Home » Modeling » GMF (Graphical Modeling Framework) » ApplyAppearanceProperties Action error
Re: ApplyAppearanceProperties Action error [message #234659 is a reply to message #228447] |
Thu, 25 June 2009 12:09   |
Originally posted by: thomas.beyer81.t-online.de
Hello GMF-Team,
this issue adresses in my ealier post has not been solved within the
Galileo-release, from what I can tell.
Steps to reproduce:
1. Create a new ecore-diagram (error also occur when using the ecore
diagram editor, that ships with the ecoretools-project).
2. Create two EClass-objects.
3. Modify the background a one to any different color.
4. Try to use "Apply Appearance Properties"-action (at least that's what
its called in the context menu)
Please let me know, if I can be of further help.
Regards Thomas
Am 29.04.2009 19:38, schrieb Thomas Beyer:
> Hello community,
> I am working with GMF 2.2M6 and corresponding platform plugins.
> I cannot use the apply appearance action, since it throws an error on
> execution.
> This error not only occurs in my rcp, but also in the diagram-editor of
> the gmf-runtime and even the ecore diagram editor of the
> ecoretools-project.
> The fix for Bug 269988 doesn't resolve this problem either.
> Unfortunately my stack trace is cut off, where it gets interesting. (see
> below) So I don't have a point to start/debug at.
> More info:
> The notofy changed method doesn't get called in the editparts.
> Though the change is being copied after all.
> When saving, closing and reopening the file, all changes are applied
> appropriately.
> Is this a known issue?
> TIA & regards
> Thomas
> org.eclipse.core.commands.ExecutionException: While executing the
> operation, an exception occurred
> at
> org.eclipse.core.commands.operations.DefaultOperationHistory .execute(DefaultOperationHistory.java:519)
> at
> org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack .execute(DiagramCommandStack.java:194)
> at
> org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack .execute(DiagramCommandStack.java:169)
> at
> org.eclipse.gmf.runtime.diagram.ui.actions.DiagramAction.exe cute(DiagramAction.java:141)
> at
> org.eclipse.gmf.runtime.diagram.ui.actions.DiagramAction.doR un(DiagramAction.java:103)
> at
> org.eclipse.gmf.runtime.common.ui.action.AbstractActionHandl er.run(AbstractActionHandler.java:359)
> at
> org.eclipse.gmf.runtime.common.ui.action.ActionManager$1.run (ActionManager.java:225)
> at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
> at
> org.eclipse.gmf.runtime.common.ui.action.ActionManager.run(A ctionManager.java:223)
> at
> org.eclipse.gmf.runtime.common.ui.action.AbstractActionHandl er.runWithEvent(AbstractActionHandler.java:377)
> at
> org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:584)
> at
> org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:501)
> at
> org.eclipse.jface.action.ActionContributionItem$6.handleEven t(ActionContributionItem.java:452)
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
> at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3880)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3473)
> at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2393)
> at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2357)
> at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 09)
> at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:499)
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
> at
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:492)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
> at
> org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:597)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 556)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:511)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1284)
> at org.eclipse.equinox.launcher.Main.main(Main.java:1260)
> Caused by: java.lang.IllegalStateException: Transaction is already closing
> at
> org.eclipse.emf.transaction.impl.TransactionImpl.rollback(Tr ansactionImpl.java:527)
> at
> org.eclipse.emf.workspace.AbstractEMFOperation.rollback(Abst ractEMFOperation.java:630)
> at
> org.eclipse.emf.workspace.AbstractEMFOperation.execute(Abstr actEMFOperation.java:187)
> at
> org.eclipse.core.commands.operations.DefaultOperationHistory .execute(DefaultOperationHistory.java:511)
> .... 37 more
Re: ApplyAppearanceProperties Action error [message #234679 is a reply to message #234659] |
Thu, 25 June 2009 13:28   |
I think the problem occurs only when copying FillStyle.
While debugging, the command executed once I added FillStyle in
PropertyHandlerEditPolicy as follows:
protected List getStyleExclusionsForCopyAppearance() {
List exclusions = new ArrayList();
exclusions.add(NotationPackage.eINSTANCE.getDescriptionStyle ());
exclusions.add(NotationPackage.eINSTANCE.getImageBufferStyle ());
exclusions.add(NotationPackage.eINSTANCE.getFillStyle());
return exclusions;
I also had to modify the
FillStyleImpl#
protected static final int TRANSPARENCY_EDEFAULT = -1;
to value <<255>>, since it threw errors when copying shapes to the
clipboard (with fillstyle) and no transparency set initially.
This error seems reasonable, since
org.eclipse.awt.AlphaComposite#
private AlphaComposite(int rule, float alpha) {
if (alpha < 0.0f || alpha > 1.0f) {
throw new IllegalArgumentException("alpha value out of range");
is called, when the default transparency is set to -1.
I hope this helps a bit investigating.
Thomas
Am 25.06.2009 14:09, schrieb Thomas Beyer:
> Hello GMF-Team,
> Steps to reproduce:
> Regards Thomas
>> Hello community,
>> execution.
>> ecoretools-project.
>> More info:
>> appropriately.
>> TIA & regards
>> Thomas
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> closing
>> at
>> at
>> at
>> at
>> .... 37 more
Re: ApplyAppearanceProperties Action error [message #234693 is a reply to message #234679] |
Thu, 25 June 2009 14:31  |
Filed a bug report and attached a quick fix for getting the basic
functionality working.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=281506
Regards Thomas
Am 25.06.2009 15:28, schrieb Thomas Beyer:
> return exclusions;
> FillStyleImpl#
> Regards
> Thomas
>> Hello GMF-Team,
>> Steps to reproduce:
>> Regards Thomas
>>> Hello community,
>>> execution.
>>> ecoretools-project.
>>> More info:
>>> appropriately.
>>> TIA & regards
>>> Thomas
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> closing
>>> at
>>> at
>>> at
>>> at
>>> .... 37 more
Current Time: Sat Apr 17 17:57:19 GMT 2021
Powered by FUDForum. Page generated in 0.02364 seconds
