Home » Language IDEs » Java Development Tools (JDT) » Java 6 interfaces
Java 6 interfaces [message #229904] Thu, 18 May 2006 18:55 Go to next message
Originally posted by: wharley.bea.com
Java 6 adds a number of interfaces in the javax.* packages. Several such,
peripherally involved in the JSR269 annotation processing scheme and thus of
interest to me, are javax.tools.FileObject, javax.tools.JavaFileObject, and
javax.tools.JavaFileManager.
These interfaces are intended to provide a file abstraction layer for tools
(see e.g.
http://download.java.net/jdk6/docs/api/javax/tools/JavaFileM anager.html).
It looks like I'll need an implementation of these on top of the Eclipse
resource framework. (Yet another abstraction of the filesystem, just what
we need...)
Is there anyone already planning on implementing these interfaces, within
JDT or the Platform? I didn't see anything in Bugzilla and I don't know if
3.3 planning docs are published yet.
Thanks!
-Walter Harley
JDT APT team
Re: Java 6 interfaces [message #229913 is a reply to message #229904] Thu, 18 May 2006 20:38 Go to previous messageGo to next message
> (see e.g.
> we need...)
As far as I know, these types are part of the JSR199. See
https://bugs.eclipse.org/bugs/show_bug.cgi?id=81471.
Olivier
Re: Java 6 interfaces [message #229920 is a reply to message #229904] Thu, 18 May 2006 21:09 Go to previous messageGo to next message
Originally posted by: pascal.ibm.canada
This seems to be a fine requirement for the JDT team and since you are
part of it... ;-)
PaScaL
> (see e.g.
> we need...)
> Thanks!
> -Walter Harley
> JDT APT team
Re: Java 6 interfaces [message #229928 is a reply to message #229920] Thu, 18 May 2006 21:12 Go to previous messageGo to next message
"Pascal Rapicault" <pascal@ibm.canada> wrote in message
news:e4j5sm$glp$1@utils.eclipse.org...
> part of it... ;-)
Oh, I agree completely - just want to be sure I'm not duplicating existing
effort.
-walter
Re: Java 6 interfaces [message #229935 is a reply to message #229928] Thu, 18 May 2006 21:45 Go to previous messageGo to next message
Make sure you talk to Philippe about that
>> part of it... ;-)
> effort.
> -walter
Re: Java 6 interfaces [message #229976 is a reply to message #229913] Fri, 19 May 2006 17:54 Go to previous messageGo to next message
"Olivier Thomann" <olivier_thomann@ca.ibm.com> wrote in message
news:e4j41j$be1$1@utils.eclipse.org...
> Walter Harley a
Re: Java 6 interfaces [message #230092 is a reply to message #229904] Wed, 24 May 2006 10:40 Go to previous messageGo to next message
Originally posted by: john.eclipsefaq.org
Hi Walter,
Can you briefly describe why you would need to implement these
interfaces on top of the IResource API? Another option to consider is
to implement those interfaces on top of the Eclipse file system API (in
org.eclipse.core.filesystem plugin). The IResource framework itself is
built on top of the EFS API. Since the EFS API is much closer to the
file system level, it seems like a logical fit to bridge the APIs at
that level. The fact that both javax.tools.FileObject and the EFS
IFileStore both use URI as identifiers should make it easier.
> (see e.g.
> we need...)
> Thanks!
> -Walter Harley
> JDT APT team
Re: Java 6 interfaces [message #230167 is a reply to message #230092] Thu, 25 May 2006 21:09 Go to previous messageGo to next message
"John Arthorne" <john@eclipsefaq.org> wrote in message
news:e51r8k$j07$1@utils.eclipse.org...
> Hi Walter,
> Can you briefly describe why you would need to implement these interfaces
> on top of the IResource API? Another option to consider is to implement
> built on top of the EFS API. Since the EFS API is much closer to the file
> system level, it seems like a logical fit to bridge the APIs at that
> level. The fact that both javax.tools.FileObject and the EFS IFileStore
Hi, John.
No good reason at present; I'm still just learning about the requirements.
Actually, I've just been digging into the code and it looks like when
generating Java files we actually sit on top of the Java Model, rather than
even on the IResource framework, in order to manage some resource-listener
issues: e.g., we call methods like
IPackageFragmentRoot.createPackageFragment(). Conversely, when generating
non-Java files it looks like we're using java.io.File, so I'm not sure how
we're coordinating with the workspace in that case.
The relevant JSR-269 APIs are just things like this:
JavaFileObject createSourceFile(CharSequence name)
Client code (specifically, a JSR-175 annotation processor) would call that
method to create a file, and would then write text into the file; the file
would then participate in further compilation.
Re: Java 6 interfaces [message #230222 is a reply to message #230167] Fri, 26 May 2006 15:16 Go to previous message
> Hi, John.
Generally using java.io.File when interacting with files in an Eclipse
workspace is not the best choice. Since this will go straight to disk,
you miss out on useful illusions created by the resource framework and
the Java model, such as linked resources, non-local files, etc. If you
are creating files and packages directly using either Java model or
resource API, you are better off. Generally the higher the level of
abstraction, the more you get for free. From a JDT perspective, the
order of preference would be Java Model > Resource model > EFS >
java.io.File. Many levels of indirection, indeed.
Previous Topic:Non-internal equivalent to JavaSourceViewer?
Next Topic:3.2RC5 Key binding for Next/Previous Search Occurrence?
Current Time: Sun Nov 02 21:53:02 EST 2025
Powered by FUDForum. Page generated in 0.03870 seconds
