Re: [EMFStore] authentication and authorization [message #1328469 is a reply to message #1328198] |
Fri, 02 May 2014 18:13 |
Scott Dybiec Messages: 148 Registered: July 2009 |
No worries, I figured it out by tracing through the code. Using the
'model' authentication policy fixed my problem.
On 5/2/2014 11:14 AM, scott@xxxxxxxx wrote:
> I resurrected the ESBrowser View. Good stuff. Now I'm trying to
> understand how authentication and authorization for users, groups and
> projects is supposed to work.
> On the server I've configured users/passwords using the 'Simple property
> file verification' user.properties file. But when I bring up the 'Manage
> Users and Groups' dialog, I don't see those users. Also, when I create
> users and/or change passwords through the UI, the users.properties file
> does not change. If I remove the user.properties file and users are only
> configured through the UI, then none of my users can log in, except
> 'super'.
> Where are the users, groups and project permissions persisted when they
> are configured through the UI. Should I expect changes made through the
> UI to be reflected in the SPFV auth file? If LDAP is used instead of the
> SPFV file, will changes made through the UI be reflected in LDAP?
> $cott
FUDForum. Page generated in 0.02613 seconds
