| Using CompilationUnitEditor without a .java file? [message #227093] |
Mon, 03 April 2006 21:45  |
Hi all,
I'm implementing an editor for Java source code, where the source is
unpacked from another file. As a result, there is no .java resource in
the project. Can someone give me some guidance on how best to set up a
CompilationUnitEditor to code from a buffer in memory?
Here's what I've done so far:
- I created a new input derived from IStorageEditorInput.
- I created a new document provider derived from StorageDocumentProvider.
- I created a new editor derived from CompilationUnitEditor that sets
the document provider to my document provider in the constructor.
What I'm fuzzy on is where exactly the file dependencies are. It's
pretty clear that CompilationUnitDocumentProvider assumes a file, and
that CompilationUnitEditor tests the document provider against
ICompilationUnitDocumentProvider. Is this the only file dependency in
CompilationUnitEditor? If so, would it be sufficient to have my document
provider implement ICompilationUnitDocumentProvider?
David
| Re: Using CompilationUnitEditor without a .java file? [message #227456 is a reply to message #227384] |
Sun, 09 April 2006 12:20  |
Originally posted by: daniel.megert.eclipse.org
>>> in the project. Can someone give me some guidance on how best to set
>>> up a CompilationUnitEditor to code from a buffer in memory?
>> It should be sufficient to write your own editor input and then use
>> IDE.openEditor(page, editorInput, editorID). What stopped this from
>> working?
> My editor is being opened in a page of a MultiPageEditor. openEditor
> is for a top-level editor. I did try what you suggested anyway, and I
> did get syntax highlighting, but not the annotations ruler.
Which build did you use?
Dani
> So I gave up on an in-memory editor input. Now I create temporary
> files in the workspace, and that seems to work well. I'll end up
> filtering them out of the workspace view so that the user doesn't notice.
> David
FUDForum. Page generated in 0.25251 seconds
