Home » Archived » Hudson » Warnings Plug-in 4.23-h-1: Console log file not found(Error console log file not found while looking for details)
Warnings Plug-in 4.23-h-1: Console log file not found [message #1327638] Fri, 02 May 2014 04:59
Hudson 3.1.2
Remote Build Clients (all jobs are running on remove build clients)
My developers love the Warnings plug-in for their Maven 3 builds. The overview works fine (trend graph is shown and the error/warning overview works fine), but if you go to the tab "warnings" in the "details" view you see a list of files in a tabel (e.g. "Console log:62". If you now press to one of that links you get the following page:
Inhalt der Datei
1 Copying the source file 'Console Log' from the workspace to the build folder '/srv/hudson/hudson_home/jobs/XXX_parent/builds/2014-05-02_10-12-14/workspace-files/f0ffc0bb.tmp' on the Hudson master failed.
2 Seems that the path is relative, however an absolute path is required when copying the sources.
3 Is the file 'Console Log' contained more than once in your workspace?
4 Is the file 'Console Log' a valid filename?
5 If you are building on a slave: please check if the file is accessible under '$JENKINS_HOME/[job-name]/Console Log'
6 If you are building on the master: please check if the file is accessible under '$JENKINS_HOME/[job-name]/workspace/Console Log'
Is there some environment variable missing in my server/client configuration?
Thanks for helping ...
Denis
Previous Topic:Downstream build view 1.9-h-1: Missing pictures
Next Topic:Please review 2 trivial pull requests in subversion-plugin
Current Time: Sat Sep 27 11:58:27 EDT 2025
Powered by FUDForum. Page generated in 0.03019 seconds
