Home » Language IDEs » ServerTools (WTP) » Custom Outline View for HTML files
Custom Outline View for HTML files [message #227789] Thu, 12 February 2009 17:01 Go to next message
Hi all,
I try to provide a custom outline view for HTML files. In my plugin.xml
I have
<extension point="org.eclipse.wst.sse.ui.editorConfiguration">
<sourceViewerConfiguration
class="ch.raymi.plugin.coder.StructuredTextViewerConfiguration "
target="org.eclipse.wst.html.core.htmlsource"/>
<contentOutlineConfiguration
class="ch.raymi.plugin.coder.outline.OutlineConfiguration"
</extension>
My StructuredTextViewerConfiguration extends
StructuredTextViewerConfigurationHTML. This seems to work (I am able to
provide my own content assist processors).
My OutlineConfiguration extends
org.eclipse.wst.html.ui.views.contentoutline.HTMLContentOutl ineConfiguration.
However none of the overridden methods is called (not even the
constructor), when I open a HTML file. The Outline View is there, but it
doesn't seem to use my class.
What's wrong?
Thanks for your help.
Dominik
Re: Custom Outline View for HTML files [message #227822 is a reply to message #227789] Fri, 13 February 2009 11:41 Go to previous messageGo to next message
Providing new extensions for the same targets we already provide
extensions for is not supported. You can, however, try using a
target ID higher than the content type ID in the target search list.
Ideally you would be using a more specific content type, and using
its ID as its target, or requesting an enhancement to contribute to
the existing outline configurations in some way.
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
Re: Custom Outline View for HTML files [message #227849 is a reply to message #227822] Sat, 14 February 2009 12:14 Go to previous messageGo to next message
Thanks for your quick reply.
Being new to plugin development in general (and wst extensions
specifically) I do not really understand what you mean by "higher target
IDs".
The following naive approach of extending the HTML content type does not
seem to work either:
<extension
point="org.eclipse.core.runtime.contentTypes">
<content-type
file-extensions="html"
priority="high"
name="BX HTML"
id="ch.raymi.plugin.html"
base-type="org.eclipse.wst.html.core.htmlsource"
default-charset="UTF-8" />
</extension>
<extension
class=" ch.raymi.plugin.html.plugin.coder.StructuredTextViewerConfig uration "
target="ch.raymi.plugin.html"/>
class=" ch.raymi.plugin.html.plugin.coder.outline.OutlineConfigurati on "
</extension>
Now even my StructuredTextViewerConfiguation doesn't seem to work any
longer. Could someone elaborate a bit further, what needs to be done?
Sorry for my newbie questions, but I find it quite difficult to get started.
Dominik
> extensions for is not supported. You can, however, try using a target
> ID higher than the content type ID in the target search list. Ideally
> you would be using a more specific content type, and using its ID as its
> target, or requesting an enhancement to contribute to the existing
Re: Custom Outline View for HTML files [message #227907 is a reply to message #227849] Mon, 16 February 2009 09:29 Go to previous messageGo to next message
> IDs".
> <extension
> <content-type
> priority="high"
> name="BX HTML"
> </extension>
> <extension
> </extension>
> started.
Odds are you're making invalid assumptions about the ID for your
content type, since I think the value is always appended to the
declaring plug-in's ID. For example, our org.eclipse.wst.html.core
plug-in specifies an ID value of "htmlsource" to its HTML content
type, but the end result is the org.eclipse.wst.html.core.htmlsource
that you are referring to above.
As for the target IDs, we look them up using a list we generate at
runtime with a very specific order, so when I say "higher" I mean
higher in that list. Targets based on content types come after the
IDs based on the editor's part ID and class name. The generation of
target IDs occurs in the
org.eclipse.wst.sse.ui.internal.provisional.extensions.Confi gurationPointCalculator
class if you're curious.
http://www.eclipse.org/webtools/wst/components/sse/designs/E ditorConfiguration.html
mentions it as the "Target Resolution Policy".
Nitin Dahyabhai
IBM Rational
Re: Custom Outline View for HTML files [message #227937 is a reply to message #227907] Mon, 16 February 2009 18:19 Go to previous messageGo to next message
Thanks Nitin for your reply.
However, I'm really going to become desperate. Whatever I try, nothing
seems to work.
I tried as suggested (with ch.raymi.plugin being my Plugin ID):
<extension
<content-type
priority="high"
name="BX HTML"
id="bx"
base-type="org.eclipse.wst.html.core.htmlsource"/>
</extension>
<extension
class=ch.raymi.plugin.coder.StructuredTextViewerConfiguratio n "
target="ch.raymi.plugin.bx" />
target="ch.raymi.plugin.bx"/>
</extension>
Neither my StructuredTextViewerConfiguration nor the
OutlineConfiguration work with this configuration. If I change both
targets to the super type "org.eclipse.wst.html.core.htmlsource" (as in
my first attempt): the StructuredTextViewerConfiguration starts to work,
the OutlineConfiguration does not.
How can this asymmetrical behavior be explained? Why are the targets
differently resolved?
Is there a way I can debug this problem easily?
Can you provide a working example (this should be easily reproducible,
shouldn't it?)?
Thank you very much for your help. I'd really like this to work...
Dominik
>> target IDs".
>> not seem to work either:
>> <extension
>> <content-type
>> priority="high"
>> name="BX HTML"
>> </extension>
>> <extension
>> </extension>
>> started.
> Odds are you're making invalid assumptions about the ID for your content
> type, since I think the value is always appended to the declaring
> plug-in's ID. For example, our org.eclipse.wst.html.core plug-in
> specifies an ID value of "htmlsource" to its HTML content type, but the
> end result is the org.eclipse.wst.html.core.htmlsource that you are
> referring to above.
> runtime with a very specific order, so when I say "higher" I mean higher
> in that list. Targets based on content types come after the IDs based
> on the editor's part ID and class name. The generation of target IDs
> occurs in the
Re: Custom Outline View for HTML files [message #227985 is a reply to message #227937] Tue, 17 February 2009 18:18 Go to previous messageGo to next message
Note:
I read the following on
http://help.eclipse.org/help32/index.jsp?topic=/org.eclipse. wst.doc.isv/html/plugin_descriptions_WST/cheatsheet_tutorial .html
Providing your own outline view
To change the default outline view you have to provide your own adapter
factory provider. To register it with the SSE extend the
org.eclipse.wst.sse.ui.adapterFactoryDescription extension point.
<extension point="org.eclipse.wst.sse.ui.adapterFactoryDescription">
<adapterFactoryDescription
class="org.eclipse.wst.cs.ui.registry.AdapterFactoryProviderForCS "/>
</extension>
The adapter factory provider should add your own adapter factory to the
factory registry.
Do I really have to provide an implementation of this adapter? How
should I do that?
> seems to work.
> <extension
> <content-type
> priority="high"
> name="BX HTML"
> id="bx"
> </extension>
> <extension
> </extension>
> shouldn't it?)?
> Dominik
>>> target IDs".
>>> <extension
>>> <content-type
>>> priority="high"
>>> name="BX HTML"
>>> </extension>
>>> <extension
>>> </extension>
>>> started.
Re: Custom Outline View for HTML files [message #228065 is a reply to message #227937] Thu, 19 February 2009 12:31 Go to previous messageGo to next message
> seems to work.
> <extension
> <content-type
> priority="high"
> name="BX HTML"
> id="bx"
> </extension>
> <extension
> </extension>
> shouldn't it?)?
I think part of it is that you're trying to grab the html filename
extension from your base content type. The Properties dialog on the
file should tell you which content type is winning--I'm betting not
yours.
Nitin Dahyabhai
IBM Rational
Re: Custom Outline View for HTML files [message #228081 is a reply to message #228065] Thu, 19 February 2009 14:00 Go to previous messageGo to next message
>> <extension
>> <content-type
>> priority="high"
>> name="BX HTML"
>> id="bx"
>> </extension>
> file should tell you which content type is winning--I'm betting not yours.
Well, certainly it's not _me_, who's winning at the moment ;-)
You are right, it was not my content type that was shown in the
properties dialog. However, if I associate my content type with a
specific file (test.html), it _is_ my content type that's winning. But
still no custom outline...
<extension
<content-type
priority="high"
name="BX HTML"
id="bx"
<file-association
content-type="ch.raymi.plugin.bx"
file-names="test.html"
file-extensions="test.html"
</extension>
By now I think I have to provide a custom extension to
org.eclipse.wst.sse.ui.adapterFactoryDescription, because it's how they
do it in the cheat sheet tutorial. But I don't really like the idea of
doing it (and I don't really see a reason why one have to do this, since
it's so easy to provide a sourceViewerConfiguration but so hard to
provide a contentOutlineConfiguration).
Re: Custom Outline View for HTML files [message #228142 is a reply to message #228081] Sat, 21 February 2009 03:33 Go to previous messageGo to next message
That shouldn't be necessary, after all, contentOutlineConfiguration
is the same extension point as sourceViewerConfiguration. If one
loads, the other should. Are you certain your content outline
configuration class is not being instantiated?
Re: Custom Outline View for HTML files [message #228149 is a reply to message #228142] Sat, 21 February 2009 12:20 Go to previous messageGo to next message
Nitin Dahyabhai schrieb:>
> That shouldn't be necessary, after all, contentOutlineConfiguration is
> the same extension point as sourceViewerConfiguration. If one loads,
> the other should. Are you certain your content outline configuration
I'm quite sure. But because you made me uncertain, I started over (using
the Plugin Wizard) with a minimalistic example. I permit myself to
include all the files of this little test plugin at the end of this
post. When you run the plugin and create/open a file named test.html,
you'll see, that the constructor of the
StructuredTextViewerConfiguration is called, but the one of the
OutlineConfiguration is not.
-- MANIFEST.MF --
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: MyPlugin Plug-in
Bundle-SymbolicName: ch.raymi.plugin;singleton:=true
Bundle-Version: 1.0.0
Bundle-Activator: ch.raymi.plugin.Activator
Require-Bundle: org.eclipse.ui,
org.eclipse.core.runtime,
org.eclipse.wst.sse.ui,
org.eclipse.wst.html.ui;bundle-version="1.0.301",
org.eclipse.jface.text;bundle-version="3.4.1",
org.eclipse.wst.xml.ui;bundle-version="1.0.410"
Bundle-ActivationPolicy: lazy
Bundle-RequiredExecutionEnvironment: JavaSE-1.6
-- END OF MANIFEST.MF --
-- plugin.xml --
<?eclipse version="3.2"?>
<plugin>
<extension
<content-type
priority="high"
name="BX HTML"
id="bx"
<file-association
file-names="test.html" />
</extension>
<extension
class="ch.raymi.plugin.StructuredTextViewerConfiguration"
class="ch.raymi.plugin.OutlineConfiguration"
</extension>
</plugin>
-- END OF plugin.xml --
-- ch.raymi.plugin.Activator --
public class Activator extends AbstractUIPlugin {
Standard Implementation as generated by wizard
-- END OF ch.raymi.plugin.Activator --
-- ch.raymi.plugin.StructuredTextViewerConfiguration --
package ch.raymi.plugin;
import org.eclipse.wst.html.ui.StructuredTextViewerConfigurationHTM L;
public class StructuredTextViewerConfiguration extends
StructuredTextViewerConfigurationHTML {
public StructuredTextViewerConfiguration() {
System.out.println("structured configuration called");
-- END OF ch.raymi.plugin.StructuredTextViewerConfiguration --
-- ch.raymi.plugin.OutlineConfiguration --
import
org.eclipse.wst.html.ui.views.contentoutline.HTMLContentOutl ineConfiguration;
public class OutlineConfiguration extends HTMLContentOutlineConfiguration {
public OutlineConfiguration() {
System.out.println("outline configuration called");
-- END OF ch.raymi.plugin.OutlineConfiguration --
Re: Custom Outline View for HTML files [message #228164 is a reply to message #228149] Sat, 21 February 2009 23:45 Go to previous messageGo to next message
It's really confusing. I suppose the next step is to trace through
org.eclipse.wst.sse.ui.internal.ExtendedConfigurationBuilder and see
why it's not choosing your outline configuration class. Luckily,
you have the source for that :)
Nitin Dahyabhai
IBM Rational
Re: Custom Outline View for HTML files [message #228180 is a reply to message #228164] Sun, 22 February 2009 07:49 Go to previous messageGo to next message
> org.eclipse.wst.sse.ui.internal.ExtendedConfigurationBuilder and see why
> it's not choosing your outline configuration class. Luckily, you have
All's well that ends well.
I checked out the sources for ExtendedConfigurationBuilder & Co. (I
didn't manage to attach the source to my existing plugin project but I
was able to set breakpoints and inspect the variables' values). From the
information I gathered I guessed that I would have to change my target
ID's from my custom content type to
"org.eclipse.wst.html.core.htmlsource.source":
<extension
target="org.eclipse.wst.html.core.htmlsource.source"/>
</extension>
I can't believe it, but now it works! No need for a custom content type.
Funny though that if you change the target to
"org.eclipse.wst.html.core.htmlsource" the outline works no longer, but
the viewer configuration does. I don't even understand the difference
between the two content types. But - hey! - it works, so I don't really
care ;-)
Thanks for your patience and your hints Nitin. If there is a place where
I can post a little HowTo about this topic please tell me.
Dominik
Re: Custom Outline View for HTML files [message #228188 is a reply to message #228180] Sun, 22 February 2009 10:35 Go to previous message
> Cheers,
The WTP Wiki would be a good place. You can find it on the eclipse wiki:
http://wiki.eclipse.org/
Dave
Previous Topic:An internal error occurred during: "J2EEComponentMappingUpdateJob"
Next Topic:Debug RCP on WTP
Current Time: Sun Jun 01 07:20:06 EDT 2025
Powered by FUDForum. Page generated in 0.07084 seconds
