Re: enable and set debug options [message #22796 is a reply to message #22619] |
Sun, 04 May 2008 12:26 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Andrei Sobolev![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=haiodo%40xored.com) Messages: 72 Registered: July 2009 |
Member |
Hi Chuck,
You also could specify this options from "Run Configurations" dialog -> Then select your launch shortcut -> Tracing tab
and set required options.
Andrei Sobolev.
> I'm not sure why it wasn't working before - but I believe it is working now.
> Chuck
> "Chuck Doucette" <cdoucette@vaultus.com> wrote in message
> news:fvco3p$nai$1@build.eclipse.org...
>> I would like to debug certain behavior, starting with completion.
>> I found conditional debugging statements in the DLTK source code referring
>> to these constants:
>> public static final boolean DEBUG = Boolean.valueOf(
>> Platform.getDebugOption("org.eclipse.dltk.core/debug")).booleanValue();
>> //$NON-NLS-1$
>> public static final boolean DEBUG_COMPLETION = Boolean.valueOf(
>> Platform.getDebugOption("org.eclipse.dltk.core/debugCompletion ")).booleanValue();
>> //$NON-NLS-1$
>> I googled Eclipse getDebugOption and found this page:
>> http://wiki.eclipse.org/FAQ_How_do_I_use_the_platform_debug_ tracing_facility%3F
>> I created a .options file, and put it into C:\java\eclipse, and it has
>> this contents:
>> org.eclipse.dltk.core/debug=true
>> org.eclipse.dltk.core/debugCompletion=true
>> I invoked Eclipse with the -debug flag and it said this:
>> Debug options:
>> file:/C:/Java/eclipse/.options loaded
>> When I attempt to debug the line which sets DEBUG_SELECTION, it didn't
>> step into getDebugOptions, it simply stepped into Boolean.valueOf() and
>> said the string value was null.
>> So, how do I set debug options?
>> Thanks,
>> Chuck
Re: enable and set debug options [message #22837 is a reply to message #22796] |
Sun, 04 May 2008 15:35 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Charles Doucette![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=cdoucette%40vaultus.com) Messages: 125 Registered: July 2009 |
That didn't work for me since none of the DLTK plugins were listed in the
tracing tab (and therefore couldn't be selected and enabled).
Chuck
"Andrei Sobolev" <haiodo@xored.com> wrote in message
news:fvka1e$8td$2@build.eclipse.org...
> Hi Chuck,
> Best regards,
> Andrei Sobolev.
>> now.
>> Chuck
>>> referring
>>> to these constants:
>>> //$NON-NLS-1$
>>> //$NON-NLS-1$
>>> this contents:
>>> Debug options:
>>> Thanks,
>>> Chuck
FUDForum. Page generated in 0.03413 seconds
