Re: Javascript libs not resolved [message #229855 is a reply to message #229178] |
Mon, 30 March 2009 19:38 |
Frank wrote:
> I'm working under Eclipse Ganymede 3.4.2 and created a "Static Web
> Project". I've "added Javascript Support" by "rightClick-on-Project >
> Web Development Tools"
> Under ""rightClick-on-Project > Properties > JavaScript > JavaScript
> Libraries > Source" I've added the two Google Gears js-Files
> gears_init.js and js_utils.js. They show up in the "JavaScript
> Support"-area of the project in "Script Explorer", which seems to be
> correct.
> Afterwards I've created a HTML-file in WebContent named test.html an
> copied some example code from Google into it. It starts with
> <html>
> <body>
> <script type="text/javascript" src="../gears_init.js"></script>
> <script type="text/javascript" src="../js_utils.js"></script>
> <script type="text/javascript">
> try {
> detectPlatform();
> } catch (e) {
> document.write(e);
> </script>
> detectPlatform() is marked with red underline "The function
> detectPlatform() is undefined", which is definitely wrong.
> detectPlatform () is defined in js_utils.js. After exporting, everything
> works fine in Tomcat. But why do I receive a lot of "The function xyz is
> undefined" and "xyz cannot be resolved or is not a field" and why is
> autocompletion turned off.
> Seems to me, that I misunderstood the whole concept.
> Any hints appreciated
Sounds like a valid problem. Please open a bug report at
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=WTP%20So urce%20Editing&component=wst.jsdt
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
_
Nitin Dahyabhai
Eclipse Web Tools Platform
FUDForum. Page generated in 0.04535 seconds
