Home » Language IDEs » ServerTools (WTP) » XML not Publishing to Tomcat 6.x and 5.5
XML not Publishing to Tomcat 6.x and 5.5 [message #224691] Thu, 04 December 2008 07:26 Go to next message
I have a .war project with Spring Nature mixed with Hibernate. When
published to a Tomcat
application server outside of Eclipse (tested on 5.5 and 6.0.18) all
works as described.
When the war is deployed to a Tomcat server running in Eclipse/Tomcat not
all xml files are published. Any xml file in the
WEB-INf/classes/any/and/all/subfolders is not published. If the name of
any file that is not published has the extension xml removed it publishes
as expected. This has gone through the bugzilla process (bug/256707)
without success. Has anyone else seen this effect and successfully dealt
with it. I believe any question you have has been asked and answered in
the bug comments, for brevity I have not repeated the detail tests here.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=256707
Ralph
Re: XML not Publishing to Tomcat 6.x and 5.5 [message #224706 is a reply to message #224691] Thu, 04 December 2008 08:21 Go to previous messageGo to next message
> works as described. When the war is deployed to a Tomcat server running
> in Eclipse/Tomcat not all xml files are published. Any xml file in the
> publishes as expected. This has gone through the bugzilla process
> (bug/256707) without success. Has anyone else seen this effect and
> successfully dealt with it. I believe any question you have has been
> asked and answered in the bug comments, for brevity I have not repeated
> Thanks Ralph
I've replied in the bug report. Maybe your problem is caused by bug #230050?
Mauro.
Re: XML not Publishing to Tomcat 6.x and 5.5 [message #224714 is a reply to message #224706] Thu, 04 December 2008 08:43 Go to previous message
Thanks Mauro that was the problem. Don't know how these extensions where
added to the filtered source list, but both *.xml and *.html where added.
For those who need the path to the build filter it is:
Eclipse/Preferences/Java/Compiler/Building/ - then under the Output Folder
section you will find the Filtered resources list.
Thanks again
Ralph
Previous Topic:Moving from Europa to Ganymede
Next Topic:Newbie: Server publish not including extra RMIC stubs
Current Time: Fri Nov 07 08:32:18 EST 2025
Powered by FUDForum. Page generated in 0.34722 seconds
