Re: FileChooser in RAP [message #1339036 is a reply to message #1327779] |
Wed, 07 May 2014 13:36 |
Hi all,
I find also this problem in the Dependencies for RAP .product and I think is the reason of my problem.
The five following plug-ins are marked with a red X:
- org.apache.commons.io
- org.apache.commons.fileupload
- org.eclipse.rap.rwt.supplemental.filedialog
- org.eclipse.rap.rwt.supplemental.fileupload
- org.eclipse.scout.rt.ui.rap.incubator.filechooser
Any suggestions about a possible solution of this problem?
Thanks in advance for any help
Re: FileChooser in RAP [message #1341132 is a reply to message #1340757] |
Thu, 08 May 2014 10:37 |
Hi Matthias,
I followed your suggestion, I uncheck "RAP FileChooser Support" and after I clean and rebuild my project. Afert that, I check "RAP FileChooser Support" again and I clean and rebuild again my project but unfortunately nothing change.
Re: FileChooser in RAP [message #1341368 is a reply to message #1341157] |
Thu, 08 May 2014 12:57 |
Hi Matthias,
yes I have different ScoutRAP.target (one for RAP, one for SWT, etc)
And the Target Content contains 895 items (see image below)
But I found in my console the following message, probably is directed linked to my problem. This message appears now after I follow your suggestion.
What do you think?
!ENTRY org.eclipse.osgi 2 0 2014-05-08 12:10:47.085
!MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2014-05-08 12:10:47.085
!MESSAGE Bundle update@../../Projects/scout/.metadata/.plugins/org.eclipse.pde.core/.bundle_pool/plugins/org.eclipse.scout.rt.ui.rap.incubator.filechooser_3.8.2.201302111336.jar was not resolved.
!SUBENTRY 2 org.eclipse.scout.rt.ui.rap.incubator.filechooser 2 0 2014-05-08 12:10:47.085
!MESSAGE Missing required bundle org.eclipse.scout.rt.ui.rap_3.8.2.
!ENTRY org.eclipse.osgi 2 0 2014-05-08 12:10:47.095
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2014-05-08 12:10:47.095
!MESSAGE Bundle org.eclipse.scout.rt.ui.rap.incubator.filechooser_3.8.2.201302111336 [98] was not resolved.
!SUBENTRY 2 org.eclipse.scout.rt.ui.rap.incubator.filechooser 2 0 2014-05-08 12:10:47.095
[Updated on: Thu, 08 May 2014 13:02] Report message to a moderator
Re: FileChooser in RAP [message #1343291 is a reply to message #1341433] |
Fri, 09 May 2014 08:10 |
Hi Matthias,
after this operation my UI.RAP goes in error and disappeared from the list (see image below)
And the following packages go in errors (see image below)
For example in class "StandaloneRwtEnvironment" the error reported is "AbstractStandaloneRwtEnvironment cannot be resolved to a type"
On the MANIFEST.MF, the error is located to Require-Bundle for the package "org.eclipse.scout.rt.ui.rap"
Can you help me to repair this errors?
Thanks in advance for your help
Re: FileChooser in RAP [message #1343393 is a reply to message #1343326] |
Fri, 09 May 2014 09:13 |
For SWT, the bundle "org.eclipse.scout.rt.ui.rap" is activated in the ScoutRAP.target
For RAP, in the ScoutRAP.target I have the following situation
First of all, have you an idea why I have a double entry of "org.eclipse.scout.rt.ui.rap"?
Second, I need to check only "org.eclipse.scout.rt.ui.rap" or also "org.eclipse.scout.rt.ui.rap.incubator.filechooser"?
Re: FileChooser in RAP [message #1343420 is a reply to message #1343410] |
Fri, 09 May 2014 09:29 |
Ok, I do.
The situation has improved a little; the error on MANIFEST.MF resolved but remain open on plugin.xml
and StandaloneRwtEnvironment.java
Attachment: err1.PNG
(Size: 11.85KB, Downloaded 916 times) -
Attachment: err2.PNG
(Size: 35.14KB, Downloaded 1020 times)
Re: FileChooser in RAP [message #1343441 is a reply to message #1343430] |
Fri, 09 May 2014 09:36 |
Yes, I alredy clean and rebuild but these errors remains.
Now I try to start the RAP and give me the following messages:
!SESSION 2014-05-09 11:35:13.668 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_24
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=it_IT
Framework arguments: -product org.zeiss.mo.scout.CZVEDIController.ui.rap.product
Command-line arguments: -product org.zeiss.mo.scout.CZVEDIController.ui.rap.product -data C:\Projects\scout/../runtime-CZVEDIController-rap-dev.product -dev file:C:/Projects/scout/.metadata/.plugins/org.eclipse.pde.core/CZVEDIController-rap-dev.product/dev.properties -os win32 -ws win32 -arch x86_64 -consoleLog
!ENTRY org.eclipse.equinox.app 0 0 2014-05-09 11:35:15.764
!MESSAGE Product org.zeiss.mo.scout.CZVEDIController.ui.rap.product could not be found.
!ENTRY org.eclipse.osgi 2 0 2014-05-09 11:35:15.814
!SUBENTRY 1 org.eclipse.osgi 2 0 2014-05-09 11:35:15.824
!MESSAGE Bundle update@../Projects/scout/.metadata/.plugins/org.eclipse.pde.core/.bundle_pool/plugins/org.eclipse.rap.rwt.supplemental.fileupload_1.5.0.20120220-1720.jar was not resolved.
!SUBENTRY 2 org.eclipse.rap.rwt.supplemental.fileupload 2 0 2014-05-09 11:35:15.824
!MESSAGE Missing required bundle org.eclipse.rap.rwt_1.5.0.
!MESSAGE Bundle update@../Projects/scout/.metadata/.plugins/org.eclipse.pde.core/.bundle_pool/plugins/org.eclipse.rap.rwt.supplemental.filedialog_1.5.0.20120220-1720.jar was not resolved.
!SUBENTRY 2 org.eclipse.rap.rwt.supplemental.filedialog 2 0 2014-05-09 11:35:15.824
!MESSAGE Missing required bundle org.eclipse.rap.rwt_0.0.0.
!MESSAGE Bundle update@../Projects/scout/.metadata/.plugins/org.eclipse.pde.core/.bundle_pool/plugins/org.eclipse.scout.rt.ui.rap_3.8.2.201302111336.jar was not resolved.
!SUBENTRY 2 org.eclipse.scout.rt.ui.rap 2 0 2014-05-09 11:35:15.824
!MESSAGE Missing required bundle org.eclipse.rap.jface_1.5.0.
!MESSAGE Missing required bundle org.eclipse.rap.ui_1.5.0.
!MESSAGE Missing required bundle org.eclipse.rap.ui.forms_1.5.0.
!MESSAGE Missing required bundle org.eclipse.rap.jface.databinding_1.5.0.
!ENTRY org.eclipse.osgi 2 0 2014-05-09 11:35:15.834
!SUBENTRY 1 org.eclipse.osgi 2 0 2014-05-09 11:35:15.834
!MESSAGE Bundle org.zeiss.mo.scout.CZVEDIController.ui.rap_1.0.0.qualifier [9] was not resolved.
!SUBENTRY 2 org.zeiss.mo.scout.CZVEDIController.ui.rap 2 0 2014-05-09 11:35:15.834
!MESSAGE Missing required bundle org.eclipse.scout.rt.ui.rap_0.0.0.
!MESSAGE Bundle org.eclipse.rap.rwt.supplemental.filedialog_1.5.0.20120220-1720 [82] was not resolved.
!SUBENTRY 2 org.eclipse.rap.rwt.supplemental.filedialog 2 0 2014-05-09 11:35:15.834
!MESSAGE Missing required bundle org.eclipse.rap.rwt.supplemental.fileupload_1.5.0.
!MESSAGE Bundle org.eclipse.rap.rwt.supplemental.fileupload_1.5.0.20120220-1720 [83] was not resolved.
!SUBENTRY 2 org.eclipse.rap.rwt.supplemental.fileupload 2 0 2014-05-09 11:35:15.834
!MESSAGE Bundle org.eclipse.scout.rt.ui.rap_3.8.2.201302111336 [85] was not resolved.
!SUBENTRY 2 org.eclipse.scout.rt.ui.rap 2 0 2014-05-09 11:35:15.834
Instead in SWT all works fine
[Updated on: Fri, 09 May 2014 09:37] Report message to a moderator
Re: FileChooser in RAP [message #1349529 is a reply to message #1349476] |
Mon, 12 May 2014 08:26 |
Hi Matthias,
I do what you suggest only in ScoutRAP.target for RAP section, not in SWT or Swing section, after that I clean and rebuild entirerly my project but the errors that I highlighted in my previous post remains.
I check and for the class StandaloneRwtEnvironment.java, the error become the following "The hierarchy of the type StandaloneRwtEnvironment is inconsistent"; instead in plugin.xml remains all the same.
Have you other suggestions or ideas?
Re: FileChooser in RAP [message #1349593 is a reply to message #1349547] |
Mon, 12 May 2014 09:00 |
Hi Matthias,
I create a new project and add FileChooser but when I start in RAP my project give me the same error present in my official project. But I haven't signs of error on plugin.xml and on class StandaloneRwtEnvironment.java, now I compare them.
The console error message is:
Framework arguments: -product org.zeiss.test.ui.rap.product
Command-line arguments: -product org.zeiss.test.ui.rap.product -data C:\Projects\scout/../runtime-test-rap-dev.product -dev file:C:/Projects/scout/.metadata/.plugins/org.eclipse.pde.core/test-rap-dev.product/dev.properties -os win32 -ws win32 -arch x86_64 -consoleLog
!ENTRY org.eclipse.osgi 2 0 2014-05-12 10:55:13.409
!SUBENTRY 1 org.eclipse.osgi 2 0 2014-05-12 10:55:13.409
!SUBENTRY 2 org.eclipse.scout.rt.ui.rap.incubator.filechooser 2 0 2014-05-12 10:55:13.409
!MESSAGE Bundle org.eclipse.scout.rt.ui.rap.incubator.filechooser_3.8.2.201302111336 [85] was not resolved.
Re: FileChooser in RAP [message #1349627 is a reply to message #1349593] |
Mon, 12 May 2014 09:25 |
Hi Matthias,
I find some differences in ScoutRAP.target and *.product, I replace some difference and now I'm back to the initial situation reported on the initial post of this thread.
Quote:Hi all,
I have a problem with FileChooser in RAP because it doesn't work correctly (see image below), instead in SWT works fine.
I followed this tutorial http://wiki.eclipse.org/Scout/HowTo/3.9/Add_FileChooser_support_for_RAP_UI
index.php/fa/18008/0/
I use Eclipse Juno 3.8
And this is my configuration:
index.php/fa/18033/0/
Thanks in advance for any help and suggestions
Attachment: img_FileChooser.PNG
(Size: 3.92KB, Downloaded 201 times)
Attachment: imgRapVers.PNG
Re: FileChooser in RAP [message #1349656 is a reply to message #1349647] |
Mon, 12 May 2014 09:35 |
Here it is:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<?pde version="3.8"?>
<target name="ScoutRAP" sequenceNumber="18">
<locations>
<location includeAllPlatforms="false" includeConfigurePhase="false" includeMode="slicer" includeSource="true" type="InstallableUnit">
<unit id="org.eclipse.scout.rt.ui.rap.incubator.filechooser.feature.feature.group" version="3.8.2.201302111336"/>
<location path="${eclipse_home}\rap_target" type="Directory"/>
</location>
<location path="${eclipse_home}\" type="Directory"/>
<unit id="org.eclipse.rap.runtime.feature.group" version="1.5.2.20130205-2024"/>
<repository location="http://download.eclipse.org/releases/juno"/>
</location>
<unit id="org.eclipse.scout.rt.rap.feature.feature.group" version="3.8.2.201302111336"/>
</location>
<location path="C:\eclipse_scout\deltapack_4.2.2" type="Directory"/>
<location path="C:\eclipse_scout\rap_target" type="Directory"/>
<unit id="org.eclipse.rap.incubator.supplemental.fileupload.feature.feature.group" version="1.5.0.20120220-1720"/>
<repository location="http://download.eclipse.org/rt/rap/1.5/incubator"/>
</location>
<location includeAllPlatforms="false" includeConfigurePhase="true" includeMode="slicer" includeSource="true" type="InstallableUnit">
<repository location="http://download.eclipse.org/scout/releases/3.8"/>
</location>
</locations>
<includeBundles>
<plugin id="javax.el.source"/>
<plugin id="org.eclipse.jface.databinding"/>
<plugin id="javax.mail"/>
<plugin id="org.eclipse.ui.workbench"/>
<plugin id="org.eclipse.ui.views.properties.tabbed.source"/>
<plugin id="org.eclipse.platform"/>
<plugin id="org.eclipse.e4.ui.workbench.addons.swt"/>
<plugin id="org.eclipse.mylyn.discovery.ui"/>
<plugin id="org.eclipse.equinox.security.ui"/>
<plugin id="org.eclipse.mylyn.discovery.core"/>
<plugin id="org.eclipse.core.filebuffers.source"/>
<plugin id="org.eclipse.core.runtime.compatibility.registry.source"/>
<plugin id="org.eclipse.rap.tools.launch.rwt.source"/>
<plugin id="org.eclipse.ui.externaltools.source"/>
<plugin id="org.eclipse.jdt"/>
<plugin id="org.eclipse.wst.wsdl.ui"/>
<plugin id="org.eclipse.ant.launching"/>
<plugin id="org.eclipse.emf.codegen"/>
<plugin id="org.eclipse.wst.validation.ui"/>
<plugin id="org.eclipse.equinox.launcher.source"/>
<plugin id="org.eclipse.osgi.services"/>
<plugin id="org.eclipse.wst.command.env.infopop"/>
<plugin id="org.eclipse.ecf.filetransfer"/>
<plugin id="org.eclipse.mylyn.wikitext.confluence.core"/>
<plugin id="org.eclipse.ui.editors" version="3.6.0.v20100520-0800"/>
<plugin id="org.eclipse.wst.common.project.facet.ui"/>
<plugin id="org.eclipse.e4.ui.di.source"/>
<plugin id="org.eclipse.wst.command.env"/>
<plugin id="org.eclipse.ui.intro"/>
<plugin id="org.eclipse.equinox.p2.metadata.repository"/>
<plugin id="org.eclipse.pde.ds.ui"/>
<plugin id="org.eclipse.wst.ws.parser"/>
<plugin id="org.eclipse.wst.ws.infopop"/>
<plugin id="org.eclipse.ltk.core.refactoring.source"/>
<plugin id="org.hamcrest.core.source"/>
<plugin id="org.eclipse.equinox.p2.jarprocessor"/>
<plugin id="org.eclipse.jem.beaninfo"/>
<plugin id="org.eclipse.e4.ui.workbench3"/>
<plugin id="org.eclipse.mylyn.commons.workbench"/>
<plugin id="org.eclipse.jetty.continuation.source"/>
<plugin id="org.eclipse.jdt.launching.source"/>
<plugin id="org.eclipse.wb.os" version="1.6.1.r42x201401161243"/>
<plugin id="org.eclipse.team.svn.sources"/>
<plugin id="org.eclipse.wst.html.core"/>
<plugin id="org.eclipse.libra.framework.core"/>
<plugin id="org.eclipse.pde.ds.ui.source"/>
<plugin id="org.eclipse.equinox.preferences.source"/>
<plugin id="org.eclipse.jst.jee.ui"/>
<plugin id="org.eclipse.pde"/>
<plugin id="org.eclipse.equinox.p2.publisher.eclipse"/>
<plugin id="org.eclipse.equinox.event.source"/>
<plugin id="org.eclipse.e4.ui.workbench.addons.swt.source" version="0.10.3.v20130124-185622"/>
<plugin id="org.eclipse.mylyn.help.ui"/>
<plugin id="org.eclipse.equinox.p2.ui.sdk"/>
<plugin id="org.eclipse.equinox.p2.publisher"/>
<plugin id="javax.xml.bind"/>
<plugin id="org.eclipse.scout.svg.ui.swing"/>
<plugin id="org.eclipse.equinox.frameworkadmin.equinox"/>
<plugin id="org.eclipse.wb.core.databinding.xml" version="1.7.0.r42x201405021458"/>
<plugin id="org.eclipse.wst.internet.monitor.ui"/>
<plugin id="org.eclipse.libra.framework.editor.integration"/>
<plugin id="org.eclipse.scout.rt.ui.rap" version="3.8.2.201302111336"/>
<plugin id="org.eclipse.xsd.edit"/>
<plugin id="org.eclipse.gef.doc.isv"/>
<plugin id="org.eclipse.mylyn.team.ui"/>
<plugin id="org.eclipse.core.runtime.source"/>
<plugin id="org.eclipse.scout.nls.sdk.services.source"/>
<plugin id="org.eclipse.wst.xml.ui.infopop"/>
<plugin id="org.eclipse.pde.api.tools.source"/>
<plugin id="org.eclipse.mylyn.ide.ui"/>
<plugin id="org.eclipse.equinox.p2.directorywatcher"/>
<plugin id="org.eclipse.jst.standard.schemas"/>
<plugin id="org.apache.xmlrpc"/>
<plugin id="org.eclipse.ui.views.source"/>
<plugin id="org.eclipse.compare.core.source"/>
<plugin id="org.eclipse.jetty.http"/>
<plugin id="org.eclipse.e4.core.services"/>
<plugin id="org.eclipse.wb.swing.FormLayout" version="1.7.0.r42x201405021531"/>
<plugin id="org.eclipse.text.source"/>
<plugin id="org.eclipse.rap.tools.launch"/>
<plugin id="org.eclipse.scout.svg.ui.swt.source"/>
<plugin id="org.eclipse.wb.rcp.databinding" version="1.6.1.r42x201401161337"/>
<plugin id="org.eclipse.e4.ui.model.workbench.source"/>
<plugin id="org.eclipse.wb.rcp.SWT_AWT" version="1.7.0.r42x201405021546"/>
<plugin id="org.eclipse.mylyn.wikitext.tasks.ui"/>
<plugin id="org.eclipse.scout.sdk.rap.source"/>
<plugin id="org.eclipse.wst.common.infopop"/>
<plugin id="org.eclipse.libra.framework.equinox.ui"/>
<plugin id="org.eclipse.team.core.source"/>
<plugin id="org.eclipse.epp.package.scout"/>
<plugin id="org.apache.ws.commons.util"/>
<plugin id="org.eclipse.pde.runtime"/>
<plugin id="org.eclipse.jem.workbench"/>
<plugin id="org.eclipse.zest.doc.isv"/>
<plugin id="org.eclipse.gef.examples.logic"/>
<plugin id="org.eclipse.scout.sdk.ui.source"/>
<plugin id="org.eclipse.platform.source"/>
<plugin id="org.eclipse.wst.wsi.ui"/>
<plugin id="org.eclipse.core.databinding"/>
<plugin id="org.eclipse.ui.intro.source"/>
<plugin id="org.eclipse.equinox.p2.director.app.source"/>
<plugin id="org.eclipse.rcp.source"/>
<plugin id="org.eclipse.jst.jee"/>
<plugin id="org.eclipse.e4.ui.model.workbench"/>
<plugin id="org.eclipse.equinox.security.ui.source"/>
<plugin id="org.eclipse.ui.navigator.resources.source"/>
<plugin id="javax.xml.soap"/>
<plugin id="javax.xml.ws"/>
<plugin id="org.eclipse.wb.core.databinding" version="1.7.0.r42x201405021448"/>
<plugin id="org.eclipse.compare.source"/>
<plugin id="org.eclipse.wst.xsd.core"/>
<plugin id="org.eclipse.equinox.p2.artifact.repository.source"/>
<plugin id="org.eclipse.wst.common.emf"/>
<plugin id="org.eclipse.jst.common.project.facet.ui"/>
<plugin id="org.eclipse.equinox.p2.extensionlocation.source"/>
<plugin id="org.eclipse.scout.sdk.rap.ui.source"/>
<plugin id="org.eclipse.emf.ecore"/>
<plugin id="org.eclipse.pde.ui.templates.source"/>
<plugin id="org.eclipse.jst.ws.jaxws.dom.integration"/>
<plugin id="org.eclipse.scout.sdk.compatibility"/>
<plugin id="org.eclipse.ui.workbench.source" version="3.104.0.v20130204-164612"/>
<plugin id="org.eclipse.scout.sdk.util"/>
<plugin id="org.eclipse.ui.navigator.source"/>
<plugin id="org.eclipse.wb.runtime.lib" version="1.6.1.r42x201401161243"/>
<plugin id="javax.servlet.source"/>
<plugin id="org.eclipse.team.cvs.core.source"/>
<plugin id="org.eclipse.jdt.ui.source"/>
<plugin id="org.eclipse.wb.rcp" version="1.6.1.r42x201401161337"/>
<plugin id="org.eclipse.scout.sdk.compatibility.v38v42.fragment"/>
<plugin id="org.eclipse.wst.xml.core"/>
<plugin id="org.eclipse.jsch.ui"/>
<plugin id="org.eclipse.wst.html.ui"/>
<plugin id="org.eclipse.jst.ws.jaxws.ui"/>
<plugin id="org.eclipse.scout.rt.ui.swing.browser.swt.fragment.source"/>
<plugin id="org.eclipse.scout.service.source"/>
<plugin id="org.eclipse.equinox.p2.ui.importexport"/>
<plugin id="org.eclipse.search"/>
<plugin id="org.eclipse.jst.j2ee.web"/>
<plugin id="org.eclipse.search.source"/>
<plugin id="org.eclipse.jdt.ui"/>
<plugin id="org.eclipse.core.runtime.compatibility.registry"/>
<plugin id="org.eclipse.equinox.p2.publisher.eclipse.source"/>
<plugin id="org.eclipse.team.svn.mylyn"/>
<plugin id="org.eclipse.core.expressions"/>
<plugin id="org.eclipse.wst.sse.ui.infopop"/>
<plugin id="org.apache.lucene.core"/>
<plugin id="org.eclipse.jst.j2ee.jca"/>
<plugin id="org.eclipse.team.ui.source"/>
<plugin id="org.eclipse.jetty.security.source"/>
<plugin id="org.eclipse.libra.framework.felix.ui"/>
<plugin id="org.apache.derby.jdbc_1082.fragment.source"/>
<plugin id="org.eclipse.wb.rcp.nebula" version="1.6.1.r42x201401161337"/>
<plugin id="org.eclipse.wst.common.emfworkbench.integration"/>
<plugin id="org.eclipse.scout.sdk.help.source"/>
<plugin id="org.eclipse.jdt.launching"/>
<plugin id="org.eclipse.ltk.core.refactoring"/>
<plugin id="org.eclipse.rap.tools.intro"/>
<plugin id="org.eclipse.ui"/>
<plugin id="org.eclipse.debug.ui.source"/>
<plugin id="org.eclipse.equinox.jsp.jasper.registry.source"/>
<plugin id="org.eclipse.help.ui"/>
<plugin id="org.apache.commons.logging"/>
<plugin id="org.eclipse.compare.win32.source"/>
<plugin id="org.eclipse.team.svn.resource.ignore.rules.jdt.source"/>
<plugin id="org.eclipse.scout.rt.jdbc.derby.source"/>
<plugin id="org.eclipse.jst.server.core"/>
<plugin id="org.eclipse.gef.examples.text"/>
<plugin id="org.eclipse.wb.core.databinding.xml" version="1.6.1.r42x201401161254"/>
<plugin id="org.eclipse.jst.jee.web"/>
<plugin id="org.eclipse.equinox.app"/>
<plugin id="org.eclipse.mylyn.commons.notifications.core"/>
<plugin id="org.eclipse.team.svn.mylyn.source"/>
<plugin id="org.eclipse.ui.console"/>
<plugin id="org.eclipse.wb.runtime.lib" version="1.7.0.r42x201405021445"/>
<plugin id="org.eclipse.wb.core.java" version="1.7.0.r42x201405021448"/>
<plugin id="org.eclipse.swt.win32.win32.x86_64.source" version="3.100.1.v4236b"/>
<plugin id="org.w3c.dom.smil"/>
<plugin id="org.eclipse.equinox.preferences"/>
<plugin id="org.eclipse.team.cvs.ssh2.source"/>
<plugin id="org.eclipse.wst.validation"/>
<plugin id="org.eclipse.wst.common.uriresolver"/>
<plugin id="org.eclipse.wst.css.core"/>
<plugin id="org.apache.felix.gogo.command.source"/>
<plugin id="org.eclipse.mylyn.commons.identity"/>
<plugin id="org.eclipse.jdt.doc.user"/>
<plugin id="org.eclipse.scout.nls.sdk.simple"/>
<plugin id="org.eclipse.zest.layouts"/>
<plugin id="org.eclipse.help.webapp"/>
<plugin id="org.eclipse.ui.source"/>
<plugin id="org.eclipse.gef.examples.ui.pde"/>
<plugin id="org.eclipse.wb.core.databinding" version="1.6.1.r42x201401161246"/>
<plugin id="org.apache.jasper.glassfish.source"/>
<plugin id="org.eclipse.ui.workbench.source" version="3.104.0.v20121219-151754"/>
<plugin id="org.eclipse.jdt.core.manipulation.source"/>
<plugin id="org.eclipse.scout.rt.ui.swt"/>
<plugin id="org.eclipse.e4.ui.workbench.renderers.swt.source" version="0.10.3.v20121206-163705"/>
<plugin id="org.eclipse.wb.rcp.databinding" version="1.7.0.r42x201405021526"/>
<plugin id="org.eclipse.equinox.http.registry"/>
<plugin id="javax.xml.stream"/>
<plugin id="org.eclipse.core.filesystem.source"/>
<plugin id="org.apache.ant.source"/>
<plugin id="org.eclipse.wst.common.environment"/>
<plugin id="org.jdom"/>
<plugin id="org.eclipse.jst.common.annotations.controller"/>
<plugin id="org.eclipse.wst.wsdl.ui.doc.user"/>
<plugin id="org.eclipse.scout.net.source"/>
<plugin id="org.eclipse.jface.text.source"/>
<plugin id="org.eclipse.pde.build.source"/>
<plugin id="org.eclipse.e4.ui.workbench3.source"/>
<plugin id="org.eclipse.ecf.provider.filetransfer.ssl"/>
<plugin id="org.eclipse.wst.xml.ui"/>
<plugin id="org.eclipse.scout.http.servletfilter.source"/>
<plugin id="org.eclipse.libra.framework.jonas"/>
<plugin id="org.eclipse.team.cvs.core"/>
<plugin id="org.eclipse.equinox.p2.metadata.repository.source"/>
<plugin id="org.eclipse.core.jobs.source"/>
<plugin id="org.eclipse.e4.core.services.source"/>
<plugin id="org.eclipse.equinox.servletbridge"/>
<plugin id="org.eclipse.wb.swing" version="1.6.1.r42x201401161333"/>
<plugin id="org.eclipse.equinox.jsp.jasper.registry"/>
<plugin id="org.eclipse.equinox.jsp.jasper.source"/>
<plugin id="org.eclipse.gef.examples.logic.source"/>
<plugin id="org.eclipse.scout.rt.client"/>
<plugin id="org.eclipse.wst.sse.doc.user"/>
<plugin id="org.eclipse.epp.mpc.core"/>
<plugin id="org.eclipse.scout.rt.ui.swt.source"/>
<plugin id="org.eclipse.e4.core.contexts.source" version="1.2.0.v20121024-182359"/>
<plugin id="org.eclipse.equinox.p2.ui.source"/>
<plugin id="org.eclipse.scout.rt.ui.rap.incubator.filechooser"/>
<plugin id="org.eclipse.wst.ws.explorer"/>
<plugin id="org.eclipse.help"/>
<plugin id="org.eclipse.jetty.security"/>
<plugin id="org.eclipse.mylyn.commons.ui"/>
<plugin id="org.eclipse.equinox.simpleconfigurator"/>
<plugin id="org.eclipse.scout.sdk.compatibility.v35.fragment.source"/>
<plugin id="org.eclipse.equinox.simpleconfigurator.manipulator"/>
<plugin id="org.eclipse.team.svn.resource.ignore.rules.jdt"/>
<plugin id="org.eclipse.ui.ide.source"/>
<plugin id="org.eclipse.jst.ws.jaxws.core"/>
<plugin id="org.eclipse.core.databinding.beans.source"/>
<plugin id="org.apache.ant"/>
<plugin id="org.eclipse.equinox.p2.touchpoint.eclipse.source"/>
<plugin id="org.eclipse.team.svn.ui.startup"/>
<plugin id="com.jcraft.jsch.source"/>
<plugin id="org.eclipse.swt.win32.win32.x86_64.source" version="3.100.1.v4235f"/>
<plugin id="org.eclipse.mylyn.wikitext.twiki.ui"/>
<plugin id="org.eclipse.osgi.source"/>
<plugin id="org.eclipse.equinox.p2.discovery.compatibility"/>
<plugin id="org.eclipse.osgi.util.source"/>
<plugin id="org.eclipse.pde.build"/>
<plugin id="org.apache.commons.codec" version="1.3.0.v201101211617"/>
<plugin id="org.eclipse.pde.ui.templates"/>
<plugin id="org.apache.commons.httpclient.source"/>
<plugin id="org.eclipse.equinox.p2.repository"/>
<plugin id="org.eclipse.equinox.http.servletbridge"/>
<plugin id="org.eclipse.wst.web.ui"/>
<plugin id="org.eclipse.e4.core.di.extensions"/>
<plugin id="org.eclipse.wb.rcp.databinding.xwt" version="1.6.1.r42x201401161343"/>
<plugin id="org.eclipse.ui.win32"/>
<plugin id="org.eclipse.wb.swt" version="1.6.1.r42x201401161320"/>
<plugin id="org.eclipse.wst.ws.service.policy"/>
<plugin id="org.eclipse.wb.os.win32" version="1.7.0.r42x201405021445"/>
<plugin id="org.eclipse.scout.sdk.compatibility.v38v42.fragment.source"/>
<plugin id="org.eclipse.scout.nls.sdk"/>
<plugin id="org.eclipse.scout.rt.feature.about"/>
<plugin id="org.eclipse.e4.ui.css.swt.theme.source"/>
<plugin id="org.eclipse.team.cvs.ui"/>
<plugin id="org.eclipse.mylyn.bugzilla.core"/>
<plugin id="org.eclipse.libra.framework.editor.ui"/>
<plugin id="org.eclipse.e4.ui.workbench"/>
<plugin id="org.eclipse.e4.ui.css.core"/>
<plugin id="org.eclipse.osgi.services.source"/>
<plugin id="org.eclipse.jst.jsp.ui.infopop"/>
<plugin id="org.apache.batik.ext.awt"/>
<plugin id="org.eclipse.equinox.security.win32.x86_64"/>
<plugin id="org.eclipse.jst.j2ee.ejb"/>
<plugin id="org.eclipse.wb.swing.jsr296" version="1.7.0.r42x201405021531"/>
<plugin id="org.apache.commons.logging.source"/>
<plugin id="org.eclipse.jem"/>
<plugin id="org.eclipse.wb.core" version="1.6.1.r42x201401161243"/>
<plugin id="org.junit4"/>
<plugin id="org.eclipse.ui.editors" version="3.8.0.v20120523-1540"/>
<plugin id="org.eclipse.e4.ui.services.source" version="0.10.2.v20121129-151235"/>
<plugin id="org.eclipse.mylyn.commons.core"/>
<plugin id="org.eclipse.wst.internet.cache"/>
<plugin id="org.apache.commons.fileupload"/>
<plugin id="org.eclipse.compare"/>
<plugin id="org.eclipse.scout.sdk.compatibility.source"/>
<plugin id="org.eclipse.ui.views"/>
<plugin id="javax.xml.rpc"/>
<plugin id="org.eclipse.jdt.annotation"/>
<plugin id="org.eclipse.update.configurator.source"/>
<plugin id="org.eclipse.mylyn.wikitext.twiki.core"/>
<plugin id="org.eclipse.equinox.launcher.win32.win32.x86_64"/>
<plugin id="org.eclipse.jst.server.ui"/>
<plugin id="org.eclipse.wb.doc.user" version="1.7.0.r42x201405021506"/>
<plugin id="org.eclipse.equinox.app.source"/>
<plugin id="org.apache.batik.dom"/>
<plugin id="org.eclipse.ui.workbench.texteditor"/>
<plugin id="org.eclipse.scout.sdk.rap.ui"/>
<plugin id="org.eclipse.jst.common.project.facet.core"/>
<plugin id="org.eclipse.wb.core.ui" version="1.7.0.r42x201405021455"/>
<plugin id="org.eclipse.ecf.provider.filetransfer.httpclient"/>
<plugin id="javax.annotation"/>
<plugin id="org.eclipse.wb.swing.doc.user" version="1.6.1.r42x201401180444"/>
<plugin id="org.eclipse.scout.sdk.ws.jaxws"/>
<plugin id="org.eclipse.equinox.security"/>
<plugin id="org.eclipse.pde.runtime.source"/>
<plugin id="org.eclipse.jst.j2ee.ui"/>
<plugin id="com.oracle.oracle11g.jdbc.fragment"/>
<plugin id="org.eclipse.equinox.p2.ui"/>
<plugin id="org.eclipse.ui.workbench.texteditor.source"/>
<plugin id="org.eclipse.e4.ui.widgets.source"/>
<plugin id="org.eclipse.text"/>
<plugin id="org.eclipse.core.resources.source"/>
<plugin id="org.eclipse.ui.editors" version="3.7.0.v20110517-0800"/>
<plugin id="org.eclipse.equinox.security.source"/>
<plugin id="org.eclipse.wb.os.win32" version="1.6.1.r42x201401161243"/>
<plugin id="org.eclipse.team.core"/>
<plugin id="org.eclipse.team.ui"/>
<plugin id="org.eclipse.jetty.continuation"/>
<plugin id="org.eclipse.compare.win32"/>
<plugin id="org.eclipse.wb.swing.FormLayout" version="1.6.1.r42x201401161333"/>
<plugin id="org.eclipse.compare.core"/>
<plugin id="org.eclipse.jdt.annotation.source"/>
<plugin id="org.eclipse.ecf.filetransfer.source"/>
<plugin id="org.polarion.eclipse.team.svn.connector.sources"/>
<plugin id="org.objectweb.asm.source"/>
<plugin id="org.eclipse.mylyn.commons.notifications.ui"/>
<plugin id="org.polarion.eclipse.team.svn.connector.javahl17"/>
<plugin id="org.eclipse.equinox.p2.ui.sdk.scheduler"/>
<plugin id="org.eclipse.jst.j2ee"/>
<plugin id="org.eclipse.mylyn.tasks.index.core"/>
<plugin id="org.eclipse.draw2d"/>
<plugin id="org.eclipse.e4.ui.services.source" version="0.10.3.v20130123-162658"/>
<plugin id="org.eclipse.mylyn.commons.screenshots"/>
<plugin id="org.w3c.css.sac"/>
<plugin id="org.eclipse.wst.internet.monitor.core"/>
<plugin id="org.eclipse.core.net"/>
<plugin id="org.eclipse.jdt.compiler.apt"/>
<plugin id="org.eclipse.scout.sdk.rap"/>
<plugin id="org.eclipse.jdt.compiler.tool"/>
<plugin id="com.bsiag.scout.rt.server.jdbc.oracle11g2.source"/>
<plugin id="org.eclipse.wst.sse.ui"/>
<plugin id="org.eclipse.pde.ds.core"/>
<plugin id="org.objectweb.asm"/>
<plugin id="org.eclipse.emf.edit.ui"/>
<plugin id="org.polarion.eclipse.team.svn.connector"/>
<plugin id="org.eclipse.jsch.core"/>
<plugin id="javax.xml"/>
<plugin id="org.eclipse.team.svn.nl1"/>
<plugin id="org.eclipse.wb.core" version="1.7.0.r42x201405021445"/>
<plugin id="org.apache.batik.parser"/>
<plugin id="org.eclipse.wb.swing.FormLayout.lib" version="1.7.0.r42x201405021531"/>
<plugin id="org.eclipse.ui.forms.source"/>
<plugin id="org.eclipse.rap.rwt.supplemental.filedialog"/>
<plugin id="org.eclipse.mylyn.ide.ant"/>
<plugin id="org.eclipse.core.databinding.property.source"/>
<plugin id="org.eclipse.jdt.core"/>
<plugin id="org.eclipse.wb.swing.jsr296" version="1.6.1.r42x201401161333"/>
<plugin id="org.eclipse.sdk"/>
<plugin id="org.eclipse.rap.tools.templates.source"/>
<plugin id="org.eclipse.mylyn.wikitext.tracwiki.ui"/>
<plugin id="org.eclipse.equinox.p2.reconciler.dropins.source"/>
<plugin id="org.eclipse.wb.swing.MigLayout" version="1.6.1.r42x201401161333"/>
<plugin id="com.ibm.icu.source"/>
<plugin id="org.eclipse.mylyn.wikitext.confluence.ui"/>
<plugin id="org.eclipse.jst.ws.jaxb.core"/>
<plugin id="org.eclipse.jst.j2ee.navigator.ui"/>
<plugin id="org.eclipse.jetty.xml"/>
<plugin id="com.jcraft.jsch"/>
<plugin id="org.eclipse.scout.sdk.util.source"/>
<plugin id="org.eclipse.equinox.p2.director"/>
<plugin id="org.eclipse.zest.core.source"/>
<plugin id="org.eclipse.wst.ws"/>
<plugin id="org.eclipse.equinox.p2.repository.tools"/>
<plugin id="org.eclipse.ecf.provider.filetransfer"/>
<plugin id="org.eclipse.jdt.doc.isv"/>
<plugin id="org.eclipse.equinox.http.jetty"/>
<plugin id="org.eclipse.wst.wsi"/>
<plugin id="org.eclipse.gef"/>
<plugin id="org.apache.lucene.analysis"/>
<plugin id="org.eclipse.scout.rt.ui.svg.calendar"/>
<plugin id="org.eclipse.e4.ui.css.core.source"/>
<plugin id="javax.inject"/>
<plugin id="org.eclipse.wst.sse.core"/>
<plugin id="org.eclipse.osgi"/>
<plugin id="org.eclipse.rcp"/>
<plugin id="org.eclipse.e4.ui.workbench.addons.swt.source" version="0.10.2.v20121204-133635"/>
<plugin id="org.apache.batik.util.gui"/>
<plugin id="org.eclipse.equinox.p2.updatechecker.source"/>
<plugin id="org.eclipse.rap.tools.launch.rwt"/>
<plugin id="org.eclipse.platform.doc.isv"/>
<plugin id="org.eclipse.help.base"/>
<plugin id="org.easymock"/>
<plugin id="org.eclipse.libra.framework.editor.core"/>
<plugin id="org.eclipse.mylyn.wikitext.tracwiki.core"/>
<plugin id="org.eclipse.jetty.io.source"/>
<plugin id="org.eclipse.wb.xwt" version="1.7.0.r42x201405021548"/>
<plugin id="org.eclipse.mylyn.commons.identity.core"/>
<plugin id="org.eclipse.jdt.junit"/>
<plugin id="org.eclipse.core.databinding.observable.source"/>
<plugin id="org.eclipse.core.jobs"/>
<plugin id="org.eclipse.ant.launching.source"/>
<plugin id="org.eclipse.jface"/>
<plugin id="org.eclipse.debug.core"/>
<plugin id="org.eclipse.e4.core.commands"/>
<plugin id="org.eclipse.mylyn.context.ui"/>
<plugin id="org.eclipse.ecf.identity.source"/>
<plugin id="org.eclipse.e4.ui.widgets"/>
<plugin id="org.eclipse.equinox.p2.ui.importexport.source"/>
<plugin id="org.apache.lucene.analysis.source"/>
<plugin id="org.eclipse.pde.ui.source"/>
<plugin id="org.eclipse.e4.ui.workbench.source" version="0.10.3.v20121207-204447"/>
<plugin id="org.eclipse.e4.ui.workbench.swt.source" version="0.10.3.v20130124-133900"/>
<plugin id="org.eclipse.core.externaltools.source"/>
<plugin id="org.polarion.eclipse.team.svn.connector.javahl16.sources"/>
<plugin id="org.eclipse.mylyn.commons.net"/>
<plugin id="org.eclipse.mylyn.tasks.core"/>
<plugin id="org.eclipse.jst.common.frameworks"/>
<plugin id="org.eclipse.jst.jsp.core"/>
<plugin id="org.eclipse.wst.dtd.core"/>
<plugin id="org.eclipse.jdt.compiler.tool.source"/>
<plugin id="org.eclipse.team.svn.nl1.sources"/>
<plugin id="org.eclipse.wb.rcp.swing2swt" version="1.7.0.r42x201405021526"/>
<plugin id="org.eclipse.mylyn.resources.ui"/>
<plugin id="org.eclipse.gef.examples.shapes"/>
<plugin id="com.oracle.oracle11g.jdbc.fragment.source"/>
<plugin id="org.eclipse.equinox.ds.source"/>
<plugin id="org.eclipse.cvs"/>
<plugin id="org.eclipse.equinox.http.jetty.source"/>
<plugin id="org.eclipse.scout.svg.ui.swt"/>
<plugin id="org.eclipse.wst.jsdt.core"/>
<plugin id="org.eclipse.mylyn.commons.notifications.feed"/>
<plugin id="org.uddi4j"/>
<plugin id="org.apache.lucene.source"/>
<plugin id="org.eclipse.ui.intro.universal.source"/>
<plugin id="org.eclipse.equinox.frameworkadmin.source"/>
<plugin id="org.eclipse.rap.rwt.supplemental.filedialog.source"/>
<plugin id="org.eclipse.scout.nls.sdk.source"/>
<plugin id="org.eclipse.jst.common.annotations.ui"/>
<plugin id="org.eclipse.wst.ws.service.policy.ui"/>
<plugin id="org.eclipse.e4.ui.bindings.source" version="0.10.2.v20121107-162442"/>
<plugin id="org.eclipse.jst.j2ee.core"/>
<plugin id="org.jsoup"/>
<plugin id="org.eclipse.mylyn.commons.xmlrpc"/>
<plugin id="org.eclipse.mylyn.bugzilla.ui"/>
<plugin id="org.eclipse.scout.svg.client"/>
<plugin id="org.eclipse.platform.doc.user"/>
<plugin id="org.eclipse.jst.j2ee.ejb.annotation.model"/>
<plugin id="org.eclipse.jface.text"/>
<plugin id="org.eclipse.mylyn.wikitext.help.ui"/>
<plugin id="org.eclipse.rap.rwt.supplemental.fileupload.source"/>
<plugin id="org.eclipse.wb.core.ui" version="1.6.1.r42x201401161252"/>
<plugin id="org.eclipse.help.webapp.source"/>
<plugin id="org.eclipse.jetty.server.source"/>
<plugin id="org.eclipse.ecf.source"/>
<plugin id="org.eclipse.scout.sdk.compatibility.v36.fragment.source"/>
<plugin id="org.eclipse.jst.ws.annotations.core"/>
<plugin id="org.eclipse.wb.core.java" version="1.6.1.r42x201401161246"/>
<plugin id="org.eclipse.jsch.ui.source"/>
<plugin id="javax.el"/>
<plugin id="org.apache.batik.dom.svg"/>
<plugin id="org.eclipse.scout.rt.rap.target"/>
<plugin id="org.eclipse.wb.rcp.nebula" version="1.7.0.r42x201405021526"/>
<plugin id="org.eclipse.wb.core.xml" version="1.6.1.r42x201401161254"/>
<plugin id="org.eclipse.jetty.server"/>
<plugin id="org.eclipse.scout.net"/>
<plugin id="org.eclipse.e4.ui.bindings"/>
<plugin id="org.eclipse.wb.doc.user" version="1.6.1.r42x201401161302"/>
<plugin id="org.eclipse.core.runtime.compatibility.source"/>
<plugin id="org.eclipse.wb.rcp.SWT_AWT" version="1.6.1.r42x201401161350"/>
<plugin id="org.eclipse.mylyn.tasks.index.ui"/>
<plugin id="org.eclipse.equinox.jsp.jasper"/>
<plugin id="org.apache.batik.util"/>
<plugin id="org.eclipse.e4.core.di.extensions.source"/>
<plugin id="org.eclipse.wb.swing.FormLayout.lib" version="1.6.1.r42x201401161333"/>
<plugin id="org.eclipse.ui.win32.source"/>
<plugin id="org.eclipse.jst.jsp.ui"/>
<plugin id="org.eclipse.ecf.ssl"/>
<plugin id="org.eclipse.core.variables"/>
<plugin id="org.eclipse.scout.sdk.ui"/>
<plugin id="org.eclipse.team.cvs.ssh2"/>
<plugin id="org.eclipse.pde.core"/>
<plugin id="org.eclipse.core.expressions.source"/>
<plugin id="javax.wsdl" version="1.5.1.v201012040544"/>
<plugin id="org.eclipse.scout.rt.shared.legacy.texts.fragment"/>
<plugin id="org.eclipse.wst.xsd.ui"/>
<plugin id="org.eclipse.scout.rt.server.source"/>
<plugin id="org.eclipse.ui.ide"/>
<plugin id="org.polarion.eclipse.team.svn.connector.javahl17.win64"/>
<plugin id="org.eclipse.equinox.p2.repository.tools.source"/>
<plugin id="org.eclipse.wst.wsdl"/>
<plugin id="org.eclipse.wb.swing.java6" version="1.7.0.r42x201405021531"/>
<plugin id="org.eclipse.gef.examples.shapes.source"/>
<plugin id="org.eclipse.core.commands.source"/>
<plugin id="org.eclipse.equinox.common.source"/>
<plugin id="org.eclipse.equinox.registry.source"/>
<plugin id="org.apache.derby.jdbc_1053.fragment"/>
<plugin id="org.eclipse.pde.launching"/>
<plugin id="org.eclipse.scout.sdk.compatibility.v37v41.fragment.source"/>
<plugin id="org.eclipse.equinox.bidi.source"/>
<plugin id="org.eclipse.scout.nls.sdk.simple.source"/>
<plugin id="org.eclipse.scout.rt.ui.swing.browser.swt.fragment"/>
<plugin id="org.eclipse.core.net.source"/>
<plugin id="org.eclipse.ui.browser"/>
<plugin id="org.eclipse.pde.core.source"/>
<plugin id="org.eclipse.wb.swing.databinding" version="1.7.0.r42x201405021531"/>
<plugin id="org.eclipse.core.filesystem.win32.x86_64"/>
<plugin id="org.eclipse.jst.j2ee.jca.ui"/>
<plugin id="org.eclipse.ui.navigator.resources"/>
<plugin id="org.eclipse.jem.beaninfo.vm"/>
<plugin id="org.eclipse.e4.ui.css.swt.theme"/>
<plugin id="org.eclipse.scout.nls.sdk.services"/>
<plugin id="org.eclipse.scout.jaxws216"/>
<plugin id="org.eclipse.wst.standard.schemas"/>
<plugin id="org.eclipse.team.svn.ui"/>
<plugin id="org.eclipse.pde.junit.runtime.source"/>
<plugin id="org.eclipse.equinox.launcher"/>
<plugin id="com.sun.el.source"/>
<plugin id="org.eclipse.mylyn.commons.notifications"/>
<plugin id="org.eclipse.equinox.p2.ui.sdk.scheduler.source"/>
<plugin id="org.eclipse.wb.swt.widgets.baseline" version="1.6.1.r42x201401161337"/>
<plugin id="org.eclipse.jst.ws.jaxws.dom.runtime"/>
<plugin id="org.eclipse.ecf.provider.filetransfer.httpclient.ssl"/>
<plugin id="org.eclipse.ui.cheatsheets"/>
<plugin id="org.eclipse.ui.editors.source"/>
<plugin id="org.eclipse.team.svn.ui.nl1"/>
<plugin id="org.eclipse.e4.core.contexts.source" version="1.2.0.v20121221-192508"/>
<plugin id="org.eclipse.jst.common.ui"/>
<plugin id="org.eclipse.wb.swing.databinding" version="1.6.1.r42x201401161333"/>
<plugin id="org.eclipse.wst.common.modulecore"/>
<plugin id="org.eclipse.gef.examples.flow.source"/>
<plugin id="org.eclipse.equinox.p2.operations"/>
<plugin id="org.eclipse.gef.source"/>
<plugin id="org.eclipse.wst.jsdt.web.support.jsp"/>
<plugin id="org.apache.wsil4j"/>
<plugin id="org.eclipse.scout.rt.ui.swing"/>
<plugin id="org.eclipse.scout.jaxws216.source"/>
<plugin id="org.eclipse.mylyn.wikitext.textile.ui"/>
<plugin id="org.eclipse.libra.framework.jonas.ui"/>
<plugin id="org.eclipse.libra.facet.ui"/>
<plugin id="org.eclipse.wb.swing.doc.user" version="1.7.0.r42x201405030444"/>
<plugin id="org.eclipse.pde.source"/>
<plugin id="org.eclipse.jst.ws"/>
<plugin id="org.eclipse.emf.common"/>
<plugin id="org.eclipse.equinox.p2.transport.ecf.source"/>
<plugin id="org.eclipse.pde.ua.core"/>
<plugin id="org.eclipse.equinox.p2.director.app"/>
<plugin id="org.eclipse.ant.ui"/>
<plugin id="org.eclipse.wst.server.core"/>
<plugin id="org.eclipse.update.configurator"/>
<plugin id="org.sat4j.pb"/>
<plugin id="org.junit" version="3.8.2.v3_8_2_v20100427-1100"/>
<plugin id="org.eclipse.pde.api.tools.ui.source"/>
<plugin id="org.eclipse.team.svn.core"/>
<plugin id="org.eclipse.wst.css.ui"/>
<plugin id="org.eclipse.mylyn.wikitext.textile.core"/>
<plugin id="org.eclipse.mylyn.tasks.ui"/>
<plugin id="org.eclipse.emf.common.ui"/>
<plugin id="org.apache.batik.svggen"/>
<plugin id="org.eclipse.equinox.p2.reconciler.dropins"/>
<plugin id="org.eclipse.e4.ui.workbench.renderers.swt.source" version="0.10.3.v20130124-170312"/>
<plugin id="org.eclipse.pde.ui"/>
<plugin id="org.apache.batik.swing"/>
<plugin id="org.eclipse.equinox.registry"/>
<plugin id="org.eclipse.wst.wsdl.validation"/>
<plugin id="org.eclipse.wst.server.discovery"/>
<plugin id="org.eclipse.team.svn.revision.graph.source"/>
<plugin id="org.eclipse.ecf.identity"/>
<plugin id="org.eclipse.wst.jsdt.web.core"/>
<plugin id="org.eclipse.equinox.http.servlet"/>
<plugin id="org.eclipse.jface.source" version="3.8.102.v20130123-162658"/>
<plugin id="org.apache.derby.jdbc_1053.fragment.source"/>
<plugin id="org.eclipse.scout.rt.client.source"/>
<plugin id="org.eclipse.wst.validation.infopop"/>
<plugin id="org.eclipse.core.variables.source"/>
<plugin id="org.eclipse.draw2d.doc.isv"/>
<plugin id="org.apache.felix.gogo.runtime.source"/>
<plugin id="org.eclipse.jem.beaninfo.vm.common"/>
<plugin id="org.eclipse.ant.core.source"/>
<plugin id="org.eclipse.e4.core.di"/>
<plugin id="org.eclipse.wst.dtd.ui.infopop"/>
<plugin id="org.eclipse.wst.dtdeditor.doc.user"/>
<plugin id="org.eclipse.mylyn.wikitext.ui"/>
<plugin id="org.eclipse.jdt.junit.core"/>
<plugin id="org.eclipse.scout.http.servletfilter"/>
<plugin id="org.eclipse.jdt.apt.ui.source"/>
<plugin id="org.eclipse.equinox.p2.touchpoint.natives.source"/>
<plugin id="org.eclipse.wst.common.modulecore.ui"/>
<plugin id="org.eclipse.core.contenttype"/>
<plugin id="org.eclipse.ui.cheatsheets.source"/>
<plugin id="org.eclipse.jdt.debug.source"/>
<plugin id="org.eclipse.wb.swt.widgets.baseline" version="1.7.0.r42x201405021526"/>
<plugin id="org.junit" version="4.10.0.v4_10_0_v20120426-0900"/>
<plugin id="org.eclipse.wb.core.xml" version="1.7.0.r42x201405021458"/>
<plugin id="org.eclipse.mylyn.commons.repositories.core"/>
<plugin id="org.eclipse.core.filesystem"/>
<plugin id="org.eclipse.equinox.p2.core.source"/>
<plugin id="org.apache.lucene"/>
<plugin id="org.eclipse.jetty.webapp"/>
<plugin id="org.eclipse.zest.core"/>
<plugin id="org.eclipse.mylyn.commons.repositories"/>
<plugin id="org.eclipse.xsd"/>
<plugin id="org.apache.batik.bridge"/>
<plugin id="javax.servlet"/>
<plugin id="org.polarion.eclipse.team.svn.connector.svnkit17"/>
<plugin id="org.eclipse.equinox.p2.ui.sdk.source"/>
<plugin id="org.eclipse.osgi.util"/>
<plugin id="org.eclipse.scout.svg.client.source"/>
<plugin id="org.eclipse.scout.sdk.help"/>
<plugin id="org.eclipse.jetty.io"/>
<plugin id="org.sat4j.core"/>
<plugin id="org.eclipse.jdt.apt.core"/>
<plugin id="org.eclipse.emf.ecore.change"/>
<plugin id="org.eclipse.equinox.p2.engine"/>
<plugin id="com.sun.el"/>
<plugin id="org.eclipse.mylyn.java.ui"/>
<plugin id="org.eclipse.mylyn.team.cvs"/>
<plugin id="org.eclipse.jdt.core.manipulation"/>
<plugin id="org.eclipse.mylyn.pde.ui"/>
<plugin id="org.eclipse.wb.swing.java6" version="1.6.1.r42x201401161333"/>
<plugin id="org.eclipse.equinox.p2.updatesite"/>
<plugin id="org.eclipse.e4.ui.css.swt.source"/>
<plugin id="org.apache.derby.jdbc_1082.fragment"/>
<plugin id="org.eclipse.team.svn.core.nl1"/>
<plugin id="org.eclipse.mylyn.wikitext.core"/>
<plugin id="org.eclipse.jdt.junit.core.source"/>
<plugin id="com.sun.syndication"/>
<plugin id="org.eclipse.core.databinding.property"/>
<plugin id="org.apache.felix.gogo.runtime"/>
<plugin id="org.eclipse.wb.swing" version="1.7.0.r42x201405021531"/>
<plugin id="org.eclipse.jst.common.annotations.core"/>
<plugin id="org.eclipse.ui.ide.application.source"/>
<plugin id="org.eclipse.rap.rwt.supplemental.fileupload"/>
<plugin id="org.eclipse.jsch.core.source"/>
<plugin id="org.eclipse.scout.sdk"/>
<plugin id="org.eclipse.debug.core.source"/>
<plugin id="org.eclipse.equinox.p2.ql.source"/>
<plugin id="org.eclipse.pde.ds.core.source"/>
<plugin id="org.eclipse.libra.framework.felix"/>
<plugin id="org.eclipse.equinox.p2.publisher.source"/>
<plugin id="org.eclipse.wb.rcp.swing2swt" version="1.6.1.r42x201401161337"/>
<plugin id="org.eclipse.scout.sdk.compatibility.v35.fragment"/>
<plugin id="org.eclipse.ui.navigator"/>
<plugin id="org.eclipse.equinox.p2.operations.source"/>
<plugin id="org.eclipse.ui.views.log.source"/>
<plugin id="org.eclipse.jetty.servlet.source"/>
<plugin id="org.eclipse.equinox.p2.jarprocessor.source"/>
<plugin id="org.junit.source" version="3.8.2.v3_8_2_v20100427-1100"/>
<plugin id="org.eclipse.scout.rt.jdbc.derby"/>
<plugin id="org.eclipse.mylyn.java.tasks"/>
<plugin id="org.eclipse.wb.rcp.databinding.emf" version="1.7.0.r42x201405021526"/>
<plugin id="org.eclipse.wst.command.env.core"/>
<plugin id="org.eclipse.e4.core.di.source"/>
<plugin id="org.eclipse.e4.ui.workbench.source" version="0.11.0.v20130125-100758"/>
<plugin id="org.eclipse.wb.swing.MigLayout.lib" version="1.6.1.r42x201401161333"/>
<plugin id="org.eclipse.wb.rcp.databinding.emf" version="1.6.1.r42x201401161337"/>
<plugin id="org.eclipse.wst.dtd.ui"/>
<plugin id="org.eclipse.scout.sdk.ws.jaxws.source"/>
<plugin id="org.eclipse.emf.edit"/>
<plugin id="org.eclipse.ui.trace"/>
<plugin id="org.eclipse.ui.net"/>
<plugin id="org.eclipse.core.runtime.compatibility"/>
<plugin id="org.eclipse.core.runtime.compatibility.auth"/>
<plugin id="org.apache.batik.css"/>
<plugin id="org.eclipse.equinox.p2.updatesite.source"/>
<plugin id="org.apache.lucene.core.source"/>
<plugin id="org.eclipse.pde.junit.runtime"/>
<plugin id="org.eclipse.wb.core.lib" version="1.7.0.r42x201405021445"/>
<plugin id="org.eclipse.jdt.debug.ui"/>
<plugin id="org.eclipse.gef.examples.flow"/>
<plugin id="org.eclipse.e4.core.commands.source"/>
<plugin id="org.eclipse.mylyn.bugzilla.ide"/>
<plugin id="org.eclipse.wst.wsi.ui.doc.user"/>
<plugin id="org.eclipse.wst.common.ui"/>
<plugin id="org.eclipse.ui.views.properties.tabbed"/>
<plugin id="javax.jws"/>
<plugin id="org.eclipse.core.resources"/>
<plugin id="org.apache.axis"/>
<plugin id="org.eclipse.mylyn.tasks.search"/>
<plugin id="org.hamcrest.core"/>
<plugin id="org.apache.commons.io"/>
<plugin id="org.eclipse.swt.win32.win32.x86_64"/>
<plugin id="org.eclipse.wb.os" version="1.7.0.r42x201405021445"/>
<plugin id="org.eclipse.mylyn.wikitext.mediawiki.ui"/>
<plugin id="org.eclipse.mylyn.context.core"/>
<plugin id="javax.wsdl" version="1.6.2.v201012040545"/>
<plugin id="org.eclipse.pde.api.tools.ui"/>
<plugin id="org.eclipse.equinox.http.registry.source"/>
<plugin id="org.eclipse.mylyn.monitor.core"/>
<plugin id="org.eclipse.wst.xmleditor.doc.user"/>
<plugin id="com.ibm.icu"/>
<plugin id="org.polarion.eclipse.team.svn.connector.javahl16"/>
<plugin id="org.eclipse.equinox.concurrent"/>
<plugin id="org.eclipse.equinox.p2.garbagecollector.source"/>
<plugin id="org.eclipse.ecf.provider.filetransfer.httpclient.ssl.source"/>
<plugin id="org.eclipse.scout.sdk.source"/>
<plugin id="org.eclipse.pde.ua.ui"/>
<plugin id="org.eclipse.scout.commons.source"/>
<plugin id="org.eclipse.wst.server.ui"/>
<plugin id="org.eclipse.debug.ui"/>
<plugin id="org.eclipse.libra.framework.equinox"/>
<plugin id="org.eclipse.jetty.http.source"/>
<plugin id="org.polarion.eclipse.team.svn.connector.svnkit16"/>
<plugin id="org.eclipse.libra.framework.knopflerfish"/>
<plugin id="org.eclipse.jetty.servlet"/>
<plugin id="org.eclipse.equinox.bidi"/>
<plugin id="org.eclipse.equinox.p2.updatechecker"/>
<plugin id="org.eclipse.wb.runtime" version="1.7.0.r42x201405021445"/>
<plugin id="org.eclipse.rap.tools.launch.source"/>
<plugin id="org.eclipse.equinox.security.win32.x86_64.source"/>
<plugin id="org.eclipse.e4.ui.css.swt"/>
<plugin id="org.eclipse.zest.layouts.source"/>
<plugin id="org.eclipse.e4.ui.workbench.swt.source" version="0.10.2.v20121207-204447"/>
<plugin id="org.eclipse.draw2d.source"/>
<plugin id="org.eclipse.jst.ws.jaxws.utils"/>
<plugin id="org.eclipse.scout.rt.ui.swing.source"/>
<plugin id="org.eclipse.jetty.util"/>
<plugin id="org.apache.felix.gogo.shell"/>
<plugin id="org.eclipse.swt"/>
<plugin id="org.eclipse.jdt.compiler.apt.source"/>
<plugin id="org.eclipse.pde.api.tools"/>
<plugin id="org.eclipse.core.contenttype.source"/>
<plugin id="org.eclipse.jdt.apt.core.source"/>
<plugin id="org.eclipse.core.runtime"/>
<plugin id="org.eclipse.jdt.junit4.runtime.source"/>
<plugin id="org.eclipse.help.base.source"/>
<plugin id="org.eclipse.e4.ui.bindings.source" version="0.10.3.v20130123-162658"/>
<plugin id="org.eclipse.jdt.junit.runtime.source"/>
<plugin id="org.eclipse.wb.core.lib" version="1.6.1.r42x201401161243"/>
<plugin id="org.eclipse.scout.commons"/>
<plugin id="org.eclipse.wst.command.env.ui"/>
<plugin id="org.apache.xml.resolver"/>
<plugin id="org.eclipse.ltk.ui.refactoring"/>
<plugin id="org.eclipse.equinox.common"/>
<plugin id="org.eclipse.equinox.event"/>
<plugin id="org.eclipse.mylyn.commons.team"/>
<plugin id="org.eclipse.equinox.util"/>
<plugin id="org.eclipse.wb.xwt" version="1.6.1.r42x201401161343"/>
<plugin id="org.eclipse.scout.rt.ui.svg.calendar.source"/>
<plugin id="org.eclipse.wb.rcp.doc.user" version="1.7.0.r42x201405030426"/>
<plugin id="org.eclipse.jdt.apt.pluggable.core"/>
<plugin id="org.eclipse.ui.views.log"/>
<plugin id="org.eclipse.wst.common.snippets"/>
<plugin id="org.eclipse.mylyn.monitor.ui"/>
<plugin id="org.eclipse.jetty.util.source"/>
<plugin id="org.eclipse.mylyn.context.tasks.ui"/>
<plugin id="org.eclipse.equinox.p2.touchpoint.eclipse"/>
<plugin id="org.eclipse.equinox.p2.metadata"/>
<plugin id="org.eclipse.libra.facet"/>
<plugin id="org.eclipse.core.externaltools"/>
<plugin id="org.polarion.eclipse.team.svn.connector.svnkit16.sources"/>
<plugin id="org.apache.commons.httpclient"/>
<plugin id="org.apache.commons.discovery"/>
<plugin id="org.eclipse.wst.web"/>
<plugin id="org.eclipse.jst.ws.jaxws.dom.ui"/>
<plugin id="org.eclipse.libra.framework.knopflerfish.ui"/>
<plugin id="org.eclipse.e4.ui.di"/>
<plugin id="org.eclipse.ui.externaltools"/>
<plugin id="org.apache.felix.gogo.command"/>
<plugin id="org.eclipse.wst.jsdt.ui"/>
<plugin id="org.eclipse.equinox.p2.directorywatcher.source"/>
<plugin id="org.eclipse.jdt.junit.source"/>
<plugin id="org.eclipse.equinox.p2.ui.discovery"/>
<plugin id="org.eclipse.ecf.provider.filetransfer.source"/>
<plugin id="org.eclipse.emf.ecore.xmi"/>
<plugin id="org.eclipse.wst.common.core"/>
<plugin id="javax.activation"/>
<plugin id="org.eclipse.ui.forms"/>
<plugin id="org.eclipse.equinox.p2.extensionlocation"/>
<plugin id="org.eclipse.ecf.provider.filetransfer.httpclient.source"/>
<plugin id="org.eclipse.jdt.debug"/>
<plugin id="org.eclipse.scout.rt.shared.legacy.texts.fragment.source"/>
<plugin id="org.eclipse.pde.ua.ui.source"/>
<plugin id="org.eclipse.jem.util"/>
<plugin id="org.eclipse.ui.intro.universal"/>
<plugin id="org.eclipse.jface.databinding.source"/>
<plugin id="org.eclipse.jdt.source"/>
<plugin id="org.eclipse.equinox.frameworkadmin.equinox.source"/>
<plugin id="org.eclipse.jface.source" version="3.8.101.v20121026-132746"/>
<plugin id="org.eclipse.equinox.p2.discovery"/>
<plugin id="org.eclipse.ui.ide.application"/>
<plugin id="org.eclipse.wb.rcp.databinding.xwt" version="1.7.0.r42x201405021548"/>
<plugin id="org.eclipse.rap.tools.intro.source"/>
<plugin id="org.eclipse.equinox.p2.director.source"/>
<plugin id="org.apache.xml.serializer"/>
<plugin id="com.bsiag.scout.rt.server.jdbc.oracle11g2"/>
<plugin id="org.eclipse.scout.rt.shared.source"/>
<plugin id="org.eclipse.jdt.apt.ui"/>
<plugin id="org.eclipse.equinox.p2.touchpoint.natives"/>
<plugin id="org.eclipse.wb.runtime" version="1.6.1.r42x201401161243"/>
<plugin id="org.eclipse.e4.ui.workbench.renderers.swt"/>
<plugin id="org.eclipse.rap.tools.templates"/>
<plugin id="org.eclipse.wb.swing.MigLayout" version="1.7.0.r42x201405021531"/>
<plugin id="org.eclipse.jem.proxy"/>
<plugin id="org.apache.commons.codec.source"/>
<plugin id="osgi.enterprise"/>
<plugin id="org.eclipse.equinox.p2.console"/>
<plugin id="org.eclipse.ui.console.source"/>
<plugin id="org.eclipse.wst.common.frameworks.ui"/>
<plugin id="org.eclipse.equinox.p2.core"/>
<plugin id="org.w3c.dom.svg"/>
<plugin id="org.apache.batik.transcoder"/>
<plugin id="org.eclipse.pde.launching.source"/>
<plugin id="org.apache.log4j"/>
<plugin id="org.apache.xerces"/>
<plugin id="org.apache.commons.codec" version="1.8.0"/>
<plugin id="org.eclipse.scout.sdk.compatibility.v36.fragment"/>
<plugin id="org.eclipse.jdt.apt.pluggable.core.source"/>
<plugin id="org.eclipse.equinox.frameworkadmin"/>
<plugin id="org.eclipse.equinox.p2.artifact.repository"/>
<plugin id="org.eclipse.ecf"/>
<plugin id="javax.servlet.jsp.source"/>
<plugin id="org.eclipse.wst.command.env.doc.user"/>
<plugin id="org.apache.jasper.glassfish"/>
<plugin id="org.eclipse.equinox.simpleconfigurator.source"/>
<plugin id="org.eclipse.equinox.console.source"/>
<plugin id="org.eclipse.equinox.http.servlet.source"/>
<plugin id="org.eclipse.emf.ecore.edit"/>
<plugin id="org.eclipse.emf"/>
<plugin id="org.eclipse.equinox.p2.transport.ecf"/>
<plugin id="org.eclipse.scout.service"/>
<plugin id="org.eclipse.jdt.core.source"/>
<plugin id="org.eclipse.wb.rcp" version="1.7.0.r42x201405021526"/>
<plugin id="org.eclipse.mylyn.wikitext.mediawiki.core"/>
<plugin id="org.eclipse.rap.doc"/>
<plugin id="org.eclipse.equinox.util.source"/>
<plugin id="org.eclipse.core.databinding.source"/>
<plugin id="org.eclipse.equinox.console"/>
<plugin id="org.eclipse.equinox.p2.ql"/>
<plugin id="org.apache.batik.xml"/>
<plugin id="org.eclipse.scout.sdk.compatibility.v37v41.fragment"/>
<plugin id="org.eclipse.libra.framework.ui"/>
<plugin id="org.eclipse.epp.mpc.ui"/>
<plugin id="org.eclipse.ltk.ui.refactoring.source"/>
<plugin id="javax.servlet.jsp"/>
<plugin id="org.eclipse.core.filebuffers"/>
<plugin id="org.eclipse.team.cvs.ui.source"/>
<plugin id="org.eclipse.mylyn.tasks.bugs"/>
<plugin id="org.eclipse.ui.browser.source"/>
<plugin id="org.eclipse.jst.jsf.doc.user"/>
<plugin id="org.eclipse.equinox.p2.garbagecollector"/>
<plugin id="org.eclipse.team.svn.help"/>
<plugin id="org.eclipse.jdt.debug.ui.source"/>
<plugin id="org.eclipse.mylyn.commons.repositories.ui"/>
<plugin id="org.eclipse.e4.ui.workbench.swt"/>
<plugin id="org.eclipse.ecf.provider.filetransfer.ssl.source"/>
<plugin id="org.eclipse.core.commands"/>
<plugin id="org.eclipse.equinox.p2.repository.source"/>
<plugin id="org.eclipse.team.svn.revision.graph"/>
<plugin id="org.eclipse.wst.jsdt.web.ui"/>
<plugin id="org.eclipse.ui.net.source"/>
<plugin id="org.eclipse.wst.common.project.facet.core"/>
<plugin id="org.eclipse.wb.rcp.doc.user" version="1.6.1.r42x201401180426"/>
<plugin id="org.apache.felix.gogo.shell.source"/>
<plugin id="org.eclipse.pde.doc.user"/>
<plugin id="org.eclipse.scout.svg.ui.swing.source"/>
<plugin id="org.eclipse.ui.trace.source"/>
<plugin id="org.eclipse.wst.common.frameworks"/>
<plugin id="org.eclipse.ecf.ssl.source"/>
<plugin id="org.eclipse.help.source"/>
<plugin id="org.eclipse.ant.core"/>
<plugin id="org.eclipse.wb.layout.group" version="1.6.1.r42x201401161311"/>
<plugin id="org.eclipse.core.databinding.beans"/>
<plugin id="org.eclipse.help.ui.source"/>
<plugin id="org.eclipse.jdt.junit.runtime"/>
<plugin id="org.eclipse.team.svn"/>
<plugin id="org.eclipse.ant.ui.source"/>
<plugin id="org.junit.source" version="4.10.0.v4_10_0_v20120426-0900"/>
<plugin id="org.eclipse.wb.swt" version="1.7.0.r42x201405021519"/>
<plugin id="org.eclipse.scout.rt.feature.about.source"/>
<plugin id="org.eclipse.cvs.source"/>
<plugin id="org.eclipse.equinox.simpleconfigurator.manipulator.source"/>
<plugin id="org.eclipse.wst.jsdt.manipulation"/>
<plugin id="org.eclipse.core.databinding.observable"/>
<plugin id="org.eclipse.wst.xsdeditor.doc.user"/>
<plugin id="org.eclipse.e4.core.contexts"/>
<plugin id="org.eclipse.jdt.junit4.runtime"/>
<plugin id="org.eclipse.equinox.ds"/>
<plugin id="org.apache.commons.lang"/>
<plugin id="org.eclipse.gef.examples.text.source"/>
<plugin id="org.eclipse.wb.swing.MigLayout.lib" version="1.7.0.r42x201405021531"/>
<plugin id="org.eclipse.e4.ui.services"/>
<plugin id="org.eclipse.core.net.win32.x86_64"/>
<plugin id="org.eclipse.equinox.p2.console.source"/>
<plugin id="org.eclipse.epp.mpc.help.ui"/>
<plugin id="org.eclipse.wst.ws.ui"/>
<plugin id="org.eclipse.wb.layout.group" version="1.7.0.r42x201405021517"/>
<plugin id="org.eclipse.pde.visualization"/>
<plugin id="org.eclipse.scout.rt.server"/>
<plugin id="org.eclipse.equinox.p2.metadata.source"/>
<plugin id="org.eclipse.equinox.p2.engine.source"/>
<plugin id="org.eclipse.scout.rt.shared"/>
<plugin id="org.eclipse.pde.ua.core.source"/>
</includeBundles>
<launcherArgs>
<vmArgs>-Xms256m -Xmx512m -XX:MaxPermSize=256m</vmArgs>
</launcherArgs>
</target>
Re: FileChooser in RAP [message #1354486 is a reply to message #1354151] |
Wed, 14 May 2014 09:24 |
Hi Urs,
I validate the RAP product and give me the following missing dependencies
I click on the button "Add Required Plug-Ins" and after that I do again a validation but give me the same result.
Any other suggestions?
Re: FileChooser in RAP [message #1366475 is a reply to message #1354486] |
Mon, 19 May 2014 10:25 |
Ken Lee Messages: 97 Registered: March 2012 |
Member |
Hi Marco,
Before I have a deeper look into your problem, can you please confirm first that you're using a plain installation of Eclipse Scout Juno SR2 [1]? Have you made any changes to your Eclipse installation by using the "Install New Software..." menu?
The ScoutRAP.target initially includes all the bundles that are located in your local Eclipse Scout installation directory which are included with
All Scout bundles for SWT/Swing and also for RAP (second entry) are set for the target platform.
Since the Scout RAP Filechooser is not included in the Eclipse package (because the RAP fileupload widget is still in incubation phase), you need to include the P2 update site for this widget directly. So your ScoutRAP.target file should look like
<?pde version="3.8"?><target name="ScoutRAP" sequenceNumber="1">
<locations>
</location>
</location>
</locations>
<launcherArgs>
</launcherArgs>
</target>
If you use the Scout SDK checkbox "RAP FileChooser Support (Incubation)", these P2 update sites will automatically be included.
In your *.product files, you need to add the bundles
(this step is also done automatically if you install the FileChooser via Scout SDK.
Now, to your actual problem:
AbstractFileChooserField contains a configuration method
protected boolean getConfiguredTypeLoad() {
return false;
that returns false by default. Depending on this configuration, a different field will be created in RAP (see FileChooserFieldFactory [2]).
What you probably want is to have the RwtScoutFileUploadField which allows you to upload files from your client to the Scout RAP server. Therefore, you need to override the method type load:
public class MyFileUploadField extends AbstractFileChooserField {
protected String getConfiguredLabel() {
return TEXTS.get("MyFileUpload");
return true;
Does that solve your problem?
[1] https://www.eclipse.org/downloads/packages/eclipse-scout-developers/junosr2
[2] https://dev.eclipse.org/svnroot/technology/org.eclipse.scout/scout.rt.incubator/branches/3.8/org.eclipse.scout.rt.ui.rap.incubator.filechooser/src/org/eclipse/scout/rt/ui/rap/form/fields/filechooserfield/FileChooserFieldFactory.java
[Updated on: Mon, 19 May 2014 10:27] Report message to a moderator
FUDForum. Page generated in 0.06017 seconds
