Home » Language IDEs » ServerTools (WTP) » Programmatically launching web service explorer
Programmatically launching web service explorer [message #227811] Fri, 13 February 2009 10:30 Go to next message
Originally posted by: marius.eich.gmx.de
I'd like to know if there is a way of programmatically launching the web
service explorer from another plugin. I haven't found any information about
this yet. I tried to launch the explorer by running
org.eclipse.wst.ws.internal.explorer.action.LaunchWSEAction but there is an
access restriction. Any ideas?
Thanks in advance and best regards
Marius Eich
Re: Programmatically launching web service explorer [message #228008 is a reply to message #227811] Wed, 18 February 2009 13:41 Go to previous messageGo to next message
Try using the WSExplorerLauncherCommand.
There is an example of this in the WSEGenerateCommand (found in the
org.eclipse.jst.ws.consumption.ui plugin)
Marius Eich wrote:
> Hello,
> Marius Eich
Re: Programmatically launching web service explorer [message #228089 is a reply to message #228008] Fri, 20 February 2009 11:31 Go to previous messageGo to next message
Hi Mark,
thank you very much. It worked.
Best regards
Marius
"Mark Hutchinson" <mahutch@ca.ibm.com> schrieb im Newsbeitrag
news:gnhkv5$3io$1@build.eclipse.org...
> Marius Eich wrote:
>> Hello,
>> about this yet. I tried to launch the explorer by running
>> an access restriction. Any ideas?
>> Marius Eich
Re: Programmatically launching web service explorer [message #228630 is a reply to message #228089] Wed, 04 March 2009 10:39 Go to previous messageGo to next message
Hi again,
now that I managed to launch the web service explorer from my plugin, I'm
trying to launch it with a binding already selected. There is no problem in
preselecting the correct wsdl by setting the wsdl location as launchoption
with the key LaunchOptions.WSDL_URL.
Now I thought that I could preselect a binding belonging to this wsdl by
adding the wsdl option and an option with the key
LaunchOptions.BINDING_NAME_STRING and the correct binding name as value. But
that doesn't work. After launching the explorer, the wsdl is selected and
one can select a binding from the binding list. Can anyone tell me what I
did wrong or where to find an example for this?
Thanks and best regards
Marius Eich
"Marius Eich" <marius.eich@gmx.de> schrieb im Newsbeitrag
news:gnmltd$emv$1@build.eclipse.org...
> Hi Mark,
> Best regards
> Marius
>> Marius Eich wrote:
>>> Hello,
>>> Marius Eich
Re: Programmatically launching web service explorer [message #228865 is a reply to message #228630] Thu, 12 March 2009 15:35 Go to previous message
Sorry for taking so long to respond. I'm not sure why this doesn't
work. I can't find any places in WTP where we use this option.
Try setting a breakpoint in the LaunchOptionsManager.loadOptions method
to see what's going on there. Make sure the bindingNameStrings array
gets populated with your binding name, and then follow the code into
WSDLPerspective.preselectServiceOrBinding.
If you find a bug with the code please open a bug, and feel free to
contribute a patch.
I hope this helps,
Mark
Marius Eich wrote:
> Hi again,
> Marius Eich
>> Hi Mark,
>> Best regards
>> Marius
>>> Marius Eich wrote:
>>>> Hello,
>>>> Marius Eich
Previous Topic:Removal of deprecated classes, methods, and statics
Next Topic:which method is called when select "START" from server's context menu?
Current Time: Fri Oct 31 05:18:30 EDT 2025
Powered by FUDForum. Page generated in 0.06505 seconds
