Eclipse won't start up after update [message #228587] |
Mon, 02 March 2009 20:38 |
Joe Gliniecki Messages: 12 Registered: July 2009 |
I was running Eclipse WTP 3.0.3 fine for months. Today I decided to update
to 3.0.4. The update went fine and it asked me to restart as usual.
However eclipse will now no longer start since the update.
The small screen that usually shows Eclipse starting up is displayed for
only a split second and then goes away. Also, the log file at
<workspace_dir>/.metadata/.log is not updated from the attempted start.
Not sure if there are any other log files to look at.
The last entry in the log is this:
!SESSION 2009-03-01 15:25:45.860
eclipse.buildId=M20080911-1700
java.version=1.6.0_07
Framework arguments: -showlocation
Command-line arguments: -os win32 -ws win32 -arch x86 -data
C:\eclipse_workspaces\eclipse_wtp_main -showlocation
!ENTRY org.eclipse.equinox.p2.metadata.repository 2 0 2009-03-01
15:28:36.203
!MESSAGE Error parsing metadata repository
!SUBENTRY 1 org.eclipse.equinox.p2.core 2 0 2009-03-01 15:28:36.203
!MESSAGE Error at line 10, column 91: Missing required attribute in
"repository": url
!MESSAGE Error at line 10, column 91: Illegal value for attribute "url" of
element "repository": null
!MESSAGE Error at line 11, column 91: Missing required attribute in
"repository": url
!MESSAGE Error at line 11, column 91: Illegal value for attribute "url" of
!MESSAGE Error at line 12, column 90: Missing required attribute in
"repository": url
!MESSAGE Error at line 12, column 90: Illegal value for attribute "url" of
!MESSAGE Error at line 13, column 90: Missing required attribute in
"repository": url
!MESSAGE Error at line 13, column 90: Illegal value for attribute "url" of
!ENTRY org.eclipse.equinox.p2.director 2 0 2009-03-01 15:29:07.736
!MESSAGE Problems resolving provisioning plan.
!SUBENTRY 1 org.eclipse.equinox.p2.director 2 0 2009-03-01 15:29:07.736
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.sse.core
1.1.203.v200802140626 to requiredCapability:
osgi.bundle/org.eclipse.emf.common/[2.2.0,2.4.0).
!MESSAGE Unable to satisfy dependency from org.eclipse.wst.sse.ui
1.0.305.v200802142230 to requiredCapability:
with many more of the "requiredCapability" lines.
This happened to me last fall also, and I then just re-installed Eclipse
from scratch (since I couldn't start Eclipse to revert to the old
configuration), but thought I'd now try and see if there is a solution, or
maybe a bug that the community could be made aware of.
Joe
Re: Eclipse won't start up after update [message #228604 is a reply to message #228587] |
Tue, 03 March 2009 06:33 |
Originally posted by: david_williams.linux.vnet.ibm.com
> Eclipse from scratch (since I couldn't start Eclipse to revert to the
> old configuration), but thought I'd now try and see if there is a
> solution, or maybe a bug that the community could be made aware of.
This sounds serious. If you take the time to figure out steps to
reproduce, that would be helpful (and if so, open a bug then with the
details).
Since it's happened to you twice, maybe there is something special you
do. Do you start off with base Eclipse and build up from there? Do you
start with Java EE IDE package? Do you have other things installed?
Especially any other plugins you might have 'unzipped' into your
installation?
The other place to look for startup logged issues is in your the
'configuration' directory of your eclipse install location (not the
workspace).
My guess it, the main thing it will say is basically "something is
invalid om your installation" but perhaps someone can interpret the
specifics.
Re: Eclipse won't start up after update [message #228644 is a reply to message #228637] |
Wed, 04 March 2009 18:06 |
Originally posted by: dcarver.starstandard.org
You use the file you downloaded to add to your dropins in a Eclispe
Classic installation. Plus you'll need the other dependencies zips
mentioned on that page as well.
Dave
> David,
> I always start out with the WTP all in one bundle. The only plugin I use
> is the Subversion one, but I use the update site for that.
> Here are the contents of my configuration/config.ini file:
> #This configuration file was written by:
> org.eclipse.equinox.internal.frameworkadmin.equinox.EquinoxF wConfigFileParser
> #Sun Mar 01 15:42:18 CST 2009
> osgi.launcherPath=.
> org.eclipse.update.reconcile=false
> eclipse.p2.profile=PlatformProfile
> osgi.instance.area.default=@user.home/workspace
> osgi.framework=file\:plugins\\org.eclipse.osgi_3.4.3.R34x_v2 0081215-1030.jar
> eclipse.buildId=M20090211-1700
> osgi.bundles=reference\:file\:org.eclipse.equinox.simpleconfigurator_1.0.0.v20080604.jar@1\:start
> org.eclipse.equinox.simpleconfigurator.configUrl=file\:org.e clipse.equinox.simpleconfigurator\\bundles.info
> eclipse.product=org.eclipse.platform.ide
> osgi.splashPath=platform\:/base/plugins/org.eclipse.platform
> osgi.launcherIni=eclipse
> eclipse.p2.data.area=@config.dir/../p2
> osgi.bundles.defaultStartLevel=4
> I tried to download WTP 3.0.3 from here
> ( http://www.eclipse.org/downloads/download.php?file=/webtools /downloads/drops/R3.0/R-3.0.3-20081113203138/wtp-R-3.0.3-200 81113203138.zip)
> so I could try to update it to 3.0.4 to try and reproduce the error, but
> the downloaded zip file doesn't have an eclipse.exe file. So not sure
> how that is usable, or how I could fire up wtp 3.0.3 so I could try this.
> So I've hit a dead end in trying to reproduce the error. Hope this
> helps, and let me know of any other suggestions to help me get on the
> path to reproducing the error.
> Joe
FUDForum. Page generated in 0.04047 seconds
