Home » Eclipse Projects » GEF » translatetoAbsolute problem
translatetoAbsolute problem [message #223981] |
Tue, 10 October 2006 18:04 |
Originally posted by: something.eclipse.org
I have read a lot of posts here, but I still am missing something. I
have a layer with some figures and some anchors on the figures. I
cannot find out how to get the absolute location of the anchors. I
start with a point relative to the figure and try to translate it to
absolute (among other things), but the point always come back unchanged.
An example:
Layer bounds (0,0, 1500, 1500)
Figure Bounds (100, 100, 50, 50)
Anchor Location (5, 5) figure relative
I tried getOwner().translateTo<Everything> on the anchor location and I
always get the same point back. I thought getOwner.translateToAbsolute
would work, but no.
I would appreciate any help with this!
thanks,
adam
Re: translatetoAbsolute problem [message #224055 is a reply to message #223981] |
Wed, 11 October 2006 11:46 |
Nhu Le Messages: 47 Registered: July 2009 |
Member |
I assume that you have set the useRelativeCoordinate in your figure to
be true (because of the relative anchor). I think as far as the figure
concerns, relative is the same as absolute as absolute is actually
relative to the layer. Have you tried anchor.translateToAbsolute()?
Nhu Le
> An example:
> would work, but no.
> thanks,
> adam
Re: translatetoAbsolute problem [message #224126 is a reply to message #223981] |
Wed, 11 October 2006 15:38 |
Originally posted by: none.unknown.com
Your anchor's not a figure, so it's relative coordinates don't mean the
figure is using a local/relative coordinate system. You just have to get
the figure's absolute location and translate the location by 5,5 (or
whatever the anchor's location is) yourself.
"AdamC" <something@eclipse.org> wrote in message
news:eggnas$vt4$1@utils.eclipse.org...
>I have read a lot of posts here, but I still am missing something. I have
>a layer with some figures and some anchors on the figures. I cannot find
>out how to get the absolute location of the anchors. I start with a point
>relative to the figure and try to translate it to absolute (among other
> An example:
> would work, but no.
> thanks,
> adam
Re: translatetoAbsolute problem [message #224134 is a reply to message #224126] |
Wed, 11 October 2006 16:44 |
Thanks for the help. I found out the problem was that layout had not
occurred yet, even though I thought it had. The only solution I could
find was to use Display.async and call translate when I knew all the
figures were placed. If there is a better place to do this, I would
like to hear it!
thanks again,
adam
>> An example:
>> would work, but no.
>> thanks,
>> adam
Re: translatetoAbsolute problem [message #224141 is a reply to message #224134] |
Wed, 11 October 2006 17:25 |
What are you trying to do? If you can give me a bigger picture than the
figure not having laid out when you're accessing anchor location, perhaps I
can help.
news:egj725$qaj$1@utils.eclipse.org...
> figures were placed. If there is a better place to do this, I would like
> to hear it!
> thanks again,
> adam
>>> An example:
>>> would work, but no.
>>> thanks,
>>> adam
Re: translatetoAbsolute problem [message #224156 is a reply to message #224141] |
Wed, 11 October 2006 17:56 |
I am trying to make connections before the diagram is shown. To make
the connections, I need to know the absolute locations of the anchors.
The only way I could find to do this is the async call as this is the
only time I can be sure layout has happened. There is still an pause
though, using this method, between the time when the diagram is shown
and when the connections are shown.
> can help.
>> to hear it!
>> thanks again,
>> adam
>>>> An example:
>>>> would work, but no.
>>>> thanks,
>>>> adam
Re: translatetoAbsolute problem [message #224173 is a reply to message #224156] |
Wed, 11 October 2006 19:11 |
Why do you need the absolute location of the anchor? Is that what you store
in your model for where the connection starts/ends? You should model
terminals, like LED or circuit in the logic example.
news:egjb7t$ik6$1@utils.eclipse.org...
>I am trying to make connections before the diagram is shown. To make the
>connections, I need to know the absolute locations of the anchors. The only
>way I could find to do this is the async call as this is the only time I
>can be sure layout has happened. There is still an pause though, using
>this method, between the time when the diagram is shown and when the
>> I can help.
>>> like to hear it!
>>> thanks again,
>>> adam
>>>> get the figure's absolute location and translate the location by 5,5
>>>> (or whatever the anchor's location is) yourself.
>>>>> unchanged.
>>>>> An example:
>>>>> I always get the same point back. I thought
>>>>> getOwner.translateToAbsolute would work, but no.
>>>>> thanks,
>>>>> adam
Re: translatetoAbsolute problem [message #224181 is a reply to message #224173] |
Wed, 11 October 2006 19:18 |
Actually, I need the absolute locations because part of my connection
algorithm check the absolute position of the anchor before deciding to
make a connection. It would really help to know where I could put code
that would be called after layout but before showing my diagram.
adam
>>> I can help.
>>>> like to hear it!
>>>> thanks again,
>>>> adam
>>>>>> unchanged.
>>>>>> An example:
>>>>>> thanks,
>>>>>> adam
Current Time: Fri Apr 26 11:29:37 GMT 2024
Powered by FUDForum. Page generated in 0.04256 seconds
