JSDT - Usage in an RCP application [message #225486] |
Fri, 19 December 2008 20:20 |
Originally posted by: eclipse.ehrnhoefer.net
I am trying to use the Javascript Editor in my own application (where I
take use of the Java Scripting API - so no web development going on).
Basically I just need syntax check / highlighting to make writing the
small scripts easier. No debugging needed at all.
I checked out the plugins:
sourceediting/plugins/org.eclipse.wst.jsdt.core
sourceediting/plugins/org.eclipse.wst.jsdt.manipulation
sourceediting/plugins/org.eclipse.wst.jsdt.ui
and put all required plug-ins in my Target. And now I am wondering where
the Editor is, how I am opening it. I have not dealt with editors yet, and
from what I read I need an EditorInput and build an Action to open it, but
eventually I need to know which Editor to open, and I can't figure out
where the Javascript Editor is.
I am most probably not graspinig the whole concept, so excuse my maybe
stupid question :) I am very thankful of any hint how to accomplish this.
Cheers
Thomas
Re: JSDT - Usage in an RCP application [message #225667 is a reply to message #225486] |
Tue, 23 December 2008 19:29 |
Still working on it, still haven't found a solution.
I would be really happy for any hint, thanks a lot.
On Fri, 19 Dec 2008 12:20:05 -0800, Thomas Ehrnhoefer
<eclipse@ehrnhoefer.net> wrote:
> Hi
> and from what I read I need an EditorInput and build an Action to open
> it, but eventually I need to know which Editor to open, and I can't
> figure out where the Javascript Editor is.
> Cheers
> Thomas
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Re: JSDT - Usage in an RCP application [message #225675 is a reply to message #225667] |
Tue, 23 December 2008 20:10 |
Originally posted by: dcarver.starstandard.org
The java script editor is in the org.eclipse.wst.jsdt.ui plugin. Check
the plugin.xml for information on the editor, including which ID it is
using.
Dave
>> Hi
>> I take use of the Java Scripting API - so no web development going
>> on). Basically I just need syntax check / highlighting to make writing
>> the small scripts easier. No debugging needed at all.
>> where the Editor is, how I am opening it. I have not dealt with
>> editors yet, and from what I read I need an EditorInput and build an
>> Action to open it, but eventually I need to know which Editor to open,
>> and I can't figure out where the Javascript Editor is.
>> Cheers
>> Thomas
FUDForum. Page generated in 0.03656 seconds
