Home » Language IDEs » ServerTools (WTP) » How to set focus in org.eclipse.wst.xml.xpath2.processor.jar
| How to set focus in org.eclipse.wst.xml.xpath2.processor.jar [message #230404] |
Wed, 15 April 2009 13:49  |
Hi there,
Need some help with the org.eclipse.wst.xml.xpath2.processor.jar API
To evaluate xpath expression, the following code works fine.
is = new FileInputStream("D:\\aFile.xml");
DOMLoader domloader = new XercesLoader();
Document doc = domloader.load(is);
ElementPSVI rootPSVI = (ElementPSVI)doc.getDocumentElement();
XSModel schema = rootPSVI.getSchemaInformation();
DynamicContext dc = new DefaultDynamicContext(schema, doc);
dc.add_function_library(new FnFunctionLibrary());
dc.add_function_library(new XSCtrLibrary());
dc.add_function_library(new XDTCtrLibrary());
String xpath = "Xpath expression";
XPathParser xpp = new JFlexCupParser();
XPath path = xpp.parse(xpath);
StaticChecker name_check = new StaticNameResolver(dc);
name_check.check(path);
Evaluator eval = new DefaultEvaluator(dc, doc);
ResultSequence rs = eval.evaluate(path);
But the context node for evaluation is the DOM Document node. We want the
context to be the top most element (which is required by the XML Schema
1.1 assertions spec).
Use the following code to do this,
// setting the focus to the document element
ElementType psyElement = new ElementType(doc.getDocumentElement(), 0);
Focus contextFocus = new Focus(new DefaultResultSequence(psyElement));
dc.set_focus(contextFocus);
but this doesn't work. The 2nd argument to the constructor of
ElementType is an integer, meaning "the document order" (ref,
http://psychopath.sourceforge.net/javadoc/org/ucl/xpath/type s/ElementType.html).
It seems, the org.eclipse.wst.xml.xpath2.processor documentation doesn't
describe what could be the possible values for "document order" integer.
tried with document order values of 0, 1 & -1. but these don't work.
How can we get the top most element?
Thanks in advance,
Ken
| Re: How to set focus in org.eclipse.wst.xml.xpath2.processor.jar [message #230502 is a reply to message #230404] |
Sat, 18 April 2009 13:50   |
Originally posted by: dcarver.starstandard.org
Ken you should be able to pass in the starting element where the Xpath
should begin, and then that should set the focus to that element.
I'll take a look later tonight when I get home, and setup a unit test
for this scenario.
If you haven't, please open a bug report and I'll track the progress and
updates there.
Dave
Ken Cai wrote:
> Hi there,
> DOMLoader domloader = new XercesLoader(); Document doc =
> domloader.load(is);
> ElementPSVI rootPSVI = (ElementPSVI)doc.getDocumentElement(); XSModel
> XPathParser xpp = new JFlexCupParser(); XPath path = xpp.parse(xpath);
> name_check.check(path); Evaluator eval = new
> DefaultEvaluator(dc, doc); ResultSequence rs = eval.evaluate(path);
> the context to be the top most element (which is required by the XML
> Schema 1.1 assertions spec).
> Use the following code to do this, // setting the focus to the document
> element
> Thanks in advance,
> Ken
| Re: How to set focus in org.eclipse.wst.xml.xpath2.processor.jar [message #230510 is a reply to message #230404] |
Sat, 18 April 2009 13:59   |
Ken, you may need to implement your own implementation of
DefaultEvaluator. That takes in a dom Node and then evaluates from
there instead of using the DefaultEvaluator. Take a look at the
DefaultEvaluator class for an example on how to implement your own
validator class. If you do implement this, please consider
contributing it back and I'll incorporate it into the base package.
So I would have a NodeEvaluator that had a constructor that took (a
DynamicContext implement, and dom DOM).
You can probably extend the DefaultEvaluator class.
Dave
Ken Cai wrote:
> Hi there,
> domloader.load(is);
> element
> Thanks in advance,
> Ken
| Re: How to set focus in org.eclipse.wst.xml.xpath2.processor.jar [message #231852 is a reply to message #230502] |
Mon, 25 May 2009 23:00  |
Ken,
While working on the XPath2 Processor (Psychopath) for the W3C Test
suite, I found another way you can accomplish what you want to do with
out creating your own implementation of a Context. You can use an
XPath variable, and assign your current context node to it. Check the
dc.set_variable() method. It takes a QName, and NodeType to be used.
You can then have your Xpath to execute be:
$variable/somexpath
And it will execute using the value you stored in the variable as the
starting point.
The W3C test suite uses this quite a bit for testing navigation.
Hope this tip helps.
Dave
> for this scenario.
> updates there.
> Dave
> Ken Cai wrote:
>> Hi there,
>> domloader.load(is);
>> schema = rootPSVI.getSchemaInformation(); DynamicContext dc = new
>> DefaultDynamicContext(schema, doc); dc.add_function_library(new
>> xpp.parse(xpath); StaticChecker name_check = new
>> StaticNameResolver(dc); name_check.check(path); Evaluator
>> eval = new DefaultEvaluator(dc, doc); ResultSequence rs =
>> eval.evaluate(path); But the context node for evaluation is the
>> DOM Document node. We want the context to be the top most element
>> (which is required by the XML Schema 1.1 assertions spec).
>> document element
>> doesn't describe what could be the possible values for "document
>> order" integer. tried with document order values of 0, 1 & -1. but
>> these don't work.
>> Thanks in advance,
>> Ken
Current Time: Fri Nov 07 08:37:26 EST 2025
Powered by FUDForum. Page generated in 0.03708 seconds
