How to make connections go under the diagram? [message #226241] |
Wed, 08 November 2006 12:14 |
Originally posted by: shruthi.cn.in.bosch.com
Hello everybody,
In GEF, Normally, the connections are drawn on top of the diagrams.
Therefore, diagrams can get overlapped with connections. But i want the
connections to go under the diagrams. How can I put them into the
background?
I tried overriding the createPrintableLayers in a class that inherits from
ScalableFreeformRootEditPart.
protected LayeredPane createPrintableLayers() {
FreeformLayeredPane layeredPane = new FreeformLayeredPane();
layeredPane.add(new ConnectionLayer(), CONNECTION_LAYER);
layeredPane.add(new FreeformLayer(), PRIMARY_LAYER);
return layeredPane;
And i also set the viewer's root edit part to an instance of the class
that extends ScalableFreeformRootEditPart.
Diagrams are made up of some polygon and inside the polygon, at the centre
there is image. With the approach described above, the portion of the
connection that gets overlapped with the image goes under the image and is
not seen. But remaining portion of the connection is still on top of the
polygon.
Therefore, Partly, the connections are on top of diagram.
Please help me in this problem. Any links, source examples would also be
of great help to me
Best Regards
Shruthi
Re: How to make connections go under the diagram? [message #226288 is a reply to message #226241] |
Thu, 09 November 2006 00:08 |
Originally posted by: none.unknown.com
Are you sure your polygon is not just transparent? Let's see a screenshot.
"shruthi" <shruthi.cn@in.bosch.com> wrote in message
news:2400de63a3bcb53f0bfc6341b6255d69$1@www.eclipse.org...
> Hello everybody,
> background?
> return layeredPane;
> polygon.
> of great help to me
> Best Regards
> Shruthi
Re: How to make connections go under the diagram? [message #226455 is a reply to message #226288] |
Mon, 13 November 2006 05:44 |
------=_Part_838_617952.1163396786303
Content-Type: text/plain; charset=ISO-8859-1
Content-Disposition: inline
I have attached a file. In the snapshot, you can see that, for element log_1, there is no image and hence the entire connection passing under it is visible.
For element "matrix" below, since there is an image at the center, only a portion of the connection is seen entering the square box of "matrix" element.
I tried out some code to solve the problem. I filled the square box with a white background color.
graphics.setBackgroundColor(ColorConstants.White);
graphics.fillPolygon(pointList);
Then the connection was not seen. Is this approach right?
Please let me know.
Best Regards
Shruthi
Content-Type: image/gif; name=connectionproblem.gif
Content-Disposition: attachment; filename=connectionproblem.gif
Qk1y5QIAAAAAADYAAAAoAAAA/AAAAPsAAAABABgAAAAAADzlAgDEDgAAxA4A AAAAAAAAAAAA////
//////////////////////////////////////////////////////////// AAAA////////////
////AAAA//////////////////////////////////////////////////// ////////////////
////////////////////////AAAA//////////////////////////////// ////////////////
////////////////////////////////////////////AAAA//////////// ////////////////
//////////////////////////////////////////////////////////// ////AAAA////////
//////////////////////////////////////////////////////////// ////////////AAAA
AAAAAAAAAAAAAAAAAAAA//////////////////////////////////////// ////////////////
////////////////////AAAAAAAAAAAAAAAA//////////////////////// ////////////////
////////////////////////////////////////////AAAAAAAA//////// ////////////////
////////////////////////////AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA//////////////////////// ////////////////
////////////////////////////////////////////////AAAA//////// ////////////////
////////////////////////////////////////////////////AAAA//// ////////////////
//////////////////////////////////////////////////////////// ////////AAAA////
////////////AAAA//////////////////////////////////////////// ////////////////
////////////////AAAA//////////////////////////////////////// ////////////////
////////////////////////////////AAAA//////////////////////// ////////////////
////////////////////////////////////AAAA//////////////////// ////////////////
////////////////////////////////////////////////////////AAAA ////////////////
AAAA//////////////////////////////////////////////////////// ////////////////
AAAA////////////AAAA////////////////////////////////////hAAA /wAA////////////
////////////////////AAAA//////////////////////////////////// ////////////////
////////////////////AAAAAAAA////////AAAA//////////////////// ////////////////
hAAA/wAA////////////////////////////////AAAA//////////////// ////////////////
////////////////////////////////////////AAAAAAAAAAAA////AAAA ////////////////
////////////////////hAAA/wAA//////////////////////////////// AAAA////////////
////////////////////////////////////AAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAA
AAAA////////////////////////hAAAhAAAhAAAhAAAhAAAhAAAhAAA/wAA ////////////////
////AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA//////////////// ////////////////
////AAAAAAAAAAAA////AAAA////////////////////////hAAA/wAA/wAA /wAA/wAA/wAA/wAA
/wAA////////////////////AAAA//////////////////////////////// ////AAAA////////
////////////////////////AAAAAAAA////////AAAA//////////////// ////////////////
////hAAA/wAA////////////////////////////////AAAA//////////// ////////////////
////////AAAA//////////////////////////////////////////////// ////////////////
////////////////////////////////////////////AAAA//////////// AAAA////////////
////////////////////////hAAA/wAA//////////////////////////// ////AAAA////////
////////////////////////////AAAA//////////////////////////// ////////////////
////AAAA////////////////////////////////////hAAA/wAA//////// ////////////////
////////AAAA////////////////////////////////////AAAA//////// ////////////////
////////////////////////////AAAA//////////////////////////// ////////AAAA////
////////////AAAA////////////////////////////////////AAAA//// ////////////////
////////////////////////////////AAAA//////////////////////// ////////////AAAA
////////////////////////////////////////////////AAAAAAAAAAAA AAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA//// ////////////////
////////////////////////////////////////AAAA//////////////// ////////////////
////////////////AAAA//////////////////////////////////////// ////AAAA////////
////////////////////////////////////////AAAA//////////////// ////AAAAAAAAAAAA
////AAAA////////////AAAA////////AAAA//////////////////////// ////////////////
////////AAAA////////////AAAA////////////AAAA////////AAAA//// ////////////////
////////////////////////////AAAA////////////AAAA//////////// AAAA////////AAAA
////////AAAAAAAAAAAA//////////////////////////////////////// ////////////////
////////////////////////////////////////////////AAAA//////// ////AAAA////////
////AAAA////////AAAA//////////////////////////////////////// ////////////////
////////AAAA////////////AAAA////////AAAA//////////////////// ////////////////
////////////////AAAA////////AAAA////////////AAAA//////////// AAAA////////////
Re: How to make connections go under the diagram? [message #226559 is a reply to message #226455] |
Thu, 16 November 2006 22:53 |
As I suspected, your figures are transparent. So, of course, you'd see
whatever's underneath them. IFigure#setOpaque(true) should do the trick.
Ensure that any custom figures you might have invoke super.paintFigure().
For Shapes (such as RectangleFigure), setFill(true) should be sufficient.
news:17606608.1163396786305.JavaMail.root@cp1.javalobby.org...
> Hello,
> is visible.
> element.
> Please let me know.
> Best Regards
> Shruthi
FUDForum. Page generated in 0.03275 seconds
