test suites are you
running that are failing.
Dave
> will fail alwais:
> because of
FUDForum. Page generated in 0.03029 seconds
