Home » Modeling » GMF (Graphical Modeling Framework) » Polygon
Polygon [message #227471] Sun, 26 April 2009 16:44 Go to next message
Hello
I want to draw a rectangle and the inside of this rectangle a polygon, I
want when I modify the size of rectangle the polygon still fix in its
place.
How to make it?
Re: Polygon [message #227504 is a reply to message #227471] Mon, 27 April 2009 05:35 Go to previous messageGo to next message
Originally posted by: cayla_sha.gmx.net
Hello Arij,
for how to define a figure in its own class and how to define a figure
always relativly to its bounds, look at the Port in the Taipan-Example:
http://wiki.eclipse.org/index.php/GMF_Tutorial#Quick_Start
For how to draw a figure inside of another figure, look at:
http://wiki.eclipse.org/GMF_Newsgroup_Q_and_A#How_do_I_draw_ an_ellipse_inside_another_ellipse.3F
Best wishes
Julia
Arij schrieb:
> Hello
> place.
> How to make it?
> Thanks
Re: Polygon [message #227602 is a reply to message #227471] Mon, 27 April 2009 08:10 Go to previous messageGo to next message
Hello Arij,
AFAIR this is a default behavior for Polygon figure.
Alex Shatalin
Re: Polygon [message #227764 is a reply to message #227602] Mon, 27 April 2009 16:10 Go to previous messageGo to next message
Yes sir but when I modify the size of rectangle the place of polygon is
going to change, but I want that the polygon is always stuck in border low
of rectangle.
Thank you
Re: Polygon [message #227840 is a reply to message #227764] Tue, 28 April 2009 07:03 Go to previous message
Hello Arij,
Then the reason should be in a figure containing this polygon. Can you check
if it was moved?
Alex Shatalin
Previous Topic:Drag and Drop on a diagram creates EditPart in wrong place
Next Topic:Taipan example: SVGFigure
Current Time: Sun Nov 09 20:37:03 EST 2025
Powered by FUDForum. Page generated in 0.04476 seconds
