Home » Archived » BIRT » Out of Memory Exception
Re: Out of Memory Exception [message #225150 is a reply to message #225108] |
Wed, 14 March 2007 16:47 |
Mathi wrote:
> Hello folks,
> I m using BIRT 2.2 M4 . Rendering my reports through URL with
> frameset servelet.
> I use Jboss server. Jboss is started with the following setting.
> -Xms256m -Xmx600m -server -XX:PermSize=64m -XX:MaxPermSize=128m
> After plying with reports for an hour , it produces an out of memory Error.
> Error is :
> 18:52:49,770 ERROR [[ViewerServlet]] Servlet.service() for servlet
> ViewerServlet threw exception
> java.lang.OutOfMemoryError: PermGen space
> Any suggestion ?
Can you change this setting -XX:MaxPermSize=128m
to -XX:MaxPermSize=256m. Also log a bugzilla entry for this if you do
not mind?
Jason
Re: Out of Memory Exception [message #229674 is a reply to message #229396] |
Thu, 22 March 2007 21:51 |
Mathi wrote:
> Jason,
> I ll enter a Bugzilla posting for this . But can you explain why it
> behaves so .. Why should it goes to that much size? Any Quick Fix apart
> from increasing the size?
> Regards
> Mathi
There is a bug in the platform on this, but I do not remember the
number. I may be wrong but I thought increasing this did more than
just delay the issue.
Jason
Re: Out of Memory Exception [message #242377 is a reply to message #225150] |
Wed, 13 June 2007 07:09 |
Originally posted by: wohlgemuth.ucdavis.edu
as said as it is I get this error which forces me to restart the server. And
i can't accept it to restart the server all the time.
I playing with the current RC2 and have a pretty simple report with 5
datasets connecting to a database to generate some simple graphs.
any ideas when the "perm problem" is fixed?
i'm running in it using jboss 4.0.3 and java 1.5 - 1.6
thx gert
"Jason Weathersby" <jasonweathersby@alltel.net> wrote in message
news:et98tt$s9i$1@utils.eclipse.org...
> Mathi wrote:
>> Hello folks,
>> frameset servelet.
>> Error.
>> Error is :
>> Any suggestion ?
> to -XX:MaxPermSize=256m. Also log a bugzilla entry for this if you do not
> mind?
> Jason
Re: Out of Memory Exception [message #242388 is a reply to message #242377] |
Wed, 13 June 2007 07:24 |
some more informations:
00:16:57,767 INFO [STDOUT] Jun 13, 2007 12:16:57 AM
org.eclipse.birt.report.engine.api.impl.RunTask doRun
SEVERE: An OutOfMemory error happened while running the report.
00:17:15,508 INFO [STDOUT] Exception in thread "State Saver"
00:17:15,509 INFO [STDOUT] java.lang.OutOfMemoryError: PermGen space
00:17:15,509 INFO [STDOUT] at java.lang.ClassLoader.defineClass1(Native
Method)
00:17:15,509 INFO [STDOUT] at java.lang.ClassLoader.defineClass(Unknown
Source)
java.security.SecureClassLoader.defineClass(Unknown Source)
00:17:15,509 INFO [STDOUT] at java.net.URLClassLoader.defineClass(Unknown
Source)
00:17:15,510 INFO [STDOUT] at java.net.URLClassLoader.access$000(Unknown
Source)
00:17:15,510 INFO [STDOUT] at java.net.URLClassLoader$1.run(Unknown
Source)
java.security.AccessController.doPrivileged(Native Method)
00:17:15,510 INFO [STDOUT] at java.net.URLClassLoader.findClass(Unknown
Source)
org.eclipse.birt.core.framework.osgi.OSGILauncher$ChildFirst URLClassLoader.loadClass(OSGILauncher.java:628)
00:17:15,510 INFO [STDOUT] at java.lang.ClassLoader.loadClass(Unknown
Source)
java.lang.ClassLoader.loadClassInternal(Unknown Source)
org.eclipse.osgi.internal.resolver.StateObjectFactoryImpl.wr iteState(StateObjectFactoryImpl.java:336)
org.eclipse.osgi.internal.baseadaptor.StateManager.writeStat e(StateManager.java:187)
org.eclipse.osgi.internal.baseadaptor.StateManager.update(St ateManager.java:126)
00:17:15,511 INFO [STDOUT] at
org.eclipse.osgi.internal.baseadaptor.BaseStorage.saveStateD ata(BaseStorage.java:545)
org.eclipse.osgi.internal.baseadaptor.BaseStorage.saveAllDat a(BaseStorage.java:383)
org.eclipse.osgi.internal.baseadaptor.BaseStorage.access$1(B aseStorage.java:372)
org.eclipse.osgi.internal.baseadaptor.BaseStorage$StateSaver .run(BaseStorage.java:1115)
00:17:15,511 INFO [STDOUT] at java.lang.Thread.run(Unknown Source)
any ideas?
g.
"gert wohlgemuth" <wohlgemuth@ucdavis.edu> wrote in message
news:f4o56v$m77$1@build.eclipse.org...
> And i can't accept it to restart the server all the time.
> thx gert
>> Mathi wrote:
>>> Hello folks,
>>> frameset servelet.
>>> Error.
>>> Error is :
>>> Any suggestion ?
>> not mind?
>> Jason
Re: Out of Memory Exception [message #250253 is a reply to message #242388] |
Sat, 28 July 2007 06:30 |
Originally posted by: shaun.methodmaker.co.nz
Gert,
I too can confirm your problem. I am experiencing out of memory Permgen
space issues being reported by the Tomcat JVM. We are using BIRT 2.2 /
Java 1.6 and Tomcat 6.0.13. We are using the JSP tag library options to
embed the engine into our web app.
There have been other posts recently highlighting potential memory leak
problems which I am starting to think are related. Search using the
keyword memory within the newsgroup to find them.
Our JVM options are as follows:
-Xms128m -Xmx512m -server -XX:PermSize=64m -XX:MaxPermSize=128m
Currently we are having to restart the Tomcat server every 12 hours in
order to keep things running.
Shaun
> java.lang.ClassLoader.defineClass1(Native Method)
> java.lang.ClassLoader.defineClass(Unknown Source)
> java.net.URLClassLoader.defineClass(Unknown Source)
> java.net.URLClassLoader.access$000(Unknown Source)
> Source)
> java.net.URLClassLoader.findClass(Unknown Source)
> Source)
> any ideas?
> g.
>> server. And i can't accept it to restart the server all the time.
>> thx gert
>>> Mathi wrote:
>>>> Hello folks,
>>>> frameset servelet.
>>>> Error.
>>>> Error is :
>>>> servlet ViewerServlet threw exception
>>>> Any suggestion ?
>>> do not mind?
>>> Jason
Shaun Forgie
Principal - Method Maker Ltd
Mobile [64] 21-666-910 http://www.methodmaker.co.nz
PO Box 1513, Auckland, New Zealand
Re: Out of Memory Exception [message #250310 is a reply to message #250253] |
Mon, 30 July 2007 05:45 |
Wang Qiangsheng Messages: 76 Registered: July 2009 |
Member |
Shaun Forgie wrote:
> Gert,
> Regards
> Shaun
>> Source)
>> java.lang.ClassLoader.loadClass(Unknown Source)
>> any ideas?
>> g.
>>> thx gert
>>>> Mathi wrote:
>>>>> Hello folks,
>>>>> frameset servelet.
>>>>> memory Error.
>>>>> Error is :
>>>>> Any suggestion ?
>>>> do not mind?
>>>> Jason
https://bugs.eclipse.org/bugs/show_bug.cgi?id=92250
Take a look at above link.
Qiangsheng
Re: Out of Memory Exception [message #252936 is a reply to message #250310] |
Sat, 18 August 2007 01:47 |
Wang,
The bug you referred me to is totally unrelated to the issues we are
discussing -> which is to do with server side Tomcat JVM out of memory
errors. You seem to be referring to an eclipse IDE related heap
reporting / allocation discrepancy.
It would appear that Tomcat is partially to blame as it is not
reclaiming heap for libraries re-deployed within
tomcat/webapps/WEB-INF/lib. In the case of Tomcat 6.0 it is far better
to put libraries directly into tomcat/lib as they are not reloaded each
time an app is redeployed.
Shaun
WangQS wrote:
> Shaun Forgie wrote:
>> Gert,
>> Regards
>> Shaun
>>> Source)
>>> any ideas?
>>> g.
>>>> thx gert
>>>>> Mathi wrote:
>>>>>> Hello folks,
>>>>>> frameset servelet.
>>>>>> memory Error.
>>>>>> Error is :
>>>>>> Any suggestion ?
>>>>> do not mind?
>>>>> Jason
> Thanks
> Qiangsheng
Shaun Forgie
Current Time: Fri Apr 26 15:08:54 GMT 2024
Powered by FUDForum. Page generated in 0.04572 seconds
