Re: Bringing up the WSDL Editor in Debugger [message #227466 is a reply to message #227454] |
Thu, 29 January 2009 20:45 |
Originally posted by: dcarver.starstandard.org
Jesse Valianes wrote:
> I just recently got involved with developing for WTP, and I am having a
> problem. I've been looking into a bug involving the UI in the WSDL
> Editor (https://bugs.eclipse.org/bugs/show_bug.cgi?id=209289). When I
> try to debug the Eclipse Application and bring up the WSDL editor, the
> editor is different from the editor in my main Eclipse window, and among
> the various differences, the properties are inaccessible. How do I fix
> this?
> <a href="http://img518.imageshack.us/img518/7851/mainwindowuc1.jpg">Main
> Window</a>
> <a href="http://img98.imageshack.us/img98/9448/debugwindowrr3.jpg">Debug
> Window</a>
It appears to be bring up the XML editor instead of the WSDL editor.
When you are launching your application you are debugging, are all of
the WSDL related plugins being included. Are there any validation
warnings when you validate the launch configuration and plugin
configuration before launching?
If there are issues then you will need to fix those before you launch.
Re: Bringing up the WSDL Editor in Debugger [message #227474 is a reply to message #227470] |
Thu, 29 January 2009 23:35 |
> Thank you for the quick reply. In my run configurations I made sure that
> my plug-ins included everything in my workspace and the target platform.
> When I try to validate i get the same error in several packages saying
> "Missing Constraint: Require Bundle: org.eclipse.wst.wsdl;
> bundle-version=[1.1.0, 1.2.0)" I'm not sure why I get this error as this
> package is a part of my workspace.
Well since it can't seem to find that bundle, it is why you are having
issues, and you aren't getting the appropriate editor loaded. Is the
version in your workspace a different version number than what is being
requested. You can check the manifest file of the org.eclipse.wst.wsdl
to see.
Re: Bringing up the WSDL Editor in Debugger [message #227478 is a reply to message #227470] |
Fri, 30 January 2009 02:20 |
Originally posted by: valentinbaciu.hotmail.com
You have to ensure that you get the code from the branch that matches your
target. For example if you're trying to fix this in WTP 3.1 you will need a
recent WTP 3.1 target and code from HEAD. If you're trying to fix it in WTP
3.0.4 you need a WTP 3.0.4 target and code from the branch named
R3_0_maintenance.
Hope this helps. Valentin
"Jesse Valianes" <jvaliane@learn.senecac.on.ca> wrote in message
news:a0ebd237c00cd2c3711be2fc9af7c6fa$1@www.eclipse.org...
>>> this?
>>> Window</a>
>>> Window</a>
>> It appears to be bring up the XML editor instead of the WSDL editor. When
>> you are launching your application you are debugging, are all of the WSDL
>> related plugins being included. Are there any validation warnings when
>> you validate the launch configuration and plugin configuration before
>> launching?
FUDForum. Page generated in 0.04617 seconds
