Home » Eclipse Projects » Eclipse Platform » PDE: Adding to ant's classpath
PDE: Adding to ant's classpath [message #228038] Tue, 13 April 2004 15:53 Go to next message
I've generated a build script from PDE export, however this script
contains a reference to "pde.exportFeatures". When I try to run the
script I (predictably) get the error:
Could not create task or type of type: pde.exportFeatures.
Where is the task pde.exportFeatures (for that matter - any of the PDE
related ant tasks) and how do I tell ant where to find these?
Many thanks.
James
Re: Adding to ant's classpath [message #228045 is a reply to message #228038] Tue, 13 April 2004 16:02 Go to previous messageGo to next message
I am assuming you are using 3.0 (relatively latest?)
You will need to perform this build in the same VM as Eclipse as I believe
the pde.exportFeatures task requires the eclipse runtime to function.
See the JRE tab of the Ant launch configuration for the build
HTH
Darins
"James Willans" <jwillans@cs.york.ac.uk> wrote in message
news:c5hggm$ahi$1@eclipse.org...
> Many thanks.
> James
Re: Adding to ant's classpath [message #228068 is a reply to message #228045] Tue, 13 April 2004 16:33 Go to previous messageGo to next message
Darin,
That worked - thanks.
James
> HTH
> Darins
> > Many thanks.
> > James
Re: Adding to ant's classpath [message #228121 is a reply to message #228045] Tue, 13 April 2004 18:18 Go to previous messageGo to next message
I have a further question regarding this. The ant script seems to kick
off pde.exportFeatures and then continue, since the next task is dependent
on the output of the exportFeatures task - this doesn't work too well.
What is the standard approach for dealing with this problem?
James
> HTH
> Darins
> > Many thanks.
> > James
Re: Adding to ant's classpath [message #228162 is a reply to message #228121] Tue, 13 April 2004 18:40 Go to previous message
I believe they are using an Eclipse Job and then immediately returning while
the Job is running in the background.
You should file a bug report against PDE with your problem as you really
want to wait on this task
Sorry I am not more help,
Darins
news:c5hout$kpf$1@eclipse.org...
> James
believe
> > HTH
> > Darins
> > > Many thanks.
> > > James
Previous Topic:OSGi matter
Next Topic:delete metadata?
Current Time: Thu Jul 17 07:18:23 EDT 2025
Powered by FUDForum. Page generated in 0.28661 seconds
