Home » Eclipse Projects » GEF » change figure associated with an edit-part dynamically
change figure associated with an edit-part dynamically [message #225322] |
Mon, 30 October 2006 13:49 |
Originally posted by: prashanto.chatterjee.softwareag.com
I have this scenario wherein I need to change the figure associated with an
edit-part. What I do in the concerned edit-part is:
Map partMap = getViewer().getVisualPartMap();
partMap.remove(oldFigureInstance);
partMap.put(newFigureInstance, this);
This however has no effect and the old figure persists in the viewer. Is
there a central place wherein I can update the EditPart to Figure mapping?
How do I change the figure associated with an edit-part dynamically at
runtime?
Appreciate your help.
Kind Regards,
Prashanto
Re: change figure associated with an edit-part dynamically [message #225348 is a reply to message #225322] |
Mon, 30 October 2006 16:31 |
Xiang Qinxian Messages: 119 Registered: July 2009 |
在 2006-10-30一的 14:49 +0100,Prashanto Chatterjee写道:
> runtime?
> Kind Regards,
> Prashanto
Maybe Pratik and Hudson not advice you do like above yet.:)
OK, this part with an only figure, and once created, no dead if no
exception.How?
1, get parent model, remove this child model, update;
and add this model, update. It works.
2, let a Figure object contains really needed figure.
and editpart can control this parent virtual figure update status
according concret condition.
Hope this help.
Qinxian.
Re: change figure associated with an edit-part dynamically [message #225449 is a reply to message #225348] |
Tue, 31 October 2006 06:44 |
Thanks for responding.
In the meantime I tried out the following sequence:
unregisterVisuals();
setFigure(newFigure);
registerVisuals();
But even this didn't work :(. I get the old figure with connections and the
new Figure without the connections.
This is baffling. I was wondering whether GEF has any update mechanism that
automatically updates any mappings with the corresponding figure?
Any help would be appreciated.
Prashanto
"Xiang Qinxian" <fyaoxy@gmail.com> wrote in message
news:1162225891.30390.6.camel@qinxian.xiang...
? 2006-10-30?? 14:49 +0100,Prashanto Chatterjee??:
> an
> runtime?
> Kind Regards,
> Prashanto
exception.How?
Hope this help.
Qinxian.
Re: change figure associated with an edit-part dynamically [message #225472 is a reply to message #225449] |
Tue, 31 October 2006 09:07 |
在 2006-10-31二的 07:44 +0100,Prashanto Chatterjee写道:
> registerVisuals();
This way could work yet, try to get a place update it or notifiy it's
update.
Try to add refreshVisuals();
Qinxian
> Regards,
> Prashanto
> > Hi,
> > an
> > runtime?
> > Kind Regards,
> > Prashanto
> exception.How?
> Hope this help.
> Regards,
> Qinxian.
Re: change figure associated with an edit-part dynamically [message #225644 is a reply to message #225472] |
Wed, 01 November 2006 06:25 |
I already have that. I call refresh() which calls both refreshVisuals() and
refreshChildren(). But still it does not help :(
Prashanto
news:1162285623.14126.14.camel@qinxian.xiang...
? 2006-10-31?? 07:44 +0100,Prashanto Chatterjee??:
> registerVisuals();
update.
Qinxian
> the
> that
> Regards,
> Prashanto
> > Hi,
> > an
> > mapping?
> > runtime?
> > Kind Regards,
> > Prashanto
> exception.How?
> Hope this help.
> Regards,
> Qinxian.
Re: change figure associated with an edit-part dynamically [message #226222 is a reply to message #225322] |
Wed, 08 November 2006 06:01 |
Originally posted by: none.unknown.com
There's a simple solution to this. In your createFigure() method, first
create a figure with a stack layout. In there, you put the figure that you
expect to be changed. Then, simply switch that figure whenever you need to,
leaving the parent figure (the one returned by getFigure()) alone. It gets
trickier if this editpart can have children.
"Prashanto Chatterjee" <prashanto.chatterjee@softwareag.com> wrote in
message news:ei4vst$ci9$1@utils.eclipse.org...
> an edit-part. What I do in the concerned edit-part is:
> runtime?
> Kind Regards,
> Prashanto
Re: change figure associated with an edit-part dynamically [message #226235 is a reply to message #226222] |
Wed, 08 November 2006 10:42 |
Hi Pratik,
Thanks for your response. I have done as you had suggested and it works like
a wonder.
However, I have one single doubt. What I've currently done is:
protected IFigure createFigure() {
stackFigure = new Figure();
stackFigure.setLayoutManager(new StackLayout());
stackFigure.add(_insertionPointFigure = new
ImageFigure(InsertionPoint.INSERTION_POINT_IMAGE.createImage ()));
stackFigure.add(_enabledBreakpointFigure = new
ImageFigure(InsertionPoint.ENABLED_BREAKPOINT_IMAGE.createIm age()));
stackFigure.add(_disabledBreakpointFigure = new
ImageFigure(InsertionPoint.DISABLED_BREAKPOINT_IMAGE.createI mage()));
resetFigure();
if (getModel() instanceof TreeNode) {
stackFigure.setToolTip(((TreeNode)getModel()).getToolTip());
return stackFigure;
followed by:
public void resetFigure() {
if(getCastedModel().containsBreakpoint()){
if(getCastedModel().isBreakpointEnabled()){
stackFigure.add(_enabledBreakpointFigure);
}else{
stackFigure.add(_disabledBreakpointFigure);
}else{
stackFigure.add(_insertionPointFigure);
Is this the correct way to use a StackLayout? Why isn't there an option for
something like a top-control in StackLayout?
Thanks once again.
Prashanto
"Pratik Shah" <none@unknown.com> wrote in message
news:eirrsl$def$1@utils.eclipse.org...
> you expect to be changed. Then, simply switch that figure whenever you
> need to, leaving the parent figure (the one returned by getFigure())
> alone. It gets trickier if this editpart can have children.
>> Hi,
>> mapping?
>> runtime?
>> Kind Regards,
>> Prashanto
Current Time: Fri Apr 26 13:11:48 GMT 2024
Powered by FUDForum. Page generated in 0.03185 seconds
